Есть идея использовать 2 вифи бриджа с каждой стороны на разных каналах и Linux бондинг драйвер - для увеличения ширины канала. Как я понял это типа транка получается.
Может кто уже пробовал? какие идеи?
Примерно такая же тема обсуждается в соседнем разделе.
Не совсем. Интересно какой из этих режимов будет работать с ВиФИ.
И что более предпочтительнее.
balance-rr or 0
Round-robin policy: Transmit in a sequential order
from the first available slave through the last. This
mode provides load balancing and fault tolerance.
active-backup or 1
Active-backup policy: Only one slave in the bond is
active. A different slave becomes active if, and only
if, the active slave fails. The bond's MAC address is
externally visible on only one port (network adapter)
to avoid confusing the switch. This mode provides
fault tolerance.
balance-xor or 2
XOR policy: Transmit based on [(source MAC address
XOR'd with destination MAC address) modula slave
count]. This selects the same slave for each
destination MAC address. This mode provides load
broadcast or 3
Broadcast policy: transmits everything on all slave
interfaces. This mode provides fault tolerance.
802.3ad or 4
IEEE 802.3ad Dynamic link aggregation. Creates aggregation
groups that share the same speed and duplex settings.
Transmits and receives on all slaves in the active
aggregator.
balance-tlb or 5
Adaptive transmit load balancing: channel bonding that does
not require any special switch support. The outgoing
traffic is distributed according to the current load
(computed relative to the speed) on each slave. Incoming
traffic is received by the current slave. If the receiving
slave fails, another slave takes over the MAC address of
the failed receiving slave.
balance-alb or 6
Adaptive load balancing: includes balance-tlb + receive
load balancing (rlb) for IPV4 traffic and does not require
any special switch support. The receive load balancing is
achieved by ARP negotiation. The bonding driver intercepts
the ARP Replies sent by the server on their way out and
overwrites the src hw address with the unique hw address of
one of the slaves in the bond such that different clients
use different hw addresses for the server.
Receive traffic from connections created by the server is
also balanced. When the server sends an ARP Request the
bonding driver copies and saves the client's IP information
from the ARP. When the ARP Reply arrives from the client,
its hw address is retrieved and the bonding driver
initiates an ARP reply to this client assigning it to one
of the slaves in the bond. A problematic outcome of using
ARP negotiation for balancing is that each time that an ARP
request is broadcasted it uses the hw address of the
bond. Hence, clients learn the hw address of the bond and
the balancing of receive traffic collapses to the current
salve. This is handled by sending updates (ARP Replies) to
all the clients with their assigned hw address such that
the traffic is redistributed. Receive traffic is also
redistributed when a new slave is added to the bond and
when an inactive slave is re-activated. The receive load is
distributed sequentially (round robin) among the group of
highest speed slaves in the bond.
When a link is reconnected or a new slave joins the bond
the receive traffic is redistributed among all active
slaves in the bond by intiating ARP Replies with the
selected mac address to each of the clients. The updelay
modeprobe parameter must be set to a value equal or greater
than the switch's forwarding delay so that the ARP Replies
sent to the clients will not be blocked by the switch.
zASSAz если удастся поставить эксперемент, то сообщи сюда результаты, если не затруднит. Сам собираюсь такое проделать.
OK. На днях обещали еще два AP принести ...вот и буду пробовать...
