ThreeDHead Posted July 17, 2017 Posted July 17, 2017 Настраиваю Радиус. Радтестом проверяю, параметры с radgroupreply отдаёт, а с radreply нет. По дебагу видно что даже не читает эту таблицу. Почему так? rad_recv: Access-Request packet from host 127.0.0.1 port 55588, id=70, length=98 User-Name = "10.230.51.15" User-Password = "VasExperts.FastDPI" NAS-IP-Address = 127.0.1.1 NAS-Port = 1812 Message-Authenticator = 0xb290d0abf4b714e3816e9ed04aa67282 # Executing section authorize from file /etc/freeradius/sites-enabled/sql +group authorize { [sql] expand: %{User-Name} -> 10.230.51.15 [sql] sql_set_user escaped user --> '10.230.51.15' rlm_sql (sql): Reserving sql socket id: 12 [sql] expand: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radcheck WHERE username = '10.230.51.15' ORDER BY id [sql] expand: SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority -> SELECT groupname FROM radusergroup WHERE username = '10.230.51.15' ORDER BY priority [sql] expand: SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = '%{Sql-Group}' ORDER BY id -> SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'subscribers' ORDER BY id [sql] User found in group subscribers [sql] expand: SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = '%{Sql-Group}' ORDER BY id -> SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'subscribers' ORDER BY id rlm_sql (sql): Released sql socket id: 12 ++[sql] = ok +} # group authorize = ok Found Auth-Type = Accept Auth-Type = Accept, accepting the user # Executing section post-auth from file /etc/freeradius/sites-enabled/sql +group post-auth { [sql] expand: %{User-Name} -> 10.230.51.15 [sql] sql_set_user escaped user --> '10.230.51.15' [sql] expand: %{User-Password} -> VasExperts.FastDPI [sql] expand: INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ( '%{User-Name}', '%{%{User-Password}:-%{Chap-Password}}', '%{reply:Packet-Type}', '%S') -> INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ( '10.230.51.15', 'VasExperts.FastDPI', 'Access-Accept', '2017-07-17 20:01:28') rlm_sql (sql) in sql_postauth: query is INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ( '10.230.51.15', 'VasExperts.FastDPI', 'Access-Accept', '2017-07-17 20:01:28') rlm_sql (sql): Reserving sql socket id: 11 rlm_sql (sql): Released sql socket id: 11 ++[sql] = ok +} # group post-auth = ok Sending Access-Accept of id 70 to 127.0.0.1 port 55588 Finished request 14. Going to the next request Waking up in 4.9 seconds. Cleaning up request 14 ID 70 with timestamp +661 Ready to process requests. Вставить ник Quote
snvoronkov Posted July 18, 2017 Posted July 18, 2017 (edited) Так выдает? user@host:/etc/freeradius/mods-enabled# grep authreply_table sql authreply_table = "radreply" И еще на проверку (сам не пользовался): # If set to 'yes' (default) we read the group tables unless Fall-Through = no in the reply table. # If set to 'no' we do not read the group tables unless Fall-Through = yes in the reply table. # read_groups = yes # If set to 'yes' (default) we read profiles unless Fall-Through = no in the groupreply table. # If set to 'no' we do not read profiles unless Fall-Through = yes in the groupreply table. # read_profiles = yes Edited July 18, 2017 by snvoronkov Вставить ник Quote
ThreeDHead Posted July 18, 2017 Author Posted July 18, 2017 Думал лыжи не едут потому что старый фрирадиус, обновил до крайнего, всё то же самое :( Так выдает? user@host:/etc/freeradius/mods-enabled# grep authreply_table sql authreply_table = "radreply" Выдаёт: # grep authreply_table /etc/freeradius/3.0/mods-enabled/sql authreply_table = "radreply" С Fall-Through с сотой попытки разобрался, не причем он тут, т.к. групповые ответы читаются уже после radreply, а Fall-Through надо писать в radreply, а radreply не читается... Вставить ник Quote
ThreeDHead Posted July 18, 2017 Author Posted July 18, 2017 Вот сам лог, но в нем опять ни одного упоминания о radreply (0) sql: EXPAND %{User-Name} (0) sql: --> 10.11.100.254 (0) sql: SQL-User-Name set to '10.11.100.254' rlm_sql (sql): Reserved connection (1) (0) sql: EXPAND SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id (0) sql: --> SELECT id, username, attribute, value, op FROM radcheck WHERE username = '10.11.100.254' ORDER BY id (0) sql: Executing select query: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '10.11.100.254' ORDER BY id (0) sql: User found in radcheck table (0) sql: EXPAND SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority (0) sql: --> SELECT groupname FROM radusergroup WHERE username = '10.11.100.254' ORDER BY priority (0) sql: Executing select query: SELECT groupname FROM radusergroup WHERE username = '10.11.100.254' ORDER BY priority (0) sql: User found in the group table (0) sql: EXPAND SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = '%{SQL-Group}' ORDER BY id (0) sql: --> SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'subscribers' ORDER BY id (0) sql: Executing select query: SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'subscribers' ORDER BY id (0) sql: Group "subscribers": Conditional check items matched (0) sql: Group "subscribers": Merging assignment check items (0) sql: Auth-Type := Accept (0) sql: EXPAND SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = '%{SQL-Group}' ORDER BY id (0) sql: --> SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'subscribers' ORDER BY id (0) sql: Executing select query: SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'subscribers' ORDER BY id (0) sql: Group "subscribers": Merging reply items rlm_sql (sql): Released connection (1) rlm_sql (sql): Need 4 more connections to reach 10 spares rlm_sql (sql): Opening additional connection (6), 1 of 26 pending slots used rlm_sql_mysql: Starting connect to MySQL server rlm_sql_mysql: Connected to database 'radius' on Localhost via UNIX socket, server version 10.1.23-MariaDB-9+deb9u1, protocol version 10 (0) [sql] = ok (0) [expiration] = noop (0) [logintime] = noop (0) pap: WARNING: Auth-Type already set. Not setting to PAP (0) [pap] = noop (0) } # authorize = ok (0) Found Auth-Type = Accept (0) Auth-Type = Accept, accepting the user Вставить ник Quote
snvoronkov Posted July 19, 2017 Posted July 19, 2017 ThreeDHead, в группе "Auth-Type := Accept" вывешено? Еслида, то оно дальше и не смотрит. Все равно уже акцепт. Вставить ник Quote
ThreeDHead Posted July 19, 2017 Author Posted July 19, 2017 В качестве бреда, указал в проверке операцию присвоения (:=), вместо сравнения (==) - заработало. Видимо у меня еще нет понимания как как и где их применять. snvoronkov, спасибо за диалог. MariaDB [radius]> SELECT * FROM `radcheck`; +----+---------------+--------------------+----+--------------------+ | id | username | attribute | op | value | +----+---------------+--------------------+----+--------------------+ | 1 | 10.11.100.254 | Cleartext-Password | := | VasExperts.FastDPI | +----+---------------+--------------------+----+--------------------+ 1 row in set (0.00 sec) (0) sql: EXPAND %{User-Name} (0) sql: --> 10.11.100.254 (0) sql: SQL-User-Name set to '10.11.100.254' rlm_sql (sql): Reserved connection (1) (0) sql: EXPAND SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id (0) sql: --> SELECT id, username, attribute, value, op FROM radcheck WHERE username = '10.11.100.254' ORDER BY id (0) sql: Executing select query: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '10.11.100.254' ORDER BY id (0) sql: User found in radcheck table (0) sql: Conditional check items matched, merging assignment check items (0) sql: Cleartext-Password := "VasExperts.FastDPI" (0) sql: EXPAND SELECT id, username, attribute, value, op FROM radreply WHERE username = '%{SQL-User-Name}' ORDER BY id (0) sql: --> SELECT id, username, attribute, value, op FROM radreply WHERE username = '10.11.100.254' ORDER BY id (0) sql: Executing select query: SELECT id, username, attribute, value, op FROM radreply WHERE username = '10.11.100.254' ORDER BY id (0) sql: EXPAND SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority (0) sql: --> SELECT groupname FROM radusergroup WHERE username = '10.11.100.254' ORDER BY priority (0) sql: Executing select query: SELECT groupname FROM radusergroup WHERE username = '10.11.100.254' ORDER BY priority (0) sql: User found in the group table (0) sql: EXPAND SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = '%{SQL-Group}' ORDER BY id (0) sql: --> SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'subscribers' ORDER BY id (0) sql: Executing select query: SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'subscribers' ORDER BY id (0) sql: Group "subscribers": Conditional check items matched (0) sql: Group "subscribers": Merging assignment check items (0) sql: EXPAND SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = '%{SQL-Group}' ORDER BY id (0) sql: --> SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'subscribers' ORDER BY id (0) sql: Executing select query: SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'subscribers' ORDER BY id (0) sql: Group "subscribers": Merging reply items Вставить ник Quote
snvoronkov Posted July 19, 2017 Posted July 19, 2017 В качестве бреда, указал в проверке операцию присвоения (:=), вместо сравнения (==) - заработало. Это не бред для 'Cleartext-Password'. Это так и должно быть! Буквально на днях на те-же грабли наступил - перевожу сервис с freeradius 1.x с атрибутами "Password ==" на freeradius 3.x Разницу в операциях смотреть тут: https://wiki.freeradius.org/config/Operators Для чек-атрибута: '==' - не сравнение, а атрибут ЕСТЬ такой И у него ТАКОЕ значение. В запросах от брасов 'Cleartext-Password' не встречается ин зэ вайлд. :-) ':=' - для 'Cleartext-Password' самое оно! Значит, его надо ЗАДАТЬ для дальнейшей проверки. Вставить ник Quote
TeCHNoiD Posted October 8, 2024 Posted October 8, 2024 (edited) Зарание извиняюсь за поднятие семилетнего треда, но сам столкнулся с той же проблемой. Если в таблице radcheck нет ни одного упоминания для запрашиваемого UserName, то таблица radreply просто не читается модулем SQL, хотя групповые атрибуты (при наличии юзера в radusergroup конечно же) всё равно отдаются. Поведение не очевидное. FreeRADIUS Version 3.0.26 Edited October 8, 2024 by TeCHNoiD Вставить ник Quote
