Добрый день!
имеется цыска 7609S вот с таким рсп:
RSP720-3CXL-10GE
софт:
c7600rsp72043-adventerprisek9-mz.122-33.SRE12.bin
У нее один аплинк пока который дает фул и дефолт:
C7606S-II#sh ip bgp vpnv4 vrf INET summary
BGP router identifier 172.16.50.234, local AS number 43031
BGP table version is 3193494, main routing table version 3193494
712752 network entries using 108338304 bytes of memory
1425712 path entries using 74137024 bytes of memory
214555/107149 BGP path/bestpath attribute entries using 28321260 bytes of memory
96632 BGP AS-PATH entries using 3899456 bytes of memory
6 BGP community entries using 144 bytes of memory
1 BGP extended community entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 214696212 total bytes of memory
712855 received paths for inbound soft reconfiguration
BGP activity 738109/25351 prefixes, 2924822/1499110 paths, scan interval 60 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
172.16.50.134   4        43031  199409  775934  3193496    0    0 1d18h         109
195.69.217.136  4        29196  765002    5594  3193496    0    0 1d18h      712746
Есть еще сосед но там префиксом мало.
C7606S-II#sh ip route vrf INET
Routing Table: INET
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP
       + - replicated route, % - next hop override
Gateway of last resort is 195.69.217.136 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 195.69.217.136
      1.0.0.0/8 is variably subnetted, 2625 subnets, 18 masks
B        1.0.0.0/24 [20/0] via 195.69.217.136, 1d17h
B        1.0.4.0/22 [20/0] via 195.69.217.136, 1d17h
B        1.0.4.0/24 [20/0] via 195.69.217.136, 1d17h
Собственно вопрос, пугает рост счетчика вот этого:
C7606S-II#show mls statistics | i drop
  No-route packet drops                 : 26377718
  No-route packet drops                 : 26377827
  No-route packet drops                 : 26377943
  No-route packet drops                 : 26455535
Ктонибудь скажите как это дебажить? Есть же дефолт че собаке нада? почему но роут?
При этом цпу не нагружен:
C7606S-II#sh proc cpu sort
CPU utilization for five seconds: 9%/0%; one minute: 26%; five minutes: 23%
C7606S-II#sh platform hardware capacity
System Resources
  PFC operating mode: PFC3CXL
  Supervisor redundancy mode: administratively sso, operationally sso
  Switching resources: Module   Part number               Series      CEF mode
                       1        WS-X6516A-GBIC            CEF256           CEF
                       5        RSP720-3CXL-10GE      supervisor           CEF
                       6        RSP720-3CXL-10GE      supervisor           CEF
Power Resources
  Power supply redundancy mode: administratively redundant
                                operationally redundant
  System power: 2669W, 0W (0%) inline, 1088W (41%) total allocated
  Powered devices: 0 total, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco
Flash/NVRAM Resources
  Usage: Module Device               Bytes:      Total          Used     %Used
         5  SP  disk0:                       512106496     342278144       67%
         5  SP  sup-bootdisk:                512081920     433553408       85%
         5  SP  const_nvram:                    127212         60564       48%
         5  SP  hidden-nvram:                  4059328         62805        2%
         5  RP  nvram:                         4059328         62805        2%
         5  RP  bootdisk:                    512081920     340172800       66%
         6      slavenvram:                    4059328         62805        2%
         6      slaveconst_nvram:               127212         60564       48%
         6      slavesup-bootdisk:           512090112     373948416       73%
         6      slavebootdisk:               512090112             0        0%
CPU Resources
  CPU utilization: Module             5 seconds       1 minute       5 minutes
                   5  RP               1% /  0%            20%             22%
                   5  SP               5% /  1%            11%             10%
                   6  RP               0% /  0%             0%              0%
                   6  SP               3% /  0%             3%              3%
  Processor memory: Module   Bytes:       Total           Used           %Used
                    5  RP            3504155084      909981944             26%
                    5  SP             705884964      370720228             53%
                    6  RP            3504155084      292611224              8%
                    6  SP             705534424      368791152             52%
  I/O memory: Module         Bytes:       Total           Used           %Used
              5  RP                   268435456       57941032             22%
              5  SP                    67108864       43861352             65%
              6  RP                   268435456       57937660             22%
              6  SP                    67108864       43819112             65%
EOBC Resources
  Module                     Packets/sec     Total packets     Dropped packets
  5  RP      Rx:                     624          98307858                   0
             Tx:                     623          98516738                   0
  5  SP      Rx:                     612          96906384                   0
             Tx:                     613          96858763                   0
  6  RP      Rx:                       0           1148419                   0
             Tx:                       0           1043215                   0
  6  SP      Rx:                      10           2058602                   0
             Tx:                      11           2002669                   0
VLAN Resources
  VLANs: 4094 total, 1005 VTP, 0 extended, 16 internal, 3073 free
L2 Forwarding Resources
           MAC Table usage:   Module  Collisions  Total       Used       %Used
                              5                0  98304         98          1%
                              6                0  98304         56          1%
             VPN CAM usage:                       Total       Used       %Used
                                                    512          0          0%
L3 Forwarding Resources
 Module              FIB TCAM usage:                     Total        Used     %Used
   5                     72 bits (IPv4, MPLS, EoM)      1032192      714523     69%
                        144 bits (IP mcast, IPv6)        8192           16      1%
                     detail:      Protocol                    Used       %Used
                                  IPv4                      713499         69%
                                  MPLS                        1024          1%
                                  EoM                            0          0%
                                  IPv6                           9          1%
                                  IPv4 mcast                     4          1%
                                  IPv6 mcast                     3          1%
            Adjacency usage:                     Total        Used       %Used
                                               1048576         179          1%
   6                     72 bits (IPv4, MPLS, EoM)      1032192      714523     69%
                                  IPv4                      713499         69%
                                  MPLS                        1024          1%
                                  EoM                            0          0%
                                  IPv6                           9          1%
                                  IPv4 mcast                     4          1%
                                  IPv6 mcast                     3          1%
                                               1048576         177          1%
     Forwarding engine load:
                     Module       pps   peak-pps                     peak-time
                     5          51735     218169  23:50:56 CHEL Sat Jul 21 2018
                     6          17059      37802  13:40:48 CHEL Mon Jul 23 2018
Netflow Resources
          TCAM utilization:       Module       Created      Failed       %Used
                                  5                  1           0          0%
                                  6                  1           0          0%
          ICAM utilization:       Module       Created      Failed       %Used
                                  5                  0           0          0%
                                  6                  0           0          0%
                 Flowmasks:   Mask#   Type        Features
                        IPv4:     0   reserved    none
                        IPv4:     1   unused      none
                        IPv4:     2   unused      none
                        IPv4:     3   reserved    none
                        IPv6:     0   reserved    none
                        IPv6:     1   unused      none
                        IPv6:     2   unused      none
                        IPv6:     3   reserved    none
CPU Rate Limiters Resources
             Rate limiters:       Total         Used      Reserved       %Used
                    Layer 3           9            7             1         78%
                    Layer 2           4            3             2         75%
ACL/QoS TCAM Resources
  Key: ACLent - ACL TCAM entries, ACLmsk - ACL TCAM masks, AND - ANDOR,
       QoSent - QoS TCAM entries, QOSmsk - QoS TCAM masks, OR - ORAND,
       Lbl-in - ingress label, Lbl-eg - egress label, LOUsrc - LOU source,
       LOUdst - LOU destination, ADJ - ACL adjacency
  Module ACLent ACLmsk QoSent QoSmsk Lbl-in Lbl-eg LOUsrc LOUdst  AND  OR  ADJ
  5          1%     1%     1%     1%     1%     1%     0%     0%   0%  0%   1%
  6          1%     1%     1%     1%     1%     1%     0%     0%   0%  0%   1%
L3 Multicast Resources
  Replication mode: Egress
  Replication capability: Module                                         Mode
                               1                                         Egress
                               5                                         Egress
                               6                                         Egress
  MET table Entries: Module                             Total    Used    %Used
                     5                                  32744       2       1%
                     6                                  32752       2       1%
QoS Policer Resources
  Aggregate policers: Module                      Total         Used     %Used
                      5                            1024            1        1%
                      6                            1024            1        1%
  Microflow policer configurations: Module        Total         Used     %Used
                                    5                64            1        1%
                                    6                64            1        1%
Switch Fabric Resources
  Bus utilization: current: 0%, peak was 0% at 17:47:35 CHEL Mon Jul 23 2018
  Fabric utilization:     Ingress                    Egress
    Module  Chanl  Speed  rate  peak                 rate  peak
    1       0         8G    0%    0%                   0%    0%
    5       0        20G    0%    8% @16:53 23Jul18    0%    3% @03:31 22Jul18
    5       1        20G    0%    0%                   0%    0%
    6       0        20G    0%    3% @03:31 22Jul18    0%    8% @16:53 23Jul18
    6       1        20G    0%    0%                   0%    0%
  Switching mode: Module                                        Switching mode
                  1                                                    compact
                  5                                                    compact
                  6                                                    compact
Interface Resources
  Interface drops:
    Module    Total drops:    Tx            Rx      Highest drop port:  Tx  Rx
         no modules reported drops
  Interface buffer sizes:
    Module                            Bytes:     Tx buffer           Rx buffer
    1                                               901120              147456
    5                                              8640448            10127296
    6                                              8640448            10127296
IBC Resources
  5  RP      Rx:                     110          17866651                   0
             Tx:                      19           2518825                   0
  5  SP      Rx:                     501          77424146                   0
             Tx:                      17           1272380                   0
  6  RP      Rx:                       0             75112                   0
             Tx:                       0             75112                   0
  6  SP      Rx:                       0             78253                   0
             Tx:                       0             78259                   0
SPAN Resources
  Source sessions: 18 maximum, 0 used
    Type                                    Used
    Local                                      0
    RSPAN source (max   2)                     0
    ERSPAN source                              0
    Service module                             0
  Destination sessions: 62 maximum, 0 used
    Type                                    Used
    RSPAN destination                          0
    ERSPAN destination (max  24)               0
судя по выводу команд, дефолт у вас в vrf? а в глобале вообще что живет? а другие vrf-ы есть?
сделайте дефолт во всех таблицах, путь даже Null0, тогда оно в другие дропы должно записаться
5 часов назад, s.lobanov сказал:
В глобале дефолт есть но там тупо менеджмент.
Других врф нету.
6 часов назад, ShyLion сказал:
Так эта... а че-то не работает? Может нет причины "чинить" ?
есть фантомные боли и подземный стук, пытаемся найти откуда ноги ростут.
Если проблему еще не решили, то можете попробовать воспользоваться фичей RP-SPAN, которая присутствует у RSP-720. Вероятно, пакеты без route попадут на процессор, и он Вам их аккуратно отзеркалирует на Wireshark, например. А там Вы уже сможете посмотреть, что это за пакеты.
