есть cisco 7206VXR (NPE-G1)
show version
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 15.2(4)S7, RELEASE SOFTWARE (fc4)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 01-Apr-15 20:30 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
KharinoIPoE uptime is 34 minutes
System returned to ROM by reload at 22:33:51 MVT Sun Nov 18 2018
System restarted at 22:35:43 MVT Sun Nov 18 2018
System image file is "disk2:c7200-advipservicesk9-mz.152-4.S7.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Processor board ID 37051912
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
125440K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
при вводе в настройки ip nat translation max-entries all-host (от 200 до 10000)
выходит ошибка
<179>3002: Nov 18 17:47:37.928: %SYS-3-INVMEMINT: Invalid memory action (malloc) at interrupt level
<179>3003: -Traceback= 61E32564z 60E81F6Cz 60E82268z 60E72C94z 60E7533Cz 62B1C218z 62B1C528z 6209F7D0z 631C04ECz 6310CFE4z 6310ED00z 62C81E68z 63170984z
абонентов около 40, время в нагрузке
проблемы с памятью?
#sh proc cpu
CPU utilization for five seconds: 3%/2%; one minute: 4%; five minutes: 3%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1          20         187        106  0.00%  0.00%  0.00%   0 Chunk Manager
   2           8        3910          2  0.00%  0.00%  0.00%   0 Load Meter
   3        2428        2253       1077  0.07%  0.03%  0.00%   2 SSH Process
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   5       29112        2980       9769  0.00%  0.12%  0.11%   0 Check heaps
   6         316         328        963  0.00%  0.00%  0.00%   0 Pool Manager
   7           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9           0          98          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  10        3820       19240        198  0.00%  0.01%  0.00%   0 ARP Input
  11           4       20394          0  0.00%  0.00%  0.00%   0 ARP Background
  12           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  13           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  14           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  15           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  16           0           3          0  0.00%  0.00%  0.00%   0 Entity MIB API
  17         492           6      82000  0.00%  0.00%  0.00%   0 PrstVbl
  18           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  19           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  20           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  21           0           2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  22           0           2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  23           0        3910          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  24           0       19085          0  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  25           0         326          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  26           0        3910          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  27           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  28           4       19085          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  29           0       19085          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  30           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  31           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  32           0        1117          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  33           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  34           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  35           0        1955          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  36           0        3910          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  37           0        1955          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  38       12476       19589        636  0.00%  0.11%  0.05%   0 EnvMon
  39           0           1          0  0.00%  0.00%  0.00%   0 OIR Handler
  40           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  41           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  42           0        3886          0  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  43           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  44           0       19544          0  0.00%  0.00%  0.00%   0 GraphIt
#sh proc memory
Processor Pool Total:  128353804 Used:   64678252 Free:   63675552
      I/O Pool Total:   33554432 Used:    3860272 Free:   29694160
Transient Pool Total:   16777216 Used:      15252 Free:   16761964
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   95865408   38245004   55051584        372    1510420 *Init*
   0   0      12052     328956      12052          0          0 *Sched*
   0   0     251444     147004     142804         24         24 *Dead*
   0   0          0          0     788496          0          0 *MallocLite*
   1   0    2466204     307660    2165808          0          0 Chunk Manager
   2   0        240        240       4264          0          0 Load Meter
   3   2    3440220    2885940     565788       1408       1407 SSH Process
   4   0          0          0       7264          0          0 RO Notify Timers
   5   0       4684        240      11708          0          0 Check heaps
   6   0   22153460   22243668     115516         49          0 Pool Manager
   7   0          0          0       7264          0          0 DiscardQ Backgro
   8   0        240        240       7264          0          0 Timers
   9   0          0          0       4264          0          0 WATCH_AFS
  10   0    4785828    4765776      27316      19295      19295 ARP Input
  11   0      17516      17516       7264         33         33 ARP Background
  12   0        240        240       7264          0          0 ATM Idle Timer
  13   0          0          0       7264          0          0 ATM ASYNC PROC
  14   0          0          0       7264          0          0 AAA_SERVER_DEADT
  15   0          0          0      13264          0          0 Policy Manager
  16   0      15852          0      23116         30         30 Entity MIB API
  17   0        240        240       7264          0          0 PrstVbl
  18   0        240        240       7264          0          0 Serial Backgroun
  19   0          0          0       4264          0          0 RMI RM Notify Wa
  20   0        240        240       7264          0          0 DDR Timers
  21   0        240        240      10264          0          0 ATM AutoVC Perio
  22   0        240        240       7264          0          0 ATM VC Auto Crea
  23   0          0          0       7264          0          0 IPC Event Notifi
  24   0          0          0       7264          0          0 IPC Mcast Pendin
  25   0          0          0       7264          0          0 IPC Dynamic Cach
  26   0          0          0       7264          0          0 IPC Service NonC
  27   0          0          0       7264          0          0 IPC Zone Manager
  28   0          0          0       7264          0          0 IPC Periodic Tim
  29   0          0          0       7264          0          0 IPC Deferred Por
  30   0          0          0       7264          0          0 IPC Process leve
  31   0       2104          0       9368          0          0 IPC Seat Manager
  32   0          0          0       7264          0          0 IPC Check Queue
  33   0          0          0       7264          0          0 IPC Seat RX Cont
  34   0          0          0       7264          0          0 IPC Seat TX Cont
  35   0          0          0       7264          0          0 IPC Keep Alive M
  36   0          0          0       7264          0          0 IPC Loadometer
Добавил ip nat translation max-entries all-host 50000
#sh proc cpu
CPU utilization for five seconds: 14%/12%; one minute: 5%; five minutes: 4%
   1          20         188        106  0.00%  0.00%  0.00%   0 Chunk Manager
   2           8        3935          2  0.00%  0.00%  0.00%   0 Load Meter
   3        2488        2325       1070  0.07%  0.03%  0.01%   2 SSH Process
   5       29280        2998       9766  0.00%  0.11%  0.11%   0 Check heaps
   6         324         330        981  0.00%  0.00%  0.00%   0 Pool Manager
   9           0         102          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  10        3844       19348        198  0.07%  0.01%  0.00%   0 ARP Input
  11           4       20524          0  0.00%  0.00%  0.00%   0 ARP Background
  23           0        3935          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  24           0       19210          0  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  25           0         329          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  26           0        3935          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  28           4       19210          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  29           0       19210          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  32           0        1125          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  35           0        1968          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  36           0        3935          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  37           0        1968          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  38       12476       19717        632  0.00%  0.00%  0.02%   0 EnvMon
  42           0        3912          0  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  44           0       19672          0  0.00%  0.00%  0.00%   0 GraphIt
#sh proc memory
Processor Pool Total:  128353804 Used:   64596408 Free:   63757396
   0   0   95865408   38245004   55051584        372    1521117 *Init*
   1   0    2466204     378876    2094592          0          0 Chunk Manager
   3   2    3440220    2896664     555064       1467       1466 SSH Process
   6   0   22288620   22378828     115516         49          0 Pool Manager
  10   0    4811620    4791568      27316      19399      19399 ARP Input
  11   0      17764      17764       7264         34         34 ARP Background
нагрузки нет 4 утра
mem-npe-g1-1gb 2x512MB память 4 Cisco 7200 npe-g1 новый имеет смысл?
Edited by Andrey75
поменял на c7200-advipservicesk9-mz.124-24.T4.bin
при включенном ip nat translation max-entries all-host 200
sh proc cpu
CPU utilization for five seconds: 33%/27%; one minute: 20%; five minutes: 8%
   1           4          35        114  0.00%  0.00%  0.00%   0 Chunk Manager
   2           4          48         83  0.07%  0.01%  0.00%   0 Load Meter
   3         200         243        823  0.00%  0.03%  0.02%   0 Exec
   5         468          39      12000  1.11%  0.18%  0.07%   0 Check heaps
   6           4           5        800  0.00%  0.00%  0.00%   0 Pool Manager
   9           0          26          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  10          52         223        233  0.00%  0.01%  0.00%   0 ARP Input
  11           4         254         15  0.07%  0.00%  0.00%   0 ARP Background
  17         240           4      60000  0.00%  0.00%  0.02%   0 PrstVbl
  23           0          48          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  24           0         231          0  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  25           0           5          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  26           0          48          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  28           0         231          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  29           0         231          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  32           0          14          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  35           0          24          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  36           0          48          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  37           0          24          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  38         232         236        983  0.00%  0.01%  0.03%   0 EnvMon
  42           0          25          0  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  44           0         235          0  0.00%  0.00%  0.00%   0 GraphIt
sh proc memory
Processor Pool Total:  128329516 Used:   65057040 Free:   63272476
      I/O Pool Total:   33554432 Used:    3907504 Free:   29646928
   0   0   95873484   38253672   55120048        370      13325 *Init*
   0   0      12052      39508      12052          0          0 *Sched*
   0   0     162188      16228     142836          1          1 *Dead*
   0   0          0          0    1182024          0          0 *MallocLite*
   1   0    2082132       2360    2087036          0          0 Chunk Manager
   3   0    1642612    1133132     534196          3          3 Exec
   6   0     344944     270320     149468         49          0 Pool Manager
  10   0      81184      61132      27316        248        248 ARP Input
  11   0      17172      17172       7264         29         29 ARP Background
  37   0          0          0       7264          0          0 Compute SRP rate
  38   0          0          0       7264          2          2 EnvMon
  39   0          0          0       7264          0          0 OIR Handler
  40   0          0          0      25264          0          0 Crash writer
  41   0        352          0       7616          0          0 Exception contro
  42   0          0          0       7264          0          0 ALARM_TRIGGER_SC
  43   0          0          0       7264          0          0 CEF MIB API
  44   0        240        240       7264          0          0 GraphIt
  45   0          0          0       7264          0          0 SERIAL A'detect
  46   0        240        240      13264          0          0 Dialer event
  47   0        240        240       7264          0          0 SMART
  48   0          0          0      13264          0          0 RFS server proce
  49   0          0          0       7264          0          0 Critical Bkgnd
  50   0     151516       2056     114524         70         70 Net Background
  51   0       1200       1200      13264          0          0 IDB Work
  52   0        240        240      13264      11611      11610 Logger
  53   0      25912        240       7808          0          0 TTY Background
  54   0        988          0       8252          0          0 IF-MGR control p
  55   0          0          0       7264          0          0 IF-MGR event pro
  56   0          0          0       4264          0          0 Inode Table Dest
  57   0          0          0       7264          0          0 Transport Port A
  58   0        240        240      13264          0          0 INTR MGR PROCESS
та же картина, может косяк в конфиге?
4 часа назад, Andrey75 сказал:
на 122 прошивках радиус будет?
Version 12.2(31)SB11жуёт pptp, с натом у неё хреново, дохнет по цпу при >200 юзеров. Радиус ессесно есть. Без ната - 800 коннектов и предел для npe-g1.
52 минуты назад, Andrei сказал:
У меня на c7200-is-mz.122-31.SB11 спокойно живет до 400 сессий с тарифами от 10 до 80 Мбит/сек, pptp и pppoe вперемешку, на той же циске NAT, rate-limit, PBR, шифрования нет.
есть только эта c7200-is-mz.122-31.SB2, subscriber-service пойдет?
может поделитесь?
Edited by Andrey75
В 20.11.2018 в 00:24, Andrei сказал:
 Все аналогично, только есть ibgp и нет nat. Нат меня совершенно не порадовал, поэтому сдаю маршруты по ibgp и натам и другим насам. pbr конечно тоже есть - клиента с реальником через нат совершенно не нужно гонять. Ip - соотв радиусом от биллинга, админ совсем не нужен, при смене тарифов в биллинге автоматом меняется и рейтлимит, он как радиус-атрибут на сессию прилетает, с ip не завязан.
выходит при загрузке
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "cisco2-C7200" using boot helper "bootflash:c7200-kboot-mz.124-24.T3.bin" failed
error returned: File boot failed -- File not accessible
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
как я понял
sh ver
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)S7, RELEASE SOFTWARE (fc4)
KharinoIPoE uptime is 5 hours, 31 minutes
System returned to ROM by reload at 07:42:54 MVT Fri Nov 23 2018
System restarted at 07:56:45 MVT Fri Nov 23 2018
System image file is "disk2:c7200-adventerprisek9-mz.152-4.S7.bin"
работает с этого IOS System image file is "disk2:c7200-adventerprisek9-mz.152-4.S7.bin"
все есть кроме ip nat translation max-entries all-host
может не трогать BOOT, будет работать?
и прошивки М поддерживают subscriber-service?
В 20.11.2018 в 01:17, Andrey75 сказал:
9 часов назад, Andrey75 сказал:
Ставить. Пробовать.
 Если есть физдоступ к консоли, чтобы не ломать существующий образ,я бы по tftp забутил новый образ, с текущим конфигом и посмотрел. Вкл полное логгирование загрузки образа и конфига в консоли, далее  просто перезагрузка, если чего не так. Места во флэше может для двух образов не хватить.
11 часов назад, Andrei сказал:
Я думал, что вы в лабе играетесь
в лабах с циской даже не играл ни разу, на этих выходных командировка, на следующие буду пробывать.
10 часов назад, YuryD сказал:
два образа рядом живут, через консоль и работаю. про бывал  менять образы, нет субскрибер ( у меня на нем радиус ) думаю поможет только метод научного тыка.
