Timax Posted May 7, 2019 Posted May 7, 2019 (edited) Доброго времени суток. Столкнулся с проблемой при установке драйвера для тюнера Hauppauge WinTV-HVR-1600. ОС Debian 9. Установка драйверов производится по инструкции ТУТ. Доходим до компиляции и тут затык: root@Astra:~/v4l-dvb# make menuconfig make -C /root/v4l-dvb/v4l menuconfig make[1]: Entering directory '/root/v4l-dvb/v4l' make -C /lib/modules/4.9.0-8-amd64/build -f /root/v4l-dvb/v4l/Makefile.kernel config-targets=1 mixed-targets=0 dot-config=0 SRCDIR=/lib/modules/4.9.0-8-amd64/source v4l-mconf make[2]: Entering directory '/usr/src/linux-headers-4.9.0-8-amd64' /lib/modules/4.9.0-8-amd64/source/Makefile:573: arch/x86/Makefile: No such file or directory make[2]: *** No rule to make target 'arch/x86/Makefile'. Stop. make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-8-amd64' Makefile:388: recipe for target '/lib/modules/4.9.0-8-amd64/build/scripts/kconfig/mconf' failed make[1]: *** [/lib/modules/4.9.0-8-amd64/build/scripts/kconfig/mconf] Error 2 make[1]: Leaving directory '/root/v4l-dvb/v4l' Makefile:27: recipe for target 'menuconfig' failed make: *** [menuconfig] Error 2 root@Astra:~/v4l-dvb# Соответственно дальше так же ошибка: root@Astra:~/v4l-dvb# make make -C /root/v4l-dvb/v4l make[1]: Entering directory '/root/v4l-dvb/v4l' creating symbolic links... make -C firmware prep make[2]: Entering directory '/root/v4l-dvb/v4l/firmware' make[2]: Leaving directory '/root/v4l-dvb/v4l/firmware' make -C firmware make[2]: Entering directory '/root/v4l-dvb/v4l/firmware' make[2]: Nothing to be done for 'default'. make[2]: Leaving directory '/root/v4l-dvb/v4l/firmware' Kernel build directory is /lib/modules/4.9.0-8-amd64/build make -C /lib/modules/4.9.0-8-amd64/build SUBDIRS=/root/v4l-dvb/v4l CFLAGS="-I../linux/include -D__KERNEL__ -I/include -DEXPORT_SYMTAB" modules make[2]: Entering directory '/usr/src/linux-headers-4.9.0-8-amd64' CC [M] /root/v4l-dvb/v4l/tuner-xc2028.o cc1: fatal error: include/linux/version.h: No such file or directory compilation terminated. /usr/src/linux-headers-4.9.0-8-common/scripts/Makefile.build:315: recipe for target '/root/v4l-dvb/v4l/tuner-xc2028.o' failed make[5]: *** [/root/v4l-dvb/v4l/tuner-xc2028.o] Error 1 /usr/src/linux-headers-4.9.0-8-common/Makefile:1546: recipe for target '_module_/root/v4l-dvb/v4l' failed make[4]: *** [_module_/root/v4l-dvb/v4l] Error 2 Makefile:152: recipe for target 'sub-make' failed make[3]: *** [sub-make] Error 2 Makefile:8: recipe for target 'all' failed make[2]: *** [all] Error 2 make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-8-amd64' Makefile:43: recipe for target 'default' failed make[1]: *** [default] Error 2 make[1]: Leaving directory '/root/v4l-dvb/v4l' Makefile:27: recipe for target 'all' failed make: *** [all] Error 2 Может кто сможет направить в нужное направление? Edited May 7, 2019 by Timax Вставить ник Quote
NewUse Posted May 7, 2019 Posted May 7, 2019 Вы уверены, что нужно собирать модуль, а не достаточно просто загрузить готовый? 9-ка вроде не самая старая... Вставить ник Quote
[anp/hsw] Posted May 8, 2019 Posted May 8, 2019 23 часа назад, Timax сказал: Hauppauge WinTV-HVR-1600 Интересно, где вы нашли ей применение? Это же ATSC-карта, кто у нас вещает в нем? Вставить ник Quote
Timax Posted May 11, 2019 Author Posted May 11, 2019 В 08.05.2019 в 02:51, NewUse сказал: Вы уверены, что нужно собирать модуль, а не достаточно просто загрузить готовый? 9-ка вроде не самая старая... Не уверен, поэтому и спрашиваю. В 08.05.2019 в 13:21, [anp/hsw] сказал: Интересно, где вы нашли ей применение? Это же ATSC-карта, кто у нас вещает в нем? Нужно временно с эфира принять тв канал. Вставить ник Quote
[anp/hsw] Posted May 11, 2019 Posted May 11, 2019 40 минут назад, Timax сказал: Нужно временно с эфира принять тв канал. И в какой стране происходит данное безобразие? https://ru.wikipedia.org/wiki/ATSC#Северная_Америка Вставить ник Quote
Timax Posted May 11, 2019 Author Posted May 11, 2019 2 часа назад, [anp/hsw] сказал: И в какой стране происходит данное безобразие? https://ru.wikipedia.org/wiki/ATSC#Северная_Америка Карта умеет многое. Стоят такие на аневии, прекрасно все принимают. Вставить ник Quote
murano Posted May 11, 2019 Posted May 11, 2019 В 07.05.2019 в 12:40, Timax сказал: Доброго времени суток. Столкнулся с проблемой при установке драйвера для тюнера Hauppauge WinTV-HVR-1600. ОС Debian 9. Установка драйверов производится по инструкции ТУТ. Доходим до компиляции и тут затык: root@Astra:~/v4l-dvb# make menuconfig make -C /root/v4l-dvb/v4l menuconfig make[1]: Entering directory '/root/v4l-dvb/v4l' make -C /lib/modules/4.9.0-8-amd64/build -f /root/v4l-dvb/v4l/Makefile.kernel config-targets=1 mixed-targets=0 dot-config=0 SRCDIR=/lib/modules/4.9.0-8-amd64/source v4l-mconf make[2]: Entering directory '/usr/src/linux-headers-4.9.0-8-amd64' /lib/modules/4.9.0-8-amd64/source/Makefile:573: arch/x86/Makefile: No such file or directory make[2]: *** No rule to make target 'arch/x86/Makefile'. Stop. make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-8-amd64' Makefile:388: recipe for target '/lib/modules/4.9.0-8-amd64/build/scripts/kconfig/mconf' failed make[1]: *** [/lib/modules/4.9.0-8-amd64/build/scripts/kconfig/mconf] Error 2 make[1]: Leaving directory '/root/v4l-dvb/v4l' Makefile:27: recipe for target 'menuconfig' failed make: *** [menuconfig] Error 2 root@Astra:~/v4l-dvb# Соответственно дальше так же ошибка: root@Astra:~/v4l-dvb# make make -C /root/v4l-dvb/v4l make[1]: Entering directory '/root/v4l-dvb/v4l' creating symbolic links... make -C firmware prep make[2]: Entering directory '/root/v4l-dvb/v4l/firmware' make[2]: Leaving directory '/root/v4l-dvb/v4l/firmware' make -C firmware make[2]: Entering directory '/root/v4l-dvb/v4l/firmware' make[2]: Nothing to be done for 'default'. make[2]: Leaving directory '/root/v4l-dvb/v4l/firmware' Kernel build directory is /lib/modules/4.9.0-8-amd64/build make -C /lib/modules/4.9.0-8-amd64/build SUBDIRS=/root/v4l-dvb/v4l CFLAGS="-I../linux/include -D__KERNEL__ -I/include -DEXPORT_SYMTAB" modules make[2]: Entering directory '/usr/src/linux-headers-4.9.0-8-amd64' CC [M] /root/v4l-dvb/v4l/tuner-xc2028.o cc1: fatal error: include/linux/version.h: No such file or directory compilation terminated. /usr/src/linux-headers-4.9.0-8-common/scripts/Makefile.build:315: recipe for target '/root/v4l-dvb/v4l/tuner-xc2028.o' failed make[5]: *** [/root/v4l-dvb/v4l/tuner-xc2028.o] Error 1 /usr/src/linux-headers-4.9.0-8-common/Makefile:1546: recipe for target '_module_/root/v4l-dvb/v4l' failed make[4]: *** [_module_/root/v4l-dvb/v4l] Error 2 Makefile:152: recipe for target 'sub-make' failed make[3]: *** [sub-make] Error 2 Makefile:8: recipe for target 'all' failed make[2]: *** [all] Error 2 make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-8-amd64' Makefile:43: recipe for target 'default' failed make[1]: *** [default] Error 2 make[1]: Leaving directory '/root/v4l-dvb/v4l' Makefile:27: recipe for target 'all' failed make: *** [all] Error 2 Может кто сможет направить в нужное направление? apt install -y linux-headers ? Вставить ник Quote
Timax Posted May 11, 2019 Author Posted May 11, 2019 5 часов назад, murano сказал: apt install -y linux-headers ? Находил этот момент, актуальные установлены. Вставить ник Quote
murano Posted May 12, 2019 Posted May 12, 2019 9 часов назад, Timax сказал: Находил этот момент, актуальные установлены. uname -r, dpkg -l | grep linux покажите Вставить ник Quote
Timax Posted May 12, 2019 Author Posted May 12, 2019 3 часа назад, murano сказал: uname -r, dpkg -l | grep linux покажите root@Astra:~# uname -r 4.9.0-8-amd64 root@Astra:~# dpkg -l | grep linux ii console-setup-linux 1.164 all Linux specific part of console-setup ii libselinux1:amd64 2.6-3+b3 amd64 SELinux runtime shared libraries ii linux-base 4.5 all Linux image base package ii linux-compiler-gcc-6-x86 4.9.168-1 amd64 Compiler for Linux on x86 (meta-package) ii linux-headers-4.9.0-8-amd64 4.9.144-3.1 amd64 Header files for Linux 4.9.0-8-amd64 ii linux-headers-4.9.0-8-common 4.9.144-3.1 all Common header files for Linux 4.9.0-8 ii linux-headers-4.9.0-9-amd64 4.9.168-1 amd64 Header files for Linux 4.9.0-9-amd64 ii linux-headers-4.9.0-9-common 4.9.168-1 all Common header files for Linux 4.9.0-9 ii linux-headers-amd64 4.9+80+deb9u7 amd64 Header files for Linux amd64 configuration (meta-package) ii linux-image-4.9.0-8-amd64 4.9.144-3.1 amd64 Linux 4.9 for 64-bit PCs ii linux-image-amd64 4.9+80+deb9u6 amd64 Linux for 64-bit PCs (meta-package) ii linux-kbuild-4.9 4.9.168-1 amd64 Kbuild infrastructure for Linux 4.9 ii linux-libc-dev:amd64 4.9.168-1 amd64 Linux support headers for userspace development ii linux-source 4.9+80+deb9u7 all Linux kernel source (meta-package) ii linux-source-4.9 4.9.168-1 all Linux kernel source for version 4.9 with Debian patches ii util-linux 2.29.2-1+deb9u1 amd64 miscellaneous system utilities ii util-linux-locales 2.29.2-1+deb9u1 all locales files for util-linux root@Astra:~# Вставить ник Quote
NewUse Posted May 12, 2019 Posted May 12, 2019 (edited) прежде, чем что-то собирать, сделайте : Цитата dmesg|grep cx драйвер, исходя из ссылки в той же Вики уже давно в ядре и собирать ничего не надо. Edited May 14, 2019 by NewUse опечатка в комманде Вставить ник Quote
