Добрый день!
SNR-S2965-8T, HardWare Version 2.0.2-UPS
Кто в курсе, в данной модели отсутствует мониторинг статуса питания?
sw1#sh ver
  SNR-S2965-8T Device, Compiled on Dec 04 15:45:31 2018
  sysLocation Msk, per. Susalnyj Nizh., d. 5, str. 19
  CPU Mac f8:f0:82:7a:03:87
  Vlan MAC f8:f0:82:7a:03:86
  SoftWare Version 7.0.3.5(R0241.0284)
  BootRom Version 7.2.40
  CPLD Version N/A
  Serial No.:SW052610I505000XXX
  Copyright (C) 2018 NAG LLC
  All rights reserved
  Last reboot is cold reset.
  Uptime is 0 weeks, 0 days, 1 hours, 57 minutes
Скрытый текст
sw1#show ?
  aaa                          AAA protocol
  access-group                 Access-list group
  access-lists                 Display access-list structure
  acl                          ACL information
  am                           Show am
  anti-arpscan                 Anti-arpscan
  archive                      archive
  arp                          ARP table
  arp-dynamic                  ARP dynamic  table
  asset                        Asset
  bandwidth                    Show bandwidth
  boot-files                   Boot-files
  captive-portal               Captive Portal
  class-map                    Display QoS Class Map
  clock                        Show clock information
  cluster                      Display cluster information
  collision-mac-address-table  HASH collision mac address table
  copp-policy-map              Show Copp QoS Policy Map
  cpu                          CPU status and configuration
  cpu-rx                       CPU received traffic
  crypto                       Show ssh server crypto key information
  debugging                    Debugging functions
  dot1q-tunnel                 Dot1q-tunnel
  dot1x                        Show dot1x information
  dynamic-vlan                 Show dynamic vlan
  erps                         Ethernet ring protection switching
  errdisable                   errdisable
  ethernet                     Ethernet
  ethernet-oam                 Ethernet in the First Mile Operation, Administration and Maintenance
  firewall                     Display firewall status
  flash                        Flash files information
  flow-based-redirect          Flow redirect for interface
  ftp                          Ftp server information
  fulleaps                     FULL Ethernet Automatic Protection Switching
  garp                         GARP
  gvrp                         GVRP
  history                      Display the session command history
  interface                    Select an interface to configure
  ip                           IP information
  ipv6                         IPv6 information
  isolate-port                 Isolate-port information
  keepalive                    Keepalive
  l2-address-table             l2 address table commands
  lldp                         Link Layer Discovery Protocol
  logging                      Display logging buffered information
  loopback-detection           Show loopback-detection information
  mac-address                  Mac address information
  mac-address-table            Mac address table commands
  mac-authentication-bypass    Show MAC authentication bypass feature information
  mac-notification             MAC address information notification message transmit
  mac-vlan                     Mac vlan
  memory                       Memory configuration
  mls                          Configure MultiLayer Switching characteristics
  monitor                      Display a SPAN session
  mrpp                         Multi-layer Ring Protection Protocol
  mst-pending                  Admin regional config information
  nd-dynamic                   ND dynamic table
  ntp                          Network time protocol
  policy-map                   Show QoS Policy Map
  port-group                   Port-group configuration
  port-security                Security related command
  pppoe                        PPPOE intermediate Agent
  private-mib                  Private-mib
  privilege                    Show current privilege level
  protocol-vlan                Protocol vlan
  radius                       RADIUS protocol
  reload                       Reboot switch
  running-config               Current Operating configuration
  savi                         Source Address Validation Improvements
  sflow                        Sflow Global Configuration
  sn                           sn
  snmp                         Display information of snmp
  sntp                         Simple Network Time Protocol
  spanning-tree                Spanning-tree config
  ssh-server                   Show ssh server information
  startup-config               Contents of startup configuration
  subnet-vlan                  Subnet vlan
  switchport                   Switchport information
  tcam                         TCAM statistics
  tcp                          Show tcp
  tech-support                 Tech-support information
  telnet                       Telnet information
  tftp                         Tftp server information
  time-range                   Configure a time range
  transceiver                  Transceiver digital diagnostic monitor information
  trustview                    Show trustview status
  udp                          Show udp
  uldp                         ULDP information
  ulpp                         Uplink Protection Protocol
  ulsm                         Uplink State Monitor
  users                        Display information about terminal lines
  vacl                         Configure Vlan Acl
  version                      System hardware and software status
  vlan                         VLAN information
  vlan-translation             Configure multi-to-one VLAN translation
  voice-vlan                   Voice vlan
Вывод команды: show ?
Edited by Ромео
snmpget oid .1.3.6.1.4.1.40418.7.100.1.23.2 - возвращает 2, если коммутатор аппаратно не поддерживает мониторинг питания, по идеи он должен говорить что такой oid не существует :о)
