QWE Posted January 16, 2019 Posted January 16, 2019 Хочу узнать задержку до Южно-Сахалинска, кто знает где взять IP для пинга? Вставить ник Quote
guеst Posted January 16, 2019 Posted January 16, 2019 ping www.yuzhno-sakh.ru / mx1.yuzhno-sakh.ru нет? Вставить ник Quote
QWE Posted January 16, 2019 Author Posted January 16, 2019 (edited) 4 минуты назад, guеst сказал: ping www.yuzhno-sakh.ru / mx1.yuzhno-sakh.ru нет? возможно, я ж не знаю IP ЮС. но похоже судя по whois так и есть # ping www.yuzhno-sakh.ru PING yuzhno-sakh.ru (188.168.190.107) 56(84) bytes of data. 64 bytes from 188.168.190.107.static.sakhttk.ru (188.168.190.107): icmp_seq=1 ttl=53 time=103 ms 64 bytes from 188.168.190.107.static.sakhttk.ru (188.168.190.107): icmp_seq=2 ttl=53 time=104 ms 64 bytes from 188.168.190.107.static.sakhttk.ru (188.168.190.107): icmp_seq=3 ttl=53 time=104 ms 64 bytes from 188.168.190.107.static.sakhttk.ru (188.168.190.107): icmp_seq=4 ttl=53 time=104 ms # ping mx1.yuzhno-sakh.ru PING mx1.yuzhno-sakh.ru (188.168.190.81) 56(84) bytes of data. 64 bytes from mx1.yuzhno-sakh.ru (188.168.190.81): icmp_seq=1 ttl=117 time=106 ms 64 bytes from mx1.yuzhno-sakh.ru (188.168.190.81): icmp_seq=2 ttl=117 time=105 ms 64 bytes from mx1.yuzhno-sakh.ru (188.168.190.81): icmp_seq=3 ttl=117 time=106 ms 64 bytes from mx1.yuzhno-sakh.ru (188.168.190.81): icmp_seq=4 ttl=117 time=106 ms Edited January 16, 2019 by QWE Вставить ник Quote
anatoly Posted January 16, 2019 Posted January 16, 2019 91.212.81.241 - бордер правительства сахалинской области, например Вставить ник Quote
QWE Posted January 16, 2019 Author Posted January 16, 2019 7 часов назад, anatoly сказал: 91.212.81.241 - бордер правительства сахалинской области, например # ping 91.212.81.241 PING 91.212.81.241 (91.212.81.241) 56(84) bytes of data. 64 bytes from 91.212.81.241: icmp_seq=1 ttl=235 time=125 ms 64 bytes from 91.212.81.241: icmp_seq=2 ttl=235 time=125 ms 64 bytes from 91.212.81.241: icmp_seq=3 ttl=235 time=125 ms 64 bytes from 91.212.81.241: icmp_seq=4 ttl=235 time=125 ms Вставить ник Quote
mcdemon Posted January 17, 2019 Posted January 17, 2019 Прям стоило целую тему создавать... Вставить ник Quote
QWE Posted January 17, 2019 Author Posted January 17, 2019 9 часов назад, mcdemon сказал: Прям стоило целую тему создавать... научите как без темы найти IP в каждой области РФ? Вставить ник Quote
alibek Posted January 17, 2019 Posted January 17, 2019 Ну навскидку можно тупо базу geoip взять или просто потыкать в карту Speedtest.net. Наверняка есть и более удобные способы. Вставить ник Quote
guеst Posted January 18, 2019 Posted January 18, 2019 (edited) 14 часов назад, QWE сказал: научите как без темы найти IP в каждой области РФ? ну мне кажется можно логически порассуждать, это не сложно. Думается, что официальные сайты администраций/правительств области отлично гуглятся. Ну а далее достаточно посмотреть трасер до этих сайтов (или к чьей AS он принадлежит), если они не где-то на хостинге в Москве - бинго! Если не повезло, то ищем на оф.сайтах email органа, смотрим по домену какой IP у MX. Трасируем, смотрим AS. Чаще всего почтовики у них свои стоят или их ближайшего ISP. Если опять не свезло, можно и дальше развивать логику в этом же направлении и проделать тоже самое по администрации столицы области/края... Edited January 18, 2019 by guеst Вставить ник Quote
