Andrei Posted October 22, 2019 Posted October 22, 2019 Сделал вируталку с Debian 9, рутовый пароль был сгенерен pwgen-ом и на всякий случай положен в виде текстовика в home-каталог другого пользователя. Оставили виртуалку до утра, fail2ban думал поставить утром. Но с утра - загрузка проца: top top - 13:31:33 up 7 min, 1 user, load average: 1.48, 1.20, 0.66 Tasks: 110 total, 1 running, 109 sleeping, 0 stopped, 0 zombie %Cpu(s): 6.5 us, 20.5 sy, 0.0 ni, 41.2 id, 0.0 wa, 0.0 hi, 31.8 si, 0.0 st KiB Mem : 8463984 total, 6299580 free, 1345092 used, 819312 buff/cache KiB Swap: 2317308 total, 2317308 free, 0 used. 6870524 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 349 root 20 0 93024 2576 404 S 140.5 0.0 6:25.43 lcirauqola 3 root 20 0 0 0 0 S 31.6 0.0 1:12.09 ksoftirqd/0 28 root 20 0 0 0 0 S 18.3 0.0 0:38.09 ksoftirqd/3 22 root 20 0 0 0 0 S 9.6 0.0 0:23.09 ksoftirqd/2 Ну и трафик тут же: iftop -i eth0 interface: eth0 19.1Mb 38.1Mb 57.2Mb 76.3Mb 95.4Mb mqqqqqqqqqqqqqqqqqqqvqqqqqqqqqqqqqqqqqqqvqqqqqqqqqqqqqqqqqqqvqqqqqqqqqqqqqqqqqqqvqqqqqqqqqqqqqqqqqqq 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.5Mb 8.41Mb 3.82Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.4Mb 8.40Mb 3.82Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.4Mb 8.35Mb 3.80Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.5Mb 8.35Mb 3.80Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.6Mb 8.34Mb 3.79Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.3Mb 8.34Mb 3.79Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.3Mb 8.30Mb 3.77Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.4Mb 8.26Mb 3.76Mb 188.xxx.xxx.xx <=> h118-184-158-103.pubyun.com 14.2Mb 8.13Mb 3.70Mb Показания last не выявили подозрительных подключений по ssh, но : cat auth.log | grep Accept Oct 21 05:18:45 deb9lb sshd[5829]: Accepted password for root from 218.92.0.163 port 24517 ssh2 Oct 21 06:53:23 deb9lb sshd[6291]: Accepted password for root from 222.112.82.68 port 33548 ssh2 Лоханулся, виноват. :( Рутовый пароль себе конечно вернул, fail2ban поставил, настроил. Как пароль утек - не понятно. В логах apache и т.п. ничего не находится. На виртуалку кроме меня и еще одного сотрудника не пускали, пока не понятны причины инцидента. В итоге в top остались болтаться процессы с именами вида zjrysuhgxefeqy, ythovtgja, tvlnvndlywhdne и т.п. Нагрузку уже не создают ни на сеть, ни на проц, но надо ж эту заразу повывести. Из симптоматики - в кроне: cat /etc/cron.hourly/endhwyldnvnlvt.sh #!/bin/sh PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/usr/X11R6/bin cp "/bin/endhwyldnvnlvt" "/bin/twtfswvvzk" "/bin/twtfswvvzk" Ну и разумеется в /bin/ ls -l endhwyldnvnlvt* -rwxr-xr-x 1 root root 562341 Oct 22 23:43 endhwyldnvnlvt -rwxr-xr-x 1 root root 151 Oct 22 23:43 endhwyldnvnlvt.sh [1]+ Done ls --color=auto -l endhwyldnvnlv В /etc/init.d: ls -l /etc/init.d/endhwyldnvnlvt -rwxr-xr-x 1 root root 358 Oct 22 23:43 /etc/init.d/endhwyldnvnlvt cat /etc/init.d/endhwyldnvnlvt #!/bin/sh # chkconfig: 12345 90 90 # description: endhwyldnvnlvt ### BEGIN INIT INFO # Provides: endhwyldnvnlvt # Required-Start: # Required-Stop: # Default-Start: 1 2 3 4 5 # Default-Stop: # Short-Description: endhwyldnvnlvt ### END INIT INFO case $1 in start) "/bin/tvlnvndlywhdne" break ;; stop) break ;; *) "/bin/tvlnvndlywhdne" break ;; esac Можно эту заразу как-то вывести или виртуалку в морг? Вставить ник Quote
vlad11 Posted October 22, 2019 Posted October 22, 2019 Проще в морг. P.S. наверное, доступ получили через exim. Вставить ник Quote
vop Posted October 23, 2019 Posted October 23, 2019 48 minutes ago, vlad11 said: Проще в морг. P.S. наверное, доступ получили через exim. Проще переставить, если сервер новый. PS А exim4 из коробки портами наружу не светит. Вставить ник Quote
taf_321 Posted October 23, 2019 Posted October 23, 2019 4 часа назад, Andrei сказал: Можно эту заразу как-то вывести или виртуалку в морг? Однозначно в морг. 2 часа назад, vop сказал: Проще переставить, если сервер новый. Даже если сервер старый и заслуженный, то его тоже в морг. Вытягивать только данные без скриптов, бинарников и библииотек. Вставить ник Quote
maxlapshin Posted October 23, 2019 Posted October 23, 2019 вывести руткит с сервера условно невозможно. Если вам очень повезло, он не прошился в биос и вы сможете его вылечить переустановкой всего с нуля. Пытаться пройтись по операционной системе каким-нибудь антивирусом, чтобы он вам удалил руткит — на это надеяться не стоит. Может поможет, а может руткит воткнулся в ядро и перехватывает половину системных вызовов и показывает вам неправильный ps и прочее. Вставить ник Quote
Andrei Posted October 23, 2019 Author Posted October 23, 2019 7 часов назад, vlad11 сказал: наверное, доступ получили через exim. Exim-а нет. 3 часа назад, taf_321 сказал: Даже если сервер старый и заслуженный, то его тоже в морг. Это виртуалка, на хост-системе ничего такого нет. 44 минуты назад, maxlapshin сказал: Если вам очень повезло, он не прошился в биос и вы сможете его вылечить переустановкой всего с нуля. Из виртуалки прошить биос? Вставить ник Quote
NewUse Posted October 23, 2019 Posted October 23, 2019 сносить виртуалку, если система с нуля поставленна, то перед сносом не плохо бы куда-нибудь отправить на анализ, видать какая-то дырка где-то есть... 9-ка вроде на поддержке ещё, вообще, очень странно... и очень тревожный симптом... Вставить ник Quote
Andrei Posted October 23, 2019 Author Posted October 23, 2019 rkhunter ничего интересного не нашел System checks summary ===================== File properties checks... Files checked: 143 Suspect files: 0 Rootkit checks... Rootkits checked : 377 Possible rootkits: 0 Applications checks... Applications checked: 4 Suspect applications: 0 The system checks took: 14 minutes and 36 seconds Вставить ник Quote
alibek Posted October 23, 2019 Posted October 23, 2019 Качественный руткит обнаружить или убрать изнутри системы невозможно. Поэтому запущенный в системе rkhunter или любой другой подобный инструмент или антивирус бесполезен. Хоть какой-то смысл в подобных утилитах есть только при запуска их с LiveCD, но и то при условии, что известно, что искать. Так что тоже присоединяюсь к совету все снести и переустановить. Вирусы в BIOS лично я считаю за городские легенды. Еще ни разу видеть их не доводилось, да и на половине серверов запись в BIOS по умолчанию заблокирована. Вставить ник Quote
vop Posted October 23, 2019 Posted October 23, 2019 8 hours ago, alibek said: Качественный руткит обнаружить или убрать изнутри системы невозможно. Что-то вы совсем как-то пессимистично. :) Любой руткит вывести можно. Только иногда очень сложно, и не каждый сможет. :) Поэтому порой, действительно, проще сервер переставить, сохранив данные. PS А то прям ньюбов пугаете. :) Вставить ник Quote
alibek Posted October 23, 2019 Posted October 23, 2019 Проверить на какой-то конкретный руткит в ряде случаев можно. А обнаружить какой-то неизвестный нельзя. Все что детектор или антивирус может проверить, руткит может перехватить и подменить. Вставить ник Quote
vop Posted October 23, 2019 Posted October 23, 2019 7 hours ago, alibek said: Проверить на какой-то конкретный руткит в ряде случаев можно. А обнаружить какой-то неизвестный нельзя. Все что детектор или антивирус может проверить, руткит может перехватить и подменить. Ладно, пусть будет по вашему... Просто намекну, что кроме антивирусов и детекторов есть голова, руки, аналитика. Но это не каждому под силу. Ну и проверить целостность системы не катастрофически сложно. Для этого известность руткиту не особо нужна. Нужно понимание, что и как может он делать. У себя я ловил руткит один раз лет 15 назад, если не раньше. Но коллекция из тех, которых пришлось выковыривать у страдальцев набралась средненькая. Вставить ник Quote
Andrei Posted October 24, 2019 Author Posted October 24, 2019 В 23.10.2019 в 12:33, NewUse сказал: перед сносом не плохо бы куда-нибудь отправить на анализ, видать какая-то дырка где-то есть... 9-ка вроде на поддержке ещё, вообще, очень странно... и очень тревожный симптом... Кто-то занимается таким анализом? Поискать на debian.org сообщества разработчиков? Вставить ник Quote
alibek Posted October 24, 2019 Posted October 24, 2019 Сегодня сам поймал какую-то инфекцию. У меня есть один отдельный ПК на Windows XP. На нем минимум софта, только сетевые утилиты, я обычно использую его для настройки оборудования. XP SP3 с последними обновлениями, которые были выпущены, и с отключенным встроенным файрволом. Сегодня для проверки качества ПМ подал на него транспортный VLAN (от другого оператора) и статикой задал публичные IP-адреса. Прошло, чтобы не соврать, максимум три минуты и ПК перегрузился. После загрузки на нем выявились созданные левые учетки, изменения в сетевых настройках (был изменен DNS-сервер), прописались посторонние службы и драйвера, и вообще, такое проще убить, чем лечить. Конечно на ПК был Acronis Startup Recovery Manager, поэтому восстановил его я быстро, но все равно был впечатлен скоростью заражения. Вставить ник Quote
Andrei Posted October 24, 2019 Author Posted October 24, 2019 Я тоже, как только создал новую виртуалку и дал ей публичный ip, сразу в логах увидел попытки перебора паролей по ssh. Поэтому первым делом /etc/host.allow и /etc/host.deny, потом fail2ban и только потом уже занялся основными задачами. Вставить ник Quote
vop Posted October 24, 2019 Posted October 24, 2019 По ipv6 идет бешенное "нападение" от китайских "друзей" (China Telecom) - перебор адресов случайным образом - а там поле для выбора адресов огромное. Как подключаешь /64 - поехали. reject list постепенно пополняется. :) Кстати, паролями в ssh давно не пользуюсь. Только ключами. Вставить ник Quote
Andrei Posted October 24, 2019 Author Posted October 24, 2019 10 часов назад, vop сказал: Для этого известность руткиту не особо нужна. Нужно понимание, что и как может он делать. Пока зараженную виртуалку не выключил, послушал что за трафик и куда с нее сейчас идет. Идут dns-запросы на 53 порт dns.google 8.8.8.8 на счет доменов типа k1.2018fly.com или p11.2017fly.com или p11.sb1024.net и т.п.. В ответ от гугла прилетает либо перечень ip, либо "No such name". Вставить ник Quote
vop Posted October 24, 2019 Posted October 24, 2019 27 minutes ago, Andrei said: Пока зараженную виртуалку не выключил, послушал что за трафик и куда с нее сейчас идет. Идут dns-запросы на 53 порт dns.google 8.8.8.8 на счет доменов типа k1.2018fly.com или p11.2017fly.com или p11.sb1024.net и т.п.. В ответ от гугла прилетает либо перечень ip, либо "No such name". Многие заразы заливают /tmp перловую молотилку (любого предназначения), запускают ее, и стирают на диске все следы. Расчет идет на то, что сервер работает долго без перезагрузок. Иногда можно найти в /proc ссылку exe на несуществующий файл в каталоге /tmp. Это самый простой и самый частый вариант, который не сильно зависит от дистрибутива и версии линукса. В любом случае, надо искать эксплоит и "того", кто/что его применил. Вставить ник Quote
Andrei Posted October 24, 2019 Author Posted October 24, 2019 2 часа назад, vop сказал: В любом случае, надо искать эксплоит Из любопытства поковыряюсь. Так-то вчера уже сделал другую виртуалку и за сегодня все на нее накатил. Эту, после удаления установленного мной софта, можно и отдать для опытов. Вставить ник Quote
Ivan_83 Posted October 24, 2019 Posted October 24, 2019 Как дети. Цепляете диск виртуалки к чистой системе и сверяете хэши файлов, ищите файлы которые не относятся ни к одному пакету. В результате получите список всех файлов которые были зменены либо не относятся ни к одному из пакетов. По крайней мере во фре это всё сделать можно почти на автомате, особенно тем кто обновляет систему с бинарников, а не как я компеляет всё с исходников. Вставить ник Quote
Andrei Posted October 24, 2019 Author Posted October 24, 2019 1 час назад, Ivan_83 сказал: Цепляете Я далеко не ребенок, но как это сделать не представляю. Да и не стОит оно того. Вставить ник Quote
vop Posted October 24, 2019 Posted October 24, 2019 1 hour ago, Ivan_83 said: Как дети. Цепляете диск виртуалки к чистой системе и сверяете хэши файлов, ищите файлы которые не относятся ни к одному пакету. В результате получите список всех файлов которые были зменены либо не относятся ни к одному из пакетов. По крайней мере во фре это всё сделать можно почти на автомате, особенно тем кто обновляет систему с бинарников, а не как я компеляет всё с исходников. В deb-линуксах целостность проверяется по контрольным суммам файлов (например, при помощи debsums). Так находятся подмены всех этих ps, sshd и т.д. А подмены - это второй вариант заразы, который остается на диске и рассчитан на перегрузку системы. Вставить ник Quote
NewUse Posted October 24, 2019 Posted October 24, 2019 9 часов назад, Andrei сказал: Кто-то занимается таким анализом? Поискать на debian.org сообщества разработчиков? Вроде Касперский раньше принимал, ну и в сообщество тоже стоит... Вставить ник Quote
NiTr0 Posted October 25, 2019 Posted October 25, 2019 В 24.10.2019 в 12:26, alibek сказал: У меня есть один отдельный ПК на Windows XP. На нем минимум софта, только сетевые утилиты, я обычно использую его для настройки оборудования. XP SP3 с последними обновлениями, которые были выпущены, и с отключенным встроенным файрволом. Сегодня для проверки качества ПМ подал на него транспортный VLAN (от другого оператора) и статикой задал публичные IP-адреса. Прошло, чтобы не соврать, максимум три минуты и ПК перегрузился. После загрузки на нем выявились созданные левые учетки, изменения в сетевых настройках (был изменен DNS-сервер), прописались посторонние службы и драйвера, и вообще, такое проще убить, чем лечить. небось самба не отключена? так ничего удивительного, SMBv1 похож на штопаное-перештопаное резиновое изделие - сколько его ни штопали, а победить все дыры так и не смогли, причем обнаруживаемые дыры существовали во всех виндах NT начиная с NT4 (а возможно - и 9х + NT3.51 за компанию). потом правда майкрософт решил не писать уже в багрепортах EOL операционки :) собссно почему сейчас SMBv1 в десятке то ли отключен по дефолту и включается очень шершавым напильником, то ли вообще уже выпилен. Вставить ник Quote
