Конфиг сети. Влан100, в нем сидит радиус-сервер (192.168.0.5) и линк на циску (192.168.0.12).
ip циски находится в vrf MGMT.
c4948#show version
Скрытый текст
c4948#show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 15.0(2)SG8, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 02-Dec-13 17:11 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123ACE64
ROM: 12.2(31r)SGA7
Pod Revision 0, Force Revision 31, Gill Revision 20
c4948 uptime is 13 hours, 22 minutes
System returned to ROM by reload
System restarted at 19:24:57 MSK Tue Jul 10 2018
System image file is "bootflash:cat4500-entservicesk9-mz.150-2.SG8.bin"
Last reload reason: Reload command
cisco WS-C4948-10GE (MPC8540) processor (revision 5) with 262144K bytes of memory.
Processor board ID FOX1243GWZL
MPC8540 CPU at 667Mhz, Fixed Module
Last reset from Reload
2 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
c4948#ping vrf MGMT 192.168.0.5
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 192.168.0.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
c4948#sho running-config  brief
Скрытый текст
Building configuration...
Current configuration : 4181 bytes
! Last configuration change at 20:08:10 MSK Tue Jul 10 2018 by admin
version 15.0
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
service compress-config
service unsupported-transceiver
hostname c4948
boot-start-marker
boot system flash bootflash:cat4500-entservicesk9-mz.150-2.SG8.bin
boot-end-marker
enable password 7 06070B2C4540
username admin password 7 104F0D140C19
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius if-authenticated
aaa session-id common
clock timezone MSK 3
ip subnet-zero
ip domain-name freebit.net.ua
ip name-server 192.168.0.5
ip vrf MGMT
ip vrf mgmtVrf
password encryption aes
crypto pki trustpoint TP-self-signed-1243
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1243
 revocation-check none
 rsakeypair TP-self-signed-1243
crypto pki certificate chain TP-self-signed-1243
 certificate self-signed 01
power redundancy-mode redundant
archive
 log config
  logging enable
 path tftp://192.168.0.5/$H-$T.txt
 write-memory
spanning-tree mode pvst
spanning-tree extend system-id
no spanning-tree vlan 100
vlan internal allocation policy ascending
vlan dot1q tag native
ip tftp source-interface Vlan100
ip ssh source-interface Vlan100
ip ssh version 2
interface Loopback0
 no ip address
interface Port-channel1
 no ip address
interface FastEthernet1
 description mgmtport
 ip vrf forwarding mgmtVrf
 ip address 192.168.10.1 255.255.255.0
 speed auto
 duplex auto
interface GigabitEthernet1/1
interface GigabitEthernet1/48
 description mgmt_access_port
 switchport access vlan 100
 switchport mode access
interface TenGigabitEthernet1/49
 shutdown
interface TenGigabitEthernet1/50
 shutdown
interface Vlan1
 no ip address
interface Vlan100
 description mgmt_interface
 ip vrf forwarding MGMT
 ip address 192.168.0.12 255.255.254.0
no ip http server
ip http secure-server
ip radius source-interface Vlan100
radius-server attribute 6 on-for-login-auth
radius-server dead-criteria tries 100
radius-server host 192.168.0.5 auth-port 1814 acct-port 1815 timeout 2 retransmit 2 key 7 095F4A5848023638022609
radius-server deadtime 1
control-plane
line con 0
 stopbits 1
 speed 115200
line vty 0 4
 exec-timeout 60 0
 transport input ssh
line vty 5 15
 exec-timeout 0 0
 transport input ssh
ntp clock-period 17180946
ntp peer vrf MGMT 192.168.0.8
end
При сохранении конфига - на тфтп он сохраняется, доступ через ssh есть.
При попытке авторизации ("debug radius"):
Скрытый текст
Jul 11 05:58:25.559: RADIUS/ENCODE(00000004): ask "Password: "
Jul 11 05:58:26.879: RADIUS/ENCODE(00000004):Orig. component type = EXEC
Jul 11 05:58:26.879: RADIUS:  AAA Unsupported Attr: interface         [170] 4
Jul 11 05:58:26.879: RADIUS:   74 74                [ tt]
Jul 11 05:58:26.879: RADIUS(00000004): Config NAS IP: 192.168.0.12
Jul 11 05:58:26.879: RADIUS/ENCODE(00000004): acct_session_id: 4
Jul 11 05:58:26.879: RADIUS(00000004): sending
Jul 11 05:58:26.879: RADIUS(00000004): Send Access-Request to 192.168.0.5:1814 id 1645/4, len 90
Jul 11 05:58:26.879: RADIUS:  authenticator BA D6 97 61 C6 92 7C F4 - 8B 5A D5 E0 12 2C 47 34
Jul 11 05:58:26.879: RADIUS:  User-Name           [1]   6   "user"
Jul 11 05:58:26.879: RADIUS:  User-Password       [2]   18  *
Jul 11 05:58:26.879: RADIUS:  NAS-Port            [5]   6   2
Jul 11 05:58:26.879: RADIUS:  NAS-Port-Id         [87]  6   "tty2"
Jul 11 05:58:26.879: RADIUS:  NAS-Port-Type       [61]  6   Virtual                   [5]
Jul 11 05:58:26.879: RADIUS:  Calling-Station-Id  [31]  16  "192.168.0.252"
Jul 11 05:58:26.879: RADIUS:  Service-Type        [6]   6   Login                     [1]
Jul 11 05:58:26.879: RADIUS:  NAS-IP-Address      [4]   6   192.168.0.12
Jul 11 05:58:26.879: RADIUS(00000004): Started 2 sec timeout
Jul 11 05:58:28.892: RADIUS(00000004): Request timed out
Jul 11 05:58:28.892: RADIUS: Retransmit to (192.168.0.5:1814,1815) for id 1645/4
Jul 11 05:58:28.892: RADIUS(00000004): Started 2 sec timeout
Jul 11 05:58:30.680: RADIUS(00000004): Request timed out
Jul 11 05:58:30.680: RADIUS: Retransmit to (192.168.0.5:1814,1815) for id 1645/4
Jul 11 05:58:30.680: RADIUS(00000004): Started 2 sec timeout
Jul 11 05:58:32.572: RADIUS(00000004): Request timed out
Jul 11 05:58:32.572: RADIUS: No response from (192.168.0.5:1814,1815) for id 1645/4
Jul 11 05:58:32.572: RADIUS/DECODE: parse response no app start; FAIL
Jul 11 05:58:32.572: RADIUS/DECODE: parse response; FAIL
Никаких пакетов при этом на 192.168.0.5 не прилетает. Подскажите, уважаемые гуру, в чем может быть дело?
 А чего порты немного нестандартные у радиуса ? у меня обычно 1812/1813
24 минуты назад, stalker86 сказал:
ip radius source-interface vlan100 vrf MGMT
К сожалению, указание vrf ничего не меняет. Тоже самое.
55 минут назад, YuryD сказал:
А на тех портах у меня другой инстанс радиуса висит. Кстати, по умолчанию циска ипользует порты 1645, 1646.
aaa group server radius radiusServerGroup
 server-private 192.168.0.12 auth-port 1812 acct-port 1813 key 7 RADIUS_KEY
 ip radius source-interface Loopback20
примерно так у меня работает. Ну и соотв. настройки aaa.
Добавлю. включил debug ip packet.
Jul 11 08:03:13.057: RADIUS: Retransmit to (192.168.0.5:1814,1815) for id 1645/10
Jul 11 08:03:13.057: IP: s=0.0.0.0 (local), d=192.168.0.5, len 119, local feature, Local Clustering(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jul 11 08:03:13.057: IP: s=0.0.0.0 (local), d=192.168.0.5, len 119, unroutable
Написано unroutable. Почему?
c4948#sho ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
c4948#sho ip route vr
c4948#sho ip route vrf MGMT
Routing Table: MGMT
     192.168.0/23 is subnetted, 1 subnets
C       192.168.0.0 is directly connected, Vlan100
c4948#
Edited by DemonS
7 минут назад, DemonS сказал:
Jul 11 08:03:13.057: RADIUS: Retransmit to (172.16.100.5:1814,1815) for id 1645/10
Jul 11 08:03:13.057: IP: s=0.0.0.0 (local), d=172.16.100.5, len 119, local feature, Local Clustering(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jul 11 08:03:13.057: IP: s=0.0.0.0 (local), d=172.16.100.5, len 119, unroutable
А это вообще из другой песни. Вполне возможно что нет destination в route table для 172.16.100.5
2 минуты назад, StSphinx сказал:
Думаете, циска ищет в основной таблице вместо vrf? (172.16.100.5 читать, как 192.168.0.5, спалил все таки ip-шки...)
12 минут назад, StSphinx сказал:
Сделал так же. Заработало. Всем спасибо!
Edited by DemonS
1 минуту назад, DemonS сказал:
 Она ищет destination в той таблице, к которой принадлежит интерфейс, с которого принят пакет.
