Привет всем!
Столкнулся с проблемой, не работает policy-options на import маршрутов в ospf.
Juniper MX80, JUNOS 12.3R4.6
routing-instances {
    NextOne {
        instance-type vrf;
        interface xe-0/0/0.4015;
        interface xe-0/0/0.4019;
        protocols {
            ospf {
                export ospf-vrf-NextOne-export;
                import ospf-vrf-NextOne-import;
                area 0.0.0.0 {
                    interface xe-0/0/0.4015 {
                        metric 150;
                        authentication {
                            md5 19 key "***"; ## SECRET-DATA
                    interface xe-0/0/0.4019 {
                        metric 150;
                        authentication {
                            md5 20 key "***"; ## SECRET-DATA
policy-options {
    policy-statement ospf-vrf-NextOne-import {
        term 1 {
            from {
                protocol ospf2;
                route-filter 83.167.66.225/32 exact;
                route-filter 83.167.66.226/32 exact;
                route-filter 10.100.101.118/32 exact;
                route-filter 83.167.66.1/32 exact;
                route-filter 83.167.66.5/32 exact;
                route-filter 83.167.66.9/32 exact;
                route-filter 83.167.66.10/32 exact;
                route-filter 83.167.66.16/32 exact;
                route-filter 83.167.66.19/32 exact;
                route-filter 83.167.72.1/32 exact;
                route-filter 83.167.81.1/32 exact;
                route-filter 83.167.88.1/32 exact;
                route-filter 10.100.101.44/30 orlonger;
                route-filter 83.167.65.0/24 orlonger;
                route-filter 83.167.66.160/29 orlonger;
                route-filter 83.167.66.164/30 orlonger;
            then accept;
        term 2 {
            then reject;
Но в NextOne.inet.0 попадают маршруты, которые не должны туда попадать
Скрытый текст
> show route table NextOne.inet.0 protocol ospf
NextOne.inet.0: 3440 destinations, 3475 routes (3440 active, 0 holddown, 0 hidden)
+ = Active Route, - = Last Active, * = Both
10.100.101.44/30   *[OSPF/150] 01:20:10, metric 120, tag 0
                    > to 83.167.66.250 via xe-0/0/0.4019
                      to 83.167.66.238 via xe-0/0/0.4015
10.100.101.118/32  *[OSPF/150] 01:20:10, metric 120, tag 0
                    > to 83.167.66.238 via xe-0/0/0.4015
10.222.255.52/30   *[OSPF/10] 6d 03:16:52, metric 161
10.222.255.56/30   *[OSPF/10] 6d 03:16:52, metric 162
83.167.65.0/24     *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.65.40/29    *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.65.52/30    *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.65.56/30    *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.65.60/30    *[OSPF/150] 01:20:10, metric 20, tag 0
83.167.66.1/32     *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.5/32     *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.8/32     *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.9/32     *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.10/32    *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.11/32    *[OSPF/10] 6d 03:16:52, metric 162
83.167.66.12/32    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.13/32    *[OSPF/10] 6d 03:16:52, metric 162
83.167.66.16/32    *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.22/32    *[OSPF/10] 6d 03:16:52, metric 163
83.167.66.32/30    *[OSPF/10] 6d 03:33:04, metric 160
83.167.66.36/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.40/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.44/30    *[OSPF/10] 2d 00:26:41, metric 162
83.167.66.52/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.64/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.68/30    *[OSPF/10] 6d 03:33:04, metric 200
83.167.66.72/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.80/30    *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.84/30    *[OSPF/10] 6d 03:16:52, metric 162
83.167.66.96/30    *[OSPF/10] 6d 03:33:04, metric 200
83.167.66.100/30   *[OSPF/10] 6d 03:16:52, metric 200
83.167.66.104/30   *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.108/30   *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.120/30   *[OSPF/10] 6d 03:33:04, metric 200
83.167.66.140/30   *[OSPF/10] 6d 03:16:52, metric 160
83.167.66.144/29   *[OSPF/10] 6d 03:16:52, metric 162
83.167.66.152/30   *[OSPF/10] 6d 03:16:52, metric 200
83.167.66.156/30   *[OSPF/10] 6d 03:16:52, metric 200
83.167.66.160/30   *[OSPF/10] 6d 03:16:52, metric 162
83.167.66.188/30   *[OSPF/10] 6d 03:16:52, metric 161
83.167.66.225/32   *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.226/32   *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.66.236/31   *[OSPF/10] 6d 03:33:04, metric 180
83.167.66.244/31   *[OSPF/10] 6d 03:07:28, metric 300
83.167.66.246/31   *[OSPF/10] 6d 01:28:25, metric 300
83.167.66.248/31   *[OSPF/10] 6d 03:16:52, metric 180
83.167.66.252/31   *[OSPF/10] 6d 03:03:38, metric 300
83.167.66.254/31   *[OSPF/10] 6d 02:58:33, metric 300
83.167.67.4/30     *[OSPF/10] 6d 03:16:52, metric 160
83.167.72.1/32     *[OSPF/150] 01:20:10, metric 120, tag 0
83.167.88.1/32     *[OSPF/150] 01:20:10, metric 120, tag 0
172.16.0.160/30    *[OSPF/10] 6d 03:16:52, metric 161
172.16.0.164/30    *[OSPF/10] 6d 03:16:52, metric 161
172.16.0.172/30    *[OSPF/10] 6d 03:16:52, metric 161
172.16.0.180/30    *[OSPF/10] 6d 03:16:52, metric 161
172.16.1.32/30     *[OSPF/10] 6d 03:16:52, metric 161
172.16.6.4/30      *[OSPF/10] 6d 03:16:52, metric 162
172.16.6.16/30     *[OSPF/10] 6d 03:16:52, metric 162
172.16.6.248/29    *[OSPF/10] 6d 03:16:52, metric 161
172.20.49.64/27    *[OSPF/10] 6d 03:16:52, metric 161
224.0.0.5/32       *[OSPF/10] 6d 03:43:55, metric 1
                      MultiRecv
Пробовал менять policy:
policy-options {
        term 2 {
            then reject;
Однако, в NextOne.inet.0 попадают все те же маршруты.
Ребята-джуноводы, помогите, пожалуйста, советом. Как отфильтровать import ospf маршруты?
2 hours ago, qelso said:
Привет всем!
routing-instances {
    NextOne {
        instance-type vrf;
        protocols {
            ospf {
                area 0.0.0.0 {
                        metric 150;
                        authentication {
                        metric 150;
                        authentication {
policy-options {
        term 1 {
            from {
                protocol ospf2;
            then accept;
        term 2 {
            then reject;
  Reveal hidden contents
                      MultiRecv
policy-options {
        term 2 {
            then reject;
А что вы фильтруете ? Вы учли что
The filtering is done only on external routes in OSPF. The intra-area and interarea routes are not considered for filtering.
@vvertexx , верное замечание. Сразу не обратил внимание, LSA5 фильтруются. Помимо разрешенных в policy-options маршрутов, прилетают LSA 3, которые согласно policy-options, не должны попадать в таблицу.
Видимо, @orlik прав:
Коллеги подсказывают:
"you are correct in that you cannot filter intra-area routes with the ospf import statement. However, you could configure the routes as martians under routing-options to prevent them from being installed in the routing table."
Но что-то не хочется городить.
Есть идеи, помимо the routes as martians? Или смириться?
На крайний случай можно через
 routing-options forwarding-table export <policy>
предотвратить установку конкретных роутов в pfe. Но зачем?
+1 полностью поддерживаю , если очень мешают можно не инставить в фиб
@Mystray@orlik, чтобы клиенты из этого vrf могли ходить только на разрешенные хосты. Решили пока забить, т.к. ничего страшного не должно произойти. Но за наводку спасибо, буду иметь ввиду.
