Собственно, имеется suricata со следующими правилами:
#pass tls any any -> any any (pcre: "/play.google.com/i"; tls_sni;nfq_set_mark:0x8/0xffffffff; sid:2466;)
#pass tls any any -> any any (pcre: "/google.com/i"; tls_sni;nfq_set_mark:0x8/0xffffffff; sid:2465;)
#pass tls any any -> any any (pcre: "/gstatic.com/i"; tls_sni;nfq_set_mark:0x8/0xffffffff; sid:2467;)
#pass tls any any -> any any (pcre: "/googleservice.com/i"; tls_sni;nfq_set_mark:0x8/0xffffffff; sid:2467;)
pass tls any any -> any any (pcre: "/youtube.com/s"; tls_sni;nfq_set_mark:0x2/0xffffffff; sid:2455;)
pass tls any any -> any any (pcre: "/googlevideo.com/s"; tls_sni;nfq_set_mark:0x2/0xffffffff; sid:2456;)
pass http any any <> any any (content: "tactical-market.ru"; http_header;nfq_set_mark:0x4/0xffffffff; sid:2457;)
pass http any any <> any any (content: "voent.org"; http_header;nfq_set_mark:0x4/0xffffffff; sid:2458;)
pass http any any <> any any (content: "h-mag.ru"; http_header;nfq_set_mark:0x4/0xffffffff; sid:2459;)
pass tls any any <> any any (content: "voent.org";tls_sni;nfq_set_mark:0x4/0xffffffff; sid:2460;)
pass tls any any <> any any (content: "h-mag.ru";tls_sni;nfq_set_mark:0x4/0xffffffff; sid:2461;)
rejectboth tcp any any <> any any (content: "GET http://";content: "Host: "; sid:2462;)
pass http any any <> any any (content: "302";http_stat_code;content: "ivrn.net";http_header;nfq_set_mark:0x64/0xffffffff; sid:2463;)
pass ssh any any <> any any (nfq_set_mark:0x6/0xffffffff; sid:2464;)
#reject tls any any <> any any (content:"www.youtube.com"; tls_sni;nfq_set_mark:0x2/0xffffffff; sid:2456;)
#ytimg.com
iptables:
Chain PREROUTING (policy ACCEPT 228K packets, 138M bytes)
 pkts bytes target     prot opt in     out     source               destination
   11  3630 RETURN     all  --  *      *       0.0.0.0              255.255.255.255
 127K  121M RETURN     all  --  eth1   *       0.0.0.0/0            0.0.0.0/0
  187 11489 RETURN     all  --  ppp0   *       0.0.0.0/0            0.0.0.0/0
10365 2323K RETURN     all  --  vpns0.10 *       0.0.0.0/0            0.0.0.0/0
    0     0 LOG        all  --  *      *       0.0.0.0/0            0.0.0.0/0            rpfilter invert LOG flags 0 level 4 prefix "IP SPOOFING: "
    0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            rpfilter invert
    0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            -m ipv4options --flags 7
    0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            -m ipv4options --flags 3
    0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            -m ipv4options --flags 9
    0     0 MARK       all  --  *      *       0.0.0.0/0            0.0.0.0/0            match-set dpi_detect dst MARK xset 0x40/0xfe
    0     0 MARK       all  --  *      *       0.0.0.0/0            0.0.0.0/0            match-set dpi_detect src MARK xset 0x40/0xfe
Chain INPUT (policy ACCEPT 107K packets, 45M bytes)
Chain FORWARD (policy ACCEPT 120K packets, 93M bytes)
 241K  185M DPI        all  --  *      *       0.0.0.0/0            0.0.0.0/0
 120K   93M DPI_SH     all  --  *      *       0.0.0.0/0            0.0.0.0/0
 2063  123K TCPMSS     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp flags:0x06/0x02 TCPMSS clamp to PMTU
Chain OUTPUT (policy ACCEPT 109K packets, 24M bytes)
Chain POSTROUTING (policy ACCEPT 229K packets, 116M bytes)
Chain DPI (1 references)
    0     0 RETURN     all  --  *      *       198.18.0.0/15        192.168.0.0/15
    0     0 RETURN     all  --  *      *       192.168.0.0/16       198.18.0.0/15
    0     0 RETURN     all  --  *      *       192.168.0.0/16       192.168.0.0/16
 121K   93M NFQUEUE    all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match ! 0x1/0x1 NFQUEUE num 0
Chain DPI_SH (1 references)
 3542 2688K RETURN     all  --  *      *       0.0.0.0/0            0.0.0.0/0            connmark match  0x8/0xfe
   53 45450 CONNMARK   all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match 0x8/0xfe CONNMARK xset 0x8/0xfe
    0     0 CONNMARK   all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match 0x4/0xfe CONNMARK xset 0x4/0xfe
    8  9366 CONNMARK   all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match 0x2/0xfe CONNMARK xset 0x2/0xfe
24094   27M CLASSIFY   all  --  *      *       0.0.0.0/0            0.0.0.0/0            connmark match  0x2/0xfe CLASSIFY set 1:11
    0     0 CLASSIFY   all  --  *      *       0.0.0.0/0            0.0.0.0/0            connmark match  0x4/0xfe CLASSIFY set 1:12
    0     0 SET        all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match 0x64/0xfe add-set dpi_detect src
    0     0 LOG        all  --  *      *       0.0.0.0/0            0.0.0.0/0            mark match 0x64/0xfe LOG flags 0 level 4 prefix "INFOROOM DPI: "
ip6tables:
Chain PREROUTING (policy ACCEPT 314 packets, 60079 bytes)
    0     0 RETURN     all      eth1   *       ::/0                 ::/0
 6722 5704K RETURN     all      ppp0   *       ::/0                 ::/0
    2   112 RETURN     all      vpns0.10 *       ::/0                 ::/0
    0     0 LOG        all      *      *       ::/0                 ::/0                 rpfilter invert LOG flags 0 level 4 prefix "IP6 SPOOFING: "
    0     0 DROP       all      *      *       ::/0                 ::/0                 rpfilter invert
Chain INPUT (policy ACCEPT 15 packets, 984 bytes)
Chain FORWARD (policy ACCEPT 299 packets, 59095 bytes)
23065   13M DPI        all      *      *       ::/0                 ::/0
11539 6450K DPI_SH     all      *      *       ::/0                 ::/0
  172 13760 TCPMSS     tcp      *      *       ::/0                 ::/0                 tcp flags:0x06/0x02 TCPMSS clamp to PMTU
Chain OUTPUT (policy ACCEPT 13 packets, 896 bytes)
Chain POSTROUTING (policy ACCEPT 312 packets, 59991 bytes)
    1  1280 RETURN     all      *      *       2a01:d0:c353::/48    2a01:d0:c353::/48
    0     0 RETURN     all      *      *       2a01:d0:c353::/48    2a01:d0:c353::/48
11526 6448K NFQUEUE    all      *      *       ::/0                 ::/0                 mark match ! 0x1/0x1 NFQUEUE num 0
    0     0 RETURN     all      *      *       ::/0                 ::/0                 connmark match  0x8/0xfe
    0     0 CONNMARK   all      *      *       ::/0                 ::/0                 mark match 0x8/0xfe CONNMARK xset 0x8/0xfe
    0     0 CONNMARK   all      *      *       ::/0                 ::/0                 mark match 0x4/0xfe CONNMARK xset 0x4/0xfe
   31 36225 CONNMARK   all      *      *       ::/0                 ::/0                 mark match 0x2/0xfe CONNMARK xset 0x2/0xfe
  215 86776 CLASSIFY   all      *      *       ::/0                 ::/0                 connmark match  0x2/0xfe CLASSIFY set 1:11
    0     0 CLASSIFY   all      *      *       ::/0                 ::/0                 connmark match  0x4/0xfe CLASSIFY set 1:12
    0     0 LOG        all      *      *       ::/0                 ::/0                 mark match 0x64/0xfe LOG flags 0 level 4 prefix "INFOROOM DPI: "
Теперь вопрос: почему при вхлде на google.com, правило
  314  115K CLASSIFY   all      *      *       ::/0                 ::/0                 connmark match  0x2/0xfe CLASSIFY set 1:11
начинает срабатывать? По идее оно должно срабатывать, если заходишь на youtube.com.
1 час назад, default_vlan сказал:
Потому что Гугл сервисы в 80% случаев висят на одном и том же ip. К тому же ssl у Гугла волшебные
connmark по идее должен запоминать ip источника и назначения, исходящий и входящий порт, а также состояние сессии. Когда сессия разрывается, он должен о ней забывать.
В 16.09.2018 в 20:28, ne-vlezay80 сказал:
Да никто никому ничего не должен, если разобраться.
Цитата
$ nslookup google.ru
Server:        127.0.1.1
Address:    127.0.1.1#53
Non-authoritative answer:
Address: 173.194.44.31
Address: 173.194.44.24
Address: 173.194.44.15
Address: 173.194.44.23
Цитата
$ nslookup youtube.com
Server:        127.0.1.1
Address: 173.194.44.14
Address: 173.194.44.7
Address: 173.194.44.8
Address: 173.194.44.9
Address: 173.194.44.6
Address: 173.194.44.5
Address: 173.194.44.4
Address: 173.194.44.0
А все это раунд-робин мативоити.
Разумеется, вы скажете, что ip разные и бла бла бла. Но если прописать соответствия в /etc/hosts, то вопросы отпадут.
тут доменное имя надо запоминать или ssl-сертификат.
11 минут назад, default_vlan сказал:
это iptables не может.
