soi Posted May 20, 2019 Posted May 20, 2019 Hi ALL, версия софта 6.42.4 в /ip firewall mangle> создаю правило chain=prerouting action=accept src-address=ХХ.ХХ.ХХ.ХХ in-interface=ether1 log=no пакеты ловит в /ip firewall nat> создаю аналогичное правило chain=dstnat action=accept src-address=ХХ.ХХ.ХХ.ХХ in-interface=ether1 log=no пакеты не ловит подскажите где копать? PS Пакеты направляются самому микротику. Вставить ник Quote
Chexov Posted May 20, 2019 Posted May 20, 2019 А выложить /export или вы думаете здесь форум гадалок. Вставить ник Quote
soi Posted May 20, 2019 Author Posted May 20, 2019 Sorry, вот export # jan/02/1970 04:12:33 by RouterOS 6.42.4 # software id = B5ES-UHS8 # # model = RouterBOARD wAP 2nD r2 # serial number = 6D820467EB2D /interface bridge add fast-forward=no name=br-eth add fast-forward=no name=br-wlan /interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \ disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\ MikroTik-Test wireless-protocol=802.11 /interface list add comment=defconf name=WAN add comment=defconf name=LAN /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-eap mode=dynamic-keys \ supplicant-identity=MikroTik /ip hotspot profile set [ find default=yes ] html-directory=flash/hotspot /ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254 /ip dhcp-server add address-pool=default-dhcp disabled=no interface=br-wlan name=server1 /interface bridge port add bridge=br-eth interface=ether1 add bridge=br-wlan interface=wlan1 /ip neighbor discovery-settings set discover-interface-list=LAN /interface list member add comment=defconf disabled=yes interface=wlan1 list=LAN add comment=defconf disabled=yes interface=ether1 list=WAN add disabled=yes interface=ether1 list=LAN /ip address add address=192.168.88.1/24 comment=defconf interface=br-wlan network=\ 192.168.88.0 add address=172.10.255.21/29 interface=br-eth network=172.10.255.16 /ip dhcp-client add comment=defconf dhcp-options=hostname,clientid interface=ether1 /ip dhcp-server network add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 /ip dns set allow-remote-requests=yes servers=193.232.254.218,193.232.254.220 /ip dns static add address=192.168.88.1 name=router.lan /ip firewall filter add action=accept chain=input comment=\ "defconf: accept established,related,untracked" connection-state=\ established,related,untracked add action=drop chain=input comment="defconf: drop invalid" connection-state=\ invalid add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp add action=drop chain=input comment="defconf: drop all not coming from LAN" \ disabled=yes in-interface-list=!LAN add action=accept chain=forward comment="defconf: accept in ipsec policy" \ ipsec-policy=in,ipsec add action=accept chain=forward comment="defconf: accept out ipsec policy" \ ipsec-policy=out,ipsec add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \ connection-state=established,related add action=accept chain=forward comment=\ "defconf: accept established,related, untracked" connection-state=\ established,related,untracked add action=drop chain=forward comment="defconf: drop invalid" \ connection-state=invalid add action=drop chain=forward comment=\ "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \ connection-state=new in-interface-list=WAN /ip firewall mangle add action=accept chain=prerouting in-interface=br-eth src-address=\ 10.10.10.10 /ip firewall nat add action=accept chain=dstnat in-interface=br-eth src-address=10.10.10.10 /ip route add distance=1 gateway=172.10.255.22 /radius add address=10.10.10.10 secret=local_client service=wireless /system routerboard settings set silent-boot=no /tool mac-server set allowed-interface-list=LAN /tool mac-server mac-winbox set allowed-interface-list=LAN статистику по пакетам выложил картинкой Вставить ник Quote
soi Posted May 20, 2019 Author Posted May 20, 2019 Забавно, если мониторить исходящие пакеты в postrouting соответственно в mangle и src.nat то пакеты ловит и там и там /ip firewall mangle add action=accept chain=postrouting dst-address=10.10.10.10 out-interface= br-eth /ip firewall nat add action=accept chain=srcnat dst-address=10.10.10.10 out-interface=br-eth статистика картинкой. Вставить ник Quote
soi Posted May 21, 2019 Author Posted May 21, 2019 И так подытожу что получилось на сегодня, правда желаемого результата пока нет ;( 1) мониторится обмен между RADIUS-клиентом микротиком и конкретным IP RADIUS-сервера 2) исходящие пакеты от микротика к RADIUS-серверу проверяются правилами в цепочке postrouting в mangle и src.nat - ловим пакет и там и там 3) входящие пакеты от RADIUS-сервера к микротику проверяются правилами в цепочке prerouting в mangle и dst.nat - в mangle - ловятся в dst.nat - нет и дополнительно проверяются в цепочке input в mangle - тут тоже пакеты ловятся правила которые ловят пакеты абсолютно идентичные на всех точках проверки для входящего трафика и свои идентичные для исходящего трафика в связи с этим ОГРОМНЫЙ вопрос: ПОЧЕМУ ПАКЕТЫ ИГНОРИРУЮТСЯ в dst.nat ??? Очень прошу помочь в данном вопросе. PS Для наглядности картинка: кружок там где правило ловит пакет, крест - где не ловит Вставить ник Quote
jffulcrum Posted May 24, 2019 Posted May 24, 2019 Из описания действия accept: accept - accept the packet. Packet is not passed to next firewall rule. Вставить ник Quote
LostSoul Posted May 26, 2019 Posted May 26, 2019 В 21.05.2019 в 07:46, soi сказал: Очень прошу помочь в данном вопросе. через цепочки dstnat и srcnet проверяются только пакеты, не относящиеся к какому-либо уже открытому соединению. Позволю себе предположить , что если вам микротик взаимодействует с неким radius-сервером , то исходно udp соединение порождает он сам. Указанное соединение попадает в conntrack ( сессия udp с соответствующим dst ip и dst port ) Когда ваш радиус-сервер присылает ответ, указанный ответ механизмом conntrack соотносится с уже имеющимся открытым соединением в таблице и повода пропускать его через цепочку nat prerouting ( dstnat в нотации микротика ) - нету. попробуйте просто прислать себе произвольный udp пакет с устройства 10.10.10.10 на микротик ( не в рамках ответа на радиус-запрос ) и вы наверняка "поймаете" его вашим правилом. Вставить ник Quote
