Прошу помочь!
Хочу запилить на FreeBSD 11 телефонию Asterisk 15.1.2.
Вроде бы, нет, не чего сложного, скачать и установить, но не в этот раз...
cd /home/jora_cornev
wget  http://downloads.asterisk.org/pub/telephony/asterisk/releases/asterisk-15.1.2.tar.gz
tar -zxvf asterisk-15.1.2.tar.gz
cd asterisk-15.1.2
./confirure
Спойлер
checking build system type... x86_64-unknown-freebsd11.1
checking host system type... x86_64-unknown-freebsd11.1
checking for gcc... no
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether char is unsigned... no
checking for uname... /usr/bin/uname
checking for g++... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking how to run the C++ preprocessor... c++ -E
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking for a BSD-compatible install... /usr/bin/install -c
checking whether ln -s works... yes
checking for ranlib... ranlib
checking for GNU make... gmake
checking for egrep... (cached) /usr/bin/grep -E
checking for strip... strip
checking for ar... ar
checking for bison... :
checking for cmp... /usr/bin/cmp
checking for cat... /bin/cat
checking for flex... /usr/bin/flex
checking for grep... (cached) /usr/bin/grep
checking for python... :
checking for find... /usr/bin/find
checking for compress... /usr/bin/compress
checking for basename... /usr/bin/basename
checking for dirname... /usr/bin/dirname
checking for sh... /bin/sh
checking for ln... /bin/ln
checking for doxygen... :
checking for dot... :
checking for wget... /usr/local/bin/wget
checking for curl... :
checking for rubber... :
checking for catdvi... :
checking for kpsewhich... :
checking for xmllint... :
checking for xmlstarlet... :
checking for bash... :
checking for git... :
checking for alembic... :
checking for bzip2... /usr/bin/bzip2
checking for tar... /usr/bin/tar
checking for patch... /usr/bin/patch
checking for sed... (cached) /usr/bin/sed
checking for nm... /usr/bin/nm
checking for ldconfig... /sbin/ldconfig
checking for sha1sum... /home/jora_cornev/asterisk-15.1.2/build_tools/sha1sum-sh
checking for openssl... /usr/bin/openssl
checking for bison that supports parse-param...
checking for soxmix... no
checking for md5... md5
checking for a sed that does not truncate output... (cached) /usr/bin/sed
checking whether cc is Clang... yes
checking whether Clang needs flag to prevent "argument unused" warning when linking with -pthread... no
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking whether more special flags are required for pthreads... no
checking for PTHREAD_PRIO_INHERIT... yes
checking for RAII support... checking for clang -fblocks... yes
checking for clang strsep/strcmp optimization... prevent use of __string2_1bptr_p / strsep / strcmp from bits/string2.h
checking for embedded pjproject (may have to download)... configuring
[pjproject]  Verifying /tmp/pjproject-2.6.tar.bz2
[pjproject]  Verify successful
[pjproject]  Unpacking /tmp/pjproject-2.6.tar.bz2
[pjproject]  Applying patches
1 out of 1 hunks failed--saving rejects to pjsip/src/pjsip/sip_transaction.c.rej
gmake: *** [Makefile:130: source/.unpacked] Error 1
failed
configure: Unable to configure third-party/pjproject
configure: error: Re-run the ./configure command with 'NOISY_BUILD=yes' appended to see error details.
Далее запустил ./configure NOISY_BUILD=yes
И если правильно понимаю лог находится в файле config.log
Спойлер
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by asterisk configure trunk, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure NOISY_BUILD=yes
## Platform. ##
hostname = ASTERISK-1
uname -m = amd64
uname -r = 11.1-RELEASE
uname -s = FreeBSD
uname -v = FreeBSD 11.1-RELEASE #0 r321309: Fri Jul 21 02:08:28 UTC 2017     root@releng2.nyi.freebsd.org:/usr/obj/usr/src/sys/GENERIC
/usr/bin/uname -p = amd64
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /sbin
PATH: /bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /root/bin
## Core tests. ##
configure:3633: checking build system type
configure:3647: result: x86_64-unknown-freebsd11.1
configure:3667: checking host system type
configure:3680: result: x86_64-unknown-freebsd11.1
configure:3809: checking for gcc
configure:3839: result: no
configure:3809: checking for cc
configure:3825: found /usr/bin/cc
configure:3836: result: cc
configure:3867: checking for C compiler version
configure:3876: cc --version >&5
FreeBSD clang version 4.0.0 (tags/RELEASE_400/final 297347) (based on LLVM 4.0.0)
Target: x86_64-unknown-freebsd11.1
Thread model: posix
InstalledDir: /usr/bin
configure:3887: $? = 0
configure:3876: cc -v >&5
Thread model: posix
configure:3876: cc -V >&5
cc: error: argument to '-V' is missing (expected 1 value)
cc: error: no input files
configure:3887: $? = 1
configure:3876: cc -qversion >&5
cc: error: unknown argument: '-qversion'
configure:3907: checking whether the C compiler works
configure:3929: cc    conftest.c  >&5
configure:3933: $? = 0
configure:3981: result: yes
configure:3984: checking for C compiler default output file name
configure:3986: result: a.out
configure:3992: checking for suffix of executables
configure:3999: cc -o conftest    conftest.c  >&5
configure:4003: $? = 0
configure:4025: result:
configure:4047: checking whether we are cross compiling
configure:4055: cc -o conftest    conftest.c  >&5
configure:4059: $? = 0
configure:4066: ./conftest
configure:4070: $? = 0
configure:4085: result: no
configure:4090: checking for suffix of object files
configure:4112: cc -c   conftest.c >&5
configure:4116: $? = 0
configure:4137: result: o
configure:4141: checking whether we are using the GNU C compiler
configure:4160: cc -c   conftest.c >&5
configure:4160: $? = 0
configure:4169: result: yes
configure:4178: checking whether cc accepts -g
configure:4198: cc -c -g  conftest.c >&5
configure:4198: $? = 0
configure:4239: result: yes
configure:4256: checking for cc option to accept ISO C89
configure:4319: cc  -c -g -O2  conftest.c >&5
configure:4319: $? = 0
configure:4332: result: none needed
configure:4359: checking how to run the C preprocessor
configure:4390: cc -E  conftest.c
configure:4390: $? = 0
configure:4404: cc -E  conftest.c
conftest.c:9:10: fatal error: 'ac_nonexistent.h' file not found
#include <ac_nonexistent.h>
1 error generated.
configure:4404: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "asterisk"
| #define PACKAGE_TARNAME "asterisk"
| #define PACKAGE_VERSION "trunk"
| #define PACKAGE_STRING "asterisk trunk"
| #define PACKAGE_BUGREPORT "https://issues.asterisk.org"
| #define PACKAGE_URL ""
| /* end confdefs.h.  */
configure:4429: result: cc -E
configure:4449: cc -E  conftest.c
configure:4449: $? = 0
configure:4463: cc -E  conftest.c
1 error generated.
configure:4463: $? = 1
| /* confdefs.h */
configure:4492: checking for grep that handles long lines and -e
configure:4550: result: /usr/bin/grep
configure:4555: checking for egrep
configure:4617: result: /usr/bin/grep -E
configure:4622: checking for ANSI C header files
configure:4642: cc -c -g -O2  conftest.c >&5
configure:4642: $? = 0
configure:4715: cc -o conftest -g -O2   conftest.c  >&5
configure:4715: $? = 0
configure:4715: ./conftest
configure:4726: result: yes
configure:4739: checking for sys/types.h
configure:4739: cc -c -g -O2  conftest.c >&5
configure:4739: $? = 0
configure:4739: result: yes
configure:4739: checking for sys/stat.h
configure:4739: checking for stdlib.h
configure:4739: checking for string.h
configure:4739: checking for memory.h
configure:4739: checking for strings.h
configure:4739: checking for inttypes.h
configure:4739: checking for stdint.h
configure:4739: checking for unistd.h
configure:4752: checking minix/config.h usability
configure:4752: cc -c -g -O2  conftest.c >&5
conftest.c:52:10: fatal error: 'minix/config.h' file not found
#include <minix/config.h>
1 error generated.
configure:4752: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
configure:4752: result: no
configure:4752: checking minix/config.h presence
configure:4752: cc -E  conftest.c
conftest.c:19:10: fatal error: 'minix/config.h' file not found
1 error generated.
| /* confdefs.h */
configure:4752: checking for minix/config.h
configure:4773: checking whether it is safe to define __EXTENSIONS__
configure:4791: cc -c -g -O2  conftest.c >&5
configure:4791: $? = 0
configure:4798: result: yes
configure:4968: checking whether char is unsigned
configure:4980: cc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4980: $? = 0
configure:4982: result: no
configure:5044: checking for uname
configure:5062: found /usr/bin/uname
configure:5074: result: /usr/bin/uname
configure:5537: checking for g++
configure:5567: result: no
configure:5537: checking for c++
configure:5553: found /usr/bin/c++
configure:5564: result: c++
configure:5591: checking for C++ compiler version
configure:5600: c++ --version >&5
Thread model: posix
configure:5611: $? = 0
configure:5600: c++ -v >&5
Thread model: posix
configure:5600: c++ -V >&5
c++: error: argument to '-V' is missing (expected 1 value)
c++: error: no input files
configure:5611: $? = 1
configure:5600: c++ -qversion >&5
c++: error: unknown argument: '-qversion'
configure:5615: checking whether we are using the GNU C++ compiler
configure:5634: c++ -c  -I/usr/local/include conftest.cpp >&5
configure:5634: $? = 0
configure:5643: result: yes
configure:5652: checking whether c++ accepts -g
configure:5672: c++ -c -g -I/usr/local/include conftest.cpp >&5
configure:5672: $? = 0
configure:5713: result: yes
configure:5741: checking how to run the C preprocessor
configure:5811: result: cc -E
configure:5831: cc -E -I/usr/local/include conftest.c
configure:5831: $? = 0
configure:5845: cc -E -I/usr/local/include conftest.c
conftest.c:24:10: fatal error: 'ac_nonexistent.h' file not found
1 error generated.
configure:5845: $? = 1
| /* confdefs.h */
| #define __EXTENSIONS__ 1
| #define _ALL_SOURCE 1
| #define _GNU_SOURCE 1
| #define _POSIX_PTHREAD_SEMANTICS 1
| #define _TANDEM_SOURCE 1
configure:5878: checking how to run the C++ preprocessor
configure:5905: c++ -E -I/usr/local/include conftest.cpp
configure:5905: $? = 0
configure:5919: c++ -E -I/usr/local/include conftest.cpp
conftest.cpp:24:10: fatal error: 'ac_nonexistent.h' file not found
1 error generated.
configure:5919: $? = 1
| /* confdefs.h */
configure:5944: result: c++ -E
configure:5964: c++ -E -I/usr/local/include conftest.cpp
configure:5964: $? = 0
configure:5978: c++ -E -I/usr/local/include conftest.cpp
1 error generated.
configure:5978: $? = 1
| /* confdefs.h */
configure:6008: checking for a sed that does not truncate output
configure:6072: result: /usr/bin/sed
configure:6077: checking for egrep
configure:6087: result: grep -E
configure:6103: checking for ld used by cc
configure:6170: result: /usr/bin/ld
configure:6177: checking if the linker (/usr/bin/ld) is GNU ld
configure:6192: result: yes
configure:6201: checking for gawk
configure:6231: result: no
configure:6201: checking for mawk
configure:6201: checking for nawk
configure:6217: found /usr/bin/nawk
configure:6228: result: nawk
configure:6253: checking for a BSD-compatible install
configure:6321: result: /usr/bin/install -c
configure:6332: checking whether ln -s works
configure:6336: result: yes
configure:6386: checking for ranlib
configure:6402: found /usr/bin/ranlib
configure:6413: result: ranlib
configure:6435: checking for GNU make
configure:6454: result: gmake
configure:6463: checking for egrep
configure:6525: result: /usr/bin/grep -E
configure:6580: checking for strip
configure:6596: found /usr/bin/strip
configure:6607: result: strip
configure:6680: checking for ar
configure:6696: found /usr/bin/ar
configure:6707: result: ar
configure:6740: checking for bison
configure:6771: result: :
configure:6781: checking for cmp
configure:6799: found /usr/bin/cmp
configure:6812: result: /usr/bin/cmp
configure:6822: checking for cat
configure:6840: found /bin/cat
configure:6853: result: /bin/cat
configure:6863: checking for flex
configure:6881: found /usr/bin/flex
configure:6894: result: /usr/bin/flex
configure:6904: checking for grep
configure:6935: result: /usr/bin/grep
configure:6945: checking for python
configure:6976: result: :
configure:6986: checking for find
configure:7004: found /usr/bin/find
configure:7017: result: /usr/bin/find
configure:7027: checking for compress
configure:7045: found /usr/bin/compress
configure:7058: result: /usr/bin/compress
configure:7068: checking for basename
configure:7086: found /usr/bin/basename
configure:7099: result: /usr/bin/basename
configure:7109: checking for dirname
configure:7127: found /usr/bin/dirname
configure:7140: result: /usr/bin/dirname
configure:7150: checking for sh
configure:7181: result: /bin/sh
configure:7191: checking for ln
configure:7209: found /bin/ln
configure:7222: result: /bin/ln
configure:7232: checking for doxygen
configure:7263: result: :
configure:7273: checking for dot
configure:7304: result: :
configure:7314: checking for wget
configure:7332: found /usr/local/bin/wget
configure:7345: result: /usr/local/bin/wget
configure:7355: checking for curl
configure:7386: result: :
configure:7396: checking for rubber
configure:7427: result: :
configure:7437: checking for catdvi
configure:7468: result: :
configure:7478: checking for kpsewhich
configure:7509: result: :
configure:7519: checking for xmllint
configure:7550: result: :
configure:7560: checking for xmlstarlet
configure:7591: result: :
configure:7601: checking for bash
configure:7632: result: :
configure:7642: checking for git
configure:7673: result: :
configure:7683: checking for alembic
configure:7714: result: :
configure:7724: checking for bzip2
configure:7742: found /usr/bin/bzip2
configure:7755: result: /usr/bin/bzip2
configure:7765: checking for tar
configure:7783: found /usr/bin/tar
configure:7796: result: /usr/bin/tar
configure:7806: checking for patch
configure:7824: found /usr/bin/patch
configure:7837: result: /usr/bin/patch
configure:7847: checking for sed
configure:7878: result: /usr/bin/sed
configure:7888: checking for nm
configure:7906: found /usr/bin/nm
configure:7919: result: /usr/bin/nm
configure:7990: checking for ldconfig
configure:8008: found /sbin/ldconfig
configure:8021: result: /sbin/ldconfig
configure:8031: checking for sha1sum
configure:8062: result: /home/jora_cornev/asterisk-15.1.2/build_tools/sha1sum-sh
configure:8072: checking for openssl
configure:8090: found /usr/bin/openssl
configure:8103: result: /usr/bin/openssl
configure:8112: checking for bison that supports parse-param
configure:8147: result:
configure:8220: checking for soxmix
configure:8250: result: no
configure:8279: checking for md5
configure:8295: found /sbin/md5
configure:8306: result: md5
configure:8322: checking for a sed that does not truncate output
configure:8386: result: /usr/bin/sed
configure:8574: checking whether cc is Clang
configure:8599: result: yes
configure:8646: checking whether Clang needs flag to prevent "argument unused" warning when linking with -pthread
configure:8671: cc -o conftest -Werror -Wunknown-warning-option  -pthread -g -O2 -I/usr/local/include -L/usr/local/lib conftest.c  >&5
configure:8671: $? = 0
configure:8677: (cc -c -Werror -Wunknown-warning-option  -pthread -g -O2 -I/usr/local/include conftest.c >&5) && (echo ==== >&5) && (cc -o conftest -Werror -Wunknown-warning-option  -pthread -g -O2 -I/usr/local/include -L/usr/local/lib conftest.o  >&5)
configure:8677: $? = 0
configure:8695: result: no
configure:8844: checking for joinable pthread attribute
configure:8862: cc -o conftest -g -O2 -pthread -I/usr/local/include -L/usr/local/lib conftest.c   >&5
configure:8862: $? = 0
configure:8870: result: PTHREAD_CREATE_JOINABLE
configure:8884: checking whether more special flags are required for pthreads
configure:8897: result: no
configure:8905: checking for PTHREAD_PRIO_INHERIT
configure:8921: cc -o conftest -g -O2 -pthread -I/usr/local/include -L/usr/local/lib conftest.c   >&5
configure:8921: $? = 0
configure:8930: result: yes
configure:9147: checking for RAII support
configure:9169: cc -o conftest -g -O2 -I/usr/local/include -L/usr/local/lib conftest.c  >&5
conftest.c:31:15: error: function definition is not allowed here
                        int main() {
1 error generated.
configure:9169: $? = 1
| /* confdefs.h */
| #define HAVE_PTHREAD_PRIO_INHERIT 1
| #define HAVE_PTHREAD 1
| int
| main ()
|             int main() {
|                 #if defined(__clang__)
|                 choke
|                 #endif
|                 return 0;
|   return 0;
configure:9206: checking for clang -fblocks
configure:9216: result: yes
configure:9235: checking for clang strsep/strcmp optimization
configure:9264: cc -c -g -O2 -O1 -Werror=array-bounds -I/usr/local/include conftest.c >&5
conftest.c:42:9: error: second parameter of 'main' (argument array) must be of type 'char **'
                                int main(int argc, char *argv) {
1 error generated.
configure:9264: $? = 1
| /* confdefs.h */
|                 #include <stdio.h>
|                 #include <string.h>
|                 /* fails with clang and -O1 */
|                 void test_strsep_strcmp (void) {
|                     char *haystackstr = "test1,test2";
|                     char *outstr;
|                     if (!strcmp(haystackstr, ",")) {
|                         printf("fail\n");
|                     if ((outstr = strsep(&haystackstr, ","))) {
|                         printf("fail:%s\n", outstr);
|                     test_strsep_strcmp();
|                     return 0;
configure:9277: result: prevent use of __string2_1bptr_p / strsep / strcmp from bits/string2.h
configure:9310: checking for embedded pjproject (may have to download)
configure:9312: result: configuring
configure:9356: result: failed
configure:9358: Unable to configure third-party/pjproject
configure:9360: error: Re-run the ./configure command with 'NOISY_BUILD=yes' appended to see error details.
## Cache variables. ##
ac_cv_GNU_MAKE=gmake
ac_cv_GNU_MAKE_VERSION_MAJOR=4
ac_cv_GNU_MAKE_VERSION_MINOR=2
ac_cv_build=x86_64-unknown-freebsd11.1
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=''
ac_cv_env_CCC_value=''
ac_cv_env_CC_set=''
ac_cv_env_CC_value=''
ac_cv_env_CFLAGS_set=''
ac_cv_env_CFLAGS_value=''
ac_cv_env_CPPFLAGS_set=''
ac_cv_env_CPPFLAGS_value=''
ac_cv_env_CPP_set=''
ac_cv_env_CPP_value=''
ac_cv_env_CXXCPP_set=''
ac_cv_env_CXXCPP_value=''
ac_cv_env_CXXFLAGS_set=''
ac_cv_env_CXXFLAGS_value=''
ac_cv_env_CXX_set=''
ac_cv_env_CXX_value=''
ac_cv_env_GMIME_CFLAGS_set=''
ac_cv_env_GMIME_CFLAGS_value=''
ac_cv_env_GMIME_LIBS_set=''
ac_cv_env_GMIME_LIBS_value=''
ac_cv_env_GTK2_CFLAGS_set=''
ac_cv_env_GTK2_CFLAGS_value=''
ac_cv_env_GTK2_LIBS_set=''
ac_cv_env_GTK2_LIBS_value=''
ac_cv_env_ILBC_CFLAGS_set=''
ac_cv_env_ILBC_CFLAGS_value=''
ac_cv_env_ILBC_LIBS_set=''
ac_cv_env_ILBC_LIBS_value=''
ac_cv_env_LDFLAGS_set=''
ac_cv_env_LDFLAGS_value=''
ac_cv_env_LIBEDIT_CFLAGS_set=''
ac_cv_env_LIBEDIT_CFLAGS_value=''
ac_cv_env_LIBEDIT_LIBS_set=''
ac_cv_env_LIBEDIT_LIBS_value=''
ac_cv_env_LIBS_set=''
ac_cv_env_LIBS_value=''
ac_cv_env_PJPROJECT_CFLAGS_set=''
ac_cv_env_PJPROJECT_CFLAGS_value=''
ac_cv_env_PJPROJECT_CONFIGURE_OPTS_set=''
ac_cv_env_PJPROJECT_CONFIGURE_OPTS_value=''
ac_cv_env_PJPROJECT_LIBS_set=''
ac_cv_env_PJPROJECT_LIBS_value=''
ac_cv_env_PKG_CONFIG_LIBDIR_set=''
ac_cv_env_PKG_CONFIG_LIBDIR_value=''
ac_cv_env_PKG_CONFIG_PATH_set=''
ac_cv_env_PKG_CONFIG_PATH_value=''
ac_cv_env_PKG_CONFIG_set=''
ac_cv_env_PKG_CONFIG_value=''
ac_cv_env_PYTHONDEV_CFLAGS_set=''
ac_cv_env_PYTHONDEV_CFLAGS_value=''
ac_cv_env_PYTHONDEV_LIBS_set=''
ac_cv_env_PYTHONDEV_LIBS_value=''
ac_cv_env_SYSTEMD_CFLAGS_set=''
ac_cv_env_SYSTEMD_CFLAGS_value=''
ac_cv_env_SYSTEMD_LIBS_set=''
ac_cv_env_SYSTEMD_LIBS_value=''
ac_cv_env_build_alias_set=''
ac_cv_env_build_alias_value=''
ac_cv_env_host_alias_set=''
ac_cv_env_host_alias_value=''
ac_cv_env_target_alias_set=''
ac_cv_env_target_alias_value=''
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_minix_config_h=no
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=x86_64-unknown-freebsd11.1
ac_cv_objext=o
ac_cv_path_ALEMBIC=:
ac_cv_path_BASENAME=/usr/bin/basename
ac_cv_path_BASH=:
ac_cv_path_BISON=:
ac_cv_path_BZIP2=/usr/bin/bzip2
ac_cv_path_CAT=/bin/cat
ac_cv_path_CATDVI=:
ac_cv_path_CMP=/usr/bin/cmp
ac_cv_path_COMPRESS=/usr/bin/compress
ac_cv_path_CURL=:
ac_cv_path_DIRNAME=/usr/bin/dirname
ac_cv_path_DOT=:
ac_cv_path_DOXYGEN=:
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_FIND=/usr/bin/find
ac_cv_path_FLEX=/usr/bin/flex
ac_cv_path_GIT=:
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_KPATHSEA=:
ac_cv_path_LDCONFIG=/sbin/ldconfig
ac_cv_path_LN=/bin/ln
ac_cv_path_NM=/usr/bin/nm
ac_cv_path_OPENSSL=/usr/bin/openssl
ac_cv_path_PATCH=/usr/bin/patch
ac_cv_path_PYTHON=:
ac_cv_path_RUBBER=:
ac_cv_path_SED=/usr/bin/sed
ac_cv_path_SHA1SUM=/home/jora_cornev/asterisk-15.1.2/build_tools/sha1sum-sh
ac_cv_path_SHELL=/bin/sh
ac_cv_path_TAR=/usr/bin/tar
ac_cv_path_WGET=/usr/local/bin/wget
ac_cv_path_XMLLINT=:
ac_cv_path_XMLSTARLET=:
ac_cv_path_ac_pt_UNAME=/usr/bin/uname
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=nawk
ac_cv_prog_CPP='cc -E'
ac_cv_prog_CXXCPP='c++ -E'
ac_cv_prog_MD5=md5
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=cc
ac_cv_prog_ac_ct_CXX=c++
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=''
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_egrep='grep -E'
ac_cv_safe_to_define___extensions__=yes
ax_cv_PTHREAD_CLANG=yes
ax_cv_PTHREAD_CLANG_NO_WARN_FLAG=no
ax_cv_PTHREAD_JOINABLE_ATTR=PTHREAD_CREATE_JOINABLE
ax_cv_PTHREAD_PRIO_INHERIT=yes
ax_cv_PTHREAD_SPECIAL_FLAGS=no
lt_cv_path_LD=/usr/bin/ld
lt_cv_prog_gnu_ld=yes
## Output variables. ##
ALEMBIC=':'
ALLOCA=''
ALSA_DIR=''
ALSA_INCLUDE=''
ALSA_LIB=''
AR='ar'
AST_ADDRESS_SANITIZER=''
AST_ASTERISKSSL=''
AST_CLANG_BLOCKS='-fblocks'
AST_CLANG_BLOCKS_LIBS='-lBlocksRuntime'
AST_CODE_COVERAGE='no'
AST_C_COMPILER_FAMILY='clang'
AST_DECLARATION_AFTER_STATEMENT=''
AST_DEVMODE=''
AST_DEVMODE_STRICT=''
AST_DOWNLOAD_CACHE=''
AST_FORTIFY_SOURCE=''
AST_LEAK_SANITIZER=''
AST_NATIVE_ARCH=''
AST_NESTED_FUNCTIONS=''
AST_NO_FORMAT_TRUNCATION=''
AST_NO_STRICT_OVERFLOW=''
AST_RPATH=''
AST_SHADOW_WARNINGS=''
AST_THREAD_SANITIZER=''
AST_TRAMPOLINES=''
AST_UNDEFINED_SANITIZER=''
AWK='nawk'
BASENAME='/usr/bin/basename'
BASH=':'
BFD_DIR=''
BFD_INCLUDE=''
BFD_LIB=''
BIND8_CFLAGS=''
BISON=':'
BKTR_DIR=''
BKTR_INCLUDE=''
BKTR_LIB=''
BLUETOOTH_DIR=''
BLUETOOTH_INCLUDE=''
BLUETOOTH_LIB=''
BUILD_CPU='x86_64'
BUILD_OS='freebsd11.1'
BUILD_PLATFORM='x86_64-unknown-freebsd11.1'
BUILD_VENDOR='unknown'
BZIP2='/usr/bin/bzip2'
CAP_DIR=''
CAP_INCLUDE=''
CAP_LIB=''
CAT='/bin/cat'
CATDVI=':'
CC='cc'
CFLAGS='-g -O2'
CMP='/usr/bin/cmp'
CODEC2_DIR=''
CODEC2_INCLUDE=''
CODEC2_LIB=''
COMPRESS='/usr/bin/compress'
CONFIG_CFLAGS=''
CONFIG_LDFLAGS=''
CONFIG_LIBXML2=''
CONFIG_MYSQLCLIENT=''
CONFIG_NEON29=''
CONFIG_NEON=''
CONFIG_NETSNMP=''
CONFIG_SDL=''
CONFIG_SIGNED_CHAR=''
COROSYNC_CFG_STATE_TRACK_DIR=''
COROSYNC_CFG_STATE_TRACK_INCLUDE=''
COROSYNC_CFG_STATE_TRACK_LIB=''
COROSYNC_DIR=''
COROSYNC_INCLUDE=''
COROSYNC_LIB=''
CPP='cc -E'
CPPFLAGS='-I/usr/local/include'
CRYPTO_DIR=''
CRYPTO_INCLUDE=''
CRYPTO_LIB=''
CRYPT_DIR=''
CRYPT_INCLUDE=''
CRYPT_LIB=''
CURL=':'
CURL_INCLUDE=''
CURL_LIB=''
CURSES_DIR=''
CURSES_INCLUDE=''
CURSES_LIB=''
CXX='c++'
CXXCPP='c++ -E'
CXXFLAGS='-g -O2'
DAHDI_DIR=''
DAHDI_INCLUDE=''
DAHDI_LIB=''
DEFS=''
DIRNAME='/usr/bin/dirname'
DOT=':'
DOWNLOAD='/usr/local/bin/wget'
DOWNLOAD_TIMEOUT='--timeout=$1'
DOWNLOAD_TO_STDOUT='/usr/local/bin/wget -q -O-'
DOXYGEN=':'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EDITLINE_LIB=''
EXEEXT=''
EXTERNALS_CACHE_DIR=''
FETCH=''
FFMPEG_DIR=''
FFMPEG_INCLUDE=''
FFMPEG_LIB=''
FFTW3_DIR=''
FFTW3_INCLUDE=''
FFTW3_LIB=''
FIND='/usr/bin/find'
FLEX='/usr/bin/flex'
FREETDS_DIR=''
FREETDS_INCLUDE=''
FREETDS_LIB=''
GENERIC_ODBC_INCLUDE=''
GENERIC_ODBC_LIB=''
GIT=':'
GMIME_CFLAGS=''
GMIME_DIR=''
GMIME_INCLUDE=''
GMIME_LIB=''
GMIME_LIBS=''
GNU_LD='1'
GNU_MAKE='gmake'
GREP='/usr/bin/grep'
GSM_DIR=''
GSM_INCLUDE=''
GSM_INTERNAL=''
GSM_LIB=''
GTK2_CFLAGS=''
GTK2_DIR=''
GTK2_INCLUDE=''
GTK2_LIB=''
GTK2_LIBS=''
HAS_POLL=''
HOARD_DIR=''
HOARD_INCLUDE=''
HOARD_LIB=''
HOST_CPU='x86_64'
HOST_OS='freebsd11.1'
HOST_PLATFORM='x86_64-unknown-freebsd11.1'
HOST_VENDOR='unknown'
ICAL_DIR=''
ICAL_INCLUDE=''
ICAL_LIB=''
ICONV_DIR=''
ICONV_INCLUDE=''
ICONV_LIB=''
IKSEMEL_DIR=''
IKSEMEL_INCLUDE=''
IKSEMEL_LIB=''
ILBC_CFLAGS=''
ILBC_DIR=''
ILBC_INCLUDE=''
ILBC_INTERNAL=''
ILBC_LIB=''
ILBC_LIBS=''
IMAP_TK_DIR=''
IMAP_TK_INCLUDE=''
IMAP_TK_LIB=''
INOTIFY_DIR=''
INOTIFY_INCLUDE=''
INOTIFY_LIB=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
IODBC_DIR=''
IODBC_INCLUDE=''
IODBC_LIB=''
ISDNNET_DIR=''
ISDNNET_INCLUDE=''
ISDNNET_LIB=''
JACK_DIR=''
JACK_INCLUDE=''
JACK_LIB=''
JANSSON_DIR=''
JANSSON_INCLUDE=''
JANSSON_LIB=''
KPATHSEA=':'
KQUEUE_DIR=''
KQUEUE_INCLUDE=''
KQUEUE_LIB=''
LD='/usr/bin/ld'
LDAP_DIR=''
LDAP_INCLUDE=''
LDAP_LIB=''
LDCONFIG='/sbin/ldconfig'
LDFLAGS='-L/usr/local/lib'
LIBEDIT_CFLAGS=''
LIBEDIT_DIR=''
LIBEDIT_INCLUDE=''
LIBEDIT_INTERNAL=''
LIBEDIT_IS_UNICODE_DIR=''
LIBEDIT_IS_UNICODE_INCLUDE=''
LIBEDIT_IS_UNICODE_LIB=''
LIBEDIT_LIB=''
LIBEDIT_LIBS=''
LIBOBJS=''
LIBS=''
LIBXML2_DIR=''
LIBXML2_INCLUDE=''
LIBXML2_LIB=''
LIBXSLT_CLEANUP_DIR=''
LIBXSLT_CLEANUP_INCLUDE=''
LIBXSLT_CLEANUP_LIB=''
LIBXSLT_DIR=''
LIBXSLT_INCLUDE=''
LIBXSLT_LIB=''
LN='/bin/ln'
LN_S='ln -s'
LTDL_DIR=''
LTDL_INCLUDE=''
LTDL_LIB=''
LTLIBOBJS=''
LUA_DIR=''
LUA_INCLUDE=''
LUA_LIB=''
MD5='md5'
MISDN_DIR=''
MISDN_INCLUDE=''
MISDN_LIB=''
MYSQLCLIENT_DIR=''
MYSQLCLIENT_INCLUDE=''
MYSQLCLIENT_LIB=''
NBS_DIR=''
NBS_INCLUDE=''
NBS_LIB=''
NCURSES_DIR=''
NCURSES_INCLUDE=''
NCURSES_LIB=''
NEON29_DIR=''
NEON29_INCLUDE=''
NEON29_LIB=''
NEON_DIR=''
NEON_INCLUDE=''
NEON_LIB=''
NETSNMP_DIR=''
NETSNMP_INCLUDE=''
NETSNMP_LIB=''
NEWT_DIR=''
NEWT_INCLUDE=''
NEWT_LIB=''
NM='/usr/bin/nm'
NOISY_BUILD='yes'
OBJEXT='o'
OGG_DIR=''
OGG_INCLUDE=''
OGG_LIB=''
OPENH323DIR=''
OPENH323_BUILD=''
OPENH323_DIR=''
OPENH323_INCDIR=''
OPENH323_INCLUDE=''
OPENH323_LIB=''
OPENH323_LIBDIR=''
OPENH323_SUFFIX=''
OPENR2_DIR=''
OPENR2_INCLUDE=''
OPENR2_LIB=''
OPENSSL='/usr/bin/openssl'
OPENSSL_DIR=''
OPENSSL_EC_DIR=''
OPENSSL_EC_INCLUDE=''
OPENSSL_EC_LIB=''
OPENSSL_INCLUDE=''
OPENSSL_LIB=''
OPENSSL_SRTP_DIR=''
OPENSSL_SRTP_INCLUDE=''
OPENSSL_SRTP_LIB=''
OPUS_DIR=''
OPUS_INCLUDE=''
OPUS_LIB=''
OSARCH='FreeBSD'
OSPTK_DIR=''
OSPTK_INCLUDE=''
OSPTK_LIB=''
OSS_DIR=''
OSS_INCLUDE=''
OSS_LIB=''
PACKAGE_BUGREPORT='https://issues.asterisk.org'
PACKAGE_NAME='asterisk'
PACKAGE_STRING='asterisk trunk'
PACKAGE_TARNAME='asterisk'
PACKAGE_URL=''
PACKAGE_VERSION='trunk'
PATCH='/usr/bin/patch'
PATH_SEPARATOR=':'
PBX_ALSA=''
PBX_BASH='0'
PBX_BFD=''
PBX_BISON='0'
PBX_BKTR=''
PBX_BLUETOOTH=''
PBX_CAP=''
PBX_CODEC2=''
PBX_COROSYNC=''
PBX_COROSYNC_CFG_STATE_TRACK=''
PBX_CRYPT=''
PBX_CRYPTO=''
PBX_CURL=''
PBX_CURSES=''
PBX_DAHDI=''
PBX_DAHDI_HALF_FULL=''
PBX_DLADDR=''
PBX_DYNAMIC_LIST=''
PBX_FFMPEG=''
PBX_FFTW3=''
PBX_FLEX='1'
PBX_FREETDS=''
PBX_GENERIC_ODBC=''
PBX_GLOB_BRACE=''
PBX_GLOB_NOMAGIC=''
PBX_GMIME=''
PBX_GSM=''
PBX_GTK2=''
PBX_HOARD=''
PBX_ICAL=''
PBX_ICONV=''
PBX_IKSEMEL=''
PBX_ILBC=''
PBX_IMAP_TK=''
PBX_INOTIFY=''
PBX_IODBC=''
PBX_IP_MTU_DISCOVER=''
PBX_ISDNNET=''
PBX_IXJUSER=''
PBX_JACK=''
PBX_JANSSON=''
PBX_KQUEUE=''
PBX_LAUNCHD=''
PBX_LDAP=''
PBX_LIBEDIT=''
PBX_LIBEDIT_IS_UNICODE=''
PBX_LIBXML2=''
PBX_LIBXSLT=''
PBX_LIBXSLT_CLEANUP=''
PBX_LTDL=''
PBX_LUA=''
PBX_MISDN=''
PBX_MISDN_FAC_ERROR=''
PBX_MISDN_FAC_RESULT=''
PBX_MSG_NOSIGNAL=''
PBX_MYSQLCLIENT=''
PBX_NBS=''
PBX_NCURSES=''
PBX_NEON29=''
PBX_NEON=''
PBX_NETSNMP=''
PBX_NEWT=''
PBX_OGG=''
PBX_OPENH323=''
PBX_OPENR2=''
PBX_OPENSSL=''
PBX_OPENSSL_EC=''
PBX_OPENSSL_SRTP=''
PBX_OPUS=''
PBX_OSPTK=''
PBX_OSREV='11.1-RELEASE'
PBX_OSS=''
PBX_PGSQL=''
PBX_PJPROJECT=''
PBX_PJSIP_AUTH_CLT_DEINIT=''
PBX_PJSIP_DLG_CREATE_UAS_AND_INC_LOCK=''
PBX_PJSIP_EVSUB_GRP_LOCK=''
PBX_PJSIP_EVSUB_SET_UAS_TIMEOUT=''
PBX_PJSIP_EXTERNAL_RESOLVER=''
PBX_PJSIP_GET_DEST_INFO=''
PBX_PJSIP_INV_SESSION_REF=''
PBX_PJSIP_REPLACE_MEDIA_STREAM=''
PBX_PJSIP_TLS_TRANSPORT_PROTO=''
PBX_PJSIP_TSX_LAYER_FIND_TSX2=''
PBX_PJ_SSL_CERT_LOAD_FROM_FILES2=''
PBX_PJ_TRANSACTION_GRP_LOCK=''
PBX_POPT=''
PBX_PORTAUDIO=''
PBX_PRI=''
PBX_PRI_AOC_EVENTS=''
PBX_PRI_CALL_HOLD=''
PBX_PRI_CALL_REROUTING=''
PBX_PRI_CALL_WAITING=''
PBX_PRI_CCSS=''
PBX_PRI_DATETIME_SEND=''
PBX_PRI_DISPLAY_TEXT=''
PBX_PRI_HANGUP_FIX=''
PBX_PRI_INBANDDISCONNECT=''
PBX_PRI_L2_PERSISTENCE=''
PBX_PRI_MCID=''
PBX_PRI_MWI=''
PBX_PRI_MWI_V2=''
PBX_PRI_PROG_W_CAUSE=''
PBX_PRI_REVERSE_CHARGE=''
PBX_PRI_SERVICE_MESSAGES=''
PBX_PRI_SETUP_ACK_INBAND=''
PBX_PRI_SETUP_KEYPAD=''
PBX_PRI_SUBADDR=''
PBX_PRI_TRANSFER=''
PBX_PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP=''
PBX_PTHREAD_RWLOCK_INITIALIZER=''
PBX_PWLIB=''
PBX_RADIUS=''
PBX_RESAMPLE=''
PBX_RT=''
PBX_RTLD_NOLOAD=''
PBX_SDL=''
PBX_SDL_IMAGE=''
PBX_SNDFILE=''
PBX_SO_NOSIGPIPE=''
PBX_SPANDSP=''
PBX_SPEEX=''
PBX_SPEEXDSP=''
PBX_SPEEX_PREPROCESS=''
PBX_SQLITE3=''
PBX_SQLITE=''
PBX_SRTP=''
PBX_SRTP_192=''
PBX_SRTP_256=''
PBX_SRTP_GCM=''
PBX_SRTP_SHUTDOWN=''
PBX_SS7=''
PBX_SSL_OP_NO_TLSV1_1=''
PBX_SSL_OP_NO_TLSV1_2=''
PBX_SUPPSERV=''
PBX_SYSLOG=''
PBX_SYSLOG_FACILITY_LOG_AUTH=''
PBX_SYSLOG_FACILITY_LOG_AUTHPRIV=''
PBX_SYSLOG_FACILITY_LOG_CRON=''
PBX_SYSLOG_FACILITY_LOG_DAEMON=''
PBX_SYSLOG_FACILITY_LOG_FTP=''
PBX_SYSLOG_FACILITY_LOG_KERN=''
PBX_SYSLOG_FACILITY_LOG_LPR=''
PBX_SYSLOG_FACILITY_LOG_MAIL=''
PBX_SYSLOG_FACILITY_LOG_NEWS=''
PBX_SYSLOG_FACILITY_LOG_SYSLOG=''
PBX_SYSLOG_FACILITY_LOG_UUCP=''
PBX_SYSTEMD=''
PBX_TERMCAP=''
PBX_TIMERFD=''
PBX_TINFO=''
PBX_TONEZONE=''
PBX_UNBOUND=''
PBX_UNIXODBC=''
PBX_URIPARSER=''
PBX_VORBIS=''
PBX_VPB=''
PBX_WINARCH='0'
PBX_WORKING_FORK=''
PBX_X11=''
PBX_XMLSTARLET='0'
PBX_ZLIB=''
PGSQL_DIR=''
PGSQL_INCLUDE=''
PGSQL_LIB=''
PG_CONFIG=''
PJPROJECT_BUNDLED='yes'
PJPROJECT_CFLAGS=''
PJPROJECT_CONFIGURE_OPTS=''
PJPROJECT_DIR='third-party/pjproject'
PJPROJECT_INCLUDE=''
PJPROJECT_LIB=''
PJPROJECT_LIBS=''
PJSIP_AUTH_CLT_DEINIT_DIR=''
PJSIP_AUTH_CLT_DEINIT_INCLUDE=''
PJSIP_AUTH_CLT_DEINIT_LIB=''
PJSIP_DLG_CREATE_UAS_AND_INC_LOCK_DIR=''
PJSIP_DLG_CREATE_UAS_AND_INC_LOCK_INCLUDE=''
PJSIP_DLG_CREATE_UAS_AND_INC_LOCK_LIB=''
PJSIP_EVSUB_GRP_LOCK_DIR=''
PJSIP_EVSUB_GRP_LOCK_INCLUDE=''
PJSIP_EVSUB_GRP_LOCK_LIB=''
PJSIP_EVSUB_SET_UAS_TIMEOUT_DIR=''
PJSIP_EVSUB_SET_UAS_TIMEOUT_INCLUDE=''
PJSIP_EVSUB_SET_UAS_TIMEOUT_LIB=''
PJSIP_EXTERNAL_RESOLVER_DIR=''
PJSIP_EXTERNAL_RESOLVER_INCLUDE=''
PJSIP_EXTERNAL_RESOLVER_LIB=''
PJSIP_GET_DEST_INFO_DIR=''
PJSIP_GET_DEST_INFO_INCLUDE=''
PJSIP_GET_DEST_INFO_LIB=''
PJSIP_INV_SESSION_REF_DIR=''
PJSIP_INV_SESSION_REF_INCLUDE=''
PJSIP_INV_SESSION_REF_LIB=''
PJSIP_REPLACE_MEDIA_STREAM_DIR=''
PJSIP_REPLACE_MEDIA_STREAM_INCLUDE=''
PJSIP_REPLACE_MEDIA_STREAM_LIB=''
PJSIP_TLS_TRANSPORT_PROTO_DIR=''
PJSIP_TLS_TRANSPORT_PROTO_INCLUDE=''
PJSIP_TLS_TRANSPORT_PROTO_LIB=''
PJSIP_TSX_LAYER_FIND_TSX2_DIR=''
PJSIP_TSX_LAYER_FIND_TSX2_INCLUDE=''
PJSIP_TSX_LAYER_FIND_TSX2_LIB=''
PJ_SSL_CERT_LOAD_FROM_FILES2_DIR=''
PJ_SSL_CERT_LOAD_FROM_FILES2_INCLUDE=''
PJ_SSL_CERT_LOAD_FROM_FILES2_LIB=''
PJ_TRANSACTION_GRP_LOCK_DIR=''
PJ_TRANSACTION_GRP_LOCK_INCLUDE=''
PJ_TRANSACTION_GRP_LOCK_LIB=''
PKG_CONFIG=''
PKG_CONFIG_LIBDIR=''
PKG_CONFIG_PATH=''
POPT_DIR=''
POPT_INCLUDE=''
POPT_LIB=''
PORTAUDIO_DIR=''
PORTAUDIO_INCLUDE=''
PORTAUDIO_LIB=''
POW_LIB=''
PRI_AOC_EVENTS_DIR=''
PRI_AOC_EVENTS_INCLUDE=''
PRI_AOC_EVENTS_LIB=''
PRI_CALL_HOLD_DIR=''
PRI_CALL_HOLD_INCLUDE=''
PRI_CALL_HOLD_LIB=''
PRI_CALL_REROUTING_DIR=''
PRI_CALL_REROUTING_INCLUDE=''
PRI_CALL_REROUTING_LIB=''
PRI_CALL_WAITING_DIR=''
PRI_CALL_WAITING_INCLUDE=''
PRI_CALL_WAITING_LIB=''
PRI_CCSS_DIR=''
PRI_CCSS_INCLUDE=''
PRI_CCSS_LIB=''
PRI_DATETIME_SEND_DIR=''
PRI_DATETIME_SEND_INCLUDE=''
PRI_DATETIME_SEND_LIB=''
PRI_DIR=''
PRI_DISPLAY_TEXT_DIR=''
PRI_DISPLAY_TEXT_INCLUDE=''
PRI_DISPLAY_TEXT_LIB=''
PRI_HANGUP_FIX_DIR=''
PRI_HANGUP_FIX_INCLUDE=''
PRI_HANGUP_FIX_LIB=''
PRI_INBANDDISCONNECT_DIR=''
PRI_INBANDDISCONNECT_INCLUDE=''
PRI_INBANDDISCONNECT_LIB=''
PRI_INCLUDE=''
PRI_L2_PERSISTENCE_DIR=''
PRI_L2_PERSISTENCE_INCLUDE=''
PRI_L2_PERSISTENCE_LIB=''
PRI_LIB=''
PRI_MCID_DIR=''
PRI_MCID_INCLUDE=''
PRI_MCID_LIB=''
PRI_MWI_DIR=''
PRI_MWI_INCLUDE=''
PRI_MWI_LIB=''
PRI_MWI_V2_DIR=''
PRI_MWI_V2_INCLUDE=''
PRI_MWI_V2_LIB=''
PRI_PROG_W_CAUSE_DIR=''
PRI_PROG_W_CAUSE_INCLUDE=''
PRI_PROG_W_CAUSE_LIB=''
PRI_REVERSE_CHARGE_DIR=''
PRI_REVERSE_CHARGE_INCLUDE=''
PRI_REVERSE_CHARGE_LIB=''
PRI_SERVICE_MESSAGES_DIR=''
PRI_SERVICE_MESSAGES_INCLUDE=''
PRI_SERVICE_MESSAGES_LIB=''
PRI_SETUP_ACK_INBAND_DIR=''
PRI_SETUP_ACK_INBAND_INCLUDE=''
PRI_SETUP_ACK_INBAND_LIB=''
PRI_SETUP_KEYPAD_DIR=''
PRI_SETUP_KEYPAD_INCLUDE=''
PRI_SETUP_KEYPAD_LIB=''
PRI_SUBADDR_DIR=''
PRI_SUBADDR_INCLUDE=''
PRI_SUBADDR_LIB=''
PRI_TRANSFER_DIR=''
PRI_TRANSFER_INCLUDE=''
PRI_TRANSFER_LIB=''
PTHREAD_CC='cc'
PTHREAD_CFLAGS='-pthread'
PTHREAD_LIBS=''
PTLIB_CONFIG=''
PWLIBDIR=''
PWLIB_DIR=''
PWLIB_INCDIR=''
PWLIB_INCLUDE=''
PWLIB_LIB=''
PWLIB_LIBDIR=''
PWLIB_PLATFORM=''
PYTHON=':'
PYTHONDEV_CFLAGS=''
PYTHONDEV_INCLUDE=''
PYTHONDEV_LIB=''
PYTHONDEV_LIBS=''
RADIUS_DIR=''
RADIUS_INCLUDE=''
RADIUS_LIB=''
RANLIB='ranlib'
RESAMPLE_DIR=''
RESAMPLE_INCLUDE=''
RESAMPLE_LIB=''
RT_DIR=''
RT_INCLUDE=''
RT_LIB=''
RUBBER=':'
SDL_DIR=''
SDL_IMAGE_DIR=''
SDL_IMAGE_INCLUDE=''
SDL_IMAGE_LIB=''
SDL_INCLUDE=''
SDL_LIB=''
SED='/usr/bin/sed'
SHA1SUM='/home/jora_cornev/asterisk-15.1.2/build_tools/sha1sum-sh'
SHELL='/bin/sh'
SNDFILE_DIR=''
SNDFILE_INCLUDE=''
SNDFILE_LIB=''
SOUNDS_CACHE_DIR=''
SOXMIX=':'
SPANDSP_DIR=''
SPANDSP_INCLUDE=''
SPANDSP_LIB=''
SPEEXDSP_DIR=''
SPEEXDSP_INCLUDE=''
SPEEXDSP_LIB=''
SPEEX_DIR=''
SPEEX_INCLUDE=''
SPEEX_LIB=''
SPEEX_PREPROCESS_DIR=''
SPEEX_PREPROCESS_INCLUDE=''
SPEEX_PREPROCESS_LIB=''
SQLITE3_DIR=''
SQLITE3_INCLUDE=''
SQLITE3_LIB=''
SQLITE_DIR=''
SQLITE_INCLUDE=''
SQLITE_LIB=''
SRTP_192_DIR=''
SRTP_192_INCLUDE=''
SRTP_192_LIB=''
SRTP_256_DIR=''
SRTP_256_INCLUDE=''
SRTP_256_LIB=''
SRTP_DIR=''
SRTP_GCM_DIR=''
SRTP_GCM_INCLUDE=''
SRTP_GCM_LIB=''
SRTP_INCLUDE=''
SRTP_LIB=''
SRTP_SHUTDOWN_DIR=''
SRTP_SHUTDOWN_INCLUDE=''
SRTP_SHUTDOWN_LIB=''
SS7_DIR=''
SS7_INCLUDE=''
SS7_LIB=''
STRIP='strip'
SUPPSERV_DIR=''
SUPPSERV_INCLUDE=''
SUPPSERV_LIB=''
SYSTEMD_CFLAGS=''
SYSTEMD_INCLUDE=''
SYSTEMD_LIB=''
SYSTEMD_LIBS=''
TAR='/usr/bin/tar'
TERMCAP_DIR=''
TERMCAP_INCLUDE=''
TERMCAP_LIB=''
TIMERFD_DIR=''
TIMERFD_INCLUDE=''
TIMERFD_LIB=''
TINFO_DIR=''
TINFO_INCLUDE=''
TINFO_LIB=''
TONEZONE_DIR=''
TONEZONE_INCLUDE=''
TONEZONE_LIB=''
UNAME='/usr/bin/uname'
UNBOUND_DIR=''
UNBOUND_INCLUDE=''
UNBOUND_LIB=''
UNIXODBC_DIR=''
UNIXODBC_INCLUDE=''
UNIXODBC_LIB=''
URIPARSER_DIR=''
URIPARSER_INCLUDE=''
URIPARSER_LIB=''
UUID_INCLUDE=''
UUID_LIB=''
VORBIS_DIR=''
VORBIS_INCLUDE=''
VORBIS_LIB=''
VPB_DIR=''
VPB_INCLUDE=''
VPB_LIB=''
WGET='/usr/local/bin/wget'
X11_DIR=''
X11_INCLUDE=''
X11_LIB=''
XMLLINT=':'
XMLSTARLET=':'
ZLIB_DIR=''
ZLIB_INCLUDE=''
ZLIB_LIB=''
_libcurl_config=''
ac_ct_AR='ar'
ac_ct_CC='cc'
ac_ct_CXX='c++'
ac_ct_STRIP='strip'
astdatadir='${astvarlibdir}'
astdbdir='${localstatedir}/db/asterisk'
astetcdir='${sysconfdir}/asterisk'
astheaderdir='${includedir}/asterisk'
astkeydir='${astvarlibdir}'
astlibdir='${libdir}'
astlogdir='${localstatedir}/log/asterisk'
astmandir='${mandir}'
astmoddir='${libdir}/asterisk/modules'
astsbindir='${sbindir}'
astspooldir='${localstatedir}/spool/asterisk'
astvarlibdir='${prefix}/share/asterisk'
astvarrundir='${localstatedir}/run/asterisk'
ax_pthread_config=''
bindir='${exec_prefix}/bin'
build='x86_64-unknown-freebsd11.1'
build_alias=''
build_cpu='x86_64'
build_os='freebsd11.1'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-freebsd11.1'
host_alias=''
host_cpu='x86_64'
host_os='freebsd11.1'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
#define _HAVE_STRING_ARCH_strcmp 1
#define _HAVE_STRING_ARCH_strsep 1
configure: exit 1
Во FreeBSD новичок, из-за этого я х.з. куда копать =(
И гугл как на зло молчит...
2 часа назад, GrandPr1de сказал:
там в 11-ой явно что-то сломано для астериска
ставте 10.х
Хотелось бы понять, что именно и как это исправить?
Ведь, не один же я на всем шарике, решил запилить на 11-ю фряху последний релиз астериска.
P.S. Если кто-то знает, но молчит, в таком случае готов заплатить за инфу...
Ну я слышал такое же от знакомого, который пытался поставить астериск на фрю 11.
Говорит проебался там и с clang и с gcc, в общем кучу времени убил, один хрен не заработало.
20 минут назад, GrandPr1de сказал:
Такая же фигня.... Уже неделю мучаюсь...
Но я пока еще не потерял надежды =)
Вот думаю запосить тему на профильном форуме.
Только не знаю на каком, на freebsd или asterisk?
копать в направлении ошибок по применению патча
failed
сначала нужно удалить весь каталог астериска
а потом сначала запустить конфигуре с этой опции
потому что не видно на каком этапе патч ломается
судя по всему или качается не тот пгсип или в 11 версии бсд сломали комманду патч
21 минуту назад, paradox_ сказал:
Так если я удалю всё содержимое то и запускать будет не чего =)
Или тут что другое имеется ввиду?
смените профессию если не понимаете
ясно же что удалить = подразумевалось удалить, распаковать и запустить конфигуре с опцией
Ну вот, просишь помочь, а тебе говорят смени профессию...
15 минут назад, paradox_ сказал:
Делал так, но результат тот же:
Applying patches
failed
То что вы сейчас делаете - трата времени на то, чтобы насрать в систему и получить много боли при следующем же обновлении этого астериска.
Нужно не страдать хернёй а делать порт и выкладывать на багтрекер.
Начать проще скопировав net/asterisk13 в net/asterisk15, почистив патчи в files.
Потом поправить номер версии в makefile и сделать make makesum чтобы оно скачало и посчитало КС.
Потом поправить=актуализировать список опций и пытаться собрать.
Накидать патчей в files для починки сборки / добавления функционала...
Когда всё будет собираться сделать make makeplist и обновить соотвествующий файл в папке порта.
Потом на багтрекер скинуть.
Обычно для простых/качественных прог оно занимает от 5-10 минут: поменять номер версии, make makesum, потом сравнить make makeplist с тем что есть и может поправить.
Иногда бывает жопа, как например у меня с OpenCV: там 100500 опций и зависимостей, пока всё перечислишь...
Или очень большая жопа как с xorg-server - там кусок важного функционала лежит патчем, те дописан при портировании и хз почему апстриму не ушёл.
4 минуты назад, Jora_Cornev сказал:
любой уважающий себя админ должен уметь разобраться с банальным конфигуре, либо сложить полномочия
знания программирования даже не нужно что бы это пофиксить
ну показывайте  pjsip/src/pjsip/sip_transaction.c.rej
очевидно проблема с патчами в пгсип asterisk-15.1.2\third-party\pjproject\patches
сравнить файл выше и найти в каком он патче
поправить и собрать
а с учетом того что знаний у вас нет, то я не вижу смысла бежать за 15 версии, а установить 13 версию из портов
Угу, рассказывай дальше.
Раз такой умный собери у себя на фряшечке, потом будешь рассказывать.
астериск13 имеет довольно обширный makefile в котором не мало подпорок.
Что касается скачивания /tmp/pjproject-2.6.tar.bz2 из конфигуратора или makefile проекта - это ппц полный.
Я бы на месте автора заводил баг и просил помощи в рассылке и на форуме фряшном, сам он такое не осилит.
Ивану тоже бы пора сложить полномочия, да некому отмашку дать
не вижу никаких обширных мейкфайлов кроме портового, где все подпорки это перенастройка всех зависимостей на порты
а скачивание pjsip потому что дигиум ведет его отдельно у себя на гитхабе и стандартный что в бсд портах в пролете
но сейчас админы такие ленивые что лучше ставьте все из портов
11 минут назад, paradox_ сказал:
paradox_ , Ivan правильно сказал, вы сами то, попробуете!?
Если осилите, бонус с меня.
я уже вырос из возраста что бы пробовать, ваших бонусов не хватит что бы я за это взялся
за 10 лет, астериска на бсд я наставился ..., так что давайте теперь сами учитесь
для совсем ленивых порты не зря придумали, для поялёкать на нескольких телефонах вам хватит и 13 версии
1 час назад, paradox_ сказал:
У меня нет полномочий (хотя я типа коммитер пары портов, но мне они не впёрлись).
Проект - каша.
Помимо кучи зависимостей там ещё кучка костылей, отдельно патчи к системе сборки лежат.
То что оно там само тянет - это против идеологии портов: все файлы которые скачиваются - должны скачиватся самой фрёвой системой сборки до начала сборки и контрольные суммы должны быть прописаны. Те систему сборки астериска необходимо патчить чтобы она и не качала и не искала в /tmp. Хотя там вроде опция какая то была, может её достаточно будет после "ручного" скачивания и распаковки. Опять же костыль.
Это всё мне напомнило FreeRDP-WebConnect, там родная система сборки это два скрипта: один ставит зависимости а второй качает оставшееся и компеляет в хомяке. Тихий ужас.
Опять слился?)
Вот так технично меня слили с вопросом посему не работает:
Цитата
FreeBSD is not a platform used by many in the Asterisk project and not supported by the normal community. It is possible that things don’t work properly currently on it. In this case it appears as though a patch failed (that does work on Linux).
18 минут назад, Jora_Cornev сказал:
 Правда не уточнили, на каких диалектов пингвинов :). А у пингвиноидов - всё прекрасно, правда над их коммьюнити висит надпись на украинском "обережно, мавпы кидаются калом!" :)
20 часов назад, Jora_Cornev сказал:
ну дык какбы логично: никто не юзает на бзде, соответственно никто не проверяет работоспособность и вообще собираемость.
вы бы еще насчет неработоспособности на солярке или hp-ux пожаловались...
 А чего нету в версии из текущего порта, там лежит asterisk-13.16.0.tar.gz. Небольшой знаток астериска, но эту версию могу поставить банально из портов, что собственно и мэйкаю. Натащил в систему всякой хрени, полезной и не очень. Пару часов мейкался, дотащил всё что ему надо. Без ошибок, freebsd11, порты позавчерашние, свежую систему ставил. Теперь есть все исходники астерикса, могу и патчи подложить.
22 часа назад, Jora_Cornev сказал:
Откуда такая информация?
дык вам же написали: FreeBSD is not a platform used by many in the Asterisk project
можете еще статистику использования бзди в серверном хозяйстве глянуть, где она гордо конкурирует с mac os x server...
А чем обусловлен выбор именно FreeBSD?
Почему не на Linux like, на том же CentOS например? В последнем * есть даже в yum, 100% соберётся.
Тем более что...
В 23.11.2017 в 18:54, Jora_Cornev сказал:
4 часа назад, AlKov сказал:
Тем более что...
 Ну, наверное от того, что сервер давно успешно работает, и на нём кроме астериска еще много задач крутится успешно ?  Настроенных триста лет назад.  Менять сервер и ос на новые - это не в нашем кризисе пока. Хотя - пару новых б/у серверов на распродажах я прикупил. ИБМ таки, и даже ремкомлекты кулеров есть. Диски - конечно сразу под замену, хотя сас на сата можно поменять самостоятельно, правда горячей замены не будет.
