сейчас линк 9 км, прямая видимость, зона Френеля по нижней границе идет над лесом.
Сторона А:
MikroTik Antenna MTAD-5G-30D3 + MikroTik BaseBox 5,
Сторона Б:
Jirous JRC-24 EX MIMO RP-SMA-Female 5GHz + 911G-5HPnD + Jirous GentleBox JR-200 корпус
сейчас: прием на стороне А/Б -50/-50 при мощности -17/-19. ccq 100%, канальная 243мбит, реальная 70..100мбит при nstreme.
Всё бы хорошо, но линк падает несколько раз, а то и десятков раз в сутки.
Лог на Стороне А
00:41:36 wireless,info D4:CA:6D:FF:15:A1@wlan3: disconnected, too many poll timeou
ts
00:41:37 wireless,info D4:CA:6D:FF:15:A1@wlan3: connected, wants WDS
11:45:45 wireless,info D4:CA:6D:FF:15:A1@wlan3: disconnected, too many poll timeou
ts
11:45:46 wireless,info D4:CA:6D:FF:15:A1@wlan3: connected, wants WDS
11:45:46 wireless,info D4:CA:6D:FF:15:A1@wlan3: disconnected, extensive data loss
11:45:48 wireless,info D4:CA:6D:FF:15:A1@wlan3: connected, wants WDS
13:43:26 wireless,info D4:CA:6D:FF:15:A1@wlan3: disconnected, too many poll timeou
ts
13:43:27 wireless,info D4:CA:6D:FF:15:A1@wlan3: connected, wants WDS
14:04:49 wireless,info D4:CA:6D:FF:15:A1@wlan3: disconnected, extensive data loss
14:04:49 wireless,info wlan3: data from unknown device D4:CA:6D:FF:15:A1, sent dea
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
uth
14:04:49 wireless,info D4:CA:6D:FF:15:A1@wlan3: connected, wants WDS
Лог стороны Б:
00:41:27 wireless,info E4:8D:8C:F5:CF:0B@wlan1: lost connection, not polled for to
o long
00:41:37 wireless,info E4:8D:8C:F5:CF:0B@wlan1 established connection on 5780000,
SSID S-K1
11:45:37 wireless,info E4:8D:8C:F5:CF:0B@wlan1: lost connection, not polled for to
o long
11:45:46 wireless,info E4:8D:8C:F5:CF:0B@wlan1 established connection on 5780000,
SSID S-K1
11:45:48 wireless,info E4:8D:8C:F5:CF:0B@wlan1: lost connection, not polled for to
o long
11:45:48 wireless,info E4:8D:8C:F5:CF:0B@wlan1 established connection on 5780000,
SSID S-K1
13:43:18 wireless,info E4:8D:8C:F5:CF:0B@wlan1: lost connection, not polled for to
o long
13:43:27 wireless,info E4:8D:8C:F5:CF:0B@wlan1 established connection on 5780000,
SSID S-K1
14:04:36 system,info,account user admin logged in from 192.168.127.128 via winbox
14:04:49 wireless,info E4:8D:8C:F5:CF:0B@wlan1: lost connection, received deauth:
class 2 frame received (6)
14:04:49 wireless,info E4:8D:8C:F5:CF:0B@wlan1 established connection on 5780000,
SSID S-K1
линк рвется на несколько секунд, бывает на минуты, потом коннектится как ни в чем ни бывало. Раньше сторона А была на другом объекте, но расстояние было тоже, азимут отличался на 1-2 град, и были с обеих сторон джуриусы-антенны + RB911. Линк тоже падал, но нет данных так же часто или реже.
Повторную юстировку делали, витуха сейчас категории 6 sftp, частота разрешенная, без помех. От времени года частота отвалов не зависит. Озер нет.
Что можете посоветовать?
2 часа назад, devd1 сказал:
Не помню, были ли отвалы на nv2, но реальная скорость была неприемлемая.
прикол в том что весь мой опыт показывает что именно на nv2 линки и стабильней и быстрее....ну вам там виднее,  вы спросили совета я лично ответил, не более
В 20.03.2018 в 12:33, devd1 сказал:
я б wds выключил... и перевел на nv2.  Как вариант - либо помеха есть ( можно посмотреть микротовским spectral-scan на обоих сторонах, но не забыть что линк на это время пропадет :) ) либо интерференция с отраженкой - ищите металлическую крышу в пролете..
Это типичная микротиковская проблема у которой нет общего решения, как вариант поменяйте настройки Framer Policy : none или dynamic size.
