Всем привет.
Есть сервер supermicro с установленной:
# uname -a
FreeBSD nas 10.3-RELEASE FreeBSD 10.3-RELEASE #2: Tue Aug  1 02:41:55 YEKT 2017     nas@nas:/usr/obj/usr/src/sys/nas  amd64
И периодически вылезает на нем:
Thu Sep 14 22:46:57 YEKT 2017
panic: page fault
GNU gdb 6.1.1 [FreeBSD]
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "amd64-marcel-freebsd"...
Unread portion of the kernel message buffer:
stack pointer	        = 0x28:0xfffffe0221f950f0
frame pointer	        = 0x28:0xfffffe0221f95190
code segment		= base 0x0, limit 0xfffff, type 0x1b
			= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags	= interrupt enabled, resume, IOPL = 0
current process		= 13 (ng_queue0)
trap number		= 12
panic: page fault
cpuid = 3
KDB: stack backtrace:
#0 0xffffffff80994c60 at kdb_backtrace+0x60
#1 0xffffffff80957936 at vpanic+0x126
#2 0xffffffff80957803 at panic+0x43
#3 0xffffffff80d6416b at trap_fatal+0x36b
#4 0xffffffff80d6446d at trap_pfault+0x2ed
#5 0xffffffff80d63aea at trap+0x47a
#6 0xffffffff80d49ac2 at calltrap+0x8
#7 0xffffffff80aa4f16 at ip_input+0x4c6
#8 0xffffffff80a28e42 at netisr_dispatch_src+0x62
#9 0xffffffff80a7fc4f at ng_iface_rcvdata+0xdf
#10 0xffffffff80a7aabc at ng_apply_item+0x22c
#11 0xffffffff80a7a6d3 at ng_snd_item+0x1a3
#12 0xffffffff80a7aabc at ng_apply_item+0x22c
#13 0xffffffff80a7a6d3 at ng_snd_item+0x1a3
#14 0xffffffff80a7aabc at ng_apply_item+0x22c
#15 0xffffffff80a7a6d3 at ng_snd_item+0x1a3
#16 0xffffffff80a89228 at ng_ppp_comp_recv+0x148
#17 0xffffffff80a7aabc at ng_apply_item+0x22c
Uptime: 3d17h36m51s
Dumping 1247 out of 7989 MB:..2%..11%..21%..31%..42%..51%..61%..71%..81%..92%
Reading symbols from /boot/kernel/ums.ko.symbols...done.
Loaded symbols for /boot/kernel/ums.ko.symbols
#0  doadump (textdump=<value optimized out>) at pcpu.h:219
219	pcpu.h: No such file or directory.
	in pcpu.h
(kgdb) #0  doadump (textdump=<value optimized out>) at pcpu.h:219
#1  0xffffffff80957592 in kern_reboot (howto=260)
    at /usr/src/sys/kern/kern_shutdown.c:486
#2  0xffffffff80957975 in vpanic (fmt=<value optimized out>,
    ap=<value optimized out>) at /usr/src/sys/kern/kern_shutdown.c:889
#3  0xffffffff80957803 in panic (fmt=0x0)
    at /usr/src/sys/kern/kern_shutdown.c:818
#4  0xffffffff80d6416b in trap_fatal (frame=<value optimized out>,
    eva=<value optimized out>) at /usr/src/sys/amd64/amd64/trap.c:858
#5  0xffffffff80d6446d in trap_pfault (frame=0xfffffe0221f95040,
    usermode=<value optimized out>) at /usr/src/sys/amd64/amd64/trap.c:681
#6  0xffffffff80d63aea in trap (frame=0xfffffe0221f95040)
    at /usr/src/sys/amd64/amd64/trap.c:447
#7  0xffffffff80d49ac2 in calltrap ()
    at /usr/src/sys/amd64/amd64/exception.S:236
#8  0xffffffff80955a99 in __rw_rlock (c=0xfffff80195903438, file=0x0, line=0)
    at /usr/src/sys/kern/kern_rwlock.c:430
#9  0xffffffff80aa4f16 in ip_input (m=0xfffff80052283100)
    at /usr/src/sys/netinet/ip_input.c:593
#10 0xffffffff80a28e42 in netisr_dispatch_src (proto=<value optimized out>,
    source=<value optimized out>, m=0x0) at /usr/src/sys/net/netisr.c:976
#11 0xffffffff80a7fc4f in ng_iface_rcvdata (hook=<value optimized out>,
    item=<value optimized out>) at /usr/src/sys/netgraph/ng_iface.c:780
#12 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006ded0a00,
    item=0xfffff801f5821e00, rw=0) at /usr/src/sys/netgraph/ng_base.c:2397
#13 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
    flags=<value optimized out>) at /usr/src/sys/netgraph/ng_base.c:2314
#14 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006df86900,
#15 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
#16 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006dea6100,
#17 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
#18 0xffffffff80a89228 in ng_ppp_comp_recv (node=<value optimized out>,
    item=0xfffff801f5821e00, proto=<value optimized out>,
    linkNum=<value optimized out>) at /usr/src/sys/netgraph/ng_ppp.c:947
#19 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006dfe6000,
#20 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
#21 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006de5d100,
#22 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
#23 0xffffffff80a8eab4 in ng_pptpgre_rcvdata_lower (
    hook=<value optimized out>, item=0xfffff801f5821e00)
    at /usr/src/sys/netgraph/ng_pptpgre.c:811
#24 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006dfe8a00,
#25 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff801f5821e00,
#26 0xffffffff80a81812 in ng_ksocket_incoming2 (node=0xfffff8014b16c700,
    hook=<value optimized out>, arg1=0xfffff801954402b8, arg2=0)
    at /usr/src/sys/netgraph/ng_ksocket.c:1165
#27 0xffffffff80a7a93c in ng_apply_item (node=0xfffff8014b16c700,
    item=0xfffff801f5094000, rw=1) at /usr/src/sys/netgraph/ng_base.c:2468
#28 0xffffffff80a7c729 in ngthread (arg=<value optimized out>)
    at /usr/src/sys/netgraph/ng_base.c:3432
#29 0xffffffff8092276a in fork_exit (callout=0xffffffff80a7c630 <ngthread>,
    arg=0x0, frame=0xfffffe0221f959c0) at /usr/src/sys/kern/kern_fork.c:1027
#30 0xffffffff80d49ffe in fork_trampoline ()
    at /usr/src/sys/amd64/amd64/exception.S:611
#31 0x0000000000000000 in ?? ()
Current language:  auto; currently minimal
(kgdb)
Пробовал тюнить, пробовал отключать встроенный web и telnet, пробовал менять в конфиге время на реконнект - все равно никак и никуда.
Кто как боролся с этим?
Спасибо.
1 час назад, murano сказал:
Ядро с какими параметрами пересобирали?
cpu		HAMMER
ident		GENERIC
makeoptions	DEBUG=-g		# Build kernel with gdb(1) debug symbols
makeoptions	WITH_CTF=1		# Run ctfconvert(1) for DTrace support
options 	SCHED_ULE		# ULE scheduler
options 	PREEMPTION		# Enable kernel thread preemption
options 	INET			# InterNETworking
#options 	INET6			# IPv6 communications protocols
options 	TCP_OFFLOAD		# TCP offload
options 	SCTP			# Stream Control Transmission Protocol
options 	FFS			# Berkeley Fast Filesystem
options 	SOFTUPDATES		# Enable FFS soft updates support
options 	UFS_ACL			# Support for access control lists
options 	UFS_DIRHASH		# Improve performance on big directories
options 	UFS_GJOURNAL		# Enable gjournal-based UFS journaling
options 	QUOTA			# Enable disk quotas for UFS
options 	MD_ROOT			# MD is a potential root device
options 	NFSCL			# New Network Filesystem Client
options 	NFSD			# New Network Filesystem Server
options 	NFSLOCKD		# Network Lock Manager
options 	NFS_ROOT		# NFS usable as /, requires NFSCL
options 	MSDOSFS			# MSDOS Filesystem
options 	CD9660			# ISO 9660 Filesystem
options 	PROCFS			# Process filesystem (requires PSEUDOFS)
options 	PSEUDOFS		# Pseudo-filesystem framework
options 	GEOM_PART_GPT		# GUID Partition Tables.
options 	GEOM_RAID		# Soft RAID functionality.
options 	GEOM_LABEL		# Provides labelization
options 	COMPAT_FREEBSD32	# Compatible with i386 binaries
options 	COMPAT_FREEBSD4		# Compatible with FreeBSD4
options 	COMPAT_FREEBSD5		# Compatible with FreeBSD5
options 	COMPAT_FREEBSD6		# Compatible with FreeBSD6
options 	COMPAT_FREEBSD7		# Compatible with FreeBSD7
options 	SCSI_DELAY=5000		# Delay (in ms) before probing SCSI
options 	KTRACE			# ktrace(1) support
options 	STACK			# stack(9) support
options 	SYSVSHM			# SYSV-style shared memory
options 	SYSVMSG			# SYSV-style message queues
options 	SYSVSEM			# SYSV-style semaphores
options 	_KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions
options 	PRINTF_BUFR_SIZE=128	# Prevent printf output being interspersed.
options 	KBD_INSTALL_CDEV	# install a CDEV entry in /dev
options 	HWPMC_HOOKS		# Necessary kernel hooks for hwpmc(4)
options 	AUDIT			# Security event auditing
options 	CAPABILITY_MODE		# Capsicum capability mode
options 	CAPABILITIES		# Capsicum capabilities
options 	PROCDESC		# Support for process descriptors
options 	MAC			# TrustedBSD MAC Framework
options 	KDTRACE_FRAME		# Ensure frames are compiled in
options 	KDTRACE_HOOKS		# Kernel DTrace hooks
options 	DDB_CTF			# Kernel ELF linker loads CTF data
options 	INCLUDE_CONFIG_FILE	# Include this file in kernel
options 	RACCT			# Resource accounting framework
options 	RACCT_DEFAULT_TO_DISABLED # Set kern.racct.enable=0 by default
options 	RCTL			# Resource limits
# Debugging support.  Always need this:
options 	KDB			# Enable kernel debugger support.
options 	KDB_TRACE		# Print a stack trace for a panic.
# Make an SMP-capable kernel by default
options 	SMP			# Symmetric MultiProcessor Kernel
# CPU frequency control
device		cpufreq
# Bus support.
device		acpi
options 	ACPI_DMAR
device		pci
# Floppy drives
device		fdc
# ATA controllers
device		ahci			# AHCI-compatible SATA controllers
device		ata			# Legacy ATA/SATA controllers
options 	ATA_STATIC_ID		# Static device numbering
device		mvs			# Marvell 88SX50XX/88SX60XX/88SX70XX/SoC SATA
device		siis			# SiliconImage SiI3124/SiI3132/SiI3531 SATA
# SCSI Controllers
device		ahc			# AHA2940 and onboard AIC7xxx devices
options 	AHC_REG_PRETTY_PRINT	# Print register bitfields in debug
					# output.  Adds ~128k to driver.
device		ahd			# AHA39320/29320 and onboard AIC79xx devices
options 	AHD_REG_PRETTY_PRINT	# Print register bitfields in debug
					# output.  Adds ~215k to driver.
device		esp			# AMD Am53C974 (Tekram DC-390(T))
device		hptiop			# Highpoint RocketRaid 3xxx series
device		isp			# Qlogic family
#device		ispfw			# Firmware for QLogic HBAs- normally a module
device		mpt			# LSI-Logic MPT-Fusion
device		mps			# LSI-Logic MPT-Fusion 2
device		mpr			# LSI-Logic MPT-Fusion 3
#device		ncr			# NCR/Symbios Logic
device		sym			# NCR/Symbios Logic (newer chipsets + those of `ncr')
device		trm			# Tekram DC395U/UW/F DC315U adapters
device		adv			# Advansys SCSI adapters
device		adw			# Advansys wide SCSI adapters
device		aic			# Adaptec 15[012]x SCSI adapters, AIC-6[23]60.
device		bt			# Buslogic/Mylex MultiMaster SCSI adapters
device		isci			# Intel C600 SAS controller
# ATA/SCSI peripherals
device		scbus			# SCSI bus (required for ATA/SCSI)
device		ch			# SCSI media changers
device		da			# Direct Access (disks)
device		sa			# Sequential Access (tape etc)
device		cd			# CD
device		pass			# Passthrough device (direct ATA/SCSI access)
device		ses			# Enclosure Services (SES and SAF-TE)
#device		ctl			# CAM Target Layer
# RAID controllers interfaced to the SCSI subsystem
device		amr			# AMI MegaRAID
device		arcmsr			# Areca SATA II RAID
#XXX it is not 64-bit clean, -scottl
#device		asr			# DPT SmartRAID V, VI and Adaptec SCSI RAID
device		ciss			# Compaq Smart RAID 5*
device		dpt			# DPT Smartcache III, IV - See NOTES for options
device		hptmv			# Highpoint RocketRAID 182x
device		hptnr			# Highpoint DC7280, R750
device		hptrr			# Highpoint RocketRAID 17xx, 22xx, 23xx, 25xx
device		hpt27xx			# Highpoint RocketRAID 27xx
device		iir			# Intel Integrated RAID
device		ips			# IBM (Adaptec) ServeRAID
device		mly			# Mylex AcceleRAID/eXtremeRAID
device		twa			# 3ware 9000 series PATA/SATA RAID
device		tws			# LSI 3ware 9750 SATA+SAS 6Gb/s RAID controller
# RAID controllers
device		aac			# Adaptec FSA RAID
device		aacp			# SCSI passthrough for aac (requires CAM)
device		aacraid			# Adaptec by PMC RAID
device		ida			# Compaq Smart RAID
device		mfi			# LSI MegaRAID SAS
device		mlx			# Mylex DAC960 family
device		mrsas			# LSI/Avago MegaRAID SAS/SATA, 6Gb/s and 12Gb/s
#XXX PCI ID conflicts with ahd(4) and mvs(4)
#device		pmspcv			# PMC-Sierra SAS/SATA Controller driver
#XXX pointer/int warnings
#device		pst			# Promise Supertrak SX6000
device		twe			# 3ware ATA RAID
# NVM Express (NVMe) support
device		nvme			# base NVMe driver
device		nvd			# expose NVMe namespaces as disks, depends on nvme
# atkbdc0 controls both the keyboard and the PS/2 mouse
device		atkbdc			# AT keyboard controller
device		atkbd			# AT keyboard
device		psm			# PS/2 mouse
device		kbdmux			# keyboard multiplexer
device		vga			# VGA video card driver
options 	VESA			# Add support for VESA BIOS Extensions (VBE)
device		splash			# Splash screen and screen saver support
# syscons is the default console driver, resembling an SCO console
device		sc
options 	SC_PIXEL_MODE		# add support for the raster text mode
# vt is the new video console driver
device		vt
device		vt_vga
device		vt_efifb
device		agp			# support several AGP chipsets
# PCCARD (PCMCIA) support
# PCMCIA and cardbus bridge support
device		cbb			# cardbus (yenta) bridge
device		pccard			# PC Card (16-bit) bus
device		cardbus			# CardBus (32-bit) bus
# Serial (COM) ports
device		uart			# Generic UART driver
# Parallel port
device		ppc
device		ppbus			# Parallel port bus (required)
device		lpt			# Printer
device		ppi			# Parallel port interface device
#device		vpo			# Requires scbus and da
device		puc			# Multi I/O cards and multi-channel UARTs
# PCI Ethernet NICs.
device		bxe			# Broadcom NetXtreme II BCM5771X/BCM578XX 10GbE
device		de			# DEC/Intel DC21x4x (``Tulip'')
device		em			# Intel PRO/1000 Gigabit Ethernet Family
device		igb			# Intel PRO/1000 PCIE Server Gigabit Family
device		ix			# Intel PRO/10GbE PCIE PF Ethernet
device		ixv			# Intel PRO/10GbE PCIE VF Ethernet
device		ixl			# Intel XL710 40Gbe PCIE Ethernet
device		ixlv			# Intel XL710 40Gbe VF PCIE Ethernet
device		le			# AMD Am7900 LANCE and Am79C9xx PCnet
device		ti			# Alteon Networks Tigon I/II gigabit Ethernet
device		txp			# 3Com 3cR990 (``Typhoon'')
device		vx			# 3Com 3c590, 3c595 (``Vortex'')
# PCI Ethernet NICs that use the common MII bus controller code.
# NOTE: Be sure to keep the 'device miibus' line in order to use these NICs!
device		miibus			# MII bus support
device		ae			# Attansic/Atheros L2 FastEthernet
device		age			# Attansic/Atheros L1 Gigabit Ethernet
device		alc			# Atheros AR8131/AR8132 Ethernet
device		ale			# Atheros AR8121/AR8113/AR8114 Ethernet
device		bce			# Broadcom BCM5706/BCM5708 Gigabit Ethernet
device		bfe			# Broadcom BCM440x 10/100 Ethernet
device		bge			# Broadcom BCM570xx Gigabit Ethernet
device		cas			# Sun Cassini/Cassini+ and NS DP83065 Saturn
device		dc			# DEC/Intel 21143 and various workalikes
device		et			# Agere ET1310 10/100/Gigabit Ethernet
device		fxp			# Intel EtherExpress PRO/100B (82557, 82558)
device		gem			# Sun GEM/Sun ERI/Apple GMAC
device		hme			# Sun HME (Happy Meal Ethernet)
device		jme			# JMicron JMC250 Gigabit/JMC260 Fast Ethernet
device		lge			# Level 1 LXT1001 gigabit Ethernet
device		msk			# Marvell/SysKonnect Yukon II Gigabit Ethernet
device		nfe			# nVidia nForce MCP on-board Ethernet
device		nge			# NatSemi DP83820 gigabit Ethernet
#device		nve			# nVidia nForce MCP on-board Ethernet Networking
device		pcn			# AMD Am79C97x PCI 10/100 (precedence over 'le')
device		re			# RealTek 8139C+/8169/8169S/8110S
device		rl			# RealTek 8129/8139
device		sf			# Adaptec AIC-6915 (``Starfire'')
device		sge			# Silicon Integrated Systems SiS190/191
device		sis			# Silicon Integrated Systems SiS 900/SiS 7016
device		sk			# SysKonnect SK-984x & SK-982x gigabit Ethernet
device		ste			# Sundance ST201 (D-Link DFE-550TX)
device		stge			# Sundance/Tamarack TC9021 gigabit Ethernet
device		tl			# Texas Instruments ThunderLAN
device		tx			# SMC EtherPower II (83c170 ``EPIC'')
device		vge			# VIA VT612x gigabit Ethernet
device		vr			# VIA Rhine, Rhine II
device		wb			# Winbond W89C840F
device		xl			# 3Com 3c90x (``Boomerang'', ``Cyclone'')
# ISA Ethernet NICs.  pccard NICs included.
device		cs			# Crystal Semiconductor CS89x0 NIC
# 'device ed' requires 'device miibus'
device		ed			# NE[12]000, SMC Ultra, 3c503, DS8390 cards
device		ex			# Intel EtherExpress Pro/10 and Pro/10+
device		ep			# Etherlink III based cards
device		fe			# Fujitsu MB8696x based cards
device		sn			# SMC's 9000 series of Ethernet chips
device		xe			# Xircom pccard Ethernet
# Wireless NIC cards
device		wlan			# 802.11 support
options 	IEEE80211_DEBUG		# enable debug msgs
options 	IEEE80211_AMPDU_AGE	# age frames in AMPDU reorder q's
options 	IEEE80211_SUPPORT_MESH	# enable 802.11s draft support
device		wlan_wep		# 802.11 WEP support
device		wlan_ccmp		# 802.11 CCMP support
device		wlan_tkip		# 802.11 TKIP support
device		wlan_amrr		# AMRR transmit rate control algorithm
device		an			# Aironet 4500/4800 802.11 wireless NICs.
device		ath			# Atheros NICs
device		ath_pci			# Atheros pci/cardbus glue
device		ath_hal			# pci/cardbus chip support
options 	AH_SUPPORT_AR5416	# enable AR5416 tx/rx descriptors
options 	AH_AR5416_INTERRUPT_MITIGATION # AR5416 interrupt mitigation
options 	ATH_ENABLE_11N		# Enable 802.11n support for AR5416 and later
device		ath_rate_sample		# SampleRate tx rate control for ath
#device		bwi			# Broadcom BCM430x/BCM431x wireless NICs.
#device		bwn			# Broadcom BCM43xx wireless NICs.
device		ipw			# Intel 2100 wireless NICs.
device		iwi			# Intel 2200BG/2225BG/2915ABG wireless NICs.
device		iwn			# Intel 4965/1000/5000/6000 wireless NICs.
device		malo			# Marvell Libertas wireless NICs.
device		mwl			# Marvell 88W8363 802.11n wireless NICs.
device		ral			# Ralink Technology RT2500 wireless NICs.
device		wi			# WaveLAN/Intersil/Symbol 802.11 wireless NICs.
device		wpi			# Intel 3945ABG wireless NICs.
# Pseudo devices.
device		loop			# Network loopback
device		random			# Entropy device
device		padlock_rng		# VIA Padlock RNG
device		rdrand_rng		# Intel Bull Mountain RNG
device		ether			# Ethernet support
device		vlan			# 802.1Q VLAN support
device		tun			# Packet tunnel.
device		md			# Memory "disks"
#device		gif			# IPv6 and IPv4 tunneling
#device		faith			# IPv6-to-IPv4 relaying (translation)
device		firmware		# firmware assist module
# The `bpf' device enables the Berkeley Packet Filter.
# Be aware of the administrative consequences of enabling this!
# Note that 'bpf' is required for DHCP.
device		bpf			# Berkeley packet filter
# USB support
options 	USB_DEBUG		# enable debug msgs
device		uhci			# UHCI PCI->USB interface
device		ohci			# OHCI PCI->USB interface
device		ehci			# EHCI PCI->USB interface (USB 2.0)
device		xhci			# XHCI PCI->USB interface (USB 3.0)
device		usb			# USB Bus (required)
device		ukbd			# Keyboard
device		umass			# Disks/Mass storage - Requires scbus and da
# Sound support
device		sound			# Generic sound driver (required)
device		snd_cmi			# CMedia CMI8338/CMI8738
device		snd_csa			# Crystal Semiconductor CS461x/428x
device		snd_emu10kx		# Creative SoundBlaster Live! and Audigy
device		snd_es137x		# Ensoniq AudioPCI ES137x
device		snd_hda			# Intel High Definition Audio
device		snd_ich			# Intel, NVidia and other ICH AC'97 Audio
device		snd_via8233		# VIA VT8233x Audio
# MMC/SD
device		mmc			# MMC/SD bus
device		mmcsd			# MMC/SD memory card
device		sdhci			# Generic PCI SD Host Controller
# VirtIO support
device		virtio			# Generic VirtIO bus (required)
device		virtio_pci		# VirtIO PCI device
device		vtnet			# VirtIO Ethernet device
device		virtio_blk		# VirtIO Block device
device		virtio_scsi		# VirtIO SCSI device
device		virtio_balloon		# VirtIO Memory Balloon device
# HyperV drivers and enchancement support
# NOTE: HYPERV depends on hyperv.  They must be added or removed together.
options 	HYPERV			# Hyper-V kernel infrastructure
device		hyperv			# HyperV drivers
# Xen HVM Guest Optimizations
# NOTE: XENHVM depends on xenpci.  They must be added or removed together.
options 	XENHVM			# Xen HVM kernel infrastructure
device		xenpci			# Xen HVM Hypervisor services driver
# VMware support
device		vmx			# VMware VMXNET3 Ethernet
device		pf
device		pflog
options		ALTQ
options		ALTQ_CBQ        # Class Bases Queueing
options		ALTQ_RED        # Random Early Detection
options		ALTQ_RIO        # RED In/Out
options		ALTQ_HFSC       # Hierarchical Packet Scheduler
options		ALTQ_CDNR       # Traffic conditioner
options		ALTQ_PRIQ       # Priority Queueing
options		ALTQ_NOPCC      # Required for SMP build
options 	NETGRAPH
options 	NETGRAPH_PPPOE
options 	NETGRAPH_SOCKET
options 	NETGRAPH_ECHO
options 	NETGRAPH_ETHER
options 	NETGRAPH_IFACE
options 	NETGRAPH_KSOCKET
options 	NETGRAPH_L2TP
options 	NETGRAPH_MPPC_ENCRYPTION
options 	NETGRAPH_PPTPGRE
options 	NETGRAPH_NETFLOW
options 	NETGRAPH_TCPMSS
options 	NETGRAPH_VJC
options 	NETGRAPH_BPF
options 	NETGRAPH_CAR
options 	NETGRAPH_TEE
options 	PANIC_REBOOT_WAIT_TIME=10
У меня глюки с mpd5, установленного посредством pkg исчезли после того, как mpd5 был странслирован из исходников, взятых с их сайта или из портов.
41 минуту назад, Diman сказал:
Это не про меня, у меня весь софт из исходников компилился.
7 часов назад, default_vlan сказал:
cpu		HAMMER
ident		GENERIC
device		cpufreq
# Bus support.
device		acpi
options 	ACPI_DMAR
device		pci
# Floppy drives
device		fdc
# ATA controllers
# SCSI Controllers
device		cd			# CD
# RAID controllers
device		sc
device		vt
device		vt_vga
device		vt_efifb
# Parallel port
device		ppc
# Pseudo devices.
# USB support
# Sound support
# MMC/SD
# VirtIO support
# VMware support
device		pf
device		pflog
options		ALTQ
options 	NETGRAPH
Ошибки есть на интервейсах физических, которые сокет MPD слушает?
у  автора падения в ip_input что более серьезнее, чем по ссылке баг в netgraph-е
автора а у вас стектрейс при разных падениях одинаковый ?
В 15.09.2017 в 19:20, murano сказал:
Нет. Всё чисто.
В 15.09.2017 в 21:21, Ivan_83 сказал:
С таким лучше с багтрекер или рассылку.
Писал. Толку мало. Запросили данные и пропали.
8 часов назад, paradox_ сказал:
Преимущественно да. Пару раз, после внепланового отключения света были жалобы на диск (кора при проверке диска - лечилось в single user mode). Остальное одинаково. Падает с периодичность - либо раз в день, либо раз в 3 дня, либо может неделю, две, месяц проработать, а потом на тебе и кора.
Мое мнение - это что-то типа атаки на машину из сети, т.к.:
1. изначально это было замечено в версии 7.4 - переустановил ОС на 10.3
2. Это было замечено на сервере, который отработал около 5 лет - произвели замену на новый сервер
3. Новое железо валится, а другие сервера нет.
7 часов назад, Ivan_83 сказал:
Случаем не райзен?
Нет. Supermicro на Xeon E3.
Вообще, если поможет, иногда вылезало такое:
sonewconn: pcb 0xfffff8010d226930: Listen queue overflow: 193 already in queue awaiting acceptance (12576 occurrences)
[zone: pf frag entries] PF frag entries limit reached
Лечилось без ребута через ipkvm задиранием данного параметра, потом была паника.
8 часов назад, Ivan_83 сказал:
Случаем не райзен?
Вот еще, мало ли, вдруг поможет:
# pfctl -si
Status: Enabled for 3 days 23:22:36           Debug: Urgent
State Table                          Total             Rate
  current entries                   144276
  searches                     44558102200       129772.3/s
  inserts                        430607884         1254.1/s
  removals                       430463573         1253.7/s
Counters
  match                          704216423         2051.0/s
  bad-offset                             0            0.0/s
  fragment                           25306            0.1/s
  short                            1052392            3.1/s
  normalize                           4981            0.0/s
  memory                                 0            0.0/s
  bad-timestamp                          0            0.0/s
  congestion                             0            0.0/s
  ip-option                          44526            0.1/s
  proto-cksum                            0            0.0/s
  state-mismatch                    243455            0.7/s
  state-insert                          64            0.0/s
  state-limit                            0            0.0/s
  src-limit                              0            0.0/s
  synproxy                               0            0.0/s
 netstat -m
111705/6195/117900 mbufs in use (current/cache/total)
111700/2926/114626/8388608 mbuf clusters in use (current/cache/total/max)
111700/2909 mbuf+clusters out of packet secondary zone in use (current/cache)
0/85/85/247414 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/73308 9k jumbo clusters in use (current/cache/total/max)
0/0/0/41235 16k jumbo clusters in use (current/cache/total/max)
251326K/7740K/259067K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for mbufs delayed (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters delayed (4k/9k/16k)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
0 requests for sfbufs denied
0 requests for sfbufs delayed
2 requests for I/O initiated by sendfile
Привет всем.
Снова оно упало.
nas dumped core - see /var/crash/vmcore.7
Mon Sep 25 13:25:56 YEKT 2017
panic: page fault
fault code              = supervisor read data, page not present
instruction pointer     = 0x20:0xffffffff80955a99
stack pointer           = 0x28:0xfffffe0221fae0f0
frame pointer           = 0x28:0xfffffe0221fae190
current process         = 13 (ng_queue5)
trap number             = 12
panic: page fault
cpuid = 2
Uptime: 5d3h58m8s
Dumping 1253 out of 7989 MB:..2%..11%..21%..31%..41%..52%..62%..71%..81%..91%
        in pcpu.h
#5  0xffffffff80d6446d in trap_pfault (frame=0xfffffe0221fae040,
#6  0xffffffff80d63aea in trap (frame=0xfffffe0221fae040)
#8  0xffffffff80955a99 in __rw_rlock (c=0xfffff80252442c38, file=0x0, line=0)
#9  0xffffffff80aa4f16 in ip_input (m=0xfffff8006451d100)
#12 0xffffffff80a7aabc in ng_apply_item (node=0xfffff801521d3500,
    item=0xfffff8024a61c900, rw=0) at /usr/src/sys/netgraph/ng_base.c:2397
#13 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
#14 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8006cfba300,
#15 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
#16 0xffffffff80a7aabc in ng_apply_item (node=0xfffff80152fe5a00,
#17 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
    item=0xfffff8024a61c900, proto=<value optimized out>,
#19 0xffffffff80a7aabc in ng_apply_item (node=0xfffff8015232fc00,
#20 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
#21 0xffffffff80a7aabc in ng_apply_item (node=0xfffff80152225000,
#22 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
    hook=<value optimized out>, item=0xfffff8024a61c900)
#24 0xffffffff80a7aabc in ng_apply_item (node=0xfffff801520b5d00,
#25 0xffffffff80a7a6d3 in ng_snd_item (item=0xfffff8024a61c900,
#26 0xffffffff80a81812 in ng_ksocket_incoming2 (node=0xfffff80152032800,
    hook=<value optimized out>, arg1=0xfffff8025276b570, arg2=0)
#27 0xffffffff80a7a93c in ng_apply_item (node=0xfffff80152032800,
    item=0xfffff8019a847500, rw=1) at /usr/src/sys/netgraph/ng_base.c:2468
    arg=0x0, frame=0xfffffe0221fae9c0) at /usr/src/sys/kern/kern_fork.c:1027
(kgdb)
Есть идеи куда копать?
В 16.09.2017 в 14:21, paradox_ сказал:
Получается, что stack trace Одинаков.
вы не один такой
https://forums.freebsd.org/threads/56230/
и есть баг репорт с возможным решением проблемы, но без явного фикса со стороны исходников
https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=209466
как видим проблема там не в mpd и нетграфе
попробуйте засабмитить баг репорт, все же о проблеме должны знать разработчики
Edited by paradox_
