Прикупили железку ASR 1002, возникла проблема, сессии поднимает на ура, в Интернет доступа нет, хоть интерфейс внешний для pppoe-сессии виден. Настраивал по разным манам результата нет. С цисками раньше дел не имел, прошу помочь
aaa new-model
aaa session-mib disconnect
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting update periodic 5
aaa accounting network default start-stop group radius
aaa session-id common
bba-group pppoe global
 virtual-template 1
 sessions max limit 8000
 ac name ASR
 sessions per-mac limit 1
 sessions per-vlan limit 500
 sessions auto cleanup
interface GigabitEthernet0/0/1 #внешний интерфейс
 ip address 192.168.0.1 255.255.255.0
 ip nat outside
 ip route-cache flow
 negotiation auto
interface GigabitEthernet0/0/2 #внутренний интерфейс
 ip address 10.222.0.2 255.255.224.0
 pppoe enable group global
interface Virtual-Template1
 mtu 1492
 ip nat inside
 ip unnumbered GigabitEthernet0/0/2
 ip route-cache flow
 autodetect encapsulation ppp
 peer default ip address pool PPPoE
 ppp max-bad-auth 3
 ppp authentication chap radius
 ppp authorization radius
 ppp accounting radius
 ppp timeout retry 3
 ppp timeout authentication 45
 ppp timeout idle 3600
ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip classless
access-list 1 permit 10.222.2.1 10.222.9.254
ip local pool PPPoE 10.222.2.1 10.222.9.254
ip flow-cache timeout inactive 10
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0/1
ip flow-export version 5
ip flow-export destination 10.222.18.161 9996
access-list 3 permit 10.222.18.161
access-list 3 deny   any log
snmp-server community qbiqing RW 3
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps aaa_server
snmp-server host 10.222.18.161 161
snmp-server host 10.222.18.161 2c
snmp-server host 10.222.18.161 aaa
snmp-server host 10.222.18.161 qqq11  snmp
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server attribute 31 mac format unformatted
radius-server host 10.222.18.161 auth-port 1812 acct-port 1813 non-standard
radius-server retransmit 5
radius-server timeout 30
radius-server deadtime 1
radius-server key 0 gbilloy
radius-server vsa send accounting
radius-server vsa send authentication
Циска шлюз свой видит. из pppoe сессии виден внутренний и внешний интерфейс, дальше ни-ни
Всем спасибо за помощь! возникла еще одна проблема. Сессии поднимаются, доступ в интернет есть, но не работают днс, при этом сессия днс получает. Т.е. на стороне клиента по IP в интернет доступ есть а по доменному имени нет. Буду рад любому совету.
54 минуты назад, mr6in сказал:
дальнейшие копания выявили следующее. После перезагрузки циски какое то время все работает нормально. Через 5-7 минут перестают работать dns еще через пять остается виден лишь IP внешнего интерфейса (это из под сессии). Сама циска при этом пингует шлюз и днс.
И еще. Заметил что некоторые сайты грузятся дольше остальных, и похоже дело отличие в http/https
Edited by mr6in
Рано радовался((( Интернет стабильно работает несколько часов, потом сайты перестают открываться, хотя 8ки пингуются, mtu 1492 mss 1452, такое ощущение что эти значения слетают, хотя такое невозможно
А у вас банально трансляции не кончаются? А то вы как-то всех абонентов в один IP адрес натите...
покажите sh ip nat statistics в момент когда "кончается" интернет.
а еще, судя по ip адресу вашего внешнего интерфейса, вы еще где-то натите ваш трафик - это не очень хорошо....
40 минут назад, Archville сказал:
до этого работало на Debian+PPPoE таких проблем не было
это ни о чем не говорит. В линуксячем ядре все немного по другому. И таймауты другие и алгоритм обработки всяких ошибок/переполнений/коллизий скорее всего отличается.
21 час назад, Archville сказал:
Это временный IP, вообще там "белый" ip
11 минут назад, zhenya` сказал:
В логе ошибок нет?
как я уже говорил, с циской дел не имел, но просто sh log ничего странного не показывает
Таймеры попробуйте задать поменьше (значения можно подкорректировать):
ip nat settings pap
ip nat translation timeout 60
ip nat translation tcp-timeout 60
ip nat translation pptp-timeout 600
ip nat translation udp-timeout 60
ip nat translation icmp-timeout 60
ip nat translation max-entries all-host 600
Внутри шаблона у меня еще такая строка:
ip mtu 1492
P.S. Ну и, имхо, правильнее вешать шаблон на лупбек, а не на физический интерфейс.
В 24.11.2017 в 15:40, mr6in сказал:
 Похоже на протухание кэша DNS. Посмотрите - что вы отдаете клиентам в части  днс, не зафильтровано ли ? Ну и шаблоны я нарисовываю на виртуальные интерфейсы, через темплейт.
  • 1 month later...
В 26.11.2017 в 11:53, YuryD сказал:
Временно отложили циску, теперь взялсь вновь, можно поподробнее про протухание кэша, и фильтров? Самостоятельный поиск ни к чему не привел. Вот финальный конфиг:
version 15.2
service timestamps debug datetime msec
service timestamps log datetime msec
no platform punt-keepalive disable-kernel-core
hostname ASR
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password xxxxx
aaa new-model
multilink bundle-name authenticated
username xxxx privilege 15 password 0 xxxxxx
redundancy
 mode none
ip tftp source-interface GigabitEthernet0
policy-map pppoe_5000_in
 class class-default
  police 5000000 937500 1875000 conform-action transmit  exceed-action drop  violate-action drop
policy-map pppoe_5000_out
 class class-default
  shape average 5280000 5000 5000
policy-map pppoe_10000_in
 class class-default
  police 10240000 1024000 1280000 conform-action transmit  exceed-action drop  violate-action drop
policy-map pppoe_30000_in
 class class-default
  police 30000000 937500 1875000 conform-action transmit  exceed-action drop  violate-action drop
policy-map pppoe_15000_in
 class class-default
  police 15000000 937500 1875000 conform-action transmit  exceed-action drop  violate-action drop
 virtual-template 1
 ac name ASR
interface Loopback0
 no ip address
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 negotiation auto
interface GigabitEthernet0/0/3
 ip address х.х.х.х 255.255.255.252
 ip nat outside
 ip flow ingress
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address 10.222.0.6 255.255.224.0
 negotiation auto
 mtu 1492
 ip unnumbered Loopback0
 ip nat inside
 ip flow ingress
 ip flow egress
 ip tcp adjust-mss 1452
 ppp max-bad-auth 3
 ppp ipcp dns 194.67.1.154 194.67.1.155
 ppp timeout retry 3
ip local pool PPPoE 10.222.2.1 10.222.10.254
ip nat inside source list 1 interface GigabitEthernet0/0/3 overload
ip forward-protocol nd
ip flow-export source GigabitEthernet0/0/2
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 х.х.х.х
access-list 1 permit 10.222.0.0 0.0.15.255
snmp-server community bgbilling RW 3
snmp-server host 10.222.18.161 pass  snmp
snmp ifmib ifindex persist
radius-server attribute 31 mac format unformatted lower-case
radius-server key bgbilling
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password xxxxxx
end
Edited by mr6in
conf t
int lo0
ip addr <любой адрес> 255.255.255.255
как выше сказали показывайте
show ip nat stat в момент проблем.
+ на интерфейсах с айпи адресами
no ip proxy-arp
no ip unreach
no ip redirect
5 часов назад, zhenya` сказал:
conf t
int lo0
no ip proxy-arp
no ip unreach
no ip redirect
ASR#sh ip nat statistics
Total active translations: 837 (0 static, 837 dynamic; 837 extended)
Outside interfaces:
Inside interfaces:
  Virtual-Access2.1, Virtual-Access2.2, Virtual-Access2.5, Virtual-Access2.9
  Virtual-Access2.24, Virtual-Access2.34, Virtual-Access2.38
  Virtual-Access2.46, Virtual-Access2.48, Virtual-Access2.61
  Virtual-Access2.62, Virtual-Access2.86, Virtual-Access2.87
  Virtual-Access2.92, Virtual-Access2.97, Virtual-Access2.101
  Virtual-Access2.105, Virtual-Access2.114, Virtual-Access2.115
  Virtual-Access2.118, Virtual-Access2.144, Virtual-Access2.153
  Virtual-Access2.419, Virtual-Access2.428, Virtual-Access2.431
  Virtual-Access2.432, Virtual-Access2.433, Virtual-Access2.442
  Virtual-Access2.447, Virtual-Access2.459, Virtual-Template1
Hits: 18815146  Misses: 297016
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 304199
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface GigabitEthernet0/0/3 refcount 807
nat-limit statistics:
 max entry: max allowed 0, used 0, missed 0
 All Host Max allowed: 600
Pool stats drop: 0  Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
