Собственно хочу создать сабинтефейс с адресом 10.0.0.254 и маской 255.255.255.0
Но маршрутизатор говорит, что данная сеть уже арбайтен!?
Нубский вопрос, чё не так?
Ведь везде /24 маска.
Цитата
7201_L16#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
7201_L16(config)#int GI0/1.101
7201_L16(config-subif)#ip addr 10.0.0.254 255.255.255.0
% Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q,
or ISL vLAN.
Конфиг маршрутизатора:
Скрытый текст
crypto isakmp policy 1000
 authentication pre-share
crypto isakmp key 12345 address X.Y.Z.T.
crypto ipsec transform-set IPsec_Authenication_Router's ah-sha-hmac
 mode transport
crypto ipsec profile DMVPN
 set transform-set IPsec_Authenication_Router's
interface Tunnel1
 ip address 10.255.255.1 255.255.255.0
 no ip redirects
 ip nhrp map multicast dynamic
 ip nhrp network-id 1
 ip ospf network broadcast
 tunnel source GigabitEthernet0/0
 tunnel mode gre multipoint
 tunnel protection ipsec profile DMVPN
interface FastEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/0
 description UPlink_Centel
 ip address X.Y.Z.T. 255.255.255.192
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
 negotiation auto
 ntp disable
interface GigabitEthernet0/1
 ip address 192.168.200.254 255.255.254.0
 ip nat inside
 duplex auto
 speed auto
 media-type rj45
 negotiation auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
 negotiation auto
interface GigabitEthernet0/3
 no ip address
 shutdown
 duplex auto
 speed auto
 negotiation auto
router ospf 1
 router-id 10.255.255.1
 passive-interface default
 no passive-interface Tunnel1
 network 10.255.255.0 0.0.0.255 area 0
 network 192.168.200.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 X.Y.Z.T.
access-list 10 permit 192.168.200.0 0.0.1.255
no cdp run
control-plane
mgcp profile default
line con 0
 exec-timeout 60 0
 logging synchronous
 stopbits 1
line aux 0
 no exec
 transport output none
 stopbits 1
line vty 0 4
 exec-timeout 60 0
 privilege level 15
 logging synchronous
 transport input ssh
ntp server 195.3.254.2 source GigabitEthernet0/0
ntp server 192.36.143.130 source GigabitEthernet0/0
ntp server 185.22.60.71 source GigabitEthernet0/0
end
Ну сказано же
or ISL vLAN.
Сначало указываем тип саба, потом вешаем IP.
int GI0/1.101
encapsulation dot1Q 101
