SubCentrex —Carrier-Class Softswitch
SubCentrex is an Carrier-Class softswitch,based on NGN model , developed on commercial high-performance VoIP protocol stack. SubCentrex runs on Linux to provide a stable and robust core switching system. SubCentrex supports SIP, H.323, NAT traversal, various of authentication methods, Interactive Voice Response(IVR) and many value-added services. SubCentrex supports standard RADIUS protocol, and implements flexible billing functions. SubCentrex supports load balancy and redundancy. SubCentrex can provides stable and robust access-class carrier service as a result of our strict, long-term and large-capacity test.
System Features and Benefits
l voice, fax and video calls Support
l High switching capability and compatibility based on commercial VoIP protocol stack
l Load balancing, redundancy, overload protection in order to assure the stability, robustness and scalability
l Built-in IVR and service call flow, no hardware voice card needed
l NAT/Firewall traversal support including multi-layer NAT traversal, hence capable of reducing the OPEX considerably
l Web GUI for Configuring and maintaining
l Centralized monitoring and managing by uniform network management system
l Abundant value-added services and flexible service extension interface
l Aftersales services and technical support with our hearts
System Architecture
System Application Topology
Specification
1.System Function
Item Specification Description
VoIP protocol SIP(RFC3261)/H.323(V2, V3, V4) SIP2.0 (RFC3261)
Audio CODECs G.723.1/G.729/G.711
Video CODECs H.263
DTMF RFC2833/INFO/H.245 SIP(RFC 2833 and INFO), H.323(H.245 User Input Indication)
System Interconnecting H.323 Gateway mode Interwork with other GWs, as GW, no registration
H.323 Gateway registration mode Interwork with 3rd party Gatekeeper or SoftSwitch by resitering with them as GW
H.323 Gatekeeper mode Interwork with 3rd GW or SoftSwitch by accepting their registrations as a Gatekeeper
SIP UA mode Interwork with other SIP UAs, as UA, no registration
SIP UA registration mode Interwork with 3rd party SIP Proxy or SoftSwitch by resitering with them as UA
SIP Proxy mode Interwork with 3rd UA or SoftSwitch by accepting their registrations as a SIP proxy
Authentication mode Device ID mode Fit for SIP and H.323 registration
Device ID + IP mode Fit for SIP and H.323 registration
User name + Password mode Fit for SIP registration and call
Number Binding Support PSTN number binding with CPE support global roaming by binding a device with multiple phone numbers
Routing Plan Support multiple routing Plan Routing definition by number prefix
Routing distribution Distributing routing by priority, percentage and time
Automatic routing retry Automatic routing retry when previous try receives error code from trunking or detects timeout
Value-added Services Number display  Incoming caller number display/Outgoing caller number blocking
Reject/Accept anonymous call
Call restriction/Permission
Call forward Call forward unconditional, Call forward busy, Call forward no answer, Call forward offline
Call transfer Support SIP signaling mode and DTMF mode
Call hold/Retrieve
Number transform Support transforming caller or callee number by settings
Dial pattern
Abbreviated dialing Support self-service setting
IP Centrex services Enterprise grouping Support multiple enterprises and multiple groups per enterprise
Enterprise extension number Short extensioin number dialing in every enterprise
DID(Direct Inward Dialing) Support calling enterprise extension number using its E.164 number directly from outside
Group ringing All available group extensions ring at the same time, when any extension accepts the call, other extensions stop ringing. Allow for configuring ringing duration
Group hunting Select an extension by random or alphabetical order
Group IVR Support automatic/manual attendant, allow for customizing Greeting
Call Park/Call Pickup
Distinctive ringing Device support required
Line group Allow every enterprise have its own PSTN routing capability
Additional service modules Prepaid card(Calling Card) Net-2Com Billing system required
Registered call Authentication Module Authenticate PSTN caller number, allow for binding multiple caller number, support direct or indirect dialing
Follow me Service Module Support One-number and personal IP calling, allowing for binding multiple Caller numbers
Voice mail Module Allow for receiving voice mail by IVR, Web or Email .add-on module required
Voice conference Module Support multiple concurrent conference rooms, support password protection. add-on module required
WebPhone Module Support WebPhone and Web800 services. Add-on module required
IVR Voice prompt Call failure prompt, account balance prompt
Calling card IVR flow Support multiple IVR access number per IVR flow
Prepaid account recharge IVR flow
Automatic attendant IVR flow Automatic virtual attendant for enterprise user
System configuration Web Configuration GUI Support multi-level administrators
Batch add/delete users
Intelligent wizard Simplifying configuration process
Self-service configuration Allow user to query/configure personal services
Logging Operation log record and management
Network management system System status monitoring Status monitoring for servers, devices and calls
Realtime call/registration trace Call trace, registration trace, realtime call/registration linear graph
Exception alerting Allerting for server exception, resource usage exception
Statistics History calls statistics, alerting records statistics
Logging Operation log record. Allow for adjusting log level
Billing system Support Net-2Com Billing system Refer to Net-2Com Vox Billing Specification
2. System capacity
Item Maximum value(Related to hardware performance and network environment) Description
Devices 50,000 Additional cascaded modules required for supporting this maximum device capacity
Device Ports 100,000 Additional cascade modules required for supporting this maximum port capacity
Concurrent calls 5,000 Additional cascade modules required
CPS <=20 Call Per Second
3.System platform
OS RedHat Linux 9.0RedHat Enterprise Linux 3
Database Oracle 9i for Linux or PostgreSQL PostgreSQL for small-scale customer
VoX Billing —VoIP Billing System For Carrier
Net-2Com Vox Billing system is based on Linux OS, which support standard RADIUS protocol. Billing system provides secure System management, flexible configuration management, and realtime billing, standard CDR, friendly UI etc. Billing System has Capacity scalability ,and it is easy to deploy for different suppliers.
l Small/ Medium scale carrier oriented Billing platform
l Postpaid, Prepaid, Prepaid Calling Card
l 2 levels of agents and balances
l Capability scaleable
l Support multiple languages, multiple accounting periods, multiple currencies
l Realtime credit control
l Standard RADIUS protocol
l Flexible system configuration/query/statistics
System Architecture
Application Domains
l ITSP
l Virtual carrier
l Global Calling Card Provider
Specification
1.System Function
Protocol RADIUS(RFC2865/RFC2866) Support 3rd standard Soft-switch
System Configuration Filtrate CDR Filtrate invalid CDR
Multiple currencies System vendor and agents support different currency types
Multiple accounting periods System vendor and agents support different account periods
Add/delete account type
Add business type Flexible easy to support 3rd soft-switch system
Billing Plan Prefix Apply different prefix group for different area
holiday Different discount in different holiday
business fee Flexibly set business fee for different agents
batch Tariff input Import tariffs through file
Free number
Late fee set late fee for every users
Agent Multi levels of agents
Multi levels of balances Balance between superior agent and subordinate agent
Frozen agents Make agent invalid
Realtime/Quasi-realtime billing and realtime/Quasi-realtime credit control If an agent is up to alarm threshold or exhaust credit, the agent will be alerted, frozened
Register users/distribute numbers/payment/query for subordinate agents or users
Calling Card Batch Generation Flexible password length
Realtime billing Alarm at threshold and reject service when balance is zero
Transfer balance Transfer One card’s balance to another one
Authentication modes PIN authentication or Account No and password authentication
Billing plan Billing plan for every cards
expiration Fixed expiration and activation expiration
Support area card/global card/destination limited card/call limited card Limited area access,Globe access,allowed appointed destination area,Limited appointed destination area,Need soft-switch support
Calling Card DTMF timeout configuration Set the first input interval of a DTMF,input interval between a DTMF and another oneNeed soft-switch support
Configuration of Retry times Set retry times,need soft-switch support
Self-service web Query balance/CDR, transfer balance, change password and so on through self-service web or IVR
Recharge Card Batch Generation
recharge method Administrator/IVR/self-service web
Business Configuration Web configuration Friendly configuration
Activate single/batch user(s) single/batch register users
Cancel single/batch user(s) single/batch cancel users
Activate/cancel agent
Phone bill、detailed bill、CDR query、export and print
Adjust account/recharge/payment
Invoice payment Invoice payment according to account period
Lock and unlock Account
Security Administer with Different level
Different privileges
Log records Operation log records and management
Data maintenance Data manual/auto backup etc.
Carrier Balance Flexibility balance by Billing Tools Balance between different Carrier
Phone Bar IAD billing IAD terminal billing for phone bar
2.System Capability
Item System Max Value(Related to hardware performance and network environment) Description
Max User Number 100,000 Max user number
CPS 20 Max call number per second
3.System platform
OS Red Hat Linux 9.0
  • 4 weeks later...
Specification
1.System Function
Video CODECs H.263
Call hold/Retrieve
Dial pattern
2. System capacity
3.System platform
System Architecture
Application Domains
l ITSP
l Virtual carrier
Specification
1.System Function
Free number
2.System Capability
3.System platform
