Коллеги, приветствую!
Буквально 30 минут назад отвалился МХ80, в логе после ребута:
Message from syslogd@MX80 at Jun 26 17:14:15  ...
MX80 tfeb0 CMT: Fatal ASIC initialization error, Offlining FPC
Jun 26 17:14:15  MX80 tfeb0 CMT: Fatal ASIC initialization error, Offlining FPC
Jun 26 17:14:15  MX80 tfeb0 HSL2: Missing end/ends for table-trained/channel-trained channel in offset 2
Jun 26 17:14:15  MX80 tfeb0 HSL2: Table-trained sub_table 0 failed verification.
Jun 26 17:14:15  MX80 tfeb0 HSL2: cmtfpc_hsl2_bringup: hsl2_table_trained_bringup failed (1)
Jun 26 17:14:15  MX80 tfeb0 CMT: Failed to initialize HSL2 channels: generic failure
MX80 tfeb0 CMT: Error initializing PFE asics
Jun 26 17:14:15  MX80 tfeb0 CMT: Error initializing PFE asics
Message from syslogd@MX80 at Jun 26 17:14:30  ...
MX80 tfeb0 CMLC: Chassis Manager terminated
Jun 26 17:14:30  MX80 tfeb0 CMLC: Chassis Manager terminated
MX80 tfeb0 Oinker: Function CM Watchdog (0x402bb9e4) took 29068 us
Jun 26 17:14:30  MX80 tfeb0 Oinker: Function CM Watchdog (0x402bb9e4) took 29068 us
Jun 26 17:14:50  MX80 mib2d[1473]: SNMP_TRAP_LINK_DOWN: ifIndex 17, ifAdminStatus up(1), ifOperStatus down(2), ifName em0
Jun 26 17:14:53  MX80 /kernel: tcp_timer_keep: Dropping socket connection due to keepalive timer expiration
Jun 26 17:14:55  MX80 last message repeated 3 times
Jun 26 17:14:55  MX80 /kernel: peer_input_pending_internal:[4387] VKS0 for peer type 17 indx 0 reported a so_error 60
Jun 26 17:14:55  MX80 /kernel: peer_inputs:4705 VKS0 closing connection peer type 17 indx 0 err 5
Jun 26 17:14:55  MX80 /kernel: pfe_listener_disconnect: conn dropped: listener idx=0, tnpaddr=0x80000032, reason: socket error
Jun 26 17:15:13  MX80 ppmd[1385]: ppmd_rpm_rpc_build_helper: 232 type 1
Jun 26 17:15:13  MX80 /kernel: pic_listener_connect: conn established: mgmt addr=0x80000032,
Jun 26 17:15:13  MX80 tfeb0 ce_coc12_mic_module_init:1524: @# defaulting to NOT emitting syslogs for ce_coc12_mic_trace()
Jun 26 17:15:14  MX80 tfeb0 CLKSYNC: failed to connect to Master
Jun 26 17:15:14  MX80 tfeb0 L2ALM: failed to connect to Master
Jun 26 17:15:15  MX80 tfeb0 pfe_pme_max 24
Jun 26 17:15:17  MX80 tfeb0 CLKSYNC: master RE connection made
Jun 26 17:15:18  MX80 tfeb0 L2ALM master RE connection made
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Memory Error
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Test Name:Unique Address (Bottom-Up)
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Error Count: 4
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Error Address: Raw: 0x0000000000000000 Cell: 0x0000000000000000, Burst: 0, Bank: 0
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Actual Data:   0x00000000000000000040001000000000
Jun 26 17:15:19  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Expected Data: 0x00000000000000000000000000800020
Jun 26 17:15:20  MX80 tfeb0 RamBIST:LU-CHIP[0] RLDRAM 0 BIST: Vector Data:   0x000000000000000000000000009c0027
Message from syslogd@MX80 at Jun 26 17:15:20  ...
MX80 tfeb0 LUCHIP(0): Bist RLDRAM 0 failed
Jun 26 17:15:20  MX80 tfeb0 LUCHIP(0): Bist RLDRAM 0 failed
Jun 26 17:15:20  MX80 tfeb0 CMT: LU0 init failed, generic failure
Jun 26 17:15:20  MX80 tfeb0 CMT: Failed to init LU chip 0.0
Jun 26 17:15:28  MX80 tfeb0 CMT: Failed to start ASICs, PFE ID 0
Message from syslogd@MX80 at Jun 26 17:15:28  ...
Jun 26 17:15:28  MX80 tfeb0 CMT: Fatal ASIC initialization error, Offlining FPC
Jun 26 17:15:28  MX80 tfeb0 HSL2: Missing end/ends for table-trained/channel-trained channel in offset 2
Jun 26 17:15:28  MX80 tfeb0 HSL2: Table-trained sub_table 0 failed verification.
Jun 26 17:15:28  MX80 tfeb0 HSL2: cmtfpc_hsl2_bringup: hsl2_table_trained_bringup failed (1)
Jun 26 17:15:28  MX80 tfeb0 CMT: Failed to initialize HSL2 channels: generic failure
Jun 26 17:15:28  MX80 tfeb0 CMT: Error initializing PFE asics
Все, сдох бобик или память?
user@MX80> show chassis fpc
Temp CPU Utilization (%) Memory Utilization (%)
Slot State © Total Interrupt DRAM (MB) Heap Buffer
0 Empty
1 Empty
Edited by mse.rus77
Подскажите - а насколько часто такое явление на MXaх?
Предстояло ли что то этому?
П.С. Задумываемся о покупке БУ MXa.
Сдох , и да память , судя по
Покупайте контракт и меняйте
Спасибо за инфу.
А можно подробнее про покупку контракта и замену? Нужно купить на него поддержку и потом выполнить замену? Как выглядит данная процедура?
Сдох сам по себе, внезапно, до этого трудился без проблем.
Сейчас просто на консоль циклично пишет:
Message from syslogd@MX80 at Jun 26 18:27:08 ...
Message from syslogd@MX80 at Jun 26 18:27:23 ...
MX80 tfeb0 Oinker: Function CM Watchdog (0x402bb9e4) took 19490 us
Message from syslogd@MX80 at Jun 26 18:28:13 ...
Message from syslogd@MX80 at Jun 26 18:28:21 ...
Message from syslogd@MX80 at Jun 26 18:28:22 ...
Message from syslogd@MX80 at Jun 26 18:28:37 ...
MX80 tfeb0 Oinker: Function CM Watchdog (0x402bb9e4) took 20360 us
Message from syslogd@MX80 at Jun 26 18:29:27 ...
Message from syslogd@MX80 at Jun 26 18:29:34 ...
Edited by mse.rus77
кмк распаяна
была идея про 2->4gb в свое время)
У ТС проблема с линейной платой(MPC/PFE/FPC, называйте как хотите) - dataplane, а Вы про память на RE - control plane
был не внимателен, извиняюсь )
но и "кмк" не просто так писал
ТС чем спрашивать давно бы уже разобрал
  • 1 year later...
В 27.06.2017 в 14:14, mse.rus77 сказал:
Коллеги, а кто в курсе, в МХ80 память распаяна на маинборде или слот?
три слота: Оригинальная установленная память в Juniper MX80: Unigen UG12T7200M8NR-6AB-JN0 1GB DDR2 5300 (10 чипов NANYA nt5tu128M8GE-AC)
После установки модуля памяти в Juniper MX80 - MEM-RSP720-4G-EQV (SMART 18 чипов hynix hy5ps1g831c) сообщение в консоль от U-Boot 1.1.6 и отказ от загрузки:
DRAM:  Initializing DDR: NOTE: ranks OTHER than CS0 were found and they will NOT be used in this memory controller interleaving mode ...
NT5TU128M8GE-Nanya.pdf
19 часов назад, lan31 сказал:
пишет же - плашка двухранговая, хочу видеть одноранговую.
19 часов назад, vvertexx сказал:
x8 ищи
а что, разве нерегистровые бывают х4???
  • 2 weeks later...
  • 2 weeks later...
  • 1 month later...
Если пробовать воткнуть 2Gb, то вот эта должна подойти:
SG572568FG8RZIL
А на замену - искать по ключевым словам ddr2 5300  244 1gb
  • 1 month later...
В 08.08.2019 в 13:15, tros10 сказал:
SG572568FG8RZIL
Заказали. Стоила 11т рублей.
Работает, но нужно этот модуль поставить в первый слот routing engines. В других местах, либо не грузится, либо не видит.
В 11.09.2019 в 11:05, tros10 сказал:
А как в итоге работает ?
Там же три планки.
Обыкновенно работает. Больше памяти не стало. 2гб видит как 1гб
  • 7 months later...
Столкнулся с такой же проблемой на mx5-t, померла одна планка. Подскажите, пожалуйста, где можно поискать оперативку, желательно в РФ? Пока нашел только на ебее вот такую: ссылка
