catalist Posted October 17, 2017 Posted October 17, 2017 Добрый день! Имеется две цыски 6509 Sup 720 и ESR-10K Они соединены патчкордом (9/2------1/0/0) При это на стороне 6509 все ок, ни ошибо ни гигантов, а вот со стороны ESR огромный счетчик гигантов: Cisco 6509: interface GigabitEthernet9/2 description -> ESR-I 1/0/0 switchport switchport trunk encapsulation dot1q switchport mode trunk load-interval 30 speed nonegotiate hold-queue 4096 in hold-queue 4096 out GigabitEthernet9/2 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 000d.659c.3c51 (bia 000d.659c.3c51) Description: -> ESR-I 1/0/1 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 11/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is 1000BaseSX input flow-control is off, output flow-control is on Clock mode is auto ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:00:44, output hang never Last clearing of "show interface" counters never Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 573866 Queueing strategy: fifo Output queue: 0/4096 (size/max) 30 second input rate 45221000 bits/sec, 5119 packets/sec 30 second output rate 6285000 bits/sec, 4332 packets/sec 15041664370 packets input, 15865528405373 bytes, 0 no buffer Received 251172 broadcasts (1226 multicasts) 51 runts, 0 giants, 0 throttles 51 input errors, 51 CRC, 51 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 15676546352 packets output, 4517836505587 bytes, 0 underruns 0 output errors, 0 collisions, 4 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out ESR: ESR-I#sh int gig 1/0/0 GigabitEthernet1/0/0 is up, line protocol is up Hardware is Gigabit Ethernet MAC Controller, address is 0022.90a2.1418 (bia 0022.90a2.1418) Description: ->C6509V-I (9/2) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 11/255, rxload 1/255 Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set Keepalive set (10 sec) Full Duplex, 1000Mbps, link type is force-up, media type is SX output flow-control is unsupported, input flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 6w1d Input queue: 0/4096/0/1580 (size/max/drops/flushes); Total output drops: 66 Interface GigabitEthernet1/0/0 queueing strategy: PXF Class-based 30 second input rate 5864000 bits/sec, 3710 packets/sec 30 second output rate 44193000 bits/sec, 5049 packets/sec 55941839348 packets input, 17333486743506 bytes, 0 no buffer Received 422923320 broadcasts (0 IP multicasts) 0 runts, 419289435 giants, 0 throttles ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 25 multicast, 0 pause input 71409969960 packets output, 72398918950574 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out interface GigabitEthernet1/0/0 description ->C6509V-I (9/2) no ip address no ip proxy-arp load-interval 30 no negotiation auto hold-queue 4096 in hold-queue 4096 out MTU с обоих сторон совпадает. В чем может быть дело? Вставить ник Quote
zhenya` Posted October 17, 2017 Posted October 17, 2017 в том, что eltex.. вероятно они считают по разному MTU аля IOS XR vs IOS classic mtu пинги с df ходят без проблем? Вставить ник Quote
catalist Posted October 17, 2017 Author Posted October 17, 2017 ЭЭЭЭЭ, а причем тут элтекс? У меня две цыски! ESR это не элтекс это цыска! Если вы про DontFragment то пинги ходят без проблем. Вставить ник Quote
v_r Posted October 20, 2017 Posted October 20, 2017 Скорее всего на ESR это особенность интерфейса, giants'ом он считает кадр больше 1518 байт (то есть все кадры с тэгами), но такие кадры не считаются как ошибки и не дропаются. Вставить ник Quote
catalist Posted October 20, 2017 Author Posted October 20, 2017 53 минуты назад, v_r сказал: Скорее всего на ESR это особенность интерфейса, giants'ом он считает кадр больше 1518 байт (то есть все кадры с тэгами), но такие кадры не считаются как ошибки и не дропаются. хм, а как может прилететь такой кадр если мту со стороны каталиста стоит 1500? Вставить ник Quote
v_r Posted October 20, 2017 Posted October 20, 2017 1500 - IP MTU. + 18 байт заголовка Ethernet если без тэга 802.1q или +22 байта если с тэгом, а у вас кадры летят с тэгом. interface GigabitEthernet9/2 switchport switchport trunk encapsulation dot1q switchport mode trunk Вставить ник Quote
catalist Posted October 20, 2017 Author Posted October 20, 2017 тоесть или уменьшить мту? или забить? Вставить ник Quote
v_r Posted October 20, 2017 Posted October 20, 2017 Ставить MTU меньше не стоит, будет как с туннелями - часть сайтов не открывается, часть сайтов тормозит и т.д. Оставьте как есть, вот такая особенность счетчиков на данном чипе, главное что input errors по нулям. Вставить ник Quote
catalist Posted October 21, 2017 Author Posted October 21, 2017 Думаю ещё попробовать убрать вилан с куинку из транка в сторону еср Вставить ник Quote
catalist Posted November 8, 2017 Author Posted November 8, 2017 Убрал, странно, это не помогло.... Вставить ник Quote
