Доброго времени суток!
Может кто сталкивался с подобным и сможет подсказать в чем проблема.
Есть несколько колец на DES-1210-28/ME/B2(Firmware: 6.07.B061) по 10-12 коммутаторов в каждом.
Конечные коммутаторы подключаются к двум cisco, на которых настроен l2protocol-tunneling. Т.е. с точки зрения stp, первый и последний коммутатор в кольце "думают", что подключены друг к другу.
Проблема в том, что по неопределенным причинам, в рандомные моменты времени начинается такое:
240    Jan  9 17:02:04:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
239    Jan  9 16:51:26:STP-6:Port state changed (forwarding) [( port: 27)]
238    Jan  9 16:51:26:STP-6:Port state changed (discarding) [( port: 27)]
237    Jan  9 16:50:56:STP-6:Port state changed (forwarding) [( port: 27)]
236    Jan  9 16:50:55:STP-6:Port state changed (discarding) [( port: 27)]
235    Jan  9 16:50:55:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
234    Jan  9 16:50:55:STP-6:New Root bridge selected(MAC: 9C-D6-43-E0-FB-D4 Priority :32768)
233    Jan  9 16:50:55:STP-6:New Root bridge selected(MAC: 9C-D6-43-E0-FE-44 Priority :32768)
232    Jan  9 16:50:49:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
231    Jan  9 16:50:42:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
230    Jan  9 16:50:30:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
229    Jan  9 16:50:07:STP-6:Port state changed (forwarding) [( port: 27)]
228    Jan  9 16:50:07:STP-6:Port state changed (discarding) [( port: 27)]
227    Jan  9 16:50:07:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
226    Jan  9 16:50:00:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
225    Jan  9 16:49:54:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
224    Jan  9 16:49:32:STP-6:Port state changed (forwarding) [( port: 27)]
223    Jan  9 16:49:32:STP-6:Port state changed (discarding) [( port: 27)]
222    Jan  9 16:49:32:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
221    Jan  9 16:49:32:STP-6:New Root bridge selected(MAC: 9C-D6-43-E0-FE-44 Priority :32768)
220    Jan  9 16:49:26:STP-6:New Root bridge selected(MAC: 9C-D6-43-E0-FE-44 Priority :32768)
219    Jan  9 16:49:19:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
218    Jan  9 16:49:07:STP-6:New Root bridge selected(MAC: E8-CC-18-CA-E5-A0 Priority :4096)
Проще говоря, коммутаторы начинают сходить с ума, руты, состояния портов начинают флапаться, часть коммутаторов может считать рутом один коммутатор, другая часть другой, третья - третий.
С точки зрения настройки stp уверен, что все ок:
# STP
enable stp
config stp version rstp
config stp priority 32768 instance_id 0
config stp txholdcount 6 maxage 20 hellotime 2 forwarddelay 15
config stp fbpdu enable
config stp ports 1-24 externalcost auto edge auto restricted_tcn true restricted_role true p2p auto state disable priority 128 fbpdu disable
config stp ports 25-28 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
Проблема имеет абсолютно случайный характер:
Время года на проблему не влияет, месяц все может работать нормально, а потом 2 месяца нестабильно. Помогают(и то не всегда)только какие-то пляски с бубном: перезагрузка всех коммутаторов в кольце, повторная прошивка на тот же софт. А может и само собой все пройти.
Я конечно понимаю, что проблема скорее всего в самом железе и софте, но мало ли, может быть кто-то сталкивался и смог найти иную причину.
