Подскажите, кто сталкивался.
Как быстро без MySQL настроить FreeRADIUS, чтобы в файле users прописать логин, пароль и MAC.
Так должно работать?
user1   Cleartext-Password := "12345678", Calling-Station-Id == "FC-E9-98-AA-BB-CC"
Или не всё так просто?
radiusd: FreeRADIUS Version 2.2.6, for host x86_64-redhat-linux-gnu, built on Jul 18 2017 at 12:13:14
Copyright © 1999-2013 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License.
For more information about these matters, see the file named COPYRIGHT.
Starting - reading configuration files ...
including configuration file /etc/raddb/radiusd.conf
including configuration file /etc/raddb/proxy.conf
including configuration file /etc/raddb/clients.conf
including files in directory /etc/raddb/modules/
including configuration file /etc/raddb/modules/sql_log
including configuration file /etc/raddb/modules/acct_unique
including configuration file /etc/raddb/modules/pam
including configuration file /etc/raddb/modules/opendirectory
including configuration file /etc/raddb/modules/radrelay
including configuration file /etc/raddb/modules/ippool
including configuration file /etc/raddb/modules/detail
including configuration file /etc/raddb/modules/smsotp
including configuration file /etc/raddb/modules/unix
including configuration file /etc/raddb/modules/always
including configuration file /etc/raddb/modules/exec
including configuration file /etc/raddb/modules/policy
including configuration file /etc/raddb/modules/perl
including configuration file /etc/raddb/modules/mac2ip
including configuration file /etc/raddb/modules/sqlcounter_expire_on_login
including configuration file /etc/raddb/modules/preprocess
including configuration file /etc/raddb/modules/digest
including configuration file /etc/raddb/modules/chap
including configuration file /etc/raddb/modules/dhcp_sqlippool
including configuration file /etc/raddb/modules/cache
including configuration file /etc/raddb/modules/logintime
including configuration file /etc/raddb/modules/smbpasswd
including configuration file /etc/raddb/modules/etc_group
including configuration file /etc/raddb/modules/rediswho
including configuration file /etc/raddb/modules/soh
including configuration file /etc/raddb/modules/realm
including configuration file /etc/raddb/modules/detail.example.com
including configuration file /etc/raddb/modules/files
including configuration file /etc/raddb/modules/checkval
including configuration file /etc/raddb/modules/detail.log
including configuration file /etc/raddb/modules/linelog
including configuration file /etc/raddb/modules/otp
including configuration file /etc/raddb/modules/ntlm_auth
including configuration file /etc/raddb/modules/pap
including configuration file /etc/raddb/modules/attr_filter
including configuration file /etc/raddb/modules/counter
including configuration file /etc/raddb/modules/passwd
including configuration file /etc/raddb/modules/mschap
including configuration file /etc/raddb/modules/attr_rewrite
including configuration file /etc/raddb/modules/radutmp
including configuration file /etc/raddb/modules/expiration
including configuration file /etc/raddb/modules/inner-eap
including configuration file /etc/raddb/modules/dynamic_clients
including configuration file /etc/raddb/modules/wimax
including configuration file /etc/raddb/modules/expr
including configuration file /etc/raddb/modules/mac2vlan
including configuration file /etc/raddb/modules/echo
including configuration file /etc/raddb/modules/replicate
including configuration file /etc/raddb/modules/sradutmp
including configuration file /etc/raddb/modules/cui
including configuration file /etc/raddb/eap.conf
including configuration file /etc/raddb/policy.conf
including files in directory /etc/raddb/sites-enabled/
including configuration file /etc/raddb/sites-enabled/control-socket
including configuration file /etc/raddb/sites-enabled/inner-tunnel
including configuration file /etc/raddb/sites-enabled/default
main {
user = "radiusd"
group = "radiusd"
allow_core_dumps = no
including dictionary file /etc/raddb/dictionary
main {
name = "radiusd"
prefix = "/usr"
localstatedir = "/var"
sbindir = "/usr/sbin"
logdir = "/var/log/radius"
run_dir = "/var/run/radiusd"
libdir = "/usr/lib64/freeradius"
radacctdir = "/var/log/radius/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
pidfile = "/var/run/radiusd/radiusd.pid"
checkrad = "/usr/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = no
auth = no
auth_badpass = no
auth_goodpass = no
msg_badpass = "Ooops!"
msg_goodpass = "Welcome to Internet!"
security {
max_attributes = 200
reject_delay = 1
status_server = yes
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = "auth"
secret = "testing123"
response_window = 20.000000
response_timeouts = 1
max_outstanding = 65536
require_message_authenticator = yes
zombie_period = 40
status_check = "status-server"
ping_interval = 30
check_interval = 30
num_answers_to_alive = 3
num_pings_to_alive = 3
revive_interval = 120
status_check_timeout = 4
coa {
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
client localhost {
ipaddr = 127.0.0.1
require_message_authenticator = no
nastype = "other"
client 10.0.0.9 {
secret = "7IZ3j0861t2J"
shortname = "dlink"
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating module "exec" from file /etc/raddb/modules/exec
exec {
wait = no
input_pairs = "request"
shell_escape = yes
timeout = 10
Module: Linked to module rlm_expr
Module: Instantiating module "expr" from file /etc/raddb/modules/expr
Module: Linked to module rlm_expiration
Module: Instantiating module "expiration" from file /etc/raddb/modules/expiration
expiration {
reply-message = "Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating module "logintime" from file /etc/raddb/modules/logintime
logintime {
reply-message = "You are calling outside your allowed timespan "
minimum-timeout = 60
radiusd: #### Loading Virtual Servers ####
server { # from file
modules {
Module: Creating Auth-Type = digest
Module: Creating Post-Auth-Type = REJECT
Module: Checking authenticate {...} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating module "pap" from file /etc/raddb/modules/pap
pap {
encryption_scheme = "auto"
auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating module "chap" from file /etc/raddb/modules/chap
Module: Linked to module rlm_mschap
Module: Instantiating module "mschap" from file /etc/raddb/modules/mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = no
allow_retry = yes
Module: Linked to module rlm_digest
Module: Instantiating module "digest" from file /etc/raddb/modules/digest
Module: Linked to module rlm_unix
Module: Instantiating module "unix" from file /etc/raddb/modules/unix
unix {
radwtmp = "/var/log/radius/radwtmp"
Module: Linked to module rlm_eap
Module: Instantiating module "eap" from file /etc/raddb/eap.conf
eap {
default_eap_type = "md5"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 1024
Module: Linked to sub-module rlm_eap_md5
Module: Instantiating eap-md5
Module: Linked to sub-module rlm_eap_leap
Module: Instantiating eap-leap
Module: Linked to sub-module rlm_eap_gtc
Module: Instantiating eap-gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
Module: Linked to sub-module rlm_eap_tls
Module: Instantiating eap-tls
tls {
rsa_key_exchange = no
dh_key_exchange = yes
rsa_key_length = 512
dh_key_length = 512
verify_depth = 0
CA_path = "/etc/raddb/certs"
pem_file_type = yes
private_key_file = "/etc/raddb/certs/server.pem"
certificate_file = "/etc/raddb/certs/server.pem"
CA_file = "/etc/raddb/certs/ca.pem"
private_key_password = "whatever"
dh_file = "/etc/raddb/certs/dh"
fragment_size = 1024
include_length = yes
check_crl = no
cipher_list = "DEFAULT"
ecdh_curve = "prime256v1"
cache {
enable = no
lifetime = 24
max_entries = 255
verify {
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
Module: Linked to sub-module rlm_eap_ttls
Module: Instantiating eap-ttls
ttls {
copy_request_to_tunnel = no
use_tunneled_reply = no
virtual_server = "inner-tunnel"
Module: Linked to sub-module rlm_eap_peap
Module: Instantiating eap-peap
peap {
default_eap_type = "mschapv2"
proxy_tunneled_request_as_eap = yes
soh = no
Module: Linked to sub-module rlm_eap_mschapv2
Module: Instantiating eap-mschapv2
mschapv2 {
send_error = no
Module: Checking authorize {...} for more modules to load
Module: Linked to module rlm_preprocess
Module: Instantiating module "preprocess" from file /etc/raddb/modules/preprocess
preprocess {
huntgroups = "/etc/raddb/huntgroups"
hints = "/etc/raddb/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
reading pairlist file /etc/raddb/huntgroups
reading pairlist file /etc/raddb/hints
Module: Linked to module rlm_realm
Module: Instantiating module "suffix" from file /etc/raddb/modules/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
Module: Linked to module rlm_files
Module: Instantiating module "files" from file /etc/raddb/modules/files
files {
usersfile = "/etc/raddb/users"
acctusersfile = "/etc/raddb/acct_users"
preproxy_usersfile = "/etc/raddb/preproxy_users"
compat = "no"
reading pairlist file /etc/raddb/users
reading pairlist file /etc/raddb/acct_users
reading pairlist file /etc/raddb/preproxy_users
Module: Checking preacct {...} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating module "acct_unique" from file /etc/raddb/modules/acct_unique
acct_unique {
key = "User-Name, Acct-Session-Id, NAS-IP-Address, NAS-Identifier, NAS-Port"
Module: Checking accounting {...} for more modules to load
Module: Linked to module rlm_detail
Module: Instantiating module "detail" from file /etc/raddb/modules/detail
detail {
detailfile = "/var/log/radius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/detail-%Y%m%d"
header = "%t"
detailperm = 384
dirperm = 493
locking = no
log_packet_header = no
Module: Linked to module rlm_attr_filter
Module: Instantiating module "attr_filter.accounting_response" from file /etc/raddb/modules/attr_filter
attr_filter attr_filter.accounting_response {
attrsfile = "/etc/raddb/attrs.accounting_response"
key = "%{User-Name}"
relaxed = no
reading pairlist file /etc/raddb/attrs.accounting_response
Module: Checking session {...} for more modules to load
Module: Linked to module rlm_radutmp
Module: Instantiating module "radutmp" from file /etc/raddb/modules/radutmp
radutmp {
filename = "/var/log/radius/radutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
perm = 384
callerid = yes
Module: Checking post-proxy {...} for more modules to load
Module: Checking post-auth {...} for more modules to load
Module: Instantiating module "attr_filter.access_reject" from file /etc/raddb/modules/attr_filter
attr_filter attr_filter.access_reject {
attrsfile = "/etc/raddb/attrs.access_reject"
relaxed = no
reading pairlist file /etc/raddb/attrs.access_reject
} # modules
} # server
server inner-tunnel { # from file /etc/raddb/sites-enabled/inner-tunnel
modules {
} # modules
} # server
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
listen {
type = "acct"
ipaddr = *
port = 0
listen {
type = "control"
listen {
socket = "/var/run/radiusd/radiusd.sock"
listen {
type = "auth"
ipaddr = 127.0.0.1
port = 18120
... adding new socket proxy address * port 59124
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on command file /var/run/radiusd/radiusd.sock
Listening on authentication address 127.0.0.1 port 18120 as server inner-tunnel
Listening on proxy address * port 1814
Ready to process requests.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=192, length=145
User-Name = "sergey"
NAS-Port = 0
Called-Station-Id = "C4-A8-1D-05-12-AF:sunnet"
Calling-Station-Id = "80-C5-E6-16-7F-01"
Framed-MTU = 1400
NAS-Port-Type = Wireless-802.11
Connect-Info = "CONNECT 0Mbps 802.11"
EAP-Message = 0x0201000b01736572676579
Message-Authenticator = 0x1324500679f9c8a29571bbf7b5ff1ffd
# Executing section authorize from file /etc/raddb/sites-enabled/default
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
[suffix] No '@' in User-Name = "sergey", looking up realm NULL
[suffix] No such realm "NULL"
++[suffix] = noop
[eap] EAP packet type response id 1 length 11
[eap] No EAP Start, assuming it's an on-going EAP conversation
++[eap] = updated
[files] users: Matched entry sergey at line 50
++[files] = ok
++[expiration] = noop
++[logintime] = noop
[pap] WARNING: Auth-Type already set. Not setting to PAP
++[pap] = noop
+} # group authorize = updated
Found Auth-Type = EAP
# Executing group from file /etc/raddb/sites-enabled/default
+group authenticate {
[eap] EAP Identity
[eap] processing type md5
rlm_eap_md5: Issuing Challenge
++[eap] = handled
+} # group authenticate = handled
Sending Access-Challenge of id 192 to 10.0.0.9 port 39043
EAP-Message = 0x010200160410880ee0eaad9e8cec94766c50d705005e
Message-Authenticator = 0x00000000000000000000000000000000
State = 0xdc94e110dc96e57ccdd61660f7c49ce7
Finished request 0.
Going to the next request
Waking up in 4.9 seconds.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=193, length=159
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x02020007031915
Message-Authenticator = 0x9062a348d0f29a0b9391b22a887e33e8
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 2 length 7
++[eap] = updated
++[files] = ok
++[pap] = noop
[eap] Request found, released from the list
[eap] EAP NAK
[eap] EAP-NAK asked for EAP-Type/peap
[eap] processing type tls
[tls] Initiate
[tls] Start returned 1
++[eap] = handled
Sending Access-Challenge of id 193 to 10.0.0.9 port 39043
EAP-Message = 0x010300061920
State = 0xdc94e110dd97f87ccdd61660f7c49ce7
Finished request 1.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=194, length=322
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x020300aa1980000000a0160303009b01000097030359774b3b10fe48f3babfb419c9506303b0900cd8d73c4a4dc94325bdf22b4db700002ec02cc02bc030c02f009f009ec024c023c028c027c00ac009c014c013009d009c003d003c0035002f000a0005000401000040000500050100000000000a00080006001d00170018000b00020100000d001400120401050102010403050302030202060106030023000000170000ff01000100
Message-Authenticator = 0x68fd00aaa47a5cdb004bd91a4d4babed
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 3 length 170
[eap] Continuing tunnel setup.
++[eap] = ok
+} # group authorize = ok
[eap] EAP/peap
[eap] processing type peap
[peap] processing EAP-TLS
TLS Length 160
[peap] Length Included
[peap] eaptls_verify returned 11
[peap] (other): before/accept initialization
[peap] TLS_accept: before/accept initialization
[peap] <<< Unknown TLS version [length 009b]
[peap] TLS_accept: SSLv3 read client hello A
[peap] >>> Unknown TLS version [length 0039]
[peap] TLS_accept: SSLv3 write server hello A
[peap] >>> Unknown TLS version [length 08d0]
[peap] TLS_accept: SSLv3 write certificate A
[peap] >>> Unknown TLS version [length 014d]
[peap] TLS_accept: SSLv3 write key exchange A
[peap] >>> Unknown TLS version [length 0004]
[peap] TLS_accept: SSLv3 write server done A
[peap] TLS_accept: SSLv3 flush data
[peap] TLS_accept: Need to read more data: SSLv3 read client certificate A
In SSL Handshake Phase
In SSL Accept mode
[peap] eaptls_process returned 13
[peap] EAPTLS_HANDLED
++[eap] = handled
Sending Access-Challenge of id 194 to 10.0.0.9 port 39043
EAP-Message = 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
EAP-Message = 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
EAP-Message = 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
EAP-Message = 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
EAP-Message = 0x05bb3ad19d3b3737076123ee
State = 0xdc94e110de90f87ccdd61660f7c49ce7
Finished request 2.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=195, length=158
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x020400061900
Message-Authenticator = 0xb6a64c6f172f51623dec5edebfc8bca0
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 4 length 6
++[eap] = ok
[eap] EAP/peap
[peap] Received TLS ACK
[peap] ACK handshake fragment handler
++[eap] = handled
Sending Access-Challenge of id 195 to 10.0.0.9 port 39043
EAP-Message = 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
EAP-Message = 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
EAP-Message = 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
EAP-Message = 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
EAP-Message = 0x2e6578616d706c65
State = 0xdc94e110df91f87ccdd61660f7c49ce7
Finished request 3.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=196, length=158
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x020500061900
Message-Authenticator = 0xacd7dd0944ed4f3233c84cfaa6b14230
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 5 length 6
++[eap] = ok
[eap] EAP/peap
++[eap] = handled
Sending Access-Challenge of id 196 to 10.0.0.9 port 39043
EAP-Message = 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
EAP-Message = 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
EAP-Message = 0x51e613f67d93b600f6e4fcd0d37b47d2ba6be62acd9170bdf7f8f8f05ee09acb3aef2aa6598580961cdcc2e637c8dd312764b620212b99c5b2fe4a3238cd2e9247a5b95a21aed8e9fbbf3e35039ceeda393549edb3ebac2964b50f76eea51db07c64416dd06c1e8ed09cf66cd1be02734c23d551acfe6e9a3d5111c0a96ce930c0e3dfe3ea16030300040e000000
State = 0xdc94e110d892f87ccdd61660f7c49ce7
Finished request 4.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=197, length=288
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x0206008819800000007e1603030046100000424104c936b6abbd29e1a3868ce2ea3e4d920bc3f22a22b69bc3b0e5e76122e03628108103fa2cc5e305c1ad867b83a8f0d870baf23206cd9c0e6f714f19a1fd71259614030300010116030300280000000000000000133a596454b9c668c3e2065f3c1997924246bb847d1b8248d3dcf501f7edd681
Message-Authenticator = 0x5741e4c5f7343dc4891c13d246744af5
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 6 length 136
++[eap] = ok
[eap] EAP/peap
TLS Length 126
[peap] <<< Unknown TLS version [length 0046]
[peap] TLS_accept: SSLv3 read client key exchange A
[peap] <<< Unknown TLS version [length 0001]
[peap] <<< Unknown TLS version [length 0010]
[peap] TLS_accept: SSLv3 read finished A
[peap] >>> Unknown TLS version [length 0001]
[peap] TLS_accept: SSLv3 write change cipher spec A
[peap] >>> Unknown TLS version [length 0010]
[peap] TLS_accept: SSLv3 write finished A
[peap] (other): SSL negotiation finished successfully
SSL Connection Established
++[eap] = handled
Sending Access-Challenge of id 197 to 10.0.0.9 port 39043
EAP-Message = 0x01070039190014030300010116030300284e350557832a50da638773a7573130edabcad7cfe1fe9ce4dab0fe6008c7d0b770236d7646d332ce
State = 0xdc94e110d993f87ccdd61660f7c49ce7
Finished request 5.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=198, length=158
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x020700061900
Message-Authenticator = 0xcbf38e9aeb926a08a74443f03d4370de
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 7 length 6
++[eap] = ok
[eap] EAP/peap
[peap] ACK handshake is finished
[peap] eaptls_verify returned 3
[peap] eaptls_process returned 3
[peap] EAPTLS_SUCCESS
[peap] Session established. Decoding tunneled attributes.
[peap] Peap state TUNNEL ESTABLISHED
++[eap] = handled
Sending Access-Challenge of id 198 to 10.0.0.9 port 39043
EAP-Message = 0x010800281900170303001d4e350557832a50dbee01fc37e8185803b797dcfe8fafc08e54f61defc1
State = 0xdc94e110da9cf87ccdd61660f7c49ce7
Finished request 6.
Waking up in 3.2 seconds.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=199, length=194
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x0208002a1900170303001f000000000000000112e600f8eed256d0c55c18c43d1128afa6ee7484223780
Message-Authenticator = 0xd9e471034250cd2b71e613465bb605ab
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 8 length 42
++[eap] = ok
[eap] EAP/peap
[peap] eaptls_verify returned 7
[peap] Done initial handshake
[peap] eaptls_process returned 7
[peap] EAPTLS_OK
[peap] Peap state WAITING FOR INNER IDENTITY
[peap] Identity - sergey
[peap] Got inner identity 'sergey'
[peap] Setting default EAP type for tunneled EAP session.
[peap] Got tunneled request
EAP-Message = 0x0208000b01736572676579
server {
[peap] Setting User-Name to sergey
Sending tunneled request
FreeRADIUS-Proxied-To = 127.0.0.1
# Executing section authorize from file /etc/raddb/sites-enabled/inner-tunnel
+group authorize {
++[chap] = noop
++[mschap] = noop
++[suffix] = noop
++update control {
++} # update control = noop
[eap] EAP packet type response id 8 length 11
++[eap] = updated
++[files] = noop
++[pap] = noop
# Executing group from file /etc/raddb/sites-enabled/inner-tunnel
[eap] EAP Identity
[eap] processing type mschapv2
rlm_eap_mschapv2: Issuing Challenge
++[eap] = handled
} # server inner-tunnel
[peap] Got tunneled reply code 11
EAP-Message = 0x010900201a0109001b108e56a77828f7f1c7c8e392aad6998bea736572676579
State = 0x48abb49a48a2aef167353ef9cd131a85
[peap] Got tunneled reply RADIUS code Access-Challenge
[peap] Got tunneled Access-Challenge
++[eap] = handled
Sending Access-Challenge of id 199 to 10.0.0.9 port 39043
EAP-Message = 0x0109003f190017030300344e350557832a50dc83ebdcf8515e08f114dbff74a7136e312fb7a9f21476869fe51a9217fd2897115e39cb027f75247e04cbfb53
State = 0xdc94e110db9df87ccdd61660f7c49ce7
Finished request 7.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=200, length=248
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x02090060190017030300550000000000000002ab679e70d76e5a500ab38a8c0e6ccfbb46c47c71bdfa8e7c6e0b015d75ca9d826d4a7165d02868c6483882f883d63ebbce90895aaa5999e484fd80dfc844bc618d97a6eb46b75e8f10090b5718
Message-Authenticator = 0x5c226c80df12f87c3fb2453508656306
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 9 length 96
++[eap] = ok
[eap] EAP/peap
[peap] EAPTLS_OK
[peap] Peap state phase2
[peap] EAP type mschapv2
EAP-Message = 0x020900411a0209003c31df8fe254eefa77199a0dac62aea23e3700000000000000009846e8ebe183eda84a3fc1beb39192d9a4dfb9cf41895d6f00736572676579
server {
+group authorize {
++[chap] = noop
++[mschap] = noop
++[suffix] = noop
++update control {
[eap] EAP packet type response id 9 length 65
++[eap] = updated
++[files] = noop
++[pap] = noop
[eap] EAP/mschapv2
[mschapv2] # Executing group from file /etc/raddb/sites-enabled/inner-tunnel
[mschapv2] +group MS-CHAP {
[mschap] No Cleartext-Password configured. Cannot create LM-Password.
[mschap] No Cleartext-Password configured. Cannot create NT-Password.
[mschap] Creating challenge hash with username: sergey
[mschap] Client is using MS-CHAPv2 for sergey, we need NT-Password
[mschap] FAILED: No NT/LM-Password. Cannot perform authentication.
[mschap] FAILED: MS-CHAP2-Response is incorrect
++[mschap] = reject
+} # group MS-CHAP = reject
[eap] Freeing handler
++[eap] = reject
+} # group authenticate = reject
Failed to authenticate the user.
Using Post-Auth-Type REJECT
+group REJECT {
[attr_filter.access_reject] expand: %{User-Name} -> sergey
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] = updated
+} # group REJECT = updated
[peap] Got tunneled reply code 3
MS-CHAP-Error = "\tE=691 R=1"
EAP-Message = 0x04090004
[peap] Got tunneled reply RADIUS code Access-Reject
[peap] Tunneled authentication was rejected.
[peap] FAILURE
++[eap] = handled
Sending Access-Challenge of id 200 to 10.0.0.9 port 39043
EAP-Message = 0x010a002e190017030300234e350557832a50dd3df1acf4bf6e347765e347a6eefc330214922730617e3e7a8b22a0
State = 0xdc94e110d49ef87ccdd61660f7c49ce7
Finished request 8.
rad_recv: Access-Request packet from host 10.0.0.9 port 39043, id=201, length=198
NAS-Port = 0
Framed-MTU = 1400
EAP-Message = 0x020a002e190017030300230000000000000003d076e29f0013dc2e17e971482034019bb3af7da8f9fcf38b39c670
Message-Authenticator = 0x26dbd6b19372ef66f116645e43254c64
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
++[suffix] = noop
[eap] EAP packet type response id 10 length 46
++[eap] = ok
[eap] EAP/peap
[peap] EAPTLS_OK
[peap] Peap state send tlv failure
[peap] Received EAP-TLV response.
[peap] The users session was previously rejected: returning reject (again.)
[peap] *** This means you need to read the PREVIOUS messages in the debug output
[peap] *** to find out the reason why the user was rejected.
[peap] *** Look for "reject" or "fail". Those earlier messages will tell you.
[peap] *** what went wrong, and how to fix the problem.
[eap] Handler failed in EAP/peap
[eap] Failed in EAP select
++[eap] = invalid
+} # group authenticate = invalid
+group REJECT {
Delaying reject of request 9 for 1 seconds
Waking up in 0.9 seconds.
Sending delayed reject for request 9
Sending Access-Reject of id 201 to 10.0.0.9 port 39043
EAP-Message = 0x040a0004
Waking up in 2.2 seconds.
Cleaning up request 0 ID 192 with timestamp +21
Cleaning up request 1 ID 193 with timestamp +21
Cleaning up request 2 ID 194 with timestamp +21
Cleaning up request 3 ID 195 with timestamp +21
Cleaning up request 4 ID 196 with timestamp +21
Cleaning up request 5 ID 197 with timestamp +21
Waking up in 1.6 seconds.
Cleaning up request 6 ID 198 with timestamp +22
Cleaning up request 7 ID 199 with timestamp +22
Cleaning up request 8 ID 200 with timestamp +22
Waking up in 1.0 seconds.
Cleaning up request 9 ID 201 with timestamp +22
Оригинальные MAC и название сети изменены по понятным причинам.
[peap] EAPTLS_OK
Могу ошибаться , но насколько я понимаю у вас проблема с eap аутентификацией. Дело не в мак адресе
