anatoly Posted February 27, 2019 Posted February 27, 2019 Перед настройкой на реальном железе (Nexus 7K), попробовал настроить vPC на виртуальном стенде в EVE-NG. И вроде бы все по мануалам, конфиг простой, но vPC не поднимается. SH VPC: Скрытый текст NEXUS-NODE-1# sh vpc Legend: (*) - local vPC is down, forwarding via vPC peer-link vPC domain id : 1 Peer status : peer adjacency formed ok vPC keep-alive status : Suspended (Destination IP not reachable) Configuration consistency status : success Per-vlan consistency status : success Type-2 consistency status : success vPC role : secondary Number of vPCs configured : 1 Peer Gateway : Enabled Dual-active excluded VLANs : - Graceful Consistency Check : Enabled Auto-recovery status : Disabled Delay-restore status : Timer is off.(timeout = 60s) Delay-restore SVI status : Timer is off.(timeout = 10s) Operational Layer3 Peer-router : Disabled vPC Peer-link status --------------------------------------------------------------------- id Port Status Active vlans -- ---- ------ ------------------------------------------------- 1 Po1 up 1,100 Конфиг: Скрытый текст feature interface-vlan feature lacp feature vpc vlan 1,100 vrf context management vpc domain 1 peer-switch role priority 1 peer-keepalive destination 10.255.255.2 vrf default delay restore 60 peer-gateway interface Vlan100 no shutdown no ip redirects ip address 10.255.255.1/30 no ipv6 redirects ip arp timeout 100 interface port-channel1 switchport mode trunk spanning-tree port type network vpc peer-link interface port-channel10 switchport mode trunk switchport trunk allowed vlan 100 vpc 10 interface Ethernet1/1 shutdown switchport mode trunk switchport trunk allowed vlan 100 channel-group 10 mode active interface Ethernet1/2 switchport mode trunk channel-group 1 mode active interface Ethernet1/3 switchport mode trunk switchport trunk allowed vlan 100 channel-group 10 mode active С другой стороны - зеркальный. Адреса для кипэлайвов с коммутаторов доступны в обе стороны, ping идет Подскажите, пжл, где искать грабли? Вставить ник Quote
ikiliikkuja Posted February 28, 2019 Posted February 28, 2019 src попробуйте указать Вставить ник Quote
anatoly Posted February 28, 2019 Author Posted February 28, 2019 (edited) 1 час назад, ikiliikkuja сказал: src попробуйте указать указывал - все без толку Edited February 28, 2019 by anatoly Вставить ник Quote
ikiliikkuja Posted February 28, 2019 Posted February 28, 2019 ээээ, а у вас peer-keepalive внутри peer-link? Конечно не взлетит, перенесите на отдельный линк Вставить ник Quote
anatoly Posted February 28, 2019 Author Posted February 28, 2019 2 часа назад, ikiliikkuja сказал: перенесите на отдельный линк Вот это я лоханулся.. спасибо Вставить ник Quote
