mav Posted July 19, 2005 Posted July 19, 2005 Как получить статус oper в UnrealIRC? Пробую так: /oper login password выдает: No O-lines for your host В конфиге: oper login { class clients; from { userhost 192.local.net; }; password "password"; flags { netadmin; admin; netadmin; can_globalnotice; global; }; }; Вставить ник Quote
Guest Posted July 21, 2005 Posted July 21, 2005 в конфиге бред должно быть примерно так oper MY_NAME { from { userhost *@YOUr_HOST; (Или *@192.168.xx.xx;) }; password "my_pass"; class opers; level admin; flags { can_die; can_restart; can_addline; ..... }; }; Вставить ник Quote
mav Posted July 22, 2005 Author Posted July 22, 2005 Делал по ману. /* * NEW: oper {} * OLD: O:Line * Defines an IRC Operator * IRC operators are there to keep sanity to the server and usually keep it * maintained and connected to the network. * The syntax is as follows: * oper (login) { * class (class to put them in, if different from I, moves them to new * class); * from { * userhost (ident@host); * userhost (ident@host); * }; * flags * { * (flags here*); * }; * OR * flags "old type flags, like OAaRD"; * }; */ Вставить ник Quote
Guest Posted July 22, 2005 Posted July 22, 2005 Ну и я про тож! hint: clients != opers а это userhost 192.local.net; а это я вообще не понимаю Вставить ник Quote
mav Posted July 23, 2005 Author Posted July 23, 2005 Ну и я про тож!hint: clients != opers а это userhost 192.local.net; а это я вообще не понимаю все равно, поменял уже oper login { class opers; from { userhost *@*; }; password "password"; flags { netadmin; can_globalnotice; global; }; }; Добавил в конфиг группу opers. Но при выполнение команды: /op login password, выдает: +ooo No such nick/channel Вставить ник Quote
Guest Posted October 14, 2005 Posted October 14, 2005 oper NICK { class clients; from { userhost * ; }; password "YOUR_PASS"; flags { netadmin; can_zline; can_gzline; can_gkline; global; }; }; Вставить ник Quote
