shooter01 Posted April 13, 2021 Posted April 13, 2021 (edited) У меня почему-то с postrouting new-ttl=set:64 out-interface=lte1 passthrough=yes инета не было на симке с "Мы мтс для тебя". Изменил на prerouting new-ttl=increment:1 passthrough=yes все заработало. (wap lte kit, имей изменен) Edited April 13, 2021 by shooter01 Вставить ник Quote
Whistler Posted April 21, 2021 Posted April 21, 2021 https://4pda.ru/forum/index.php?s=&showtopic=624146&view=findpost&p=106103286 Тут все описано, проверил, способ работает. Вставить ник Quote
jnazaradeh Posted June 12, 2021 Posted June 12, 2021 (edited) On 10/19/2020 at 5:48 AM, MadDoktor said: In general, through the efforts of the respected @minks and no less respected PeaceDeathS from w3bsit3-dns.com found a way to change imei to R11E-4G Change imei / interface lte at-chat lte1 input = "AT% SETCFG = \" DEBUG_IMEI \ ", \" 0 00000000000000 \ "" where instead of zeros is the required imei fixed TTL / ip firewall mangle add action = change-ttl chain = postrouting new -ttl = set: 64 out-interface-list = WAN passthrough = yes or / ip firewall mangle add action = change-ttl chain = postrouting new-ttl = set: 65 out-interface = lte1 The imei change is checked, I will check the ttl fix as soon as the sim card is at hand Привет извините за ненормативную лексику, используйте гугл переводчик может кто-нибудь помочь мне сменить sxt 4g kit mikrotik попробуйте эту команду, но не работайте пожалуйста помоги Спасибо hello sorry for bad language use google translate can some one help me to change sxt 4g kit mikrotik try this command but not work please help tank you provider and sim don't have problemi test this sim on 3 modems b612 work finesim is td and band 42on this operator have two type of sim fd and tdfd band 3and 7 work on mikrotiktd band 42 not workneed change and try set one of b612 modem imei on mikrotikmany contact to operator they say no we don't have problemand can't find any mini pci 4g in my mark (Huawei) for change r11e-4g miktotik for test Edited June 16, 2021 by jnazaradeh Вставить ник Quote
shakir477 Posted June 16, 2021 Posted June 16, 2021 (edited) В 06.03.2021 в 17:32, minks сказал: Закинул в приват инфу Del. Edited June 18, 2021 by shakir477 Вставить ник Quote
kiragun Posted June 16, 2021 Posted June 16, 2021 Черкану про LTE6: Симка от МТС, Ярославская область, не менял imei, не фиксил ttl - всё завелось "из коробки". Агрегация работает, но когда модем статичен. То есть работает крайне редко, тк модем установлен в автомобильном ltAP :) Вставить ник Quote
ismax Posted June 20, 2021 Posted June 20, 2021 (edited) Замечен пренеприятнейший баг: в режиме агрегации разных несущих в одном бэнде (в моем случае band 3 c двумя несухами, одна шириной 10 вторая 15 мгц) в закладочке cellular это радостное событие не отображается никак. При этом судя по скорости агрегация работает, но вот так вот в тайне, строго секретно. Edited June 20, 2021 by ismax Вставить ник Quote
mafijs Posted June 21, 2021 Posted June 21, 2021 Агрегация зависит от оператора, как он настроил свою сеть. Если СА нет, то агрегация не работает. Проведите эксперимент- Disable / Enabel lte1 interface. Возможно на какое-то время СА появится. Вставить ник Quote
ismax Posted June 21, 2021 Posted June 21, 2021 1 hour ago, mafijs said: Если СА нет, то агрегация не работает. повторюсь 19 hours ago, ismax said: судя по скорости агрегация работает замечу, на смартфоне она там работает тоже. Вставить ник Quote
Frozer_Alive Posted June 22, 2021 Posted June 22, 2021 В 13.04.2021 в 15:39, XGate сказал: МТС отправляют в сторону клиента пакеты с TTL=1 для того чтобы эти пакеты убивались на роутере при прохождении через него (тариф как бы для мобильника). В сторону оператора устройства отправляют стандартные пакеты (обычно TTL=64), выводы делайте сами. Так вот ты сам себе и ответил, так что правильный вариант увеличивать на единичку, как я и предложил. А имеи надо ставить он уиндоусфона, потому как другие смартфоны на сайты мелкософта не лезут (это помогало работать со смартфонной етой. В 13.04.2021 в 22:05, shooter01 сказал: аботало. (wap lte kit, имей изм Потому что мтс пингует модем, присылает пакет с TTL=1, а назад ему летит с TTL=64, это залет :) А так, все правильно - назад ему прилетает с TTL=1. Вставить ник Quote
Frozer_Alive Posted June 22, 2021 Posted June 22, 2021 (edited) И это, обязательно обновляйте прошивку на модемах, я как то не заморочился, проверил в офисе - все ништяк, агрегация, скорость под 100мегабит, поехал за город - отказывается регистрироваться у того же оператора (Huawei E3372h при этом регистрируется в LTE), причем даже в 2G и 3G, заколебался репу чесать, в чем причина, осталось только на прошивку грешить... Пришлось искать другую БС что бы обновиться, обновился и тут же прицепился К БС, причем с агрегацией. Вот сейчас проблема, симки нет с модемным тарифом под рукой, а что то R11e-LTE6 как от очкую пробовать поменять имеи, тем более тут пишут, что сначала надо фирмварь обновить. UPD: Разобрался как поменять IMEI на R11e-LTE6, я так понял тут зарабатывают на этом, так что пока не публикую... Если че, в личку. Edited June 22, 2021 by Frozer_Alive Вставить ник Quote
Whistler Posted June 22, 2021 Posted June 22, 2021 1 час назад, Frozer_Alive сказал: Разобрался как поменять IMEI на R11e-LTE6, я так понял тут зарабатывают на этом, так что пока не публикую... Если че, в личку. Все уже опубликовано. Несколькими постами выше есть ссылка, где все подробно расписано по поводу смены IMEI на LTE6... Чего все страшную тайну то из этого делают? Привожу цитату с 4PDA: Цитата Заходим в Production Mode /interface lte at-chat lte1 input="AT*PROD=2" Удаляем IMEI /interface lte at-chat lte1 input="AT*MRD_IMEI=D" Теперь все Ок output: OK Записываем новый: /interface lte at-chat lte1 input="AT*MRD_IMEI=W,0,01JAN1970,3529061130xxxxx" Установить prod в 0 /interface lte at-chat lte1 input="AT*PROD=0" Перезапускаем модем /interface lte at-chat lte1 input="AT+reset" Вставить ник Quote
Frozer_Alive Posted June 22, 2021 Posted June 22, 2021 10 минут назад, Whistler сказал: Все уже опубликовано. Несколькими постами выше есть ссылка, где все подробно расписано по поводу смены IMEI на LTE6... Чего все страшную тайну то из этого делают? Привожу цитату с 4PDA: Спасибо, так и делал. На прошивке R11e-LTE6_V025, обновился потом через смартфоный тариф "Безлимитище" до R11e-LTE6_V027 - IMEI даже не поменялся на дефолтный :-) Агрегация B3 + B7 пашет, скорость не проверяю ибо SINR 0, тарелку LHG не хочу ставить пока, завтра уже на объекте протестирую. Вставить ник Quote
XGate Posted July 21, 2021 Posted July 21, 2021 В 22.06.2021 в 20:34, Frozer_Alive сказал: Так вот ты сам себе и ответил, так что правильный вариант увеличивать на единичку, как я и предложил. А имеи надо ставить он уиндоусфона, потому как другие смартфоны на сайты мелкософта не лезут (это помогало работать со смартфонной етой. Разница-то какая увеличивать значение на +1 или устанавливать сразу конечное значение на выходе? И имеи от виндафонов не всегда полезны, т2, например, их не любит. Вставить ник Quote
Meta1984 Posted July 26, 2021 Posted July 26, 2021 (edited) В 18.02.2020 в 11:51, Игорь Кнг сказал: Ошибка Edited July 26, 2021 by Meta1984 Ошибка Вставить ник Quote
bikmaev Posted September 21, 2021 Posted September 21, 2021 On 7/21/2021 at 5:08 PM, XGate said: Разница-то какая увеличивать значение на +1 или устанавливать сразу конечное значение на выходе? И имеи от виндафонов не всегда полезны, т2, например, их не любит. Так удобнее...при смене оператора. Не нужно искать правильный ттл у другого оператора. Вставить ник Quote
DEGABB Posted December 24, 2021 Posted December 24, 2021 День добрый! Подскажите, а можно ли сменить IMEI на модеме Mikrotik R11e-LTE-US? Обе команды /interface lte at-chat lte1 input="AT*MRD_IMEI=R /interface lte at-chat lte1 input="AT*PROD=2" дают ошибку: output: ERROR Пробовал и /port firmware set ignore-directip-modem=no и /port firmware set ignore-directip-modem=yes с перезагрузкой модема - не помогло. Сколько это будет стоить? Вставить ник Quote
ismax Posted February 22, 2022 Posted February 22, 2022 Интересно, а можно ли включить поддержку QAM256? Вставить ник Quote
hulitolku Posted June 25, 2023 Posted June 25, 2023 Почему на билайне (тариф для смартфона) прыгает SINR, а на МТС (тариф для модема) синр всегда стабилен? Вставить ник Quote
Saab95 Posted June 25, 2023 Posted June 25, 2023 Потому что билайн, скорее всего, ловит отраженный сигнал или прыгает с БС на БС, а МТС ловит прямой сигнал и не прыгает, вот там показатели и стабильные. Вставить ник Quote
