===>>> All >> unbound-1.6.4_1 (2/3)
===>  Cleaning for unbound-1.6.6
===>  License BSD3CLAUSE accepted by the user
===>   unbound-1.6.6 depends on file: /usr/local/sbin/pkg - found
===> Fetching all distfiles required by unbound-1.6.6 for building
===>  Extracting for unbound-1.6.6
=> SHA256 Checksum OK for unbound-1.6.6.tar.gz.
===>  Patching for unbound-1.6.6
/bin/cat /usr/ports/dns/unbound/work/unbound-1.6.6/contrib/aaaa-filter-iterator.patch | /usr/bin/patch -d /usr/ports/dns/unbound/work/unbound-1.6.6 -p1 -s
1 out of 3 hunks failed--saving rejects to iterator/iterator.h.rej
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/dns/unbound
*** Error code 1
Stop.
make: stopped in /usr/ports/dns/unbound
===>>> make build failed for dns/unbound
===>>> Aborting update
===>>> Update for dns/unbound failed
===>>> There are messages from installed ports to display,
       but first take a moment to review the error messages
       above.  Then press Enter when ready to proceed.
src.conf
WITHOUT_UNBOUND=
make reinstall clean
1 out of 4 hunks failed--saving rejects to iterator/iter_scrub.c.rej
Reversed (or previously applied) patch detected!  Assume -R? [y] y
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/dns/unbound
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
Ну и как эти патчи накатить кто мне скажет?
unbound-control | grep Version
Version 1.6.4
linked libs: libevent 2.1.8-stable (it uses kqueue), OpenSSL 1.0.2l  25 May 2017
linked modules: dns64 subnetcache respip validator iterator
BSD licensed, see LICENSE in source package for details.
Report bugs to unbound-bugs@nlnetlabs.nl
20 часов назад, Ivan_83 сказал:
svn revert -R
долбаный корявый форум!
У меня portsnap, хотя в чятике FreeBSD_ru в телеграмм его тоже захейтили и сказали, "А почему не svn ?" Как мигрировать можно? Я же по старинке как издавно по хендбуку make update или portsnap fetch )
Edited by hsvt
# migrate to SVN
cd /usr/ports/devel/subversion (+option:NEON !!!)
make install clean
svn checkout svn://svn.freebsd.org/doc/head /usr/doc
 - svn checkout https://svn0.us-west.FreeBSD.org/base/head /usr/src
 - /head/ which corresponds to HEAD, also known as -CURRENT.
 - /stable/n which corresponds to RELENG_n.
 - /releng/n.n which corresponds to RELENG_n_n.
 - /release/n.n.n which corresponds to RELENG_n_n_n_RELEASE.
svn checkout svn://svn.freebsd.org/base/stable/11 /usr/src
svn checkout svn://svn.freebsd.org/ports/head /usr/ports
# upgrade to next version
svn switch svn://svn.freebsd.org/base/stable/10 /usr/src
# return to revision
svn up -r272754 /usr/src
# change URL
svn switch --relocate https://svn0.us-west.FreeBSD.org/base/stable/9 svn://svn.freebsd.org/base/stable/9 /usr/src
# FIX: "Node remains in conflict"
svn revert -R /usr/ports
svn revert -R /usr/src
cat /root/bin/update-fast
#!/bin/sh
svn update /usr/doc && svn cleanup /usr/doc &
svn update /usr/src && svn cleanup /usr/src &
svn update /usr/ports && svn cleanup /usr/ports &
make -C /usr/ports fetchindex > /dev/null 2>&1 &
pkg audit -F &
pkg update -q &
wait
В 29.09.2017 в 01:22, Ivan_83 сказал:
# migrate to SVN
make install clean
# change URL
#!/bin/sh
pkg audit -F &
pkg update -q &
wait
Ничо не поменялось) да и реверт не проходит.
rm -rf /usr/ports
svn co svn://svn.freebsd.org/ports/head /usr/ports
Checked out revision 451317.
Service unavailableService unavailableUpdating '.':
At revision 451317.
portmaster -vda
*** Error code 1
Stop.
*** Error code 1
Stop.
===>>> You can restart from the point of failure with this command line:
       portmaster <flags> dns/unbound
This command has been saved to /tmp/portmasterfail.txt
svn revert -R /usr/ports/dns/unbound
