Mikrotik hAP ac убивает скорость через wifi
Добрый день, проблема со скоростью через wifi
От провайдера по тарифу 50мб и через провод до моего роутера выдает 50мб. А с wifi уже нет такой скорости.
Вот тесты скорости
Скрытый текст
Lan с моего Роутера 47-48мб
2.4G - скачка 17-20 загрузка в сеть 46-48
5G - скачка 13-18 загрузка в сеть 46-48
Конфиг :
# may/11/2018 08:22:45 by RouterOS 6.39.2
# software id = 1BIK-HANS
/interface bridge
add admin-mac=CC:2D:E0:2B:F7:8F auto-mac=no comment=defconf name=bridge
/interface ethernet
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode arp-timeout=1h band=2ghz-b/g/n basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
    channel-width=20/40mhz-eC country=russia disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain hw-protection-mode=rts-cts hw-retries=15 mode=ap-bridge ssid=XXX wireless-protocol=\
    802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode arp-timeout=1h band=5ghz-a/n/ac basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps channel-width=20/40/80mhz-Ceee country=\
    russia disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain hw-protection-mode=rts-cts mode=ap-bridge ssid=XXX_5G wireless-protocol=802.11 wps-mode=disabled
/interface wireless security-profiles
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys wpa-pre-shared-key=XXX wpa2-pre-shared-key=XXX
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
/ip pool
add name=dhcp ranges=192.168.1.10-192.168.1.254
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge lease-time=2h10m name=defconf
/system logging action
set 0 memory-lines=200
set 1 disk-lines-per-file=200
/interface bridge port
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan1
add bridge=bridge comment=defconf interface=wlan2
/ip address
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=192.168.1.0
add address=80.244.227.226/22 interface=ether1-wan network=80.244.224.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1-wan
/ip dhcp-server lease
add address=192.168.1.14 always-broadcast=yes client-id=1:4c:74:bf:98:41:42 mac-address=4C:74:BF:98:41:42 server=defconf
add address=192.168.1.63 client-id=1:30:cd:a7:c0:ca:3b mac-address=30:CD:A7:C0:CA:3B server=defconf
add address=192.168.1.64 client-id=1:84:25:19:11:ca:63 mac-address=84:25:19:11:CA:63 server=defconf
add address=192.168.1.47 client-id=1:c8:bc:c8:c2:3f:89 mac-address=C8:BC:C8:C2:3F:89 server=defconf
add address=192.168.1.32 client-id=1:b0:70:2d:c5:86:35 mac-address=B0:70:2D:C5:86:35 server=defconf
add address=192.168.1.200 client-id=1:d0:17:c2:a0:8:b0 comment="Asus AC1200G+" mac-address=D0:17:C2:A0:08:B0 server=defconf
add address=192.168.1.201 always-broadcast=yes client-id=1:98:de:d0:24:d7:f0 comment=REP_ASUS_350 mac-address=98:DE:D0:24:D7:F0 server=defconf
add address=192.168.1.65 always-broadcast=yes client-id=1:84:25:19:2e:2e:39 mac-address=84:25:19:2E:2E:39 server=defconf
add address=192.168.1.103 mac-address=00:26:BB:0F:68:2C use-src-mac=yes
add address=192.168.1.202 client-id=1:9a:de:0:6:65:da comment="Video reg" mac-address=9A:DE:00:06:65:DA server=defconf
add address=192.168.1.204 comment="Control Office" mac-address=9A:DE:00:10:26:FC server=defconf use-src-mac=yes
/ip dhcp-server network
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
/ip dns
set allow-remote-requests=yes servers=87.241.223.68,81.17.2.171
/ip dns static
add address=192.168.1.1 name=router
/ip firewall filter
add action=accept chain=input protocol=icmp
add action=accept chain=forward protocol=icmp
add action=accept chain=input connection-state=established
add action=accept chain=forward connection-state=established
add action=accept chain=input connection-state=related
add action=accept chain=forward connection-state=related
add action=accept chain=input in-interface=!ether1-wan src-address=192.168.1.0/24
add action=accept chain=forward dst-port=45000 in-interface=ether1-wan protocol=tcp
add action=drop chain=input connection-state=invalid
add action=drop chain=forward connection-state=invalid
add action=drop chain=input in-interface=ether1-wan
add action=accept chain=forward in-interface=!ether1-wan out-interface=ether1-wan
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1-wan
add action=dst-nat chain=dstnat comment="probros porta na lan" dst-port=45000 in-interface=ether1-wan protocol=tcp to-addresses=192.168.1.50 to-ports=45000
/ip route
add distance=1 gateway=80.244.227.225
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=Europe/Moscow
/tool mac-server
set [ find default=yes ] disabled=yes
add interface=ether2-master
add interface=sfp1
add interface=wlan2
add interface=wlan1
/tool mac-server mac-winbox
add interface=sfp1
add interface=wlan2
add interface=wlan1
Как исправить ?
Сменить канал? Сбросить радио в дефолт?
Если не поможет, значит проблема в другом, у меня, на этой ветке, все устройства заработали нормально.
7 часов назад, GSHome сказал:
arp-timeout=1h
Смысл?
band=2ghz-b/g/n
У вас что, есть копролиты, требующие b/g? Если да, то ничего приличного вы с wifi не получите в принципе, а если нет - то 2ghz-onlyn ваше всио.
Зачем переводить Data Rates в configured если оставлена поддержка всех базовых скоростей?
Зачем? К офисному роутеру коннектятся удаленные узлы с узконаправленными антеннами?
hw-retries=15
Вы точно понимаете, что меняете и зачем? Для работы внутри помещений обычно либо оставляют дефолт либо снижают до 5, к 15-й попытке передачи актуальность информации в кадре исчезнет и возможно не раз.
@GSHome
С какого девайса и чем проверяете скорость ? Данные основные регистрации девайса на точке во время download теста покажите (сигнал, SNR, CCQ, Tx / Rx rate).
@andryas
hAP AC - mipsbe, а не smips
и не нужна ему RC, он нормально на багфиксе живет
