После замены BDCOM P3310C на P3608-2TE появилась непонятная проблема - при нормальном уровне сигнала (-18.1) ONU регулярно отваливается без каких-либо видимых проблем:
Цитата
Feb 16 23:13:56 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 23:13:53 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Feb 16 23:13:53 %EPON-ONUAUTHEN: ONU 8479.73fb.08ee is authenticated on EPON0/1:40.
Feb 16 23:13:53 %EPON-ONUREG: ONU 8479.73fb.08ee is registered on EPON0/1:40.
Feb 16 23:13:49 %EPON-ONUDEREG: ONU 8479.73fb.08ee is deregistered on EPON0/1:40.
Feb 16 23:13:05 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 23:13:02 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Feb 16 23:13:01 %EPON-ONUAUTHEN: ONU 8479.73fb.08ee is authenticated on EPON0/1:40.
Feb 16 23:13:01 %EPON-ONUREG: ONU 8479.73fb.08ee is registered on EPON0/1:40.
Feb 16 23:12:57 %EPON-ONUDEREG: ONU 8479.73fb.08ee is deregistered on EPON0/1:40.
Feb 16 23:05:12 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 23:05:09 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Feb 16 23:05:08 %EPON-ONUAUTHEN: ONU 8479.73fb.08ee is authenticated on EPON0/1:40.
Feb 16 23:05:08 %EPON-ONUREG: ONU 8479.73fb.08ee is registered on EPON0/1:40.
Feb 16 23:05:04 %EPON-ONUDEREG: ONU 8479.73fb.08ee is deregistered on EPON0/1:40.
Feb 16 22:59:43 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 22:59:40 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Feb 16 22:59:40 %EPON-ONUAUTHEN: ONU 8479.73fb.08ee is authenticated on EPON0/1:40.
Feb 16 22:59:40 %EPON-ONUREG: ONU 8479.73fb.08ee is registered on EPON0/1:40.
Feb 16 22:59:36 %EPON-ONUDEREG: ONU 8479.73fb.08ee is deregistered on EPON0/1:40.
Feb 16 22:53:41 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 22:53:38 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Feb 16 22:53:38 %EPON-ONUAUTHEN: ONU 8479.73fb.08ee is authenticated on EPON0/1:40.
Feb 16 22:53:38 %EPON-ONUREG: ONU 8479.73fb.08ee is registered on EPON0/1:40.
Feb 16 22:53:31 %EPON-ONUDEREG: ONU 8479.73fb.08ee is deregistered on EPON0/1:40.
Feb 16 22:52:56 %OLT: Interface EPON0/1:40's CTC OAM extension negotiated successfully!
Feb 16 22:52:53 %OLT: Interface EPON0/1:40's OAM Operational Status: Operational
Отваливается каждые 1-5-10 минут. Вроде пробовали менять ону - результата не дало (но можно попробовать еще раз, у меня нет 100% уверенности что она менялась.
Кто-нибудь сталкивался с чем-то подобныем?
Уровень надо смотреть НА ОБОИХ КОНЦАХ линка - не только на приёмнике в ОЛТе, но и на приёмнике в ОНУ. Будете удивлены, но эти уровни всегда разные. Иногда бывают критически разные...
Edited by nemo_lynx
11 минут назад, nemo_lynx сказал:
OLT#show epon optical-transceiver-diagnosis int epoN 0/1 | in "epon0/1:40"
epon0/1:40   -18.2  - со стороны OLT
Со стороны ONU:
OLT#show epon int epoN 0/1:40 onu ctc optical-transceiver-diagnosis
 operating temperature(degree): 47
 supply voltage(V): 3.2
 bias current(mA): 15.8
 transmitted power(DBm): 1.4
 received power(DBm): -13.6
сигналы отличные с обеих сторон.
  • 2 months later...
  • 1 month later...
У нас стояла станция BDCOM 3608-2TE в одном месте в качестве временного решения, потому что не надо было в том месте столько пон-портов. Потом приехала BDCOM P3310C и залив конфиг 1 в 1 мы ее поменяли.
В итоге стало так, в разных местах работают:
BDCOM(tm) P3608-2TE Software, Version 10.1.0E Build 56869
BDCOM(tm) P3310C Software, Version 10.1.0E Build 50174
36 "сильнее" по мультикасту, чем 33
В среднем всегда 25-30 групп на OLT. Вроде все ровненько)
Какие у вас ONU?
Конфиг от 3608 никак не пойдёт 1 в 1 на 3310, ибо 36-я это уже L3, а 33-я таки L2. Отсюда же у них разные концепции и настройки dhcp-relay. 36-я потому и "сильнее по мультикасту", ибо таки для L3 нужен заметно пошустрее проц, и соответственно, другой софт.
Кроме мультикаст-команд там ничего не изменилось.
L3 не нагружал. Зачем оно там?
DHCP-RELAY 1 в 1 строчки.
Мультикаст на 36 сильнее в плане limit групп. И только. На 3310 их там 256 может быть. На 3608 - 512, если не ошибаюсь.
Для обеих железок это создает некоторое неудобство в плане конфига диапазонов групп. И всё. Ну, не считая что если групп более 256 то 33 уже не подойдет, OLT просто не даст такое применить. Но это вопрос уже к ТВ-одминам и с их головной импотенцией, когда не могут сделать упорядоченный человеческий список групп)
На самом деле, народ, ничем не отличаются железяки. Ну я по крайней мере не увидел какую то разницу в работе.
  • 4 years later...
В 24.04.2024 в 08:10, yKpon сказал:
была проблема с отвалами, причина была в sfp модулях, 6 штук гейтрей на файбертуле были куплены
заменили на SNR/BDCom и похоже, что помогло. большое спасибо от наших абонентов )
из замеченного - колбаса "включалась" у абонентов, сидящих на линиях >10км.
Edited by nixx
  • 3 weeks later...
Тоже недавно поставили SFP Gateray с двумя плюсиками на P3310D и началась такая же свистопляска.
Хотели поднять ими сигнальчик на пару децибел.
И начали отваливаться случайным образом ONU.
Поменял на FIBO.
Понаблюдаю за ситуацией.
UPD.
Спустя сутки.
Вроде как замена SFP модулей с Gateray на FIBO помогла.
Отвалов ONU-шек больше не наблюдается.
Edited by Akor4eg
  • 4 months later...
как оказалось, Gateray не очень виноваты (или очень, но местами)
стоит OLT P3608B, в ней первые четыре порта заняты Gateray'ми, оптика до абонентов сказочная - 25-27км, всё работает прекрасно (тьфу-тьфу ))
поставили в 5 и 6 порт PON-модули BDCom свежекупленные (покупались именно для того, чтобы начать избавляться от Gateray), начали подключать абонентов (длины оптики - 13-15км), и приплыли - постоянная колбаса некоторых онушек, причем не каких-то конкретных, а типа по очереди... (так же и с гейтреями было) - сначала одна колбасится полдня, потом другие две, потом третья.
сегодня коллега поменял эту пару BDCom на две Gateray. два часа - полет нормальный. ждем. сильно в задумчивости и озабоченности на тему "что это за фигня происходит".
ps: прошивка P3608B была 121083, вот три дня назад обновил до 129386. колбаса была с обоими версиями.
pps: уровни везде в порядке (от -17-18 на ONU до -27 на OLT).
Разные модули имеют разные характеристики (тайминги, алрогитмы управления лазером, итд).
Для корректной работы, если вы покупаете не оригинальный модуль, а  клон, нужно понимать, с какого именно он модуля скопирован и какие настройки выставить в типе модуля. Иначе может возникнуть такая ситуация.
3 часа назад, [anp/hsw] сказал:
а можно поподробнее - какие настройки в каком типе модуля (в конфиге OLT? в прошивке модуля? где-то еще?) выставлять? где об этом почитать?
ну и модуль, на котором написано BDCom - это оригинальный модуль? )
20 часов назад, nixx сказал:
Ну как пример:
olt(config)(if-gpon-0)# optics
   delay                Set optics delay parameters
   laser-reset          Enable optics laser reset
   preamble             Set optics preamble parameters
   reset                Set optics reset parameters
   rng                  Set optics rng parameters
   signal-detect        Enable optics signal-detect parameters
   snr                  Set optics snr parameters
   use-custom           Enable optics use-custom parameter
   voltage-if-mode      Set optics voltage-if mode
olt(config)(if-gpon-0)# optics delay
   double      Set optics double delay parameters
   single      Set optics single delay parameters
olt(config)(if-gpon-0)# optics laser-reset
   polarity      Set optics laser-reset polarity parameter
   <cr>
olt(config)(if-gpon-0)# optics preamble
   correlation-length        Set optics correlation preamble length
   delimiter                 Set optics preamble delimiter parameters
   guard-time-data-mode      Set optics preamble guard-time-data mode
   pattern                   Set optics preamble pattern
   size                      Set optics preamble size
   snr-rng-length            Set optics preamble snr-rng length
   <cr>
На вашем olt что-то похожее должно быть.
Как правило это либо профиль с уже задаными параметрами под конкретного производителя, либо в рассыпную, как я показал.
Все эти параметры есть в даташите модуля, их можно взять оттуда.
Он может и оригинальный, но может быть сделан не для вашей OLT. Или вообще вы epon-модуль в gpon голову втыкаете.
В 28.09.2024 в 14:10, [anp/hsw] сказал:
увы, нету.
специально спрашивал, потому как сам никогда такого не встречал, но вдруг где-то осталось неведомое мне меню.
там есть gpon transceiver X команда в контексте интерфейса, можете там поперебирать варианты
Edited by ShumBor
12 минут назад, h3ll1 сказал:
попробуйте:
epon oam-version 1 0x21
epon oam-version 2 0x20
Так это стандартное, оно есть по умолчанию, там разве что нужно стереть "epon oam-version 1 0x30".
