Не могу завести SIP-10 в комплектации с ESP-40 и RP-2, при загрузке получаю сообщение:
%CMRP-3-UNSUPPORTED_FRU:  R0/0: cmand:  ASR1000-SIP10 in slot 0 is not supported with this image and so it is disabled
Router#show platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       incompatible          00:16:14
R0        ASR1000-RP2         ok, active            00:16:14
F0        ASR1000-ESP40       ok, active            00:16:14
P0        ASR1006-PWR-AC      ok                    00:15:18
P1        ASR1006-PWR-AC      ps, fail              00:15:17
Slot      CPLD Version        Firmware Version
0         N/A                 N/A
R0        14111801            16.3(2r)
F0        1003190E            16.3(2r)
Читаю документ:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/cpld/hw_fp_upgrade.html#pgfId-1074550
Делаю:
upgrade hw-programmable cpld filename harddisk:asr1000-hw-programmables.16.08.01.SPA.pkg 0
И вижу в журнале:
И при этом:
Router#show upgrade hw-programmable progress
Upgrade hw-programmable progress
Slot              Hw-programmable device    Upgrade status
0                 CPLD                      in progress
И процесс upgrade никогда не завершается. Как завести SIP-10?
