the-jk Posted November 21, 2018 Posted November 21, 2018 Приветствую коллеги. Имею ОЛТ P3616-2TE. Нужно настроить multicast vlan. Мой конфиг: !version 10.1.0E build 53337 service timestamps log date service timestamps debug date service password-encryption logging 10.90.7.252 logging buffered 100000 logging buffered informational ! hostname p3616 ddm enable ! port-protected 1 ! epon mpcp-timeout 60 ! epon local-mac forward ! ! ! ! ! no spanning-tree ! ! ! ! ! ! scheduler sred ! ! ! ! ! aaa authentication login default local aaa authentication login rad-default group radius local aaa authentication enable default none ! username admin password 7 xxxxxxx ! enable password 7 xxxxxxx level 15 ! ! ! epon dynamic-binding-timeout 40 epon onu-lost-time 10 epon oam-version 1 0x21 epon oam-version 2 0x20 ! epon onu-config-template T1 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 513 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! epon onu-config-template T2 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 514 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! epon onu-config-template T3 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 544 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! epon onu-config-template T4 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 545 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! epon onu-config-template T5 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 546 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! epon onu-config-template T6 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 547 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! ! interface Null0 ! interface FastEthernet0/1 no ip address no ip directed-broadcast ! !!slot 0 85 interface GigaEthernet0/1 shutdown ! interface GigaEthernet0/2 shutdown ! interface GigaEthernet0/3 shutdown ! interface GigaEthernet0/4 shutdown ! interface GigaEthernet0/5 description client111 switchport trunk vlan-allowed 346 switchport trunk vlan-untagged none switchport pvid 346 ! interface GigaEthernet0/6 description AC_Power_State switchport pvid 90 ! interface GigaEthernet0/7 switchport pvid 6 ! interface GigaEthernet0/8 description UpLink switchport trunk vlan-allowed 6,90,129-131,133,346,513-514,555,640,770,780 switchport trunk vlan-allowed add 794,806,809,819,852,861,866-867,900 switchport mode trunk switchport pvid 555 dhcp snooping trust arp inspection trust ip-source trust ! interface TGigaEthernet0/1 shutdown ! interface TGigaEthernet0/2 description UpLink_10g switchport trunk vlan-allowed 6,90,129-131,133,346,513-514,555,640,770,780 switchport trunk vlan-allowed add 794,806,809,819,852,861,866-867,900 switchport mode trunk switchport pvid 555 dhcp snooping trust arp inspection trust ip-source trust ! interface EPON0/1 epon mpcp-registration-mode ctc 30 epon pre-config-template T1 binded-onu-llid 1-64 switchport trunk vlan-allowed 90,346,513,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/2 epon mpcp-registration-mode ctc 30 epon pre-config-template T1 binded-onu-llid 1-64 switchport trunk vlan-allowed 513,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/3 epon mpcp-registration-mode ctc 30 epon pre-config-template T1 binded-onu-llid 1-64 switchport trunk vlan-allowed 513,555,780,852,861 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/4 epon mpcp-registration-mode ctc 30 epon pre-config-template T2 binded-onu-llid 1-64 switchport trunk vlan-allowed 346,514,555,640,819 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/5 epon mpcp-registration-mode ctc 30 epon pre-config-template T2 binded-onu-llid 1-64 switchport trunk vlan-allowed 129,514,555,806,866-867 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/6 epon mpcp-registration-mode ctc 30 epon pre-config-template T2 binded-onu-llid 1-64 switchport trunk vlan-allowed 514,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/7 epon mpcp-registration-mode ctc 30 epon pre-config-template T3 binded-onu-llid 1-64 epon bind-onu mac 9845.6212.3628 1 switchport trunk vlan-allowed 544,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/7:1 switchport port-security dynamic maximum 5 switchport port-security mode dynamic epon onu port 1 ctc vlan mode tag 544 priority 0 epon onu port 1 ctc mcst tag-stripe enable epon onu port 1 ctc mcst mc-vlan add 555 epon sla upstream pir 170000 cir 15000 epon sla downstream pir 170000 cir 15000 ! interface EPON0/8 epon mpcp-registration-mode ctc 30 epon pre-config-template T3 binded-onu-llid 1-64 switchport trunk vlan-allowed 544,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/9 epon mpcp-registration-mode ctc 30 epon pre-config-template T3 binded-onu-llid 1-64 switchport trunk vlan-allowed 544,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/10 epon mpcp-registration-mode ctc 30 epon pre-config-template T4 binded-onu-llid 1-64 switchport trunk vlan-allowed 545,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/11 epon mpcp-registration-mode ctc 30 epon pre-config-template T4 binded-onu-llid 1-64 switchport trunk vlan-allowed 545,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/12 epon mpcp-registration-mode ctc 30 epon pre-config-template T4 binded-onu-llid 1-64 switchport trunk vlan-allowed 545,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/13 epon mpcp-registration-mode ctc 30 epon pre-config-template T5 binded-onu-llid 1-64 switchport trunk vlan-allowed 546,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/14 epon mpcp-registration-mode ctc 30 epon pre-config-template T5 binded-onu-llid 1-64 switchport trunk vlan-allowed 546,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/15 epon mpcp-registration-mode ctc 30 epon pre-config-template T5 binded-onu-llid 1-64 switchport trunk vlan-allowed 546,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/16 epon mpcp-registration-mode ctc 30 epon pre-config-template T6 binded-onu-llid 1-64 switchport trunk vlan-allowed 547,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! !!slot end ! interface VLAN90 ip address 10.90.0.80 255.255.248.0 no ip directed-broadcast ! ! ! vlan 5 name loopback ! vlan 6 name office_6 ! vlan 90 name MGMT_FTTX ! vlan 513 name pppoe_vlan_513 ! vlan 514 name pppoe_vlan_514 ! vlan 555 name iptv ! vlan 1,5-6,90,129-131,133,346,513-514,555,640,770,780,794,806,809,819,852,861 vlan 866-867,900 ! ! ip mcst enable ip mcst querier enable ip mcst querier address 10.60.0.80 ip mcst mrouter interface GigaEthernet0/8 ip mcst mc-vlan 555 range 238.1.1.0 - 238.1.1.255 ! ! ! ! ! ! ! ! ip route default 10.90.7.254 no ip exf ! ipv6 exf ! ! ip http server ! ! ! ! ! line vty 0 exec-timeout 0 login authentication rad-default ! line vty 1 exec-timeout 0 login authentication rad-default ! line vty 2 exec-timeout 0 login authentication rad-default ! line vty 3 exec-timeout 0 login authentication rad-default ! line vty 4 exec-timeout 0 login authentication rad-default ! line vty 5 exec-timeout 0 login authentication rad-default ! line vty 6 exec-timeout 0 login authentication rad-default ! line vty 7 exec-timeout 0 login authentication rad-default ! line vty 8 exec-timeout 0 login authentication rad-default ! line vty 9 exec-timeout 0 login authentication rad-default ! line vty 10 exec-timeout 0 login authentication rad-default ! line vty 11 exec-timeout 0 login authentication rad-default ! line vty 12 exec-timeout 0 login authentication rad-default ! line vty 13 exec-timeout 0 login authentication rad-default ! line vty 14 exec-timeout 0 login authentication rad-default ! line vty 15 exec-timeout 0 login authentication rad-default ! line vty 16 exec-timeout 0 login authentication rad-default ! line vty 17 exec-timeout 0 ! line vty 18 exec-timeout 0 ! line vty 19 exec-timeout 0 ! line vty 20 exec-timeout 0 ! line vty 21 exec-timeout 0 ! line vty 22 exec-timeout 0 ! line vty 23 exec-timeout 0 ! line vty 24 exec-timeout 0 ! line vty 25 exec-timeout 0 ! line vty 26 exec-timeout 0 ! line vty 27 exec-timeout 0 ! line vty 28 exec-timeout 0 ! line vty 29 exec-timeout 0 ! line vty 30 exec-timeout 0 ! line vty 31 exec-timeout 0 ! ! ! time-zone Europe/Moscow 3 0 ntp server 192.168.8.253 ! !Pending configurations for absent linecards: ! !No configurations pending global Однако ТВ не работает. Себя в группах вижу: sh ip mcst gr Total Group Counts: 1 Vlan Group Type Port(s) ---- --------------- -------- ------------------------------------- 555 238.1.1.21 LEARNING EPON0/7:1 Однако поток не льётся на меня. Убираю все команды ip mcst убираю switchport pvid 555 с интерфейса gi 0/8 сажаю бук в int gi 0/7, делаю switchport pvid 555 ТВ на буке работает, что исключает проблемы с пим роутером и/или любым иным источником потока. пробую с приставки, делаю конфиг ону: interface EPON0/7:1 epon onu port 1 ctc vlan mode tag 555 priority 0 epon sla upstream pir 170000 cir 15000 epon sla downstream pir 170000 cir 15000 убираю все switchport protected где есть убираю все pvid 555 пробую, тв не работает. sh ver BDCOM(tm) P3616-2TE Software, Version 10.1.0E Build 53337 Copyright by Shanghai Baud Data Communication CO. LTD. Compiled: 2018-6-1 9:23:3 by SYS, Image text-base: 0x10000 ROM: System Bootstrap, Version 0.4.5, Serial num:xxxxxxxxxxxx System image file is "Switch.bin" hardware version:V1.0 (RISC) processor with 262144K bytes of memory, 32768K bytes of flash Base ethernet MAC Address: xxxxxxxxxxxxx PCB version:B snmp info: product_ID:2011 system_ID:1.3.6.1.4.1.3320.1.2011.0 p3616 uptime is 0:00:38:24, The current time: 2018-11-21 16:7:8 Есть несколько 3616 на которых работает этот конфиг, но они PCB version:A. У меня идей нет, может кто сталкивался с таким, подскажете что я делаю не так. Вставить ник Quote
nemo_lynx Posted November 21, 2018 Posted November 21, 2018 Вот тут всё описано более чем подробно: https://www.dropbox.com/sh/o8gi2h9tkicwqhh/AACQnj4t-njGaEvnTMGRCNd0a?preview=Настройка+мультикаста.pdf Вставить ник Quote
the-jk Posted November 22, 2018 Author Posted November 22, 2018 14 часов назад, nemo_lynx сказал: Вот тут всё описано более чем подробно: https://www.dropbox.com/sh/o8gi2h9tkicwqhh/AACQnj4t-njGaEvnTMGRCNd0a?preview=Настройка+мультикаста.pdf Такой конфиг работает у меня на 3310 олтах, на 3616 не работает. Вставить ник Quote
the-jk Posted November 22, 2018 Author Posted November 22, 2018 (edited) epon onu-config-template T3 cmd-sequence 001 switchport port-security dynamic maximum 5 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag 544 cmd-sequence 004 epon onu all-port ctc mcst tag-stripe enable cmd-sequence 005 epon onu all-port ctc mcst mc-vlan add 555 cmd-sequence 006 epon sla upstream pir 170000 cir 15000 cmd-sequence 007 epon sla downstream pir 170000 cir 15000 ! interface GigaEthernet0/8 description UpLink switchport trunk vlan-allowed 6,90,129-131,133,346,513-514,555,640,770,780 switchport trunk vlan-allowed add 794,806,809,819,852,861,866-867,900 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 555 dhcp snooping trust arp inspection trust ip-source trust ! interface EPON0/7 epon mpcp-registration-mode ctc 30 epon pre-config-template T3 binded-onu-llid 1-64 epon bind-onu mac 9845.6212.3628 1 switchport trunk vlan-allowed 544,555 switchport trunk vlan-untagged none switchport mode trunk switchport pvid 5 switchport protected 1 ! interface EPON0/7:1 switchport port-security dynamic maximum 5 switchport port-security mode dynamic epon onu port 1 ctc vlan mode tag 544 priority 0 epon onu port 1 ctc mcst tag-stripe enable epon onu port 1 ctc mcst mc-vlan add 555 epon sla upstream pir 170000 cir 15000 epon sla downstream pir 170000 cir 15000 ! ip mcst enable ip mcst timer router-age 600 ip mcst timer response-time 30 ip mcst querier enable ip mcst querier address 10.60.0.80 ip mcst mrouter interface GigaEthernet0/8 ip mcst mc-vlan 555 range 238.1.1.1 - 238.1.1.254 такой конфиг заработал но есть нюансы, проверил приставки что у нас есть: bdcom p1501d1 (10.0.26A.1014) работает тв нормально bdcom p1501dt (10.0.26B.422) работает 15 сек и пропадает fora na-1001c (V2.1.13_X108) не работает тв(на других олтах работает) fora ep-1001h1 (V2.1.2) не работает тв (на других олтах работает) c-data fd600-111g-hz600 (V2.1.1) не работает тв (на других олтах работает) нет ли у кого прошивок на fora и c-data ? Edited November 22, 2018 by the-jk Вставить ник Quote
semop Posted November 23, 2018 Posted November 23, 2018 bdcom p1501dt (10.0.26B.422) - сыпет Прошивка 10.0.26B.532 - не сыпет QUERIER сама OLT? У нас 3608. Все то же самое только: ip mcst series-connection ip mcst support-reverse-stream ip mcst mrouter interface GigaEthernet0/8 QUERIER в другом месте. Вставить ник Quote
the-jk Posted November 27, 2018 Author Posted November 27, 2018 (edited) Версия по OLT на данный момент 10.1.0E Build 56869. Приставки BDCOM P1501D1 и P1501DT с прошивкой 10.0.28B.501 заработали нормально. Теперь бы решить проблемы с C-Data и Fora. Как я понимаю это один китаец с разным лого вендора. Кто-нибудь тестил iptv на P36xx серии на приставках этих товарищей? Может есть у кого прошивки на них? Edited November 27, 2018 by the-jk Вставить ник Quote
