Доброго времени суток!
Подскажите кто нибудь сталкивался с этой фичей?
У нас она почему то работает не корректно.
Есть цыска 3550-12G софтом c3550-ipservicesk9-mz.122-55.SE4.bin
На втором (запасном) интерфейсе при активном первом, есть траффик в обе стороны, но при этом нет маков с обоих сторон.
sh mac address-table int gig 0/2
Mac Address Table
Vlan Mac Address Type Ports
Вот конфиг:
interface GigabitEthernet0/1
description -> CORE (CWDM-A-1470/1610)
switchport trunk encapsulation dot1q
switchport mode trunk
switchport backup interface Gi0/2
switchport backup interface Gi0/2 preemption mode forced
switchport backup interface Gi0/2 preemption delay 15
load-interval 30
speed nonegotiate
hold-queue 4096 in
hold-queue 4096 out
end
#sh run int gig 0/2
Building configuration...
Current configuration : 215 bytes
interface GigabitEthernet0/2
description -> CORE (CWDM-B-1470/1610)
load-interval 30
speed nonegotiate
hold-queue 4096 in
hold-queue 4096 out
end
С другой стороны там просто транк без особенностей
GigabitEthernet0/2 is down, line protocol is down (connected)
Hardware is Gigabit Ethernet, address is 0009.e8f5.0482 (bia 0009.e8f5.0482)
Description: -> CORE (CWDM-B-1470/1610)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not set
Auto-duplex, Auto-speed, link type is force-up, media type is 1000BaseLX
input flow-control is off, output flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:10:24, output 00:10:24, output hang never
Last clearing of "show interface" counters never
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
30 second input rate 49458 bits/sec, 500 packets/sec
30 second output rate 3050 bits/sec, 70 packets/sec
4245521987 packets input, 1560132449 bytes, 0 no buffer
Received 58619607 broadcasts (0 multicasts)
0 runts, 3060 giants, 0 throttles
3060 input errors, 0 CRC, 0 frame, 0 overrun, 6428156 ignored
0 watchdog, 37077592 multicast, 0 pause input
0 input packets with dribble condition detected
993384878 packets output, 2248697201 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 309085 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Входящий трафик там все понятно, с той стороны херачит, но откуда исходящий?
Все бы ничего но есть жалобы, которые пропадают если второй линк руками погасить.
