Macro Posted January 23, 2018 Posted January 23, 2018 (edited) Добрый день Последний Дебиан 9.3, сервер HP Proliant DL360 сетевые 4 шт Broadcom Limited NetXtreme II BCM5709 Gigabit Ethernet (rev 20) объединены в bond интерфейс. Проблема в том, что трафик не балансится на все интерфейсы и выше 1Гбит/с не поднимается. root@nat:/home/tuxper# ethtool bond0 Settings for bond0: Supported ports: [ ] Supported link modes: Not reported Supported pause frame use: No Supports auto-negotiation: No Advertised link modes: Not reported Advertised pause frame use: No Advertised auto-negotiation: No Speed: 4000Mb/s Duplex: Full Port: Other PHYAD: 0 Transceiver: internal Auto-negotiation: off Link detected: yes Конфиг интерфейсов /etc/network/interfaces auto bond0 iface bond0 inet manual bond-mode 4 bond-miimon 100 bond-downdelay 200 bond-updelay 200 slaves enp2s0f0 enp2s0f1 enp3s0f0 enp3s0f1 auto vlanXXX iface vlanXXX inet static address xx.xx.xx.2/24 gateway xx.xx.xx.1 dns-nameservers xx.xx.xx.249 vlan-raw-device bond0 В /proc Скрытый текст root@nat:/home/tuxper# cat /proc/net/bonding/bond0 Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) Bonding Mode: IEEE 802.3ad Dynamic link aggregation Transmit Hash Policy: layer2 (0) MII Status: up MII Polling Interval (ms): 100 Up Delay (ms): 200 Down Delay (ms): 200 802.3ad info LACP rate: slow Min links: 0 Aggregator selection policy (ad_select): stable System priority: 65535 System MAC address: 00:25:b3:de:9c:02 Active Aggregator Info: Aggregator ID: 2 Number of ports: 4 Actor Key: 9 Partner Key: 5 Partner Mac Address: 44:e4:d9:9a:cc:00 Slave Interface: enp2s0f0 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:25:b3:de:9c:02 Slave queue ID: 0 Aggregator ID: 2 Actor Churn State: none Partner Churn State: none Actor Churned Count: 0 Partner Churned Count: 0 details actor lacp pdu: system priority: 65535 system mac address: 00:25:b3:de:9c:02 port key: 9 port priority: 255 port number: 1 port state: 61 details partner lacp pdu: system priority: 32768 system mac address: 44:e4:d9:9a:cc:00 oper key: 5 port priority: 32768 port number: 267 port state: 61 Slave Interface: enp2s0f1 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:25:b3:de:9c:04 Slave queue ID: 0 Aggregator ID: 2 Actor Churn State: none Partner Churn State: none Actor Churned Count: 0 Partner Churned Count: 0 details actor lacp pdu: system priority: 65535 system mac address: 00:25:b3:de:9c:02 port key: 9 port priority: 255 port number: 2 port state: 61 details partner lacp pdu: system priority: 32768 system mac address: 44:e4:d9:9a:cc:00 oper key: 5 port priority: 32768 port number: 265 port state: 61 Slave Interface: enp3s0f0 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:25:b3:de:9c:06 Slave queue ID: 0 Aggregator ID: 2 Actor Churn State: none Partner Churn State: none Actor Churned Count: 0 Partner Churned Count: 0 details actor lacp pdu: system priority: 65535 system mac address: 00:25:b3:de:9c:02 port key: 9 port priority: 255 port number: 3 port state: 61 details partner lacp pdu: system priority: 32768 system mac address: 44:e4:d9:9a:cc:00 oper key: 5 port priority: 32768 port number: 268 port state: 61 Slave Interface: enp3s0f1 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:25:b3:de:9c:08 Slave queue ID: 0 Aggregator ID: 2 Actor Churn State: none Partner Churn State: none Actor Churned Count: 0 Partner Churned Count: 0 details actor lacp pdu: system priority: 65535 system mac address: 00:25:b3:de:9c:02 port key: 9 port priority: 255 port number: 4 port state: 61 details partner lacp pdu: system priority: 32768 system mac address: 44:e4:d9:9a:cc:00 oper key: 5 port priority: 32768 port number: 269 port state: 61 На свиче порт-ченнел поднялся, трафик ходит. Меряю iperf3 с 3-х внешних серверов с разными белыми IP трафик выше 1Гбит/с с 1 интерфейса не поднимается. Edited January 23, 2018 by Macro Вставить ник Quote
arhead Posted January 23, 2018 Posted January 23, 2018 Debian 8.4 Настройка такая iface bond1 inet static address 0.0.0.0 bond_mode 4 bond_miimon 100 bond-slaves eth2 eth3 bond-xmit_hash_policy layer2+3 auto bond1 На свиче LACP вроде балансируется. Какой свич? Вставить ник Quote
zhenya` Posted January 23, 2018 Posted January 23, 2018 bond-xmit_hash_policy layer2+3. Тут и ответ. Вставить ник Quote
NiTr0 Posted January 23, 2018 Posted January 23, 2018 20 минут назад, zhenya` сказал: bond-xmit_hash_policy layer2+3 вообще-то у ТСа вообще Transmit Hash Policy: layer2 (0) Вставить ник Quote
Macro Posted January 23, 2018 Author Posted January 23, 2018 (edited) Всем спасибо! Запилил bond-xmit-hash-policy layer2+3 Теперь трафик балансится, но почему то только между 3 интерфейсами - при 4-х в апе, 1 интерфейс всегда простаивает. На сервере алиасами 253 адреса, подключаюсь iperf'ом c 4 серверов на разные IP сервера с bond интерфейсом. lo enp2s0f0 enp2s0f1 enp3s0f0 enp3s0f1 bond0 vlanXXX vlanXXX KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out KB/s in KB/s out 0.00 0.00 1531.25 0.41 135.27 113738.2 0.21 118715.7 1282.13 119864.7 2948.86 352319.0 2110.32 336947.7 0.00 0.00 0.00 0.00 1527.67 0.98 158.84 114270.7 0.06 118605.5 1330.87 120255.2 3017.44 353132.4 2162.00 337747.0 0.00 0.00 0.00 0.00 1540.88 0.41 164.47 114686.2 0.00 119001.4 1282.66 120380.9 2988.00 354068.9 2118.49 332546.5 0.00 0.00 0.00 0.00 1543.07 0.34 171.20 109944.7 0.25 118620.5 1308.14 120087.4 3022.65 348652.9 2138.58 337935.2 0.00 0.00 0.00 0.00 1530.38 0.92 146.98 115148.3 0.13 118874.4 1315.96 119794.9 2993.45 353818.5 2144.58 336750.9 0.00 0.00 0.00 0.00 1532.87 0.40 169.75 114055.5 0.00 118279.2 1310.15 120255.1 3012.78 352590.3 2143.01 336750.8 0.00 0.00 0.00 0.00 1539.45 0.34 156.05 113748.0 0.30 118565.8 1298.05 120204.4 2993.86 352518.5 2141.35 337252.5 0.00 0.00 0.00 0.00 1547.60 0.34 147.12 114134.3 0.06 119425.3 1319.14 120495.5 3013.92 354055.4 2118.26 335688.0 0.00 0.00 0.00 0.00 1514.03 0.34 169.75 113941.9 0.12 117176.5 1309.13 120214.5 2993.03 351333.2 2153.89 337442.1 0.00 0.00 0.00 0.00 1536.37 0.34 167.91 114879.1 0.37 118476.6 1293.97 120176.5 2998.63 353532.5 2144.30 336362.3 0.00 0.00 0.00 0.00 1551.12 0.28 166.79 113682.8 0.25 118797.2 1325.33 120182.8 3043.48 352663.0 2188.86 336419.8 0.00 0.00 0.00 0.00 1561.69 0.34 197.21 113148.0 0.12 118743.4 1304.46 120217.8 3063.48 352109.5 2158.40 337653.8 0.00 0.00 0.00 0.00 3082.64 0.34 161.30 114557.3 0.00 119294.6 1326.56 120515.2 4570.50 354367.5 2105.23 333260.7 0.00 0.00 Edited January 23, 2018 by Macro Вставить ник Quote
