SNR-S2985G-24T#sh ver
  SNR-S2985G-24T Device, Compiled on Jan 13 21:16:58 2016
  sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
  CPU Mac f8:f0:82:77:04:b3
  Vlan MAC f8:f0:82:77:04:b2
  SoftWare Version 7.0.3.5(R0241.0085)
  BootRom Version 7.2.25
  HardWare Version 1.0.2
  CPLD Version N/A
  Serial No.:SW067210H310000029
  Copyright (C) 2016 NAG LLC
  All rights reserved
  Last reboot is warm reset.
  Uptime is 10 weeks, 6 days, 6 hours, 10 minutes
SNR-S2985G-24T#sh ven
NAME            LEN          VALUE
SwitchName      14           SNR-S2985G-24T
VersionPre      0
VendNameEn      7            NAG LLC
VendNameBr      3            NAG
VendWWW         18           http://shop.nag.ru
VendLocate      49           Building 57/2,Predelnaya st, Ekaterinburg, Russia
CopyRight       26           Copyright (C) 2016 NAG LLC
VendContact     14           support@nag.ru
WebLogo         4530
WebLogin        11383
WebFacebd       12701
WebBG           13495
WebLang         2            en
VendorOid       19           1.3.6.1.4.1.40418.7
DeviceOid       22           1.3.6.1.4.1.40418.7.19
KeyNeed         4            0
BaseMac         6            f8 f0 82 10 00 00
CliStyle        3            0
HsrpNeed        4            0
DevType(ID)     4            281
ChassisCard     0
FileVersion     8            10.13.51
IMGPrefix       0
RomPrefix       0
HardWarePre     0
Prompt          0
UserName        5            admin
PassWord        5            admin
ManageIP        4            192.168.1.1
NeedLicense     6            NO
SNR-S2985G-24T# show logging buffer level critical
Current messages in SDRAM:1836
1436 %Feb 14 21:54:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
1435 %Feb 14 21:54:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
1402 %Feb 14 01:10:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
1401 %Feb 14 01:10:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
1285 %Feb 06 21:24:33 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
1284 %Feb 06 21:24:33 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
973 %Jan 18 02:10:13 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
972 %Jan 18 02:10:13 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
905 %Jan 02 02:17:26 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
904 %Jan 02 02:17:26 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
870 %Jan 01 07:09:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
869 %Jan 01 07:09:58 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
814 %Jan 01 01:59:10 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
813 %Jan 01 01:59:10 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
790 %Jan 01 00:01:24 2006 <critical> DEFAULT[zIMI]:System warm restart...
719 %Jan 01 00:00:00 2006 <critical> DEFAULT[tUsrRoot]:switch is booting, software version:SNR-S2985G-24T_7.0.3.5(R0241.0085)...
718 %Feb 13 00:32:31 2006 <critical> DEFAULT[zIMI]:System will be rebooted, reason: reload by CLI
528 %Jan 31 20:46:14 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2093: FS_DEV_UNLOCK Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
527 %Jan 31 20:46:14 2006 <critical> MODULE_UTILS_FILESYSTEM[zIMI]:fs_write_file 2075: FS_DEV_LOCK_NO_WAIT Slot: 1 dev_name:flash: file_name:flash:/startup.cfg
Сегодня обратил внимание что мигает лампочка Diag и в логах вижу вот это.
Что это за ошибки, как диагностировать откуда они и как исправить?
Edited by VecH
