 Именно. только дропы и ерроры там не особо посмотришь, у меня по крайней мере на брокаде. sho ip bgp summ - дает норм инфу о количестве маршрутов, полученных, отвергнутых и посланных, ну и аптайм бгп-сессии. Далее - логи и статистика интерфейсов.
У меня  конечно не киска, но я не заметил особой разницы у киски, квагги и брокады в поведении, за исключением мелочей типа синтаксиса, пробовал всех. Киска для фв у меня не нашлась, квагге плохело от падений-переподьемов аплинков, а брокада - железная, ей всё пох. Сейчас 5 сессий сконфигурено, 4 активны одна погашена. Все для приема фв, прожевывает без траблем.
BGP neighbor is *.*.*.22,  vrf inet,  remote AS 65350, external link
  BGP version 4, remote router ID *.*.*.134
  BGP state = Established, up for 5d01h
  Last read 00:00:04, last write 00:00:01, hold time is 15, keepalive interval is 5 seconds
  Configured hold time is 15, keepalive interval is 5 seconds
  Minimum holdtime from neighbor is 0 seconds
  Neighbor sessions:
    1 active, is not multisession capable (disabled)
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received
    Address family IPv4 Unicast: advertised and received
    Enhanced Refresh Capability: advertised and received
    Multisession Capability:
    Stateful switchover support enabled: NO for session 1
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:               17          2
    Keepalives:         85278      85282
    Route Refresh:          0          0
    Total:              85296      85287
  Do log neighbor state changes (via global configuration)
  Default minimum time between advertisement runs is 0 seconds
  Address tracking is enabled, the RIB does have a route to *.*.*.22
  Route to peer address reachability Up: 1; Down: 0
    Last notification 5d01h
  Connections established 1; dropped 0
  Last reset never
  External BGP neighbor configured for connected checks (single-hop no-disable-connected-check)
  Interface associated: GigabitEthernet7 (peering address in same link)
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
  SSO is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: *.*.*.21, Local port: 179
Foreign host: *.*.*.22, Foreign port: 29426
Connection tableid (VRF): 1
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x1A08396F):
Timer          Starts    Wakeups            Next
Retrans         85286          0             0x0
TimeWait            0          0             0x0
AckHold         85284      82689             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger            0          0             0x0
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss:  641675313  snduna:  643296519  sndnxt:  643296519
irs: 3887038946  rcvnxt: 3888659485
sndwnd:  16194  scale:      0  maxrcvwnd:  16384
rcvwnd:  15396  scale:      0  delrcvwnd:    988
SRTT: 1000 ms, RTTO: 1003 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 1000 ms, ACK hold: 200 ms
uptime: 436636016 ms, Sent idletime: 1130 ms, Receive idletime: 928 ms
Status Flags: passive open, gen tcbs
Option Flags: VRF id set, nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 166761 (out of order: 0), with data: 85285, total data bytes: 1620538
Sent: 169088 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 85289, total data bytes: 1621205
 Packets received in fast path: 0, fast processed: 0, slow path: 0
 fast lock acquisition failures: 0, slow path: 0
TCP Semaphore      0x7F0767815D80  FREE
Все тут есть...
