Juniper EX4200 - Fan Tray, можно ли как-то понять, когда начнут "подходить" вентиляторы?
Коллеги, добрый день!
Есть пачка EX4200 в ДЦ, заметил, что некоторые вентили в Full Speed, а какие-то в Normal
show chassis environment
Class Item                           Status     Measurement
Power FPC 0 Power Supply 0           OK
      FPC 0 Power Supply 1           OK
      FPC 1 Power Supply 0           OK
      FPC 1 Power Supply 1           OK
Temp  FPC 0 CPU                      OK         48 degrees C / 118 degrees F
      FPC 0 EX-PFE1                  OK         52 degrees C / 125 degrees F
      FPC 0 EX-PFE2                  OK         65 degrees C / 149 degrees F
      FPC 0 EX-PFE3                  OK         52 degrees C / 125 degrees F
      FPC 0 GEPHY Front Left         OK         38 degrees C / 100 degrees F
      FPC 0 GEPHY Front Middle       OK         46 degrees C / 114 degrees F
      FPC 0 GEPHY Front Right        OK         41 degrees C / 105 degrees F
      FPC 0 Uplink Conn              OK         43 degrees C / 109 degrees F
      FPC 1 CPU                      OK         54 degrees C / 129 degrees F
      FPC 1 EX-PFE1                  OK         56 degrees C / 132 degrees F
      FPC 1 EX-PFE2                  OK         61 degrees C / 141 degrees F
      FPC 1 EX-PFE3                  OK         59 degrees C / 138 degrees F
      FPC 1 GEPHY Front Left         OK         40 degrees C / 104 degrees F
      FPC 1 GEPHY Front Middle       OK         47 degrees C / 116 degrees F
      FPC 1 GEPHY Front Right        OK         41 degrees C / 105 degrees F
      FPC 1 Uplink Conn              OK         40 degrees C / 104 degrees F
Fans  FPC 0 Fan 1                    OK         Spinning at full speed
      FPC 0 Fan 2                    OK         Spinning at full speed
      FPC 0 Fan 3                    OK         Spinning at full speed
      FPC 1 Fan 1                    OK         Spinning at normal speed
      FPC 1 Fan 2                    OK         Spinning at normal speed
      FPC 1 Fan 3                    OK         Spinning at normal speed
Power FPC 2 Power Supply 0           OK
      FPC 2 Power Supply 1           OK
      FPC 3 Power Supply 0           OK
      FPC 3 Power Supply 1           OK
      FPC 4 Power Supply 0           OK
      FPC 4 Power Supply 1           OK
      FPC 5 Power Supply 0           OK
      FPC 5 Power Supply 1           OK
      FPC 6 Power Supply 0           OK
      FPC 6 Power Supply 1           OK
Temp  FPC 2 CPU                      OK         46 degrees C / 114 degrees F
      FPC 2 EX-PFE1                  OK         52 degrees C / 125 degrees F
      FPC 2 EX-PFE2                  OK         62 degrees C / 143 degrees F
      FPC 2 EX-PFE3                  OK         54 degrees C / 129 degrees F
      FPC 2 GEPHY Front Left         OK         34 degrees C / 93 degrees F
      FPC 2 GEPHY Front Middle       OK         44 degrees C / 111 degrees F
      FPC 2 GEPHY Front Right        OK         35 degrees C / 95 degrees F
      FPC 2 Uplink Conn              OK         40 degrees C / 104 degrees F
      FPC 3 CPU                      OK         39 degrees C / 102 degrees F
      FPC 3 EX-PFE1                  OK         48 degrees C / 118 degrees F
      FPC 3 EX-PFE2                  OK         66 degrees C / 150 degrees F
      FPC 3 EX-PFE3                  OK         53 degrees C / 127 degrees F
      FPC 3 GEPHY Front Left         OK         30 degrees C / 86 degrees F
      FPC 3 GEPHY Front Middle       OK         44 degrees C / 111 degrees F
      FPC 3 GEPHY Front Right        OK         42 degrees C / 107 degrees F
      FPC 3 Uplink Conn              OK         39 degrees C / 102 degrees F
      FPC 4 CPU                      OK         36 degrees C / 96 degrees F
      FPC 4 EX-PFE1                  OK         48 degrees C / 118 degrees F
      FPC 4 EX-PFE2                  OK         62 degrees C / 143 degrees F
      FPC 4 EX-PFE3                  OK         52 degrees C / 125 degrees F
      FPC 4 GEPHY Front Left         OK         30 degrees C / 86 degrees F
      FPC 4 GEPHY Front Middle       OK         43 degrees C / 109 degrees F
      FPC 4 GEPHY Front Right        OK         41 degrees C / 105 degrees F
      FPC 4 Uplink Conn              OK         41 degrees C / 105 degrees F
      FPC 5 CPU                      OK         34 degrees C / 93 degrees F
      FPC 5 EX-PFE1                  OK         43 degrees C / 109 degrees F
      FPC 5 EX-PFE2                  OK         61 degrees C / 141 degrees F
      FPC 5 EX-PFE3                  OK         48 degrees C / 118 degrees F
      FPC 5 GEPHY Front Left         OK         27 degrees C / 80 degrees F
      FPC 5 GEPHY Front Middle       OK         34 degrees C / 93 degrees F
      FPC 5 GEPHY Front Right        OK         34 degrees C / 93 degrees F
      FPC 5 Uplink Conn              OK         39 degrees C / 102 degrees F
      FPC 6 CPU                      OK         35 degrees C / 95 degrees F
      FPC 6 EX-PFE1                  OK         46 degrees C / 114 degrees F
      FPC 6 EX-PFE2                  OK         60 degrees C / 140 degrees F
      FPC 6 EX-PFE3                  OK         48 degrees C / 118 degrees F
      FPC 6 GEPHY Front Left         OK         26 degrees C / 78 degrees F
      FPC 6 GEPHY Front Middle       OK         31 degrees C / 87 degrees F
      FPC 6 GEPHY Front Right        OK         33 degrees C / 91 degrees F
      FPC 6 Uplink Conn              OK         39 degrees C / 102 degrees F
Fans  FPC 2 Fan 1                    OK         Spinning at normal speed
      FPC 2 Fan 2                    OK         Spinning at normal speed
      FPC 2 Fan 3                    OK         Spinning at normal speed
      FPC 3 Fan 1                    OK         Spinning at full speed
      FPC 3 Fan 2                    OK         Spinning at full speed
      FPC 3 Fan 3                    OK         Spinning at full speed
      FPC 4 Fan 1                    OK         Spinning at normal speed
      FPC 4 Fan 2                    OK         Spinning at normal speed
      FPC 4 Fan 3                    OK         Spinning at normal speed
      FPC 5 Fan 1                    OK         Spinning at normal speed
      FPC 5 Fan 2                    OK         Spinning at normal speed
      FPC 5 Fan 3                    OK         Spinning at normal speed
      FPC 6 Fan 1                    OK         Spinning at normal speed
      FPC 6 Fan 2                    OK         Spinning at normal speed
      FPC 6 Fan 3                    OK         Spinning at normal speed
Можно ли по данному выводу предположить, что вентили "Spinning at full speed" подходят и требуют чиски/замены?
Иногда еще замечаю, что один Fan из трех начинает вращаться "Spinning at full speed", а остальные в Normal.
Спасибо за внимание.
@mse.rus77
это не показатель. Всего лишь сигнализирует о том, что соответствующий температурный датчик показывает высокую температуру, и вентиляторы прибавили обороты. Хоть основная причина - это забившийся вентилятор, но может быть и просто недостатки охлаждения
граничные значения можно посмотреть
> show chassis temperature-thresholds
                           Fan speed      Yellow alarm      Red alarm      Fire Shutdown
                          (degrees C)      (degrees C)     (degrees C)      (degrees C)
Item                     Normal  High   Normal  Bad fan   Normal  Bad fan     Normal
FPC 0 Sensor TopMiddle C     46    66       65       65       71       71       74
FPC 0 Sensor TopRight E      52    69       68       68       74       74       77
FPC 0 Sensor TopLeft E       46    67       66       66       72       72       75
FPC 0 Sensor TopRight C      40    64       63       63       69       69       72
FPC 0 Sensor CPURight C      44    67       66       66       72       72       75
FPC 0 Sensor CPULeft I       48    68       67       67       73       73       76
FPC 0 Sensor CPU Die Temp    67    92       86       86       92       92       95
FPC 0 Sensor QIC0            43    66       65       65       71       71       74
FPC 0 Sensor QIC1            48    68       65       65       71       71       74
1 час назад, vvertexx сказал:
@mse.rus77
Благодарю!
