Всем привет. Столкнулся с интересной проблемой. Система Ubuntu 18.04.1 LTS (GNU/Linux 4.15.0-45-generic x86_64). Подключено два USB хаба по 10 портов каждый. В каждый порт хаба воткнут карт ридер (карточки для спутникового доступа). Утилита lsusb определяет все 20 ридеров:
#lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 027: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 026: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 024: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 022: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 017: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 013: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 009: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 021: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 018: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 006: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 003: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 025: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 023: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 019: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 015: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 010: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 020: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 016: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 012: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 008: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 003 Device 004: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 002: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Но в каталоге /dev/ появляется только 19.
#ll /dev/ttyUSB*
crw-rw---- 1 root dialout 188,  0 фев  8 09:36 /dev/ttyUSB0
crw-rw---- 1 root dialout 188,  1 фев  8 09:36 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 10 фев  8 09:36 /dev/ttyUSB10
crw-rw---- 1 root dialout 188, 11 фев  8 09:36 /dev/ttyUSB11
crw-rw---- 1 root dialout 188, 12 фев  8 09:36 /dev/ttyUSB12
crw-rw---- 1 root dialout 188, 13 фев  8 09:36 /dev/ttyUSB13
crw-rw---- 1 root dialout 188, 14 фев  8 09:36 /dev/ttyUSB14
crw-rw---- 1 root dialout 188, 15 фев  8 09:36 /dev/ttyUSB15
crw-rw---- 1 root dialout 188, 16 фев  8 09:36 /dev/ttyUSB16
crw-rw---- 1 root dialout 188, 17 фев  8 09:36 /dev/ttyUSB17
crw-rw---- 1 root dialout 188, 18 фев  8 09:36 /dev/ttyUSB18
crw-rw---- 1 root dialout 188,  2 фев  8 09:36 /dev/ttyUSB2
crw-rw---- 1 root dialout 188,  3 фев  8 09:36 /dev/ttyUSB3
crw-rw---- 1 root dialout 188,  4 фев  8 09:36 /dev/ttyUSB4
crw-rw---- 1 root dialout 188,  5 фев  8 09:36 /dev/ttyUSB5
crw-rw---- 1 root dialout 188,  6 фев  8 09:36 /dev/ttyUSB6
crw-rw---- 1 root dialout 188,  7 фев  8 09:36 /dev/ttyUSB7
crw-rw---- 1 root dialout 188,  8 фев  8 09:36 /dev/ttyUSB8
crw-rw---- 1 root dialout 188,  9 фев  8 09:36 /dev/ttyUSB9
Может у кого-то есть идеи, куда девается 20-й ридер? Хабы и ридеры все рабочие, если подключать хабы по отдельности, то опредеяются по 10 штук. Одновременно же, только 19.
Я бы посмотрел скрипты и конфиги udev (/etc/udev, /lib/udev и т.п.), скорее всего где-то в них эта константа будет определена.
В USB есть лимит по числу устройств на шине, я не помню, какой он, но значительно больше 20.
14 минут назад, alibek сказал:
Вроде всё тривиально...
# /dev/serial/by-path/, /dev/serial/by-id/ for USB devices
KERNEL!="ttyUSB[0-9]*|ttyACM[0-9]*", GOTO="serial_end"
lsusb | grep Futur
Bus 001 Device 028: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 027: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 026: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 025: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 024: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 023: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 022: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 021: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 020: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 019: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 018: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 017: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 016: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 015: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 013: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 012: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 008: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
lsusb | grep Futur | wc -l
20
ls -l /dev/ttyUSB???
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB111 -> ttyUSB3
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB112 -> ttyUSB2
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB113 -> ttyUSB12
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB114 -> ttyUSB15
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB115 -> ttyUSB14
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB116 -> ttyUSB13
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB117 -> ttyUSB19
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB118 -> ttyUSB18
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB119 -> ttyUSB17
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB120 -> ttyUSB16
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB121 -> ttyUSB1
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB122 -> ttyUSB0
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB123 -> ttyUSB4
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB124 -> ttyUSB7
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB125 -> ttyUSB6
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB126 -> ttyUSB5
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB127 -> ttyUSB11
lrwxrwxrwx 1 root root 8 Jan 18 10:58 /dev/ttyUSB128 -> ttyUSB10
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB129 -> ttyUSB9
lrwxrwxrwx 1 root root 7 Jan 18 10:58 /dev/ttyUSB130 -> ttyUSB8
ls -l /dev/ttyUSB???  | wc -l
20
uname -a
Linux iptv2 2.6.32-5-686 #1 SMP Sun Dec 21 11:09:34 UTC 2014 i686 GNU/Linux
Я бы тоже смотрел в сторону удава.
Спасибо всем за помощь. Решение оказалось довольно простым. Из-за кривой поддержки USB3.0 в linux ядро на отрез отказывалось определять устройства (даже клавиатуру не видело, если 19 устройств уже присутствовали в системе). Решение - отключить поддержку xhci в bios. Источник - https://superuser.com/questions/731751/not-enough-host-controller-resources-for-new-device-state и там есть ссылки внутри ещё. Всем хорошего настроения)))
Цитата:
Not enough host controller resources for new device state.
can't set config #1, error -12
Faced with the same errors. XHCI (usb 3.0) in linux kernel is limited to 32 devices. It looks like a bug. But maybe this is a Bill Gates way "640 kilobytes enough for everyone". In any case, it's a pain.
1) The easiest way to fix it: disable XHCI (usb 3.0) support in motherboard BIOS if possible. 2) The hard way to fix it: disable XHCI linux module. modprobe -r xhci-hcd But in most cases it does not work. You must recompile the kernel to disable XHCI and enable OHCI (usb 1.1) and EHXI (usb 2.0).
Edited by Sashok1985
