Коллеги нужна помощь!
Необходимо запустить martini VPLS в VRF (для изоляции основной таблицы маршрутизации от маршрутов используемых для VPLS)
VPLS instant естественно нечего не знает о VRF и VPLS не работает.
Возможно ли реализовать такую схему? Или это не возможно в Juniper (
Пока эксперементирую в лабе на EVA
Instance: vpls1
  VPLS-id: 800
    Neighbor                  Type  St     Time last up          # Up trans
    1.1.1.1(vpls-id 800)      rmt   OL
    3.3.3.3(vpls-id 800)      rmt   OL
routing-instances {
    vpls {
        instance-type vrf;
        interface ge-0/0/1.0;
        interface ge-0/0/2.0;
        interface lo0.0;
        route-distinguisher 65000:100;
        vrf-import Development-Import;
        vrf-export Development-Export;
        protocols {
            ospf {
                area 0.0.0.0 {
                    interface lo0.0 {
                        passive;
            ldp {
                interface lo0.0;
    vpls1 {
        instance-type vpls;
        interface ge-0/0/0.0;
        interface ge-0/0/0.801;
        protocols {
            vpls {
                no-tunnel-services;
                vpls-id 800;
                neighbor 1.1.1.1;
                neighbor 3.3.3.3;
root> show route
vpls.inet.0: 10 destinations, 12 routes (10 active, 0 holddown, 0 hidden)
+ = Active Route, - = Last Active, * = Both
1.1.1.1/32         *[LDP/9] 00:52:16, metric 1
                    > to 10.0.3.1 via ge-0/0/1.0, Push 299776
                    [OSPF/10] 00:52:20, metric 6
2.2.2.2/32         *[Direct/0] 00:53:10
                    > via lo0.0
4.4.4.4/32         *[LDP/9] 00:52:16, metric 1
                    [OSPF/10] 00:52:20, metric 1
10.0.0.0/24        *[OSPF/10] 00:52:20, metric 6
10.0.1.0/24        *[OSPF/10] 00:52:20, metric 7
10.0.2.0/24        *[Direct/0] 00:53:10
                    > via ge-0/0/2.0
10.0.2.1/32        *[Local/0] 00:53:10
                      Local via ge-0/0/2.0
10.0.3.0/24        *[Direct/0] 00:53:10
                    > via ge-0/0/1.0
10.0.3.2/32        *[Local/0] 00:53:10
                      Local via ge-0/0/1.0
224.0.0.5/32       *[OSPF/10] 00:53:11, metric 1
                      MultiRecv
vpls.inet.3: 2 destinations, 2 routes (2 active, 0 holddown, 0 hidden)
mpls.0: 6 destinations, 6 routes (6 active, 0 holddown, 0 hidden)
0                  *[MPLS/0] 2d 22:07:15, metric 1
                      to table inet.0
0(S=0)             *[MPLS/0] 00:53:11, metric 1
                      to table mpls.0
1                  *[MPLS/0] 2d 22:07:15, metric 1
                      Receive
2                  *[MPLS/0] 2d 22:07:15, metric 1
                      to table inet6.0
2(S=0)             *[MPLS/0] 00:53:11, metric 1
                      to table mpls.0
13                 *[MPLS/0] 2d 22:07:15, metric 1
                      Receive
vpls.mpls.0: 3 destinations, 3 routes (3 active, 0 holddown, 0 hidden)
299824             *[LDP/9] 00:52:16, metric 1
                    > to 10.0.3.1 via ge-0/0/1.0, Pop
299824(S=0)        *[LDP/9] 00:52:16, metric 1
299840             *[LDP/9] 00:52:16, metric 1
                    > to 10.0.3.1 via ge-0/0/1.0, Swap 299776
l2circuit.0: 2 destinations, 2 routes (0 active, 0 holddown, 2 hidden)
vpls.l2circuit.0: 1 destinations, 1 routes (1 active, 0 holddown, 0 hidden)
1.1.1.1:NoCtrlWord:5:800:Remote/96
                   *[LDP/9] 00:52:16
                      Discard
Вангую, что @Davion хочет, чтоб для поднятия PW использовалась информация не из inet.3, а с vpls.inet.3, или как-то так.
Не уверен в возможности подобного (это же еще и 3 метки пушить надо, нет?), но можно попробовать покрутить routing-options resolution rib l2circuit.0
29 минут назад, Mystray сказал:
В ветке 16.1 появилось import-labeled-routes, но стенд еще не собрал.
