Vircurus Posted January 25, 2019 Posted January 25, 2019 (edited) Добрый день прошу помощи в сборке прошивки желательно Openwrt немного инфы Скрытый текст Qualcomm QCA9880-BR4A FK653X9X 1653 TAIWAN Atheos AR928 -BL1A FK7065D4 1706 TAIWAN NANYA NT5CC64M16GP-DI 72311100EP F TW Memory - Winbond W29NO1HVSINA 67046S300012 736P UART - 5 PIN 1-3.3V 2rx 3tx 4gnd 55V Скрытый текст cat /proc/cpuinfo – информация о процессоре Processor : ARMv7 Processor rev 1 (v7l) BogoMIPS : 1599.07 Features : swp half fastmult edsp CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x4 CPU part : 0xc09 CPU revision : 1 Hardware : HGU Revision : 0000 Serial : 0000000000000000 cat /proc/meminfo – информация о памяти MemTotal: 100232 kB MemFree: 40776 kB Buffers: 7148 kB Cached: 20904 kB SwapCached: 0 kB Active: 9804 kB Inactive: 24132 kB Active(anon): 6020 kB Inactive(anon): 780 kB Active(file): 3784 kB Inactive(file): 23352 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 5892 kB Mapped: 6344 kB Shmem: 916 kB Slab: 12372 kB SReclaimable: 892 kB SUnreclaim: 11480 kB KernelStack: 824 kB PageTables: 452 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 50116 kB Committed_AS: 29472 kB VmallocTotal: 647168 kB VmallocUsed: 6828 kB VmallocChunk: 622120 kB df – показать информацию о использовании дисков Filesystem 1k-blocks Used Available Use% Mounted on /dev/mtdblock10 11264 11264 0 100% / /dev/mtdblock2 4096 420 3676 10% /tagparam tmpfs 25600 296 25304 1% /var /dev/mtdblock5 8192 616 7576 8% /userconfig /dev/mtdblock4 4096 384 3712 9% /usr/local/ct /dev/mtdblock8 4096 396 3700 10% /wlan Скрытый текст => printenv baudrate=115200 bootcmd=setenv bootargs console=$(console) root=/dev/mtdblock7 ro rootfstype=squashfs mem=$(memsize);bootm 0x42000100 bootdelay=2 bootfile=uboot.bin console=ttyS0,115200n8 ethact=eth0 ethaddr=00:41:71:00:00:50 fullfile=upgrade.bin ipaddr=192.168.1.1 linuzfile=vmlinuz.bin memsize=128M netretry=5 rootfile=rootfs.img serverip=192.168.1.100 stderr=serial stdin=serial stdout=serial ver=U-Boot 2013.04 (Nov 10 2017 - 12:02:38) versioninfo=U-Boot V1.0.10P5T1 20171110121604 0x1600000 0x1 0x83 0x8f Environment size: 549/131068 bytes Скрытый текст BOOT MODE: NAND ddr init U-Boot 2013.04 (Nov 10 2017 - 12:02:38) CPU: Cortex-A9 400 MHz AHB: 100 MHz APB: 50 MHz I2C: ready DRAM: 128 MiB MMU: on vid=100-F670 NAND: Manu ID: 0xef, Chip ID: 0xf1 (Winbond NAND 128MiB 3,3V 8-bit) 128 MiB <nand_read_skip_bad_,1217>!mtdpart=0x1,offset=0x0,mtdpartoffset=0x180000,mtdPart size=0x80000,length=0x20000 In: serial Out: serial Err: serial FCS: speed change finished 20000 Net: ponmode is 0 eth0 Hit 1 to upgrade softwate version Hit any key to stop autoboot: 0 addr=200000 addr=1600000 select=0x0 search=0x2 <nand_read_skip_bad_,1217>!mtdpart=0x6,offset=0x0,mtdpartoffset=0x2a00000,mtdPar tsize=0x600000,length=0x1000 BootImageNum=0x00000001,1 select = 0x1 search->result[select].entry=1600100 <nand_read_skip_bad_,1217>!mtdpart=0x3,offset=0x0,mtdpartoffset=0x1600000,mtdPar tsize=0x400000,length=0x1df800 header->contend.ih_fs_size=aff000 mtd_offset=0x0 mtdpartfs=5, fs_size=aff000 <nand_read_skip_bad_,1217>!mtdpart=0x5,offset=0x0,mtdpartoffset=0x1a00000,mtdPar tsize=0x1000000,length=0xaff000 Saving Environment to NAND... Erasing 0x180000 - 0x200000:<nand_erase_skip_bad_,1415>!mtdpart=0x1,start=0x0,mt dpartoffset=0x180000,mtdPartsize=0x80000,length=0x80000 [Done] Writing to Nand:<nand_write_skip_bad_,1310>!mtdpart=0x1,offset=0x0,mtdpartoffset =0x180000,mtdPartsize=0x80000,length=0x20000 [Done] setting versioninfo... <nand_read_skip_bad_,1217>!mtdpart=0x0,offset=0x0,mtdpartoffset=0x0,mtdPartsize= 0x180000,length=0x40000 lseek=0x43038c30 cmdline=U-Boot V1.0.10P5T1 20171110121604 Saving Environment to NAND... Erasing 0x180000 - 0x200000:<nand_erase_skip_bad_,1415>!mtdpart=0x1,start=0x0,mt dpartoffset=0x180000,mtdPartsize=0x80000,length=0x80000 [Done] Writing to Nand:<nand_write_skip_bad_,1310>!mtdpart=0x1,offset=0x0,mtdpartoffset =0x180000,mtdPartsize=0x80000,length=0x20000 [Done] ## Booting kernel from Legacy Image at 42000100 ... Image Name: Linux Kernel Image Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 1963698 Bytes = 1.9 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ---------------------- |-->setup versioninfo tag... Starting kernel ... Linux version 2.6.32.61-EMBSYS-CGEL-4.03.20.P1.F0 (root@A23176682) (gcc version 4.1.2 2011-06-24 ZTE Embsys-TSP V2.08.20_P2) #175 Fri Nov 10 12:03:35 CST 2017 CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: HGU Memory policy: ECC disabled, Data cache writeback <7>On node 0 totalpages: 32768 <7>free_area_init_node: node 0, pgdat c03edce4, node_mem_map c0422000 <4>BUG: mapping for 0x40000000 at 0xd0000000 overlaps vmalloc space L2X0 cache controller enabled Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: console=ttyS0,115200n8 root=/dev/mtdblock10 ro rootfstype=s quashfs mem=128M PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) <6>Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) <6>Memory: 128MB = 128MB total <5>Memory: 100100KB available (3691K code, 370K data, 132K init, 0K highmem) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Experimental hierarchical RCU implementation. Experimental hierarchical RCU init done. NR_IRQS:160 CPU: 800 MHz, HCLK: 200 MHz, PCLK: 100 MHz !!! WARNING: Invalid CONFIG_CLOCK_TICK_RATE (expected=100000000) !!! Console: colour dummy device 80x30 console [ttyS0] enabled Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 11930:27:43 [Klogctl][Info] [(1086)LogCtlInit] LogCtlInit begin 11930:27:43 [Klogctl][Info] [(896)AddLogOutModule] AddLogOutModule:OutputMode=0X 00000200,ptLogProcSet=c6027a98 11930:27:43 [Klogstdio][Info] [(1058)LogStdioProcInit] LogStdioProcInit LogUdpWatchProcInit product_vid = 100 <pdt_wdt_init>(514):creat proc files for watchdog!!! <pdt_wdt_init>(518):Starting Watchdog Timer... ftwdt010: heartbeat 5 msec, clock 800000000 Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled serial8250: ttyS0 at MMIO 0x0 (irq = 53) is a 16550A serial8250: ttyS1 at MMIO 0x0 (irq = 54) is a 16550A **********Init ZTE PCI Express Root Complex Add ZTE PCIe port 0 Add ZTE PCIe port 1 **********Faraday PCI driver PreInit Faraday PCI driver PreInit Controller 0 Faraday PCI driver SetSerDesPhy PLAT_FTVSEMI_PA = 90700000, PLAT_FTVSEMI_VA = c8a00000 Faraday PCI driver Reset Card Faraday PCI driver Enable Link Training Faraday PCI driver Wait Link to L0 Link state = 0 Faraday PCI driver Link to L0 Faraday PCI driver MiscSetting Faraday PCI driver Config Bar RC Faraday PCI driver Config Bar EP Faraday PCI driver MiscSetting2 Faraday PCI driver PreInit Controller 1 Faraday PCI driver SetSerDesPhy PLAT_FTVSEMI_PA = 90800000, PLAT_FTVSEMI_VA = c8c00000 Faraday PCI driver Reset Card Faraday PCI driver Enable Link Training Faraday PCI driver Wait Link to L0 Link state = 10 Faraday PCI driver Link to L0 Faraday PCI driver MiscSetting Faraday PCI driver Config Bar RC Faraday PCI driver Config Bar EP Faraday PCI driver MiscSetting2 **********Faraday PCI Preinit return **********Faraday PCI driver Setup **********Faraday PCI driver ScanBus pci 0000:00:00.0: PME# supported from D0 D1 D3hot pci 0000:00:00.0: PME# disabled PCI: bus0: Fast back to back transfers disabled **********Faraday PCI driver Setup **********Faraday PCI driver ScanBus pci 0000:01:00.0: PME# supported from D0 D1 D3hot pci 0000:01:00.0: PME# disabled PCI: bus1: Fast back to back transfers disabled **********Faraday PCI driver map_irq ftpcie_cdngen1_map_irq: slot=0 pin=1 IRQ 56/: IRQF_DISABLED is not guaranteed on shared IRQs !!!!!!!!!!!!!!!!!!!!!!!ftpcie_cdn_g1_map_irq***************** **********Faraday PCI driver map_irq ftpcie_cdngen1_map_irq: slot=0 pin=1 IRQ 57/: IRQF_DISABLED is not guaranteed on shared IRQs !!!!!!!!!!!!!!!!!!!!!!!ftpcie_cdn_g1_map_irq***************** bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource fttmr010_clksrc NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 i2c irq mode... fti2c010 fti2c010.0: i2c bus ready. fti2c010 fti2c010.0: speed=200000Hz ################spi:speed=4156250, clk=66500000, div=0x7 ftnandc024_nand_init usim init tdm registered! zx_tdm2.0_probe! g_tdm_buf =ffc00000,46092000 remap tdm reg 91000000 to c880c000 tdm irq=33 reg 0xf9120000 value is 0x5b pon init pp init pp net init ok,232/184 switch init idm_desc_init f8000000/80000000 idm net init ok squashfs: version 4.0 (2009/01/31) Phillip Lougher squashfs: version 4.0 with LZMA457 ported by BRCM NTFS driver 2.1.29 [Flags: R/W]. JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. fuse init (API version 7.13) msgmni has been set to 195 io scheduler noop registered io scheduler cfq registered (default) brd: module loaded loop: module loaded usbcore: registered new interface driver cdc_acm cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapter s usbcore: registered new interface driver usblp nf_conntrack version 0.5.0 (1564 buckets, 8192 max) ip_tables: (C) 2000-2006 Netfilter Core Team NET: Registered protocol family 10 ip6_tables: (C) 2000-2006 Netfilter Core Team IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 Bridge firewalling registered Ebtables v2.0 registered PPP generic driver version 2.4.2 NET: Registered protocol family 24 zte--oss cpu usage module init <LOGID000000005>11930:27:43 [KIGMPSNP][Warn] [br_multicast_se(200)br_del_addr_re g] register gIgmpDelAddrHook succeed! <LOGID000000005>11930:27:43 [KIGMPSNP][Warn] [br_multicast_se(206)br_del_addr_re g] register gMldDelAddrHook succeed! Use unknown,1G flash NAND chip... Scan Channel 0... NAND device: Manufacturer ID: 0xef, Chip ID: 0xf1 (Winbond NAND 128MiB 3,3V 8-bi t) Available OOB is 34 byte, but we use 32 bytes in page mode. total oobsize: 32 oobsize(page mode): 32 ECC correction bits: 3 Scanning device for bad blocks Creating 11 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x000000000000-0x000008000000 : "whole flash" 0x000000000000-0x000000200000 : "u-boot" 0x000003000000-0x000003400000 : "parameter tags" 0x000000200000-0x000000600000 : "kernel0" 0x000003c00000-0x000004000000 : "middleware" 0x000003400000-0x000003c00000 : "usercfg" 0x000001600000-0x000001a00000 : "kernel1" 0x000002a00000-0x000003000000 : "others" 0x000004000000-0x000004400000 : "wlan" 0x000000600000-0x000001600000 : "rootfs0" part[rootfs0]: logic[0]=phys[0] part[rootfs0]: logic[1]=phys[1] part[rootfs0]: logic[2]=phys[2] part[rootfs0]: logic[3]=phys[3] part[rootfs0]: logic[4]=phys[4] part[rootfs0]: logic[5]=phys[5] part[rootfs0]: logic[6]=phys[6] part[rootfs0]: logic[7]=phys[7] part[rootfs0]: logic[8]=phys[8] part[rootfs0]: logic[9]=phys[9] part[rootfs0]: logic[10]=phys[10] part[rootfs0]: logic[11]=phys[11] part[rootfs0]: logic[12]=phys[12] part[rootfs0]: logic[13]=phys[13] part[rootfs0]: logic[14]=phys[14] part[rootfs0]: logic[15]=phys[15] part[rootfs0]: logic[16]=phys[16] part[rootfs0]: logic[17]=phys[17] part[rootfs0]: logic[18]=phys[18] part[rootfs0]: logic[19]=phys[19] part[rootfs0]: logic[20]=phys[20] part[rootfs0]: logic[21]=phys[21] part[rootfs0]: logic[22]=phys[22] part[rootfs0]: logic[23]=phys[23] part[rootfs0]: logic[24]=phys[24] part[rootfs0]: logic[25]=phys[25] part[rootfs0]: logic[26]=phys[26] part[rootfs0]: logic[27]=phys[27] part[rootfs0]: logic[28]=phys[28] part[rootfs0]: logic[29]=phys[29] part[rootfs0]: logic[30]=phys[30] part[rootfs0]: logic[31]=phys[31] part[rootfs0]: logic[32]=phys[32] part[rootfs0]: logic[33]=phys[33] part[rootfs0]: logic[34]=phys[34] part[rootfs0]: logic[35]=phys[35] part[rootfs0]: logic[36]=phys[36] part[rootfs0]: logic[37]=phys[37] part[rootfs0]: logic[38]=phys[38] part[rootfs0]: logic[39]=phys[39] part[rootfs0]: logic[40]=phys[40] part[rootfs0]: logic[41]=phys[41] part[rootfs0]: logic[42]=phys[42] part[rootfs0]: logic[43]=phys[43] part[rootfs0]: logic[44]=phys[44] part[rootfs0]: logic[45]=phys[45] part[rootfs0]: logic[46]=phys[46] part[rootfs0]: logic[47]=phys[47] part[rootfs0]: logic[48]=phys[48] part[rootfs0]: logic[49]=phys[49] part[rootfs0]: logic[50]=phys[50] part[rootfs0]: logic[51]=phys[51] part[rootfs0]: logic[52]=phys[52] part[rootfs0]: logic[53]=phys[53] part[rootfs0]: logic[54]=phys[54] part[rootfs0]: logic[55]=phys[55] part[rootfs0]: logic[56]=phys[56] part[rootfs0]: logic[57]=phys[57] part[rootfs0]: logic[58]=phys[58] part[rootfs0]: logic[59]=phys[59] part[rootfs0]: logic[60]=phys[60] part[rootfs0]: logic[61]=phys[61] part[rootfs0]: logic[62]=phys[62] part[rootfs0]: logic[63]=phys[63] part[rootfs0]: logic[64]=phys[64] part[rootfs0]: logic[65]=phys[65] part[rootfs0]: logic[66]=phys[66] part[rootfs0]: logic[67]=phys[67] part[rootfs0]: logic[68]=phys[68] part[rootfs0]: logic[69]=phys[69] part[rootfs0]: logic[70]=phys[70] part[rootfs0]: logic[71]=phys[71] part[rootfs0]: logic[72]=phys[72] part[rootfs0]: logic[73]=phys[73] part[rootfs0]: logic[74]=phys[74] part[rootfs0]: logic[75]=phys[75] part[rootfs0]: logic[76]=phys[76] part[rootfs0]: logic[77]=phys[77] part[rootfs0]: logic[78]=phys[78] part[rootfs0]: logic[79]=phys[79] part[rootfs0]: logic[80]=phys[80] part[rootfs0]: logic[81]=phys[81] part[rootfs0]: logic[82]=phys[82] part[rootfs0]: logic[83]=phys[83] part[rootfs0]: logic[84]=phys[84] part[rootfs0]: logic[85]=phys[85] part[rootfs0]: logic[86]=phys[86] part[rootfs0]: logic[87]=phys[87] part[rootfs0]: logic[88]=phys[88] part[rootfs0]: logic[89]=phys[89] part[rootfs0]: logic[90]=phys[90] part[rootfs0]: logic[91]=phys[91] part[rootfs0]: logic[92]=phys[92] part[rootfs0]: logic[93]=phys[93] part[rootfs0]: logic[94]=phys[94] part[rootfs0]: logic[95]=phys[95] part[rootfs0]: logic[96]=phys[96] part[rootfs0]: logic[97]=phys[97] part[rootfs0]: logic[98]=phys[98] part[rootfs0]: logic[99]=phys[99] part[rootfs0]: logic[100]=phys[100] part[rootfs0]: logic[101]=phys[101] part[rootfs0]: logic[102]=phys[102] part[rootfs0]: logic[103]=phys[103] part[rootfs0]: logic[104]=phys[104] part[rootfs0]: logic[105]=phys[105] part[rootfs0]: logic[106]=phys[106] part[rootfs0]: logic[107]=phys[107] part[rootfs0]: logic[108]=phys[108] part[rootfs0]: logic[109]=phys[109] part[rootfs0]: logic[110]=phys[110] part[rootfs0]: logic[111]=phys[111] part[rootfs0]: logic[112]=phys[112] part[rootfs0]: logic[113]=phys[113] part[rootfs0]: logic[114]=phys[114] part[rootfs0]: logic[115]=phys[115] part[rootfs0]: logic[116]=phys[116] part[rootfs0]: logic[117]=phys[117] part[rootfs0]: logic[118]=phys[118] part[rootfs0]: logic[119]=phys[119] part[rootfs0]: logic[120]=phys[120] part[rootfs0]: logic[121]=phys[121] part[rootfs0]: logic[122]=phys[122] part[rootfs0]: logic[123]=phys[123] part[rootfs0]: logic[124]=phys[124] part[rootfs0]: logic[125]=phys[125] part[rootfs0]: logic[126]=phys[126] part[rootfs0]: logic[127]=phys[127] 0x000001a00000-0x000002a00000 : "rootfs1" part[rootfs1]: logic[0]=phys[0] part[rootfs1]: logic[1]=phys[1] part[rootfs1]: logic[2]=phys[2] part[rootfs1]: logic[3]=phys[3] part[rootfs1]: logic[4]=phys[4] part[rootfs1]: logic[5]=phys[5] part[rootfs1]: logic[6]=phys[6] part[rootfs1]: logic[7]=phys[7] part[rootfs1]: logic[8]=phys[8] part[rootfs1]: logic[9]=phys[9] part[rootfs1]: logic[10]=phys[10] part[rootfs1]: logic[11]=phys[11] part[rootfs1]: logic[12]=phys[12] part[rootfs1]: logic[13]=phys[13] part[rootfs1]: logic[14]=phys[14] part[rootfs1]: logic[15]=phys[15] part[rootfs1]: logic[16]=phys[16] part[rootfs1]: logic[17]=phys[17] part[rootfs1]: logic[18]=phys[18] part[rootfs1]: logic[19]=phys[19] part[rootfs1]: logic[20]=phys[20] part[rootfs1]: logic[21]=phys[21] part[rootfs1]: logic[22]=phys[22] part[rootfs1]: logic[23]=phys[23] part[rootfs1]: logic[24]=phys[24] part[rootfs1]: logic[25]=phys[25] part[rootfs1]: logic[26]=phys[26] part[rootfs1]: logic[27]=phys[27] part[rootfs1]: logic[28]=phys[28] part[rootfs1]: logic[29]=phys[29] part[rootfs1]: logic[30]=phys[30] part[rootfs1]: logic[31]=phys[31] part[rootfs1]: logic[32]=phys[32] part[rootfs1]: logic[33]=phys[33] part[rootfs1]: logic[34]=phys[34] part[rootfs1]: logic[35]=phys[35] part[rootfs1]: logic[36]=phys[36] part[rootfs1]: logic[37]=phys[37] part[rootfs1]: logic[38]=phys[38] part[rootfs1]: logic[39]=phys[39] part[rootfs1]: logic[40]=phys[40] part[rootfs1]: logic[41]=phys[41] part[rootfs1]: logic[42]=phys[42] part[rootfs1]: logic[43]=phys[43] part[rootfs1]: logic[44]=phys[44] part[rootfs1]: logic[45]=phys[45] part[rootfs1]: logic[46]=phys[46] part[rootfs1]: logic[47]=phys[47] part[rootfs1]: logic[48]=phys[48] part[rootfs1]: logic[49]=phys[49] part[rootfs1]: logic[50]=phys[50] part[rootfs1]: logic[51]=phys[51] part[rootfs1]: logic[52]=phys[52] part[rootfs1]: logic[53]=phys[53] part[rootfs1]: logic[54]=phys[54] part[rootfs1]: logic[55]=phys[55] part[rootfs1]: logic[56]=phys[56] part[rootfs1]: logic[57]=phys[57] part[rootfs1]: logic[58]=phys[58] part[rootfs1]: logic[59]=phys[59] part[rootfs1]: logic[60]=phys[60] part[rootfs1]: logic[61]=phys[61] part[rootfs1]: logic[62]=phys[62] part[rootfs1]: logic[63]=phys[63] part[rootfs1]: logic[64]=phys[64] part[rootfs1]: logic[65]=phys[65] part[rootfs1]: logic[66]=phys[66] part[rootfs1]: logic[67]=phys[67] part[rootfs1]: logic[68]=phys[68] part[rootfs1]: logic[69]=phys[69] part[rootfs1]: logic[70]=phys[70] part[rootfs1]: logic[71]=phys[71] part[rootfs1]: logic[72]=phys[72] part[rootfs1]: logic[73]=phys[73] part[rootfs1]: logic[74]=phys[74] part[rootfs1]: logic[75]=phys[75] part[rootfs1]: logic[76]=phys[76] part[rootfs1]: logic[77]=phys[77] part[rootfs1]: logic[78]=phys[78] part[rootfs1]: logic[79]=phys[79] part[rootfs1]: logic[80]=phys[80] part[rootfs1]: logic[81]=phys[81] part[rootfs1]: logic[82]=phys[82] part[rootfs1]: logic[83]=phys[83] part[rootfs1]: logic[84]=phys[84] part[rootfs1]: logic[85]=phys[85] part[rootfs1]: logic[86]=phys[86] part[rootfs1]: logic[87]=phys[87] part[rootfs1]: logic[88]=phys[88] part[rootfs1]: logic[89]=phys[89] part[rootfs1]: logic[90]=phys[90] part[rootfs1]: logic[91]=phys[91] part[rootfs1]: logic[92]=phys[92] part[rootfs1]: logic[93]=phys[93] part[rootfs1]: logic[94]=phys[94] part[rootfs1]: logic[95]=phys[95] part[rootfs1]: logic[96]=phys[96] part[rootfs1]: logic[97]=phys[97] part[rootfs1]: logic[98]=phys[98] part[rootfs1]: logic[99]=phys[99] part[rootfs1]: logic[100]=phys[100] part[rootfs1]: logic[101]=phys[101] part[rootfs1]: logic[102]=phys[102] part[rootfs1]: logic[103]=phys[103] part[rootfs1]: logic[104]=phys[104] part[rootfs1]: logic[105]=phys[105] part[rootfs1]: logic[106]=phys[106] part[rootfs1]: logic[107]=phys[107] part[rootfs1]: logic[108]=phys[108] part[rootfs1]: logic[109]=phys[109] part[rootfs1]: logic[110]=phys[110] part[rootfs1]: logic[111]=phys[111] part[rootfs1]: logic[112]=phys[112] part[rootfs1]: logic[113]=phys[113] part[rootfs1]: logic[114]=phys[114] part[rootfs1]: logic[115]=phys[115] part[rootfs1]: logic[116]=phys[116] part[rootfs1]: logic[117]=phys[117] part[rootfs1]: logic[118]=phys[118] part[rootfs1]: logic[119]=phys[119] part[rootfs1]: logic[120]=phys[120] part[rootfs1]: logic[121]=phys[121] part[rootfs1]: logic[122]=phys[122] part[rootfs1]: logic[123]=phys[123] part[rootfs1]: logic[124]=phys[124] part[rootfs1]: logic[125]=phys[125] part[rootfs1]: logic[126]=phys[126] part[rootfs1]: logic[127]=phys[127] fastforward_init start ! fastforward_init done ! VFS: Mounted root (squashfs filesystem) readonly on device 31:10. Freeing init memory: 132K CFS CPU scheduler. init started: BusyBox v1.01 (2017.11.10-04:08+0000) multi-call binary Starting pid 22, console /dev/ttyS0: '/etc/init.d/rcS' ====================================================== mounting /dev/mtdblock2 to /tagparam, wait ... ====================================================== Pre-initialization script ... Mounting ramdisk at /var Mounting /dev/mtdblock5 to /userconfig Mount ok! Mounting /dev/mtdblock4 to /usr/local/ct Mount ok! ====================================================== mounting /dev/mtdblock8 to /wlan, wait ... ====================================================== Configuring MAC interfaces Bringing up interface lo Bringing up interface mii0 11930:27:46 [U_busybox][Warn] [ifconfig.c(995)ifconfig] Ioctl failed!SIOCGIFFLAG S Set promisc for device mii0 11930:27:46 [U_busybox][Warn] [ifconfig.c(995)ifconfig] Ioctl failed!SIOCGIFFLAG S Configuring with no IP address (i.e. for PPP) 11930:27:46 [U_busybox][Warn] [ifconfig.c(995)ifconfig] Ioctl failed!SIOCGIFFLAG S Using /kmodule/bspdriver.ko <verinfo_module_init>(750)---->verinfo=U-Boot V1.0.10P5T1 20171110121604 0x16000 00 0x1 0x83 0x8f current version is rootfs1, disable skip bad block on rootfs0 disable skip bad block on rootfs0 addr==1600000 addr==200000 <verinfo_module_init>(755)----><verinfo_module_init>(757)----><verinfo_module_in it>(759)---->GN25L95 found. data_in=0xf1 data_in=0xf1 Using /kmodule/zx_ponreg.ko register fpga driver success, major=222 Using /kmodule/peripheral.ko register peripheral success, major = 106 Using /kmodule/tm.ko = TM Module SYS FS Init ended successfully = tm_initModule begin... tm_initial successed !!! tm_initModule end... Using /kmodule/netdriver.ko ethdriver_init.... g_mii_dev_name[0] sw g_mii_dev_name[1] pon Using /kmodule/zte_gpon.ko zteGpmac_initModule begin... ERROR: (chip_zx279100/kmodule/sdk/gmac/core/src/zteGponOnuInit.c:222) Onu Mac Ra m Init Timeout === GponMac Supported MaxTcont: 16 MaxPLI: 800B === = PON Module Operate ended successfully = = GMAC Module SYS FS Init ended successfully = zteGpmac_initModule end... Using /kmodule/gpondrv.ko zx279100_gpon_Init ok <LOGID000000005>11930:27:47 [KMONITOR][Warn] [monitor.c(617)MontorSendMsg] netli nk_unicast failed:msgid = 0xa4a7, ptr = (null), len = 0 Using /kmodule/switch.ko Init switch module zy switch detected boardtype:192 zy uni num:4 switch config 9100 GPON SFU mode! [SW][sw_init_switch] alarm init [yqs]set cpu queue rate limit to 4000pps Init switch module Success Using /kmodule/optical.ko GN25L95 found. bsp_i2c_probe 0x50 success! vendor name = ZTE_B+_G optical PN(0x60) = optical PN(0x28) = GN25L95 Using /kmodule/kudp.ko udpwatchd inited! kudp inited! Using /kmodule/voip_codec.ko Init codec v1.8(2016-12-17)! Using /kmodule/dsp_dev.ko ----VoIPCodecInit ch0 ----VoIPCodecInit ch1 P_2833: Setup 0 DSP device setup OK! Using /kmodule/redircan not open us/proc/kallsyms b.sys_access cakon not be posed insmod: cannot insert `/kmodule/redirusb.ko': Operation not permitted (-1): Oper ation not permitted =================================================================== region code:66 region name:Rostelecom USER_CFG is same as ETC_CFG, donot need copy =================================================================== Database default setting is [current : 66] Starting pid 204, console /dev/ttyS0: '/sbin/getty' 11930:27:48 [OSS_pc][Error] [pc.c(1608)main] Could not set affinity F670 11930:27:50 [dhcp4c][Warn] [dhcp4c_inst.c(3690)_dhcp4cRegSendO] Send code[60]fun [0x190614] is replaced by fun[0x196e6c] 11930:27:50 [DB][Warn] [dbc_def_dev_inf(321)dbGetOnuMode] boardType : F670 11930:27:50 [DB][Warn] [dbc_def_dev_inf(417)dbPersonInitVer] get parameter from Flash failed!VersionMode 11930:27:50 [DB][Warn] [dbc_mgr_tbl.c(1560)dbSetValComm] not find domain table(D evInfo) domain(VersionMode) 11930:27:50 [DB][Error] [dbc_mgr_def.c(75)dbMgrStaticSetI] not find table (WLANC ountry) 11930:27:50 [DB][Warn] [dbc_mgr_tbl.c(1560)dbSetValComm] not find domain table(Q OSQueue) domain(Length) 11930:27:50 [DB][Warn] [dbc_mgr_tbl.c(1560)dbSetValComm] not find domain table(Q OSQueue) domain(Length) 11930:27:50 [DB][Warn] [dbc_mgr_tbl.c(1560)dbSetValComm] not find domain table(Q OSQueue) domain(Length) 11930:27:50 [DB][Warn] [dbc_mgr_tbl.c(1560)dbSetValComm] not find domain table(Q OSQueue) domain(Length) 11930:27:50 [DB][Error] [dbc_mgr_def.c(75)dbMgrStaticSetI] not find table (PDTWL ANWAPI) 11930:27:50 [DB][Error] [dbc_def_gponcfg(54)dbDefGPONCFG] get VENDOR_ID from fl ash failed ! 11930:27:50 [DB][Error] [dbc_def_gponcfg(105)dbDefGPONCFG] get RegisterID from flash failed ! 11930:27:50 [DB][Error] [dbc_def_gponcfg(129)dbDefGPONCFG] get Loid from flash f ailed ! 11930:27:50 [DB][Error] [dbc_def_gponcfg(141)dbDefGPONCFG] get LoidPwd from fla sh failed ! 11930:27:50 [DB][Error] [dbc_person_dev_(186)dbPersonInitSNP] get VENDOR_ID from flash failed ! ----------------------------------------------AscStr is 5A544547 11930:27:50 [DB][Warn] [dbc_person_dev_(245)dbPersonInitHVT] get parameter from Flash failed!HardwareVerTag 11930:27:50 [DB][Warn] [dbc_person_auth(47)dbPersonInitAut] get parameter from F lash failed!Username 11930:27:50 [DB][Warn] [dbc_person_auth(85)dbPersonInitAut] get parameter from F lash failed!Password 11930:27:50 [OSS_cspd][Warn] [oss_comm.c(2096)SocketAsynSendM] sender = 0x000100 00 ,reciver = 0x00030101 , Event = 0xa4a7 11930:27:50 [OSS_cspd][Warn] [oss_comm.c(2098)SocketAsynSendM] send ilen = -1 Le n = 32 errno = 2 11930:27:50 [OSS_cspd][Error] [oss_common.c(480)ASEND] [][00010000] Send task Me ssage[0XA4A7] to [00030101] in SocketAsynSendMsg() ERROR ! 11930:27:52 [DB][Crit] [dbc_core.c(444)dbPersonInitPro] VIP_VOIP: Read setmac va lue to ProtocolSet 11930:27:52 [DB][Error] [dbc_def_timepol(217)dbWlanTimeTrans] {dbWlanTimeTrans} find:[0], [-1]:[-1] 11930:27:52 [DB][Error] [dbc_core_compat(880)dbUserInfoTrans] not find table 11930:27:52 [DB][Warn] [dbc_pdt_transfe(505)bIsNeedUpInc] ==== bIsNeedUpInc: [re gcode:66]V1.0.10P5T1--->V1.0.10P5T1 11930:27:52 [DB][Warn] [dbc_core.c(2409)dbAdaptDataByOn] enter dbAdaptDataByOnuM ode 00:00:00 [upgrade_mgr][Error] [upgrade_mgr.c(2407)UpgradeInit] =====RegionCodeFo rTools=-14===== 00:00:00 [dss][Warn] [dss_lla.c(955)DssLlaMain] The Dss' lpMsg is null. 00:00:00 [dhcp6s][Warn] [dhcp6s_main.c(1796)getHwMacByIfNam] Ioctl failed! >>>>>> >>>call RegNetIFForWWAN() 00:00:00 [dhcp6s][Warn] [dhcp6s_main.c(2013)startDhcp6sInst] invalid interface 00:00:00 [usb_stor][Error] [usbbakrst_cmapi(535)CmUsbBakRstSynD] BakFile Name Er ror(usbbak.cfg) ########br's FDB_MAX[1024] ADDRCONF(NETDEV_UP): br0: link is not ready ethdrv_dev_ioctl ,brdev_set.port_id 0 ,brdev_set.name eth0 ,brdev_set.flag 0 ethdrv_dev_ioctl ,brdev_set.port_id 1 ,brdev_set.name eth1 ,brdev_set.flag 0 ethdrv_dev_ioctl ,brdev_set.port_id 2 ,brdev_set.name eth2 ,brdev_set.flag 0 ethdrv_dev_ioctl ,brdev_set.port_id 3 ,brdev_set.name eth3 ,brdev_set.flag 0 00:00:03 [U_busybox][Warn] [ifconfig.c(995)ifconfig] Ioctl failed!SIOCGIFFLAGS [A DAPTER]set sn:ZTEGc84dac08, pwd:GC84DAC08 o7_flag = 0,arg_o7_Flag->ctl=0 === GponMac Supported MaxTcont: 16 MaxPLI: 800B === [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! [sw_port_set_port_floodcontrol] not support now! zte_api_sw_port_set_port_multicastrate port:(3) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(3) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_multicastrate port:(2) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(2) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_multicastrate port:(1) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(1) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_multicastrate port:(0) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(0) direct:(0) enable:(0) rate:(1024 000 kpbs) ifgMode:(1) Using /kmodule/ehci-hcd.ko ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Dr iver faraday-ehci faraday-ehci.0: Faraday EHCI Host Controller faraday-ehci faraday-ehci.0: new USB bus registered, assigned bus number 1 faraday-ehci faraday-ehci.0: otg port=1 faraday-ehci faraday-ehci.0: irq 36, io mem 0xa0400000 faraday-ehci faraday-ehci.0: USB 2.0 started, EHCI 1.00 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: Faraday EHCI Host Controller usb usb1: Manufacturer: Linux 2.6.32.61-EMBSYS-CGEL-4.03.20.P1.F0 ehci_hcd usb usb1: SerialNumber: faraday-ehci.0 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected usb usb1: csp_report_dev_addok 1d6b 2 __ratelimit: 14 callbacks suppressed faraday-ehci faraday-ehci.1: Faraday EHCI Host Controller faraday-ehci faraday-ehci.1: new USB bus registered, assigned bus number 2 faraday-ehci faraday-ehci.1: otg port=1 faraday-ehci faraday-ehci.1: irq 37, io mem 0xa0500000 faraday-ehci faraday-ehci.1: USB 2.0 started, EHCI 1.00 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: Faraday EHCI Host Controller usb usb2: Manufacturer: Linux 2.6.32.61-EMBSYS-CGEL-4.03.20.P1.F0 ehci_hcd usb usb2: SerialNumber: faraday-ehci.1 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected usb usb2: csp_report_dev_addok 1d6b 2 Using /kmodule/usb_led.ko registering usb led module! 30 30 30 30 09 31 36 38 63 66 66 31 63 09 33 38 09 20 20 20 20 20 20 20 20 63 30 30 30 30 30 30 34 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 2 0 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 2 0 30 09 20 20 20 20 20 20 20 20 20 20 20 31 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 2 0 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 0a 30 31 30 30 09 31 36 38 63 30 30 33 63 09 33 39 09 20 20 20 20 20 20 20 20 65 30 30 30 30 30 30 34 09 20 20 20 2 0 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 3 0 09 20 20 20 20 20 20 20 20 65 30 32 30 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 32 30 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 2 0 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 31 30 30 30 30 09 0a 30 30 30 30 09 31 36 38 63 66 66 31 63 09 33 38 09 20 2usbcore: regi0 stered new interface driver usbserial 20usbserial: USB Serial Driver 2core 0 20 20 20 20 63 30 30 30 30 30 30 34 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 3 0 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 31 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 2 0 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 0a 30 31 30 30 0 9 31 36 38 63 30 30 33 63 09 33 39 09 20 20 20 20 20 20 20 20 65 30 30 30 30 30 30 34 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 0 9 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 65 30 32 30 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 32 30 30 30 30 30 09 20 20 20 20 20 20 20 20 20 20 20 2 0 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 30 09 20 20 20 20 20 20 2 0 20 20 20 20 31 30 30 30 30 09 0a g_iUpLinkType=13 Using /kmodule/usbserial.ko Us ing /kmodule/option.ko USB Serial support registered for GSM modem (1-port) usbcore: registered new interface driver option option: v0.7.2:USB Driver for GSM modems 00:00:07 [OSS_cspd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[route_m gr] Event[0x1103] dwUsedTicks[326] sip alg change port ok! ftp alg change port ok! rtsp alg change port ok! swdrv_execute_capsweth Failure ret = 1 00:00:09 [qos_mgr][Error] [pon_switch_zx27(2601)switchSet_qos_e] switchSet_qp_ov erall ioctl failed! 00:00:09 [dns_mgr][Warn] [ifs_api.c(2618)GetRouteIFInfo] parameter is illegal![I GD.WD1.WCD1.WCPPP1024] 00:00:09 [dhcp6s][Warn] [dhcp6s_main.c(392)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] 00:00:09 [dhcp6s][Warn] [dhcp6s_main.c(393)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] 00:00:09 [dhcp6s][Warn] [dhcp6s_main.c(394)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] 00:00:09 [igmpproxy_mgr][Warn] [ifs_api.c(2618)GetRouteIFInfo] parameter is ille gal![IGD.WD1.WCD1.WCPPP1024] 00:00:09 [ddns_mgr][Warn] [ddns_mgr.c(1288)ddnsAddClientLi] call dbAPIQryView fa iled!DBVIEW_DDNS_SERVICE,name 00:00:09 [ddns_mgr][Warn] [ddns_mgr.c(1207)ddnsInitClientL] Call function failed !ddnsAddClientListNode 00:00:09 [U_igmp_proxy][Error] [igmp_proxy.c(3227)main] |igmp_proxy| ptr_upstrea m_ifaceName unspecified 00:00:09 [dss][Warn] [dss_lla.c(955)DssLlaMain] The Dss' lpMsg is null. 00:00:09 [prefix_mgr][Error] [prefix_mgr.c(2296)PrefixMgrInit] Init Prefix Lock error! recv EV_NORMAL_START 00:00:09 [pon_dev_mgr][Error] [pon_dev_mgr.c(425)get_falsify_def] call GetTagPa ram failed!!!! 00:00:09 [pon_dev_mgr][Error] [pon_dev_mgr.c(1065)FalsfyDefInitVi] call get_fals ify_defend_mode failed! iRet = -7 >>>>>>>>>>>>>>>>>>>>>>>>gpon_omci start success ed!<<<<<<<<<<<<<<<<<<<<<<<<<<< vendor name = ZTE_B+_G optical PN(0x60) = optical PN(0x28) = GN25L95 00:00:10 [portLocate_mgr][Warn] [portLocate_mgr.(202)portLocateStart] portLocate Init begin set format,portLocateSetPPPoEVendorInfo:00000DE9 <LOGID000000005>00:00 :10 [KPORTLOCATE][Warn] [br_portlocate.c(925)set_portlocate_] pppoe portlocate v endorInfo is:00000DE9 <LOGID000000005>00:00:10 [KPORTLOCATE][Warn] [br_portlocate.c(933)set_portlocate _] CharToHex ok,g_pppoe_vendorInfo:e90d0000! ====================gpon_omci start====================== Using /kmodule/asf.ko device eth0 entered promiscuous mode br0: port 1(eth0) entered forwarding state br0: port 1(eth0) entered forwarding state ADDRCONF(NETDEV_CHANGE): br0: link becomes ready Using /kmodule/adf.ko ****Address of trace_timer :bf22f3c8 device eth1 entered promiscuous mode br0: port 2(eth1) entered forwarding state br0: port 2(eth1) entered forwarding state Using /kmodule/ath_hal.ko ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_E EPROM, TX_DATA_SWAP, RX_DATA_SWAP, 11D) device eth2 entered promiscuous mode br0: port 3(eth2) entered forwarding state br0: port 3(eth2) entered forwarding state Using /kmodule/ath_rate_atheros.ko ath_rate_atheros: module license 'Proprietary' taints kernel. Disabling lock debugging due to kernel taint ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Right s Reserved Process_Perf's Event(4352) is not support !! ==========================sys process start========================= Omci get Byte Order is Little-Endian g_bByteSort(0) =====================omci sender process start===================== device eth3 entered promiscuous mode br0: port 4(eth3) entered forwarding state br0: port 4(eth3) entered forwarding state VOP_DspTraceTaskEntery entered:POWER ON!!!wState:0 00:00:11 [upnp_igd][Warn] [upnpigd.c(347)UPnPIGDProcessR] parameter is invalid!t WanName 00:00:11 [ifs_mgr][Warn] [ifs_notifier.c(377)delRegNotifier] parameter is illega l!not found, pid[65810] 00:00:11 [ifs_mgr][Warn] [ifs_notifier.c(377)delRegNotifier] parameter is illega l!not found, pid[65810] 00:00:11 [ifs_mgr][Warn] [ifs_notifier.c(377)delRegNotifier] parameter is illega l!not found, pid[65850] Using /kmodule/ath_dfs.ko 00:00:11 [BCC][Warn] [bcc_entry.c(242)BCC_TaskEntry] Unknown Event=0x00001100 wh en BCC PowerOn! ath_dfs: Version 2.0.0 Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved =========================omci process start========================= get omcicfg ME--[0][0][0][0][0]----- OA_Sysdrv_GetTcontBufferSize: value(0) is out of range, use def value:256 Omci Debug:CmWLANListConfig.dwCount = 8 00:00:11 [U_igmp_proxy][Error] [igmp_proxy.c(3227)main] |igmp_proxy| ptr_upstrea m_ifaceName unspecified Using /kmodule/ath_dev.ko VOP_TaskEntry entered:POWER ON!! !wState:0 ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Right s Reserved VOP_DSP2RtraceTaskEntry entered:POWER ON!!!wState:0 ==============c:a Unknown argu ment. <LOGID000000005>00:00:12 [KIGMPSNP][Error] [br_multicast_se(919)set_trap_un know] port8 trap_unknow_report_en is 0! <LOGID000000005>00:00:12 [KIGMPSNP][Error] [br_multicast_se(962)set_multicast_t] portNum = 8, tagstripe = 0 Using /kmodule/umac.ko init_ath_pci enter! init the wifi hardware forward handler(to idm0) init the wifi hardware forward handler(to idm1) ath_pci: SmartAntenna-DRT-0.1 (Atheros/multi-bss) PCI: enabling device 0000:00:00.0 (0140 -> 0142) __ath_attach: Set global_scn[0] ar5416FlashMap[400] ar5416FlashMap[437], caldata read ok! 02d7 1660 e004 0016 0000 001f 0300 133f 2803 0303 0000 0000 0000 1b00 0009 0105 fafb 00fa 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0010 0000 0010 0000 0210 0000 0000 202d 0020 e200 0200 1c0e ffff 0102 0000 0000 0001 0e0e 0000 0000 2d00 0300 0303 0303 0003 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 7000 a289 0002 0000 0000 0000 0000 007b 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000 0000 0000 0000 007b 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 0000 0000 0000 007b 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000 0000 0000 0080 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000 0000 0000 0080 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 002c 0000 0000 0000 0000 0000 0000 0000 0000 0000 2270 2222 b822 2222 2222 00ff 0000 7000 2022 191c 2289 1c20 ac19 2022 191c 2270 2022 1f20 191b 8917 2222 2020 1b1f 1719 22ac 2022 1f20 191b 7017 2222 2020 1b1d 1719 2289 2022 1d20 191b ac17 2222 2020 1b1d 1719 1211 1715 4241 4745 3231 3735 3c70 7c75 3ca2 0000 3c70 7c75 3ca2 0000 3c70 7c75 3ca2 0000 3c70 7c75 3ca2 0000 3c70 7c75 3ca2 0000 3c70 7c75 3ca2 0000 3c7a 7c7f 7c93 3c98 3c7a 7c7f 7c93 3c98 3c70 7c75 3cac 3cb8 3c70 7c75 3cac 3cb8 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c7a 7c7f 7c93 3ca2 3c7a 7c7f 7c93 3ca2 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c70 7c75 3cac 0000 3c7a 7c7f 7c93 3ca2 3c7a 7c7f 7c93 3ca2 ath_get_caps[6177] rx chainmask mismatch actual 3 sc_chainmak 0 ath_get_caps[6152] tx chainmask mismatch actual 3 sc_chainmak 0 ath_attach_dfs[12695] dfsdomain 1 request_irq type = 0x80 wifi0: Atheros ???: mem=0xc0000000, irq=56 hw_base=0xc8860000 ath_pci_probe PCI device id is 003c :003c PCI: enabling device 0000:01:00.0 (0140 -> 0142) ath: try to probe again. Resetting (attempt 1). Target Warm Reset Host Intr Cause reg 0x900c : value : 0x0 Target CPU Intr Cause 0x0 addr 0x4050 : 0x4 Target CPU Intr Cause after CE reset 0x0 RESET_CONTROL after cpu warm reset 0x800 Target Warm reset complete ol_ath_pci_probe: HIF PCI Free needs to happen here ath reprobe. PCI device id is 003c :003c ath_pci 0000:01:00.0: ath DEBUG: sc=0xc563e000 ol_ath_pci_configure : num_desired MSI set to 0 Using PCI Legacy Interrupt CE_per_engine_handler_adjust, base=c563e000 offset=00057400 CE_per_engine_handler_adjust, base=c563e000 offset=00057800 __ol_ath_attach: ath_attach TODO __ol_ath_attach: dev name wifi1 ol_ath_set_default_tgt_config : AC Minfree buffer allocation through module para m (umac.ko) OL_ACBKMinfree : 0 OL_ACBEMinfree : 0 OL_ACVIMinfree : 0 OL_ACVOMinfree : 0 ol_ath_attach() BMI inited. ol_ath_attach() BMI Get Target Info. ol_ath_attach() TARGET TYPE: 7 Vers 0x4100016c NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0 ol_ath_attach() configure Target . GetCalFromFile[1785], caldata read ok! qc98xx_verify_checksum: flash checksum passed: 0x f78 ol_transfer_bin_file 2291: Download Flash data len 2116 fw_entry->size 2116 Download AR9888v2_bin ol_transfer_bin_file 2215: Download Firmware data len 235636 >128K, use vmalloc!fw_entry->size 235636>128K, use vfree!ol_ath_attach() Downloa d FW. ol_ath_attach() HT Create . ol_ath_attach() HIF Claim. ol_ath_attach() BMI Done. ol_ath_attach() WMI attached. wmi_handle c3170000 +HWT SOC_RESET_CONTROL_ADDRESS : 800 CPU_INTR_ADDRESS = [0] SOC_GLOBAL_RESET_ADDRESS = [0] Rx_Filter : [0] CE_per_engine_handler_adjust, base=c563e000 offset=00057400 CE_per_engine_handler_adjust, base=c563e000 offset=00057800 CE_per_engine_handler_adjust, base=c563e000 offset=00057c00 CE_per_engine_handler_adjust, base=c563e000 offset=00058000 CE_per_engine_handler_adjust, base=c563e000 offset=00058400 CE_per_engine_handler_adjust, base=c563e000 offset=00058800 CE_recv_buf_enqueue 657 Populate last entry 512 for CE 5 CE_recv_buf_enqueue 666 CE 5 wi 511 dest_ptr 0x46a3f820 nbytes 0 recv_ctxt 0xc32 3e600 Target:c30e1800 HTC Service:0x0001, ULpipe:0 DLpipe:1 id:0 Ready -HWT Target:c30e1800 HTC Service:0x0300, ULpipe:4 DLpipe:5 id:1 Ready HTC Service:0x0300 ep:1 TX flow control disabled CE_pkt_dl_len_set CE 4 Pkt download length 64 ol_txrx_pdev_attach: 1424 tx desc's allocated ; range starts from c32b0000 Target:c30e1800 HTC Service:0x0100, ULpipe:3 DLpipe:2 id:2 Ready HTC Service:0x0100 ep:2 TX flow control disabled wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event num_rf_chain : 00000003 ht_cap_info: : 0000085b vht_cap_info : 338001b2 vht_supp_mcs : 0000ffea LARGE_AP enabled. num_peers 144, num_vdevs 16, num_tids 256, lteu_support 0 idx 0 req 1 num_units 0 num_unit_info 2 unit size 440 actual units 145 chunk 0 len 63800 requested ,ptr 0x432c0000 FIRMWARE:P 145 V 16 T 443 FIRMWARE:_wlan_rtt_enable wmi_ready_event_rx: WMI UNIFIED READY event ol_ath_connect_htc() WMI is ready ol_ath_set_host_app_area TODO target uses HTT version 2.1; host uses 2.1 ol_ath_attach() connect HTC. bypasswmi : 0 ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeSelect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0. ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080 Add VHT80 channel: 5210 Add VHT80 channel: 5290 Add VHT80 channel: 5530 Add VHT80 channel: 5610 Add VHT80 channel: 5690 Add VHT80 channel: 5775 Skipping VHT80 channel 5825 ol_ath_phyerr_attach: called OL Resmgr Init-ed ol_if_dfs_setup: called ol_if_dfs_attach: called; ptr=c32a9974, radar_info=c524fc28 ol_ath_rtt_meas_report_attach: called ol_ath_attach() UMAC attach . ol_if_dfs_configure: called ol_if_dfs_configure: FCC domain ol_if_dfs_disable: called ol_ath_attach: Calling ol_if_dfs_configure __ol_ath_attach: init tx/rx TODO __ol_ath_attach: hard_header_len reservation 58 00:00:17 [OSS_cspd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[wlan_co nfig] Event[0xa204] dwUsedTicks[649] ==============c:a Unknown argument. 00:00:17 [OSS_cspd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[l2b_m<L OGID0000000g05>00:00:17 [KIGr]MPSNP][Error] [br_multicast_se(919)set_trap_unknow ] port9 trap_unknow_report_en Eis 0! vent[0x9613] dwUsedTicks[471] 00<LOGID000000005>00:00:17 [KIGMPSNP][Error] [br_multicast_se(962)set_multicast: 00_t] portNum = 9, tagstripe = 0 :17 [webd][Warn] [thttpd.c(3545)webd_init_wizar] optical is lose ! 00:00:17 [OSS_httpd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[webd] Event[0x1100] dwUsedTicks[559] 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [confile][Warn] [configfile_medi(250)conFileMgrAsynM] PUBLIC_INVALID_EV ENT:wEvent:00001103 00:00:17 [tr069][Warn] [tr069_main.c(2256)tr069GetTreeFil] tr069GetTreeFile:tr06 9 tree file is /etc/device_sip_ros.xml !!!!!!!!!! GetEnvPara_noproc /userconfig/e nv_param GetEnvPara_noproc /userconfig/env_param GetEnvPara_noproc /userconfig/env _param GetEnvPara_noproc /userconfig/env_param 00:00:17 [tr069][Error] [session.c(421)SessionStart] RUN HERE OPEN TR069 IN SESS ION.C 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) ==============c:a Unknown argument. 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] <LOGID000000 005>00:00:17 [KIGIFMPSNP][Error] [br_multicast_se(919)set_trap_unknow] port10 tr ap_unknow_report_enSt is 0! atus no up,(null) <LOGID000000005>00:00:17 [KIGMPSNP][Error] [br_multicast_se(962 )set_multicast_t] portNum = 10, tagstripe = 0 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [OSS_voip][Warn] [oss_sche.c(820)RunProcess] RunProcess propen DSP_dev odriver! cess[open DSP_TRACBE driver! oardControl] Event[0x1150] dwUsedTicks[364] -----VOP_TaskEntry entered:DSP START WORK!!!-------wState:1 UDP MOD START ch:0 pcm mode:G711A_U ch 0 set pcm type is ok,val is 0! ============ch:1 pcm mode:G711A_U ==ch 1 set pcm c:type is ok,val is 0! a Unknown argument. Using /kmodule/slc/usrline_zlk.ko 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_m[wifi1] grFWLOG: [27182] WAL_DBGID_TX_AC_B][UFFER_SET ( W a0x3r, n0x1e], [0x460v, l0x460a, n0x0_ ) mo[wifi1] duFWLOG: [27182] WAL_DBGID_TX_AC_BUFFER_SET ( le0x12_, m0x1egr, (0x460 3, 50x4608, )0x0d ) e[wifi1] fCFWLOG: [27182] WAL_DBGID_TX_AC_BUFFER_SET ( o0x45m, ma0x1en, d]0x460 , I0x460F, S0x0t ) a[wifi1] tuFWLOG: [27182] WAL_DBGID_TX_AC_BUFFER_SET ( s0x67 , n0x1eo, 0x460u, p0x460,, (n0x0u ) l[wifi1] l)FWLOG: [27187] W 0x110298a0, 00x3: ) HAL_ERROR_RECV_STOPPCU ( 0[wifi1] 0:FWLOG: [27187] W1HAL_ERROR_RESET_7PM ( ) [[wifi1] vlFWLOG: [27194] WAL_DBGID_DEV_RESET ( a0x1n, _0x1m, o0x1d ) u[wifi1] leFWLOG: [27326] _mANI Enable: 1 g[wifi1] r]FWLOG: [27332] WAL_DBGID_DEV_RESET ( [0x1W, a0x1r, n0x1] ) [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) Board default00 NO PTC :0Board default0: NO PTC 17Board default NO PTC Board default NO PTC [vSLC:User SLIC Driver V3.0.0 Ilanit Finish. n_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr <LOGID000000005>00:00:17 [KIGMPSNP][Error] [][Wbr_multicast_se(919)set_trap_unka rnow] port11 trap_unknow_report_en is 0! n] [vlan_module_<LOGID0000000mg05>00:00:17 [KIGr(MPSNP][Error] [b35r_multicast_s e(962)set_multicast_t] portNum = 11, tagstripe = 0 8)defCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17usrline_ioctl port:0 is disab [le now! vlport:0 DcIndex:0-1 U:48 A:24 RingIndex:5 VPK:50 100msEn:0, iman_peIndex:2 ePTC :0 dwImpe:600 rxgamoin(D-A):-8, txgain(A-D):0, pcmlaw:0 dule_mgr][Find line 0 chan 0, cs 1 Wacann't Find arn line 1 ] cann't Find a[v line 2 lacann't Find a line 3 n_legerity_init dev:1 cs:1. module_rcn:0x8 pcn:0mgx49 r9641 found. (4VpMakeDeviceObject dev:1. 55===LE9641:VP_DEV_887_SERIES dev ac dc ring pa)urameters config!nt!!bPort:0=== agVpMakeLineObjCect dev:1 line:0. omVpInitDevice dev:1. mand] IFStatus no up,(null) 00Register port:0 0 0:wait for CHIP17_INITED, total:10 now:0 times 500ms [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null ) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:17 [vlan_module_mgr][Warn] [vlan_module_mgr(358)defCommand] IFStatus no up ,(null) 00:00:18 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) g_MeCtr_Configure=0x00000000,g_MeCtr_CreateMark1=0x00000000,g_MeCtr_Cr eateMark2=0x00000000 00:00:18 [omci][Error] [pon_dev_cmapi.c(316)CmPonGetIspCode] 04################# #call GetTagParam failed!!!!################## call CmPonGetIspCode error! dwRet = -7 00:00:18 [omci][Error] [pon_dev_cmapi.c(365)CmFalsifyGetPdt] ##################c all Get TAG_ID_PRODUCTION_SN failed!!!!################## call CmFalsifyGetPdtSn error!dwRet = -7 Open /proc/capability/battery fail 00:00:18 [omci][Error] [pon_baseinfo_cm(525)cmGetUPSInfo] cmGetUPSInfo: Get upsO nline error! Call cmGPonGetUPSInfo error, iRet = -257 OA_Pondrv_GetTcontMax result:0 tcontmax:8 OA_Pondrv_GetTcontQueueMax result:0 tcontqueuemax:8 [GoldenSea]TcontID[1], policy:0, pqinfo:0 [GoldenSea]TcontID[2], policy:0, pqinfo:0 [GoldenSea]TcontID[3], policy:0, pqinfo:0 [GoldenSea]TcontID[4], policy:0, pqinfo:0 [GoldenSea]TcontID[5], policy:0, pqinfo:0 [GoldenSea]TcontID[6], policy:0, pqinfo:0 [GoldenSea]TcontID[7], policy:0, pqinfo:0 [GoldenSea]TcontID[8], policy:0, pqinfo:0 00:00:18 [vlan_module_mgr][Warn] [vlan_module_mgr(455)untagCommand] IFStatus no up,(null) [FWPM]pInstList.dwCount = 0 [FWIP]pInstList.dwCount = 0 DB INIT not support this MECLASS[240] ##Exception! Regist me class:240 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[242] ##Exception! Regist me class:242 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[247] ##Exception! Regist me class:247 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[253] ##Exception! Regist me class:253 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[251] ##Exception! Regist me class:251 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[252] ##Exception! Regist me class:252 DB failezte_api_sw_podrt_set_port_broadcastrate port:(3) direct:(0) enable:(1) rate:(5! r12 kpbs) ifgMode:(1) et:10##-zhangyc DB INIT not support this MECLASS[65294] ##Exception! Regist me class:65294 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65295] ##Exception! Regist me class:65295 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65529] ##Exception! Regist me class:65529 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65300] ##Exception! Regist me class:65300 DB failed! ret:10##-zhangyc Sub_SNOntStaticDB:Don't create meclass:350! DB INIT not support this MECLASS[65320] ##Exception! Regist me class:65320 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65530] ##Exception! Regist me class:65530 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65306] ##Exception! Regist me class:65306 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65327] ##Exception! Regist me class:65327 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65328] ##Exception! Regist me class:65328 DB failed! ret:10##-zhangyc DB INIT not support this MECLASS[65319] ##Exception! Regist me class:65319 DB failed! ret:10##-zhangyc 00:00:18 [omci][Error] [pon_upgrade_cma(207)CmGetPrivatePro] CmGetPrivateProfile Int: GetPrivateProfileInt FAILURE! Call CmGetPrivateProfileInt error,iRet=-14,Ke yName=IsOmciUpgrading power status is 0x0!!! 00:00:18 [OSS_cspd][Warn] [oss_program.c(324)PcStopProgram] [igmpproxy_mgr] PcSt opProgram[pid743] Result = -2 failed!!! 00:00:18 [igmpproxy_mgr][Warn] [ifs_api.c(2618)GetRouteIFInfo] parameter is ille gal![IGD.WD1.WCD1.WCPPP1024] 00:00:18 [U_igmp_proxy][Error] [igmp_proxy.c(3227)main] |igmp_proxy| ptr_upstrea m_ifaceName unspecified br0 index 10 [responder.c set_udp_options-133]Joined the L LMNR multicast group on br0 [responder.c set_v4udp_options-221]getbr0Info ret = 0 , addr = 100a8c0 [responder.c set_v4udp_options-228]Joined the LLMNR v4 multicast group on br0 [main.c main-191]Setting the host name of the responder to 'rt' [ifa ddr.c ifaddr_add_addr_v4-460]ifaddr: Added an IPv4 address on br0 [1] eventCatego ry:0x0002, eventId:0x0400, channelId:0x0000, lineId:0x00c0, deviceId:0x0001 VP_EVCAT_RESPONSE : eventId 0x0400 VpInitLine line:0 on dev:1 for port:0. wait for PORT_INITED, total:10 now:0 times 10ms eventCategory:0x0002, eventId:0x0800, channelId:0x0000, lineId:0x0000, deviceId: 0x0001 VP_EVCAT_RESPONSE : eventId 0x0800 VpCalLine line:0 on dev:1 for port:0 wait for PORT_CAL_CMP, total:10 now:0 times 500ms zte_api_sw_port_set_port_broadcastrate port:(2) direct:(0) enable:(1) rate:(512 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(1) direct:(0) enable:(1) rate:(512 kpbs) ifgMode:(1) zte_api_sw_port_set_port_broadcastrate port:(0) direct:(0) enable:(1) rate:(512 kpbs) ifgMode:(1) [LHP]Update loid_authencation state wResult 0 G_ONU_REG_Authenstates 0 ##Get management vlan about HG failed!##-zhangyc 00:00:18 [[ADAPTER]set Ogpon up!!! SS[Zx9110GponStart]sn :ZTEGc84dac08, pwd :GC84D_gAC08 po====EVENT_O7_STATE_SAVE OFF==n_== omreg state change: o1 ==> o2 ci][Warn] [oss_sche.c(820)Rreg state chaunnge: o2 ==> o1 Process] RunProcess process[omci] Event[0x3e81] dwUsedTicks[688] step into Clear_ All_Dot1ag_MA step into Clear_All_Dot1ag_MD [alecal]ZTE----pon link activate success! 00:00:18 [dhcp6s][Warn] [dhcp6s_main.c(392)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] 00:00:18 [dhcp6s][Warn] [dhcp6s_main.c(393)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] 00:00:18 [dhcp6s][Warn] [dhcp6s_main.c(394)dhcp6sProcessSp] pSpeAdvDns->szIfId[: :] [LHP]Update loid_authencation state wResult 0 G_ONU_REG_Authenstates 0 [LHP]Update loid_authencation state wResult 0 G_ONU_REG_Authenstates 0 not support alarm event 0x1103. Process_Perf's Event(4355) is not support !! ath_attach_dfs[12695] dfsdomain 1 eventCategory:0x0002, eventId:0x0040, channelId:0x0000, lineId:0x0000, deviceId: 0x0001 VP_EVCAT_RESPONSE : eventId 0x0040 line:0 on dev:1 for port:0 init OK! set dev:1 power limit:9945mW dev:1 cs:1 init OK. The legerity init is finished. ol_ath_enable_ap_stats 1 VAP device wlan0 created osifp: (c3369b80) os_if: (c3914000) wlan0 zx_axi_tdm_reset,TDM reset ok zx_axi_tdm_reset,TDM reset ok zx_axi_tdm_reset,TDM reset ok zx_axi_tdm_reset,TDM reset ok DES SSID SET=RT-2.4GHz_WiFi_9D2C ##wenquan## ifaddr_add_addr_v6[505] [responder.c responder_handle_ifaddr_change-5 76]Failed to join the LLMNR multicast group on br0 [ifaddr.c ifaddr_add_addr_v6-5 50]ifaddr: Added IPv6 address fe80::1 on br0 [1] Set freq vap 0 stop send + c3914 000 Set freq vap 0 stop send -c3914000 Set wait done --c3914000 WARNING: Fragmentation with HT mode NOT ALLOWED!! Setting Max Stations:32 ##O7 STATE 0##! 00:00:22 [U_igmp_proxy][Error] [igmp_proxy.c(3227)main] |igmp_proxy| ptr_upstrea m_ifaceName unspecified device wlan0 entered promiscuous mode 00:00:22 [upgrade_mgr][Error] [upgrade_mgr.c(3134)upgradeProcTime] time is 32! 00:00:22 [upgrade_mgr][Error] [upgrade_mgr.c(2915)IsTagparamOk] tagid 2177 00:00:22 [upgrade_mgr][Error] [upgrade_mgr.c(3152)upgradeProcTime] tagparam file same, no need copy! 00:00:22 [U_igmp_proxy][Error] [igmp_proxy.c(3227)main] |igmp_proxy| ptr_upstrea m_ifaceName unspecified ==============c:a Unknown argument. <LOGID000000005>00:00:2 2 [KIGMPSNP][Error] [br_multicast_se(919)set_trap_unknow] port0 trap_unknow_repo rt_en is 0! <LOGID000000005>00:00:22 [KIGMPSNP][Error] [br_multicast_se(962)set_multicast_t] portNum = 0, tagstripe = 0 00:00:24 [tr069][Error] [session.c(421)SessionStart] RUN HERE OPEN TR069 IN SESS ION.C Configuration file: /var/secath0 ieee80211_ioctl_siwmode: imr.ifm_active=13 1712, new mode=3, valid=1 DEVICE IS DOWN ifname=wlan0 wla DEVICE IS DOWN ifname=wlan0 n0: Could not connect to kernel driver DES SSID SET=RT-2.4GHz_WiFi_9D2C br0: port 5(wlan0) entered forwarding state br0: port 5(wlan0) entered forwarding state 00:00:26 [OSS_cspd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[wlan_co nfig] Event[0xa205] dwUsedTicks[724] OK mlme_create_infra_bss : Overriding HT40 ch annel with HT20 channel mlme_create_infra_bss : Overriding HT40 channel with HT20 channel br0: port 5(wlan0) entered disabled state [ol_ath_iw_setcountry][1518] *p=52, *(p+1)=55 isCountryCodeValid: EEPROM regdomain 0x0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080 ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080 Add VHT80 channel: 5210 Add VHT80 channel: 5290 Add VHT80 channel: 5690 Add VHT80 channel: 5775 Skipping VHT80 channel 5825 ol_ath_enable_ap_stats 1 ath_ioctl: SIOC80211IFCREATE CALLED wmi_unified_vdev_create_send: ID = 0 VAP Addr = 0c:37:47:8a:9d:2d: VAP device wlan4 created osifp: (c3368b80) os_if: (c3384000) wlan4 ol_ath_wmm_update: ol_ath_wmm_update: ol_ath_wmm_update: ol_ath_wmm_update: DES SSID SET=RT-5GHz_WiFi_9D2C device wlan4 entered promiscuous mode ==============c:a Unknown argument. <LOGID000000005>00:00:28 [KIGMPSNP][Error] [br _multicast_se(919)set_trap_unknow] port4 trap_unknow_report_en is 0! <LOGID000000005>00:00:28 [KIGMPSNP][Error] [br_multicast_se(962)set_multicast_t] portNum = 4, tagstripe = 0 Set freq vap 0 stop send + c3384000 OL vap_stop + wmi_unified_vdev_stop_send for vap 0 (c3170000) OL vap_stop - STOPPED EVENT for vap 0 (c3170000) Set freq vap 0 stop send -c3384000 Set wait done --c3384000 Following channels are blocked from Channel selection algorithm [132] [134] [13 6] [138] [140] [142] [144] [149] [151] [153] [155] [157] [159] [161] [163] [165] [167] 00:00:29 [pon_dev_mgr][Error] [pon_dev_mgr.c(425)get_falsify_def] call GetTagPa ram failed!!!! 00:00:29 [pon_dev_mgr][Error] [pon_dev_mgr.c(1030)FalsfyDefInit] call get_falsif y_defend_mode failed! iRet = -7 WARNING: Fragmentation with HT mode NOT ALLOWED!! Setting Max Stations:32 Configuration file: /var/secath0 ieee80211_ioctl_siwmode: imr.ifm_active=393856, new mode=3, valid=1 DEVICE IS DOWN ifname=wlan0 wla DEVICE IS DOnWN ifname=wlan0 0: Could not connect to kernel driver DES SSID SET=RT-2.4GHz_WiFi_9D2C random: Cannot read from /dev/random: Resource temporarily unavailable random: On ly 0/20 bytes of strong random data available from /dev/random random: Not enough entropy pool available for secure operations WPA: Not enough entropy in random p ool for secure operations - update keys later when the first station connects br0 : port 5(wlan0) entered forwarding state br0: port 5(wlan0) entered forwarding state Configuration file: /var/secath4 ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1 DEVICE IS DOWN ifname=wlan4 wla DEVICE IS DOWN ifname=wlan4 n4: Could not connect to kernel driver DES SSID SET=RT-5GHz_WiFi_9D2C random: Only 8/20 byOL vap_stop +te s owmi_unified_vf dev_stop_send for vap 0 (c3170000) strOL vap_stop -o STOPPED EVENT for vap 0 (c31ng70000) random data available from /dev/random random: Not enough entropy pool available for secure operations WPA: Not enough entropy in random pool for secure operatio ns - update keys later when the first station connects wmi_unified_scan_start_sen d for vap 0 (c3170000) br0: port 6(wlan4) entered forwarding state br0: port 6(wlan4) entered forwarding state [wifi1] FWLOG: [43858] WAL_DBGID_SECURITY_ENCR_EN ( ) [wifi1] FWLOG: [43858] WAL_DBGID_SECURITY_MCAST_KEY_SET ( 0x1 ) 00:00:34 [OSS_cspd][Warn] [oss_sche.c(820)RunProcess] RunProcess process[wlan_co nfig] Event[0xa205] dwUsedTicks[850] mlme_create_infra_bss : Overriding HT40 chan nel with HT20 channel OL vap_start + wmi_unified_vdev_start_send for vap 0 (c3170000) OL vap_start - ol_vdev_start_resp_ev for vap 0 (c3170000) ol_ath_vap_join: join operation is only for STA/IBSS mode ol_ath_wmm_update: wmi_unified_vdev_up_send for vap 0 (c3170000) Notification to UMAC VAP layer [yqs]disable cpu queue rate limit 00:00:42 [tr069][Error] [session.c(421)SessionStart] RUN HERE OPEN TR069 IN SESS ION.C Edited January 25, 2019 by Vircurus Вставить ник Quote
[anp/hsw] Posted January 26, 2019 Posted January 26, 2019 бюджет вопроса какой? сомневаюсь, что кто-то захочет портировать openwrt бесплатно. имеется ли у вас файл оригинальной прошивки для этого устройства? чтобы можно было понять наличие цифровых подписей, итд. Вставить ник Quote
Vircurus Posted January 26, 2019 Author Posted January 26, 2019 (edited) 3 часа назад, [anp/hsw] сказал: бюджет вопроса какой? сомневаюсь, что кто-то захочет портировать openwrt бесплатно. имеется ли у вас файл оригинальной прошивки для этого устройства? чтобы можно было понять наличие цифровых подписей, итд. По бюджету договоримся если кто то возьмется тк примерную цену не знаю сообщество 4пда думаю будет не против скинутся прошивок нет но думаю можно слить с устройства Edited January 26, 2019 by Vircurus Вставить ник Quote
[anp/hsw] Posted January 26, 2019 Posted January 26, 2019 1 час назад, Vircurus сказал: По бюджету договоримся если кто то возьмется тк примерную цену не знаю сообщество 4пда думаю будет не против скинутся Тогда от вас техзадание мне в ЛС, от меня - цена и сроки. Файл оригинальной прошивки желателен, иначе будет невозможна прошивка устройства через веб (ведь формат файла и заголовки неизвестны!) Вставить ник Quote
Ivan_83 Posted January 26, 2019 Posted January 26, 2019 Что за устройство то? http://4pda.ru/forum/lofiversion/index.php?t848460.html Сами чего не портируете? (там 3 файла весь порт занимает, один создать, остальные дописать) Телефонные порты вряд ли оживут. С гпон - тоже хз, что то я не видел в опенврт поддержки такого, телефоны там кажется пару раз были. Вставить ник Quote
Vircurus Posted January 26, 2019 Author Posted January 26, 2019 1 минуту назад, Ivan_83 сказал: Что за устройство то? Сами чего не портируете? (там 3 файла весь порт занимает, один создать, остальные дописать) у меня дамп слить не выходит а вы про порт говорите Вставить ник Quote
Ivan_83 Posted January 26, 2019 Posted January 26, 2019 Только что, Vircurus сказал: у меня дамп слить не выходит а вы про порт говорите программатор в руки. Вставить ник Quote
Vircurus Posted January 26, 2019 Author Posted January 26, 2019 только UART и USB TTL Вставить ник Quote
[anp/hsw] Posted January 27, 2019 Posted January 27, 2019 16 часов назад, Ivan_83 сказал: С гпон - тоже хз, что то я не видел в опенврт поддержки такого GPON - это куча корпоративных секретов, естественно, не будет его в openwrt. Можно бинарный драйвер вкорячить, но это уже не -open. Вообще, как оказалось, человеку не openwrt нужна, а смена SN и отключение TR-069. А это можно сделать гораздо дешевле порта openwrt, но без физического присутствию железки и файла прошивки, которая гарантировано прошивается, будет сложно и долго. Вставить ник Quote
Vircurus Posted January 27, 2019 Author Posted January 27, 2019 а кроме как программатором больше никак дамп не вытянуть или все же можно ? Вставить ник Quote
[anp/hsw] Posted January 27, 2019 Posted January 27, 2019 Получить доступ в linux-консоль, далее скопировать /dev/mtd* по сети. cat /dev/mtd0 >/tmp/mtd0 tftp -p -l /tmp/mtd0 -r mtd0 192.168.0.2 rm -f /tmp/mtd0 И так для каждого mtd, их обычно не больше 15. 192.168.0.2 - адрес, где запущен tftpd Вставить ник Quote
Vircurus Posted January 27, 2019 Author Posted January 27, 2019 1 час назад, [anp/hsw] сказал: cat /dev/mtd0 >/tmp/mtd0 пишет нет директории сделал так прямиком на флешку cat /dev/mtd0 > /mnt/usb1_1_1/mtd0.bin Вставить ник Quote
[anp/hsw] Posted January 28, 2019 Posted January 28, 2019 ну вот теперь слейте по tftp все mtd. Таблица разделов: cat /proc/mtd Вставить ник Quote
Vircurus Posted January 30, 2019 Author Posted January 30, 2019 а каким макаром прошить это обратно Вставить ник Quote
[anp/hsw] Posted January 30, 2019 Posted January 30, 2019 dd if=/mnt/usb1_1_1/mtd0.bin of=/dev/mtdblock0 если dd или файлов /dev/mtdblock* нету, то возможно есть утилита mtd_write. Надо смотреть дампы mtd для начала. Вставить ник Quote
Vircurus Posted January 30, 2019 Author Posted January 30, 2019 dd точно нет а erase и write есь mtd_write -r write /tmp/(ваша_прошивка) Firmware_Stub оно Вставить ник Quote
mycop Posted February 14, 2019 Posted February 14, 2019 В 30 января 2019 г. в 17:08, [anp/hsw] сказал: dd if=/mnt/usb1_1_1/mtd0.bin of=/dev/mtdblock0 если dd или файлов /dev/mtdblock* нету, то возможно есть утилита mtd_write. Надо смотреть дампы mtd для начала. Добрый день! скажите вы продвинулись в теме? я хотел бы внести свой вклад. Врт например из вашего лога я понял что процессор cortex-a9 И соответсвенно вот есть ресур https://openwrt.org/docs/techref/instructionset/arm_cortex-a9 по идее уже ничего собирать не нужно. Просто залить. Вставить ник Quote
Ivan_83 Posted February 14, 2019 Posted February 14, 2019 4 часа назад, mycop сказал: я хотел бы внести свой вклад. Врт например из вашего лога я понял что процессор cortex-a9 И соответсвенно вот есть ресур https://openwrt.org/docs/techref/instructionset/arm_cortex-a9 по идее уже ничего собирать не нужно. Просто залить. Если бы было так просто, то у OpenWRT не было бы отдельных образов под каждый роутер, притом даже если эти роутеры сделаны на одном и том же чипе и одним вендором. Вставить ник Quote
mycop Posted February 14, 2019 Posted February 14, 2019 Достоврно не знаю и могу только предполагать из того что знаю что главное при прошивке чтобы стартанул, для этого и есть General образы. а остальное дело техники. Вставить ник Quote
Vircurus Posted February 15, 2019 Author Posted February 15, 2019 В 14.02.2019 в 12:27, mycop сказал: процессор cortex-a9 нет там арм 7 Processor : ARMv7 Processor rev 1 (v7l) Арм 9 больно круто даже asus себе не позволяют Как мне обясняли это что то типа микроархитуры и судя по логу загрузки там Broadcom попалась строка BRCM В 14.02.2019 в 12:27, mycop сказал: скажите вы продвинулись в теме сейчас изучаю mtd блоки нужно из них вырезать стоковую прошивку на случай упарывания роутера а это будет и не раз, и как сказал товарищ [anp/hsw] проприетарщину для ГПОН тк в открытом виде ничего нет, комерческая тайна Вставить ник Quote
mycop Posted February 16, 2019 Posted February 16, 2019 пожалуйста не путайте кодовые азвания и ядра. Ядро Cortex-A9 - armv 7 На GPON откровенно говоря наплевать. Я хочу сделать wan через Ethernet порт - это почти все что мне нужно. А то только в роли свитча сейчас приходится использовать. Вставить ник Quote
Vircurus Posted February 16, 2019 Author Posted February 16, 2019 4 минуты назад, mycop сказал: пожалуйста не путайте кодовые азвания и ядра. Ядро Cortex-A9 - armv 7 ежели там арм 9 то запустить не составить труда ибо братьев куча https://openwrt.org/docs/techref/instructionset/arm_cortex-a9 Вставить ник Quote
[anp/hsw] Posted February 16, 2019 Posted February 16, 2019 42 минуты назад, mycop сказал: Я хочу сделать wan через Ethernet порт - это почти все что мне нужно. Отлично, вам только осталось найти/написать драйвер свича, т.к. без этого вы не сможете разделить порты. 29 минут назад, Vircurus сказал: ежели там арм 9 то запустить не составить труда ибо братьев куча Со сборкой под arm нет совершенно никаких проблем. Проблема именно в том, что при старте нужно инициализировать все устройство с самого начала загрузки (обычно можно взять исходники от похожего и работа значительно облегчится, но похожих устройств с исходниками нет). Т.е. чтобы просто позапускать на нем что-нибудь нужное, достаточно их собрать с той же версией gcc и glibc/uclibc, но вот если вы хотите портировать туда openwrt, то придется найти или написать исходники ядра (как минимум драйверы свича и флешки). Вставить ник Quote
AlexPan Posted February 17, 2019 Posted February 17, 2019 А зачем вообще сей банкет? Я так понимаю человек решил свежеполученный при халявном подключении роутер приколхозить под свои нужды, ан не получилось, нет wan порта. Тут сразу приходит пионерский задор - надо всех поспрашивать, ведь обязательно кто то совершенно в халяву все сделает, а народ с форума 4pda скинется. Ну или может еще кто скинется, кто то прошивку даст, он зальет и будет ему счастье... Вот только зачем все это вам??? Вставить ник Quote
Ivan_83 Posted February 17, 2019 Posted February 17, 2019 1 час назад, AlexPan сказал: А зачем вообще сей банкет? Вероятно затем, что гпон терминал устройство тупое до уровня дискового телефона, притом что начинка там не хуже роутерв средней паршивости, вот и хочет челм может хотя бы порты прокинуть или качалку поставить или перевести в бридж и заюзать свой любимый роутер, а злобный оператор постоянно настройки сбрасывает обратно. Не думаю что кому то нужен он именно из за железа, такой мусор рублей по 500 можно набрать на авите, а то и получше, сразу совместимый с врт, но вот с гпон - беда. Вставить ник Quote
