Обрыв соединения PPPoE
Здравствуйте, помогите расшифровать лог или кто обрывает соединение провайдер или оборудование
Спойлер
Jul 19 17:36:11 ubnt: Messages cleared.
Jul 19 17:39:07 pppd[19786]: No response to 5 echo-requests
Jul 19 17:39:07 pppd[19786]: Serial link appears to be disconnected.
Jul 19 17:39:07 pppd[19786]: Connect time 7.8 minutes.
Jul 19 17:39:07 pppd[19786]: Sent 32310047 bytes, received 1757526045 bytes.
Jul 19 17:39:07 pppd[19786]: Connection terminated.
Jul 19 17:39:08 dnsmasq[19787]: no servers found in /etc/resolv.conf, will retry
Jul 19 17:39:09 pppd[19786]: PPP session is 2754
Jul 19 17:39:09 pppd[19786]: Using interface ppp0
Jul 19 17:39:09 pppd[19786]: Connect: ppp0 <--> eth0
Jul 19 17:39:09 pppd[19786]: PAP authentication succeeded
Jul 19 17:39:09 pppd[19786]: peer from calling number 4C:96:14:AB:E8:A4 authorized
Jul 19 17:39:09 pppd[19786]: local  IP address 46.158.88.143
Jul 19 17:39:09 pppd[19786]: remote IP address 178.34.128.4
Jul 19 17:39:09 pppd[19786]: primary   DNS address 85.175.46.122
Jul 19 17:39:09 pppd[19786]: secondary DNS address 85.175.46.130
Jul 19 17:39:09 dnsmasq[19787]: reading /etc/resolv.conf
Jul 19 17:39:09 dnsmasq[19787]: using nameserver 85.175.46.130#53
Jul 19 17:39:09 dnsmasq[19787]: using nameserver 85.175.46.122#53
Jul 19 17:40:01 dropbear[20506]: Child connection from 5.188.10.176:54989
Jul 19 17:40:31 dropbear[20506]: Login attempt for nonexistent user from 5.188.10.176:54989
Jul 19 17:40:33 dropbear[20506]: Exit before auth: Exited normally
Jul 19 17:40:33 dropbear[20522]: Child connection from 5.188.10.176:42842
Jul 19 17:41:04 dropbear[20522]: Login attempt for nonexistent user from 5.188.10.176:42842
Jul 19 17:41:07 dropbear[20522]: Login attempt for nonexistent user from 5.188.10.176:42842
Jul 19 17:41:12 dropbear[20522]: Exit before auth: Exited normally
Jul 19 17:41:12 dropbear[20542]: Child connection from 5.188.10.176:37981
Jul 19 17:41:38 dropbear[20542]: Exit before auth: Exited normally
Edited by avv969
3 минуты назад, NewUse сказал:
какое соединение то?
можно попробовать включить расширенное логирование
соединение pppoe
а расширенное не найду
извиняюсь за малознание но такая ситуация , ставлю в закачку торрент и идет перезагрузка pppoe
