Уведомляем вас о выходе новой версии ПО для серий S2962, S2965, S2982G, S2985G, S225Gi
Релизы доступны по ссылкам:
S2962: 7.0.3.5(R0241.0551)
S2965: 7.0.3.5(R0241.0551)
S2982G: 7.0.3.5(R0241.0551)
S2985G: 7.0.3.5(R0241.0551)
S225Gi: 7.0.3.5(R0241.0551)
Список изменений:
7.0.3.5(R0241.0551)
FIX|CRM20220929012074 issue with erps
7.0.3.5(R0241.0549)
FIX|CRM20220909011860 increased memory utilization
7.0.3.5(R0241.0548)
ADD|CRM20220725011358 add service password-encryption SHA-2 algorithm
7.0.3.5(R0241.0545)
FIX|CRM20220905011816 command 'ip dhcp disable' is not working on interface in portchannel
7.0.3.5(R0241.0544)
FIX|CRM20220901011779 issue with Auto Provisioning
7.0.3.5(R0241.0543)
ADD|CRM20220722011334 add ip source address while using tftp
7.0.3.5(R0241.0540)
FIX|CRM20220809011528 issue with repetitive dot1x authentication
7.0.3.5(R0241.0539)
FIX|CRM20220809011532 issue with LLDP field "Model Name"
7.0.3.5(R0241.0538)
ADD|CRM20220704011106 add vct shutdown mode in mib
7.0.3.5(R0241.0534)
FIX|CRM20220719011300 issue with static ip dhcp snooping binding
7.0.3.5(R0241.0532)
FIX|CRM20220715011255 issue with ifLastChange OID
7.0.3.5(R0241.0531)
FIX|CRM20220704011114 issue with snmp radius configuration commands
7.0.3.5(R0241.0530)
FIX|CRM20220627011010 issue with dynamic vlan and IP-subnet vlan
7.0.3.5(R0241.0528)
FIX|CRM20220617010881 issue with VCT
7.0.3.5(R0241.0527)
ADD|CRM20220617010883 issue with ip dhcp snooping blocked record
7.0.3.5(R0241.0526)
ADD|CRM20220621010946 add oid for getting Vlan MAC
FIX|CRM20220623010964 issue with option 82 toward cisco server
7.0.3.5(R0241.0525)
FIX|CRM20220606010743 switch learn MAC's in not created vlans
Уведомляем вас о выходе новой версии ПО для модели SNR-S2989G-48TX
Релиз доступен по ссылке:
SNR-S2989G-48TX: 7.5.3.6(R0004.0476)
Список изменений:
7.5.3.6(R0004.0476)
FIX|CRM20220826011711 issue with SFP+ modules
7.5.3.6(R0004.0472)
FIX|CRM20220830011748 tSnmpd task memory leak
7.5.3.6(R0004.0471)
ADD|CRM20220816011606 Add VRRP plaintext authentication
7.5.3.6(R0004.0470)
FIX|CRM20220829011725 switch reboot in shell
Уведомляем вас о выходе новых версий ПО для моделей SNR-S2990X-24FQ и SNR-S300X-24FQ
SNR-S2990X-24FQ: 7.5.3.2(R0010.0155)
SNR-S300X-24FQ: 7.5.3.2(R0010.0155)
Список изменений:
7.5.3.2(R0010.0155)
FIX|CRM20220901011771 issue with erps mst instance edit
7.5.3.2(R0010.0147)
ADD|CRM20220704011110 add oid for getting Vlan MAC
FIX|CRM202206161010867 issue with spanning-tree output
Уведомляем вас о выходе новых версий ПО для серий S2995G и S3850G
S2995G: 7.5.3.6(R0004.0476)
S3850G: 7.5.3.6(R0004.0476)
Список изменений:
7.5.3.6(R0004.0476)
7.5.3.6(R0004.0473)
FIX|CRM20220913011893 issue with msdp sa message
7.5.3.6(R0004.0469)
FIX|CRM20220829011724 issue with erps+mac-move on port-channel interfaces
7.5.3.6(R0004.0468)
FIX|CRM20220823011673 issue with erps mac-flap
ADD|CRM20220606010739 issue with multicast traffic on BLK port in RSTP
7.5.3.6(R0004.0467)
FIX|CRM20220725011358 The encryption algorithm sha256 is enabled and login cannot be enabled
7.5.3.6(R0004.0465)
FIX|CRM20220714011237 issue with 'dot1x re-authentication'
7.5.3.6(R0004.0461)
ADD|CRM20220720011308 add ability to view vlans in instance by snmp while spanning tree is not enable
7.5.3.6(R0004.0458)
7.5.3.6(R0004.0456)
FIX|CRM20220606010741 issue with switch stuck and reboot by watchdog 'tCpuRxLimitNotify'
7.5.3.6(R0004.0455)
FIX|CRM20220616010867 issue with spanning-tree output
Уведомляем вас о выходе новой версии ПО для модели SNR-S300G-24FX
SNR-S300G-24FX: 7.5.3.0(R0010.0294)
Список изменений:
7.5.3.0(R0010.0294)
7.5.3.0(R0010.0292)
ADD|CRM20220721011329 add an opportunity to remove SSH algorithms
7.5.3.0(R0010.0291)
ADD|CRM20220721011329 add service password-encryption SHA-2 algorithm
7.5.3.0(R0010.0289)
7.5.3.0(R0010.0287)
Уведомляем вас о выходе новой версии ПО для серии S4550
S4550: 7.0.3.0(R0246.0153)
Список изменений:
7.0.3.0(R0246.0153)
FIX|CRM20220623010959 issue with IGMP packets on isolated ports and port-channel
Уведомляем о выходе новой версии ПО для модели SNR-S4650X-48FQ
SNR-S4650X-48FQ: 7.5.3.2(R0016.0049)
Список изменений:
7.5.3.2(R0016.0049)
7.5.3.2(R0016.0048)
FIX|CRM20220524010581 no nexthop in address-family multicast
7.5.3.2(R0016.0046)
ADD|CRM20220513010418 Add show vsf config detail
7.5.3.2(R0016.0042)
FIX|CRM20220328009769 wrong time in 'sh users' while using ssh keys
FIX|CRM20220321009697 add 'configure terminal' alias
7.5.3.2(R0016.0041)
ADD|CRM20211229008805 issue with 'show aaa authenticated-user'
7.5.3.2(R0016.0038)
FIX|CRM20211229008800 ospf crash after debug arp receive enabled
Уведомляем о выходе новой версии ПО для серии S5210G
S5210G: 1.2.0
Список изменений:
### Added
- Авторизация IGMP через Radius сервер
- Функционал MAC-notification
- OID'ы для управления по SNMP функционалом AM (Address Management)
- Команда для настройки статических IGMP групп "igmp snooping static-group A.B.C.D"
### Fixed
- Запрет создания статических multicast MAC
- Автоматическое добавление vlan в список allowed при установке native vlan на порту
- Исправлена работа storm-contol multicast, добавлено ограничение всего multicast траффика, а не только unknown multicast
- Исправлена работа команды 'mls qos default-cos'
- Исправлена неработающая очистка таблицы mac-адресов на агрегированных портах
- Исправлена перезагрузка коммутатора при применении команд на interface-range после добавления портов в Port-channel/Static-channel
- Исправлено отображение access list в конфигурации
- Запрещена команда show running-config в непривилегированном режиме
### Changed
- Добавлено отключение voice-vlan на интерфейсах при глобальном отключении
  • 3 months later...
  • Replies 115
  • Created
  • Last Reply
Top Posters In This Topic
S2962: 7.0.3.5(R0241.0568)
S2965: 7.0.3.5(R0241.0568)
S2982G: 7.0.3.5(R0241.0568)
S2985G: 7.0.3.5(R0241.0568)
S225Gi: 7.0.3.5(R0241.0568)
Список изменений:
7.0.3.5(R0241.0568)
FIX|CRM20221130012655 issue with load running-config from command
7.0.3.5(R0241.0566)
ADD|CRM20221130012655 add SNMP-FRAMEWORK-MIB:snmpEngineID.0
7.0.3.5(R0241.0565)
ADD|CRM20221130012652 add "Lease time" field at "ip DHCP snooping binding" table
7.0.3.5(R0241.0562)
FIX|CRM20221213012753 issue with some LLDP MED tlv
7.0.3.5(R0241.0558)
FIX|CRM20221026012291 issue with bandwidth-control
7.0.3.5(R0241.0556)
FIX|CRM20221118012539 SNMP get wrong response for VLAN name
7.0.3.5(R0241.0555)
FIX|CRM20221103012380 issue with bpduguard logs output.
7.0.3.5(R0241.0552)
ADD|CRM20220816011599 add erps unprotected-instance
SNR-S2989G-48TX: 7.5.3.6(R0004.0500)
Список изменений:
7.5.3.6(R0004.0500)
ADD|CRM20221130012658 add tcnguard/tc-guard on switch
7.5.3.6(R0004.0498)
7.5.3.6(R0004.0496)
7.5.3.6(R0004.0495)
FIX|CRM20221202012668 LACP states down without "anti-arpscan trust supertrust-port" on Port-Channel
7.5.3.6(R0004.0493)
FIX|CRM20221130012654 lose dchp default-gateway after link flap
7.5.3.6(R0004.0490)
ADD|CRM20220816011607 requirements for dot1x&mab
7.5.3.6(R0004.0489)
FIX|CRM20221013012155 issue with BFD on loopback ports
7.5.3.6(R0004.0485)
FIX|CRM20221116012494 error prompt when configuring ip address on tunnel interface
7.5.3.6(R0004.0484)
FIX|CRM20221025012289 issue with ethernet-oam
7.5.3.6(R0004.0482)
7.5.3.6(R0004.0481)
7.5.3.6(R0004.0480)
ADD|CRM20220909011853 add command "show erps instance" to display the protected vlan information
SNR-S2990X-24FQ: 7.5.3.2(R0010.0159)
SNR-S300X-24FQ: 7.5.3.2(R0010.0159)
Список изменений:
7.5.3.2(R0010.0159)
FIX|CRM20221226012853 rebooted by watchdog [tWatchDog]
7.5.3.2(R0010.0158)
FIX|CRM20221101012365 issue with two erps rings on port
S2995G: 7.5.3.6(R0004.0500)
S3850G: 7.5.3.6(R0004.0500)
Список изменений:
7.5.3.6(R0004.0500)
FIX|CRM20221213012752 issue with OSPF
7.5.3.6(R0004.0499)
7.5.3.6(R0004.0498)
7.5.3.6(R0004.0496)
7.5.3.6(R0004.0495)
7.5.3.6(R0004.0493)
FIX|CRM20221130012654 lose dhcp default-gateway after link flap
7.5.3.6(R0004.0490)
7.5.3.6(R0004.0489)
7.5.3.6(R0004.0485)
7.5.3.6(R0004.0484)
7.5.3.6(R0004.0483)
ADD|CRM20221025012282 The loopback parameter is added after ipv6 pim bsr candidate and ip pim bsr candidate
7.5.3.6(R0004.0482)
7.5.3.6(R0004.0481)
7.5.3.6(R0004.0480)
SNR-S300G-24FX: 7.5.3.0(R0010.0304)
Список изменений:
7.5.3.0(R0010.0304)
FIX|CRM20221202012673 issue with MPLS FEC missing after OSPF convergence
7.5.3.0(R0010.0302)
7.5.3.0(R0010.0301)
7.5.3.0(R0010.0300)
FIX|CRM20220721011332 issue with MAB
7.5.3.0(R0010.0298)
FIX|CRM20221018012204 issue with erps
Уведомляем о выходе новой версии ПО для модели SNR-S7550Y-48C
SNR-S7550Y-48C: 7.6.3.2(R0005.0085)
Список изменений:
7.6.3.2(R0005.0085)
7.6.3.2(R0005.0084)
FIX|CRM20221024012254 issue with radius auth on Windows client
7.6.3.2(R0005.0083)
ADD|CRM20220721011329 An possibility to use more stronger algorithms with 'service password-encryption'
7.6.3.2(R0005.0082)
FIX|CRM20221024012259 issue with copy running config via FTP, SFTP
7.6.3.2(R0005.0081)
FIX|CRM20221020012221 issue with snmpwalk output for snmpv3
7.6.3.2(R0005.0079)
ADD|CRM20220719011297 Adjust the VRF quantity to 1024
7.6.3.2(R0005.0078)
ADD|CRM20211215008619 add command "show vsf config detail"
FIX|CRM20211207008506 show transceiver detail |load balancing algorithm problem |VSF flow problem
S5210G: 1.3.0
Список изменений:
### Added
- Поддержка режима MSTP (spanning-tree mode mstp)
- Возможность принудительной установки версии IGMP (igmp snooping force-igmp-version 2)
- Настройка IP-адреса источника для IGMP пакетов (igmp snooping report source-address)
- Возможность настройки формата DHCP Snooping Option 82 subscriber-id на порту
- Настройка карт DSCP и COS (mls qos map cos-queue; mls qos map dscp-queue)
- Функционал Policy-map и Class-map
- Команда "show spanning-tree brief"
- Команда "show etherchannel detail <1-16>"
### Changed
- Изменена команда настройки весов очередей и добавлена возможность настройки весов на порту (mls qos queue weight)
- Добавлен вывод информации о весах очередей в команде "show mls qos interface"
- Переработана команда "show tech-support"
### Fixed
- Исправлена работа management-address-tlv и system-description TLV в LLDP
- Очистка изученных mac-адресов при изменении vlan на порту ge1
- Исправлена работа IGMP Snooping в режиме "no igmp snooping report-supression" (отключена отправка лишних IGMP сообщений)
- Проблема с двойным отключением igmp snooping на vlan
- Работа функционала bdpu-filter
- Высокая нагрузка CPU при получении таблицы MAC-адресов по SNMP
- Закрытие Telnet/ssh сессии при перезагрузке коммутатора
  • 1 month later...
S2962: 7.0.3.5(R0241.0574)
S2965: 7.0.3.5(R0241.0574)
S2982G: 7.0.3.5(R0241.0574)
S2985G: 7.0.3.5(R0241.0574)
S225Gi: 7.0.3.5(R0241.0574)
Список изменений:
7.0.3.5(R0241.0574)
FIX|CRM20230109012963 issue with poe communication compatibility
7.0.3.5(R0241.0573)
FIX|CRM20220816011607 requirements for dot1x&mab
7.0.3.5(R0241.0570)
FIX|CRM20221213012755 add ethernet-oam session state log
Уведомляем вас о выходе новой версии ПО для модели SNR-S2989G-24TX
SNR-S2989G-24TX: 7.5.3.2(R0028.0127)
Список изменений:
7.5.3.2(R0028.0127)
SNR-S2989G-48TX: 7.5.3.6(R0004.0509)
Список изменений:
7.5.3.6(R0004.0509)
FIX|CRM20230118013031 can't delete file from flash
FIX|CRM20230201013091 device in voice-vlan can't get ip address
7.5.3.6(R0004.0508)
FIX|CRM20230202013120 issue with lldp while using Q-in-Q
7.5.3.6(R0004.0505)
FIX|CRM20220310009555 issue with plain text password for SNMPv3 user
7.5.3.6(R0004.0504)
ADD|CRM20221213012755 add ethernet-oam session state log
7.5.3.6(R0004.0503)
FIX|CRM20230112012992 An error is reported after the IMG upgrade is not recognized during startup
SNR-S2990X-24FQ: 7.5.3.2(R0010.0161)
SNR-S300X-24FQ: 7.5.3.2(R0010.0161)
Список изменений:
7.5.3.2(R0010.0161)
FIX|CRM20230116013013 changing SSH key
S2995G: 7.5.3.6(R0004.0509)
S3850G: 7.5.3.6(R0004.0509)
Список изменений:
7.5.3.6(R0004.0509)
7.5.3.6(R0004.0508)
7.5.3.6(R0004.0505)
7.5.3.6(R0004.0504)
7.5.3.6(R0004.0503)
SNR-S300G-24FX: 7.5.3.0(R0010.0307)
Список изменений:
7.5.3.0(R0010.0307)
FIX|CRM20230131013075 issue with mem leaking using dns relay
7.5.3.0(R0010.0306)
FIX|CRM20230116013012 mac-addresses disappear from vfi table after command "mac-address-learning cpu-control"
SNR-S4650X-48FQ: 7.5.3.2(R0016.0052)
Список изменений:
7.5.3.2(R0016.0052)
FIX|CRM20210924007379 incorrect dhcp request
SNR-S7550Y-48C: V705R203C001B002
Список изменений:
V705R203C001B002
FIX|CRM20230209013216 high cpu utilization due to the inefficient interaction between the switch and CPU
  • 1 month later...
S2962: 7.0.3.5(R0241.0588)
S2965: 7.0.3.5(R0241.0588)
S2982G: 7.0.3.5(R0241.0588)
S2985G: 7.0.3.5(R0241.0588)
S225Gi: 7.0.3.5(R0241.0588)
Список изменений:
7.0.3.5(R0241.0588)
FIX|CRM20230407013905 issue with tacacs local user authentication
7.0.3.5(R0241.0587)
ADD|CRM20221227012862 password encryption in debug aaa
7.0.3.5(R0241.0583)
ADD|CRM20221216012774 Switch web import SSL certificate
ADD|CRM20221220012792 Automatic restart when the switch temperature is too low or too high
7.0.3.5(R0241.0582)
FIX|CRM20230118013034 add ability to change mac-address format for RADIUS
7.0.3.5(R0241.0581)
FIX|CRM20221209012732 issue with transceiver-monitoring
7.0.3.5(R0241.0580)
FIX|CRM20221222012829 issue with rootguard output
7.0.3.5(R0241.0579)
FIX|CRM20230109012956 switch returns incorrect value of temperature by snmp
7.0.3.5(R0241.0577)
FIX|CRM20230130013073 issue with multi config access
7.0.3.5(R0241.0575)
ADD|CRM20220715011252 add CoA support
SNR-S2990X-24FQ: 7.5.3.2(R0010.0162)
SNR-S300X-24FQ: 7.5.3.2(R0010.0162)
Список изменений:
7.5.3.2(R0010.0162)
ADD|CRM20230321013671 dhcpv6 relay agent notification for prefix delegation function
SNR-S300G-24FX: 7.5.3.0(R0010.0321)
Список изменений:
7.5.3.0(R0010.0321)
FIX|CRM20230112012987 issue with tWatchDog tArchiveTask
7.5.3.0(R0010.0319)
ADD|CRM20230329013783 add ip dhcp broadcast suppress for vlan
7.5.3.0(R0010.0318)
ADD|CRM20221213012751 add arbitrary UDP-port for syslog
7.5.3.0(R0010.0317)
ADD|CRM20220722011334 add IP-source address while using TFTP
7.5.3.0(R0010.0316)
FIX|CRM20230315013596 issue with memory leaking related to DNS
7.5.3.0(R0010.0315)
ADD|CRM20221209012733 add feature to count mac addresses in VFI
7.5.3.0(R0010.0314)
ADD|CRM20221216012772 Validity Management of Switch Passwords
7.5.3.0(R0010.0310)
FIX|CRM20230201013102 issue with OSPF+bfd while using script
7.5.3.0(R0010.0309)
FIX|CRM20230228013409 cyclic reboot
SNR-S7550Y-48C: V705R203C001B011
Список изменений:
V705R203C001B011
FIX|CRM20230329013788 issue with USB-port
V705R203C001B010
V705R203C001B008
FIX|CRM20230313013556 Switch become unavailable out of cache overflow
V705R203C001B006
ADD|CRM20221220012792 Feature with automatic restart when the switch temperature is too low or too high
V705R203C001B005
S5210G: 1.4.0
Список изменений:
### Added
- Функционал MAC Authentication Bypass (MAB)
- Отложенная перезагрузка
- Работа MVR на портах в access режиме
- Управление настройками интерфейсов по SNMP (ветка .1.3.6.1.4.1.40418.7.100.3.2)
- Возможность фильтрации по VLAN и COS в MAC ACL
- Команда для отображения утилизации TCAM "show tcam usage"
### Changed
- Изменение имени L3 интерфейса c vlan0.X на vlanX (для ввода доступны форматы "vlan0.X", "vlanX", "vlan X"). Сохранена совместимость конфигурации с предыдущими версиями eNOS
- Изменен формат вывода команд "show version" и "show power inline"
### Fixed
- Некорректное ограничение количества VLAN со включенным DHCP Relay
- Ошибки при вводе "?" после ключевого слова no
- Некорректное редактирование ACL, примененных на портах
- Ошибка при создании extended mac acl
- Настройка igmp snooping static-group на интерфейсе c выкл. IGMP SNOOPING могла приводить к перезагруке
- Перезагрузка при вводе длинного имени интерфейса (более 46 символов)
- Отправка unknown-unicast пакетов с CPU
- Некорректная работа команды "aaa authentication login console local none"
- После удаления интерфейса в состоянии down из channel-group, некорректно отображались настройки speed-duplex данного интерфейса
  • 1 month later...
S2962: 7.0.3.5(R0241.0594)
S2965: 7.0.3.5(R0241.0594)
S2982G: 7.0.3.5(R0241.0594)
S2985G: 7.0.3.5(R0241.0594)
S225Gi: 7.0.3.5(R0241.0594)
Список изменений:
7.0.3.5(R0241.0594)
ADD|CRM20230510000001 combo negotiation feature
7.0.3.5(R0241.0593)
FIX|CRM20230410013933 issue with RADIUS + MS NPS
FIX|CRM20230426014121 issue with mac-ip-access-list when using ICMP filter
7.0.3.5(R0241.0591)
FIX|CRM20230419014030 issue with SNMP OID for ifLastChange
SNR-S2990X-24FQ: 7.5.3.2(R0010.0169)
SNR-S300X-24FQ: 7.5.3.2(R0010.0169)
Список изменений:
7.5.3.2(R0010.0169)
FIX|CRM20230504014173 issue with IGMP GQ and QinQ
7.5.3.2(R0010.0165)
FIX|CRM20230413013979 issue with traceroute
SNR-S300G-24FX: 7.5.3.0(R0010.0327)
Список изменений:
7.5.3.0(R0010.0327)
FIX|CRM20230428014143 switch reboots with tWatchDog due to DDM events
7.5.3.0(R0010.0325)
FIX|CRM20230426014119 issue with redistribute OSPF route
7.5.3.0(R0010.0323)
FIX|CRM20230210013222 fail to config user-define ACL
SNR-S7550Y-48C: V705R203C001B014
Список изменений:
V705R203C001B014
FIX|CRM20230516014325 incorrect OSPF working
V705R203C001B013
FIX|CRM20230428014149 fail to config ipv6 ospf network point-to-point
V705R203C001B012
FIX|CRM20230411013951 issue with dst cache overflow in some cases
  • 1 month later...
SNR-S2990X-24FQ: 7.5.3.2(R0010.0172)
SNR-S300X-24FQ: 7.5.3.2(R0010.0172)
Список изменений:
7.5.3.2(R0010.0172)
ADD|CRM20230213013238 unite vlan-translation IN and OUT directions in configuration
7.5.3.2(R0010.0171)
FIX|CRM20230602014590 sFlow incorrectly determines counters packets from switch
7.5.3.2(R0010.0170)
ADD|CRM20220722011334 add an opportunity to configure IP source address for TFTP usage
FIX|CRM20230602014591 BFD static route doesn't disappear from routing table
Уведомляем вас о выходе новых версий ПО для моделей SNR-S2990X-24FQ и SNR-S300X-24FQ (HA versions)
SNR-S2990X-24FQ: V706R202C002
SNR-S300X-24FQ: V706R202C002
Список изменений:
V706R202C002
ADD|ADD SNR-S300X-24FQ VSF_HA
ADD|ADD new stable version
SNR-S4650X-48FQ: 7.5.3.2(R0016.0056)
Список изменений:
7.5.3.2(R0016.0056)
ADD|CRM20230601014579 add OIDs for power units
7.5.3.2(R0016.0055)
ADD|CRM20230404013852 add arbitrary UDP-port for syslog
7.5.3.2(R0016.0054)
FIX|CRM20230113012998 issue with monitor sessions
7.5.3.2(R0016.0053)
ADD|CRM20221014012174 add multicast unknown-group drop function
ADD|CRM20220513010421 add command icmp-reply fast
Уведомляем о выходе новой версии ПО для модели SNR-S4650X-48FQ (R3)
SNR-S4650X-48FQ: V705R204C001B007
Список изменений:
V705R204C001B007
V705R204C001B006
V705R204C001B005
FIX|CRM20230322013689 issue with redistribute ospf
V705R204C001B004
V705R204C001B003
V705R204C001B002
V705R204C001B001
SNR-S7550Y-48C: V705R203C001B016
Список изменений:
V705R203C001B016
V705R203C001B015
ADD|CRM20220418009981 add 'archive running-config' functon
S5210: 1.5.0
Список изменений:
### Added
- Функционал Packet-capture (Мониторинг трафика)
- Автоопределение скорости на 10GE портах (speed-duplex auto).
- Dying gasp (для моделей SNR-S5210G-24TX(-UPS) hw 1.2.0,  SNR-S5210G-24FX, SNR-S5210X-8F)
- Поддержка режима PoE LED на SNR-S5210G-24TX-POE
- Команда для запрета отправки Broadcast и Unknown-unicast на порту "switchport flood-control bcast | ucast"
### Changed
- Сохранение конфигурации в startup-config с новым форматом SVI (VlanX) (Внимание! При необходимости downgrade eNOS на версию ниже 1.4.0 необходимо предварительно обновиться на версию 1.4.0 и сохранить конфигурацию)
- Сохранение конфигурации spanning-tree mst configuration при переключении из режима MSTP в STP/RSTP
- Логирование событий login и logout c отображением имени пользователя, протокола и IP
### Fixed
- Транзит STP BPDU пакетов при глобально выключенном STP
- Работа MSTP с разными root коммутаторами в разных MSTI
- Отображение имен пользователей, авторизованных через RADIUS/TACACS в команде "show users"
- Зависание сессий в терминале
- Разрыв всех telnet-сессий при создании 17го telnet-соединения
- Logout пользователя после завершения работы команды ping
- Некорректная работа DHCP Snooping Binding при переполнении аппаратной таблицы
- Некорректное отключение IGMP Snooping на интерфейсе
- Перезагрузка при удалении IGMP Snooping static group
- Некорректная настройка speed duplex в режиме speed-duplex auto 10 и включенном flowcontrol
- Ошибки в работе MAB
- Работа SNMP OID (ipAddressPrefixTable) .1.3.6.1.2.1.4.32 при наличии маршрута по умолчанию
  • 4 weeks later...
SNR-S2989G-24TX: V705R002C003
Список изменений:
V705R002C003
V705R002C002B038
ADD|CRM20235118013535 snmp-view requirements
V705R002C002B029
FIX|CRM20230602014592 constant high CPU utilization and reboot by Watchdog in some cases
V705R002C002B025
FIX|CRM20230602014593 issue with BPDU-tunnel and QinQ
V705R002C002B022
V705R002C002B021
FIX|CRM20230517014367 failed to read switch power information through SNMP
V705R002C002B020
V705R002C002B019
FIX|CRM20230530014543 doesn't appear link on SFP ports in some cases
V705R002C002B018
ADD|CRM20230330013809 add an ability to configure source-ip address at info-center
V705R002C002B016
ADD|CRM20230508014213 turn off/on PoE for VCT automatically
FIX|CRM20230511014277 tSshdSessionTask0 task hang
V705R002C002B015
FIX|CRM20230504014165 switch becomes unavailable after copy-paste configuration
V705R002C002B013
FIX|CRM20230329013787 fixed opportunity to enable Port-group with storm-control in some cases
V705R002C002B012
V705R002C002B010
FIX|CRM20230420014046 issue with ports in stack after adding VLAN in supervlan
V705R002C002B008
FIX|CRM20230331013814 sometimes switch drop IGMP-reports
V705R002C002B007
FIX|CRM20230210013220 stack reboot after adding VLAN in supervlan
V705R002C002B003
ADD|CRM20220816011607 requirements for dot1x&MAB
FIX|CRM20230310013530 issue with QinQ and BPDU-tunnel user-defined-protocol
V705R002C002B002
ADD|CRM20221220012798 add command to show MD5SUM
FIX|CRM20230403013841 switch becomes unavailable after "show anti-arpscan"
V705R002C002B001
ADD|CRM20230222013359 support command "show vsf config detail"
SNR-S2989G-48TX: V705R002C003
Список изменений:
V705R002C003
V705R002C002B038
V705R002C002B029
V705R002C002B025
V705R002C002B022
V705R002C002B021
V705R002C002B020
V705R002C002B019
V705R002C002B018
V705R002C002B016
V705R002C002B015
V705R002C002B013
V705R002C002B012
V705R002C002B010
V705R002C002B008
V705R002C002B007
V705R002C002B003
V705R002C002B002
V705R002C002B001
7.5.3.6(R0004.0521)
ADD|CRM20230216013283 Port Isolation SNMP MIB Requirements
7.5.3.6(R0004.0519)
7.5.3.6(R0004.0518)
ADD|CRM20221124012599 Ability to turn off/on PoE for VCT automatically
7.5.3.6(R0004.0517)
FIX|CRM20230209013218 issue with OSPF NSSA and AF changing
FIX|CRM20230131013082 issues with port-group + loopback-detection
S2995G: V705R002C003
S3850G: V705R002C003
Список изменений:
V705R002C003
V705R002C002B038
V705R002C002B029
V705R002C002B025
V705R002C002B023
ADD|CRM20230601014580 add ability to check AC status via SNMP
V705R002C002B022
V705R002C002B021
V705R002C002B020
V705R002C002B019
V705R002C002B018
V705R002C002B016
V705R002C002B015
V705R002C002B013
V705R002C002B012
V705R002C002B010
V705R002C002B008
V705R002C002B007
V705R002C002B003
V705R002C002B002
V705R002C002B001
7.5.3.6(R0004.0521)
ADD|CRM20221228012864 additional information about power on switch
7.5.3.6(R0004.0520)
7.5.3.6(R0004.0519)
7.5.3.6(R0004.0517)
SNR-S4650X-48FQ: 7.5.3.2(R0016.0057)
Список изменений:
7.5.3.2(R0016.0057)
FIX|CRM20230614014709 issue with copy running config via SFTP
SNR-S4650X-48FQ: V705R204C001B011
Список изменений:
V705R204C001B011
FIX|CRM20230626014884 issue with copy running config via SFTP
  • 1 month later...
S2962: V702R101C005
S2965: V702R101C005
S2982G: V702R101C005
S2985G: V702R101C005
S225Gi: V702R101C005
Список изменений:
V702R101C005
ADD|ADD new stable FW version
V702R101C004B010
FIX|CRM20230727015304 add to logs SSH port number
V702R101C004B008
FIX|CRM20230810015517 incorrect work of the switch with the configured dhcp-client
V702R101C004B007
FIX|CRM20230731015362 issue with creating user via SNMP in some cases
V702R101C004B003
FIX|CRM20230801015371 issue with SNMPv3 user password encryption
V702R101C004B002
FIX|CRM20230726015292 doesn't transmit Radius Accept-Request encapsulating Nak-Message
FIX|CRM20230704014987 issue with temperature output
V702R101C004B001
FIX|CRM20230707015050 issue with upgrading boot.rom with auto-provisioning if file name doesn't contain "boot.rom"
V702R101C003B010
FIX|CRM20230627014897 issue with MAC-addresses learning in VLAN after adding this VLAN
V702R101C003B009
FIX|CRM20230704014998 issues with autoprovisioning
V702R101C003B008
FIX|CRM20230620014804 issue with 'ip tftp-client source'
V702R101C003B007
FIX|CRM20230706015030 return incorrect chip value via SNMP
FIX|CRM20230705015015 issues with description characters output via SNMP and changing description via SNMP
V702R101C003B006
ADD|CRM20230407013904 add switch import SSL certificate in new web
FIX|CRM20230704014986 switch reboots if description contains '%'
V702R101C003B004
ADD|CRM20230309013520 add command 'local-arp enable subnet' so that switch can respond to ARPs that are not intended for it
V702R101C003B003
ADD|CRM20221220012798 add command to show md5sum
Уведомляем вас о выходе новых версий ПО для серий S2989G/S2995G/S3850G
S2989G: V705R002C005 (24TX) и V705R002C005 (48TX)
S2995G: V705R002C005
S3850G: V705R002C005
Список изменений:
V705R002C005
V705R002C004B020
FIX|CRM20230823015641 issue with getting IP default gateway from ARP table via SNMP request
V705R002C004B016
ADD|CRM20230615014721 add rule-id to ACL
V705R002C004B014
ADD|CRM20230601014581 add information about Port-Channel interfaces via command "show interface status"
V705R002C004B011
ADD|CRM20230727015308 add output for stack when switch boot
V705R002C004B010
V705R002C004B008
ADD|CRM20230518014385 decrease number of mac-notification messages
V705R002C004B007
FIX|CRM20230727015310 switch stuck and reboot with Watchdog task tMSTP in some cases
V705R002C004B005
FIX|CRM20230704014986 switch reboot if description contain '%'
V705R002C004B004
V705R002C004B002
V705R002C003B006
FIX|CRM20230714015139 command 'show clock' doesn’t show seconds
V705R002C003B001
FIX|CRM20230425014114 issue with low speed in some cases
SNR-S4650X-48FQ: 7.5.3.2(R0016.0060)
Список изменений:
7.5.3.2(R0016.0060)
FIX|CRM20230811015523 some configuration lost after reboot
7.5.3.2(R0016.0058)
ADD|CRM20230601014578 add function to disable messages about illegal DIP
SNR-S4650X-48FQ: V705R204C001B017
Список изменений:
V705R204C001B017
V705R204C001B016
V705R204C001B015
Релиз доступен по ссылкам:
SNR-S5210G-24TX: 1.6.0
SNR-S5210G-24TX-POE: 1.6.0
SNR-S5210G-24FX: 1.6.0
SNR-S5210X-8F: 1.6.0
Список изменений:
## [1.6.0] - 2023-09-28
### Added
- Функционал BPDU-Tunnel
- Команда "show ip dhcp-client"
- Проверка контрольной суммы, версии ПО и платформы при обновлении ПО
- SNMP OID .1.3.6.1.4.1.xxx.7.100.1.200 - название модели коммутатора
- SNMP OID .1.3.6.1.4.1.xxx.7.100.1.201 - время до отложенной перезагрузки
- Вывод информации об отложенной перезагрузке при подключении к терминалу
- Команда "mac-address-table aging-time <time>"
- Команда "show lldp neighbors brief"
- Поддержка модели SNR-S5210G-24TX-DC
- Поддержка модели SNR-S5210X-8F-UPS
- Поддержка модели SNR-S5210G-24TX-POE-R
### Changed
- Поддержка различных форматов MAC-адреса в команде "show mac address-table"
- Изменение логики настройки портов в режимах trunk и hybrid
     - Добавлены команды для перезаписи списка разрешенных vlan для режимов trunk и hybrid:
          "switchport trunk allowed vlan <vlan-list>"
          "switchport hybrid allowed vlan <vlan-list> (tag|untag)"
     - Добавлена команда "switchport hybrid allowed vlan (add | except | none | remove) <vlan-list> (tag|untag)", аналогичная
       "switchport hybrid allowed vlan (add | except | none | remove) <vlan-list> egress-tagged (enable |disable)"
     - Добавлена команда "switchport hybrid native vlan <1-4094>", аналогичная существующей "switchport hybrid vlan <1-4094>"
     - Изменена логика работы работы native vlan для режимов trunk и hybrid, в новой логике native vlan не добавляется автоматически в список allowed vlan на порт. Native vlan в режиме hybrid устанавливает только PVID порта.
     - Изменено формирование running-config c использованием команд "switchport trunk allowed vlan <vlan-list>" и "switchport hybrid allowed vlan <vlan-list> (tag|untag)"
     - Сохранена совместимость со старыми версиями конфигурации (для обновления на 1.6.0 с более ранних версий, изменение конфигурации не требуется)
     - При downgrade с 1.6.0 на более ранние версии ПО, необходимо производить downgrade через промежуточную версию 1.5.5 с сохранением конфигурации
### Fixed
- Ошибка при создании SNMP community и имен пользователей c символами "-" и "_"
- Ошибка в отображении времени в команде "show reload"
- Некорректная работа команды "igmp snooping force-igmp-version 2" после перезагрузки
- Некорректное отображение Uptime в команде "show users"
- Некорректное отображение настройки "mac-address-table limit" в конфигурации
- Некорректная работа команды "no mls qos default-cos"
- Некорректное отображение "negotiation on/off"
- SNMP OID .1.3.6.1.2.1.17.4.3.1.1 мог отдавать неактуальную таблицу MAC-адресов
- На 1G SFP портах SNR-S5210G-24FX по умолчанию отключен negotiation
- Перезагрузка при вводе команды "set lldp too-many-neighbors limit"
## [1.5.5] - 2023-09-20
### Added
- Промежуточная прошивка для downgrade с версии 1.6.0 и старше
## [1.5.4] - 2023-09-18
### Added
### Fixed
- Утечка памяти при применении Policy-map
- Зависание управления коммутатором при подключении по Telnet и последующим разрывом сессии в течении 1 сек
## [1.5.2] - 2023-07-24
### Fixed
- LLDP: Перезагрузка при получении двух одинаковых LLDP пакетов в интервале <10 секунд и последующим DOWN/UP порта
- LLDP: Исправлено отбрасывание LLDP пакетов с неизвестными TLV
- LLDP: Исправлено отображение MAC-адреса remote chassis в команде "show lldp port .."
## [1.5.1] - 2023-07-17
### Added
- Команда 'speed-duplex force10g-full high-leq'  выполняющее повышение значения LEQ 10GE интерфейса для совместимости с оборудованием на чипах Centek (Например OLT BDCOM GP3600)
### Fixed
- Перезагрузка при получении IGMP Group specific query на mrouter порт при наличии на mrouter порту подписки с группой из этого Group specific query
  • 2 months later...
S2989G: V705R002C006 (24TX) и V705R002C006 (48TX)
S2995G: V705R002C006
S3850G: V705R002C006
Список изменений:
V705R002C006
V705R002C005B016
FIX|CRM20231201017319 issue with service password-encryption
FIX|CRM20231122017172 issue with unicast ARP gets into other VLAN in some cases
V705R002C005B015
ADD|CRM20231116017031 add ability to disable CLI prompt
V705R002C005B013
FIX|CRM20231023016524 stop forwarding packets via Port-channel on ERPS-ring in some cases
FIX|CRM20231024016544 correct spanning-tree BPDU counters
V705R002C005B012
FIX|CRM20231102016729 issue with VTY auth through RADIUS in stack
V705R002C005B011
FIX|CRM20231009016276 issue with shortcut keys in some cases
V705R002C005B010
FIX|CRM20231010016310 issue with info-center and watchdog task: zIMI
ADD|CRM20230922016119 add route-map features
ADD|CRM20230919016057 self-defined subscriber-id for specific interface
V705R002C005B008
FIX|CRM20230919016052 switch flooding incorrect messages about PoE at logs
FIX|CRM20231009016290 rebooted by watchdog with error in task tSnmpd in some cases
V705R002C005B006
FIX|CRM20230926016159 fail to save the current config to startup config via WEB in some cases
V705R002C005B005
FIX|CRM20231009016275 issue when MAC-addresses are not studied in some cases
V705R002C005B004
ADD|CRM20230922016118 realize descriptions for L3-interfaces
V705R002C005B003
FIX|CRM20230831015748 issue with packets transit via VSF in some cases
V705R002C005B002
FIX|CRM20230829015717 issue with drop packets in queues in some cases
SNR-S4650X-48FQ: V705R204C002
Список изменений:
V705R204C002
V705R204C001B019
SNR-S2990X-24FQ (HA): V706R202C002
SNR-S2990X-24FQ (non-HA): 7.5.3.2(R0010.0179)
SNR-S300X-24FQ (HA): V706R202C002
SNR-S300X-24FQ (non-HA): 7.5.3.2(R0010.0179)
Список изменений для non-HA версии:
7.5.3.2(R0010.0179)
FIX|CRM20231024016544 correct STP BPDU counters
ADD|CRM20230915015980 add Dynamic ARP Inspection
FIX|CRM20231103016752 issue with authorization via SSH by SSH-key
SNR-S7550Y-48C: V705R203C001B027
Список изменений:
V705R203C001B027
FIX|CRM20231011016324 issue with privilege level configuration
V705R203C001B026
FIX|CRM20231009016289 issue with terminals freezing in some cases
V705R203C001B025
ADD|CRM20230821015620 added new VSF logs for the issue with VSF stack fall apart
V705R203C001B023
FIX|CRM20230628014920 issue with unavailable VSF stack due SKB leakage in some cases
V705R203C001B022
V705R203C001B019
SNR-S5210G-24TX: 1.7.0
SNR-S5210G-24TX-POE: 1.7.0
SNR-S5210G-24FX: 1.7.0
SNR-S5210G-8TX: 1.7.0
SNR-S5210X-8F: 1.7.0
SNR-S5310G-48TX: 1.7.0
SNR-S5310G-48TX-POE: 1.7.0
Список изменений:
## [1.7.0] - 2023-12-25
### Added
- Отключение передатчиков SFP/SFP+ при применении команды "shutdown" на порту
- Функционал Vlan-translation
- Функционал ZTP (Autoprovisioning)
- Функционал Dynamic Arp Inspection
- Команда "switchport mode trunk allow-null" запрещающая все Vlan на порту, при переводе в trunk
- Автоопределение DAC-кабелей на XGE портах
- Функционал RSPAN Vlan
- Команда "switchport flood-control mcast"
- Функционал OAM Dying Gasp
- Поддержка модели SNR-S5110G-24TX
- Поддержка модели SNR-S5110G-48TX
- Поддержка модели SNR-S5210G-8TX
- Поддержка модели SNR-S5310G-48TX-POE
- Поддержка модели SNR-S5210G-24FX-UPS
- Поддержка модели SNR-S5210G-24FX-DC
- Поддержка модели SNR-S5210G-24FX-RPS
- Поддержка модели SNR-S5210G-24TX-RPS
- Поддержка модели SNR-S5210X-8F-DC
- Поддержка модели SNR-S5210X-8F-RPS
### Changed
- Скорректирована работа IGMP Snooping:
  - Реализован флуд unknown-mcast в mrouter порты
  - Максимальное количество Vlan с включенным IGMP Snooping уменьшено до 6
- Ошибка с добавлением "/" в запрашиваемое имя файла, при копировании по TFTP
- Изменена логика работы команды "switchport mode trunk", при её применении разрешаются все Vlan на порту
### Fixed
- SNMP OID .1.3.6.1.2.1.31.1.1.1.18 не передает description порта
- Работа dying gasp
- Команда mac-address-table static не загружается из startup-config
- В Po/Sa могли быть добавлены порты с различным native vlan
- Сброс команды speed-duplex force10g-full media dac
- Нумерация ifindex xe портов на модели SNR-S5310G-48TX
## [1.6.2] - 2023-11-28
### Added
- Вывод статистики по отброшенным пакетам в выходных очередях портов в команде "show interface <ifname>"
- Команда для включения отладки IGMP Snooping "debug igmp snooping brief"
### Changed
- Изменение таймеров на отписку IGMP Snooping
  • 2 months later...
S2962: V702R101C008
S2965: V702R101C008
S2982G: V702R101C008
S2985G: V702R101C008
S225Gi: V702R101C008
Список изменений:
V702R101C008
FIX|CRM20240117018392 issue with incorrect output of SNMP OID (dot1dStpDesignatedRoot) in some cases
ADD|CRM20240125018544 add new PWD/DIAG LED state
ADD|add new stable FW version
V702R101C007B008
ADD|CRM20231222017887 add OID to get information about memory in bytes (.1.3.6.1.4.1.40418.7.100.1.11.[14-16])
V702R101C007B007
FIX|CRM20240219018826 issue with forwarding ARP-packets with configured "ip dhcp snooping binding user-control" in some cases
V702R101C007B004
FIX|CRM20240201018665 issue with configuring CFM mep-id
V702R101C007B003
FIX|CRM20240119018429 issue with MAC-address learning when using static LAG + LBD
V702R101C007B002
FIX|CRM20240117018401 issue with high utilization CPU with connecting SFP in some cases
V702R101C007
ADD|recommended FW
ADD|CRM20240110018224 add ports output in command 'sh port-group detail' when statis LAG is configured
V702R101C006B001
FIX|CRM20231207017553 port can't link up after 400 times of reboot
V702R101C006
ADD|recommended FW
V702R101C005B024
ADD|CRM20230919016056 add logging to the function "rate-violation" without configured any violation control method
V702R101C005B023
FIX|CRM20231220017817 modify output of 'show locked user'
V702R101C005B021
FIX|CRM20231218017740 issue with encrypting NTP authentication key with 'service password-encryption'
V702R101C005B016
V702R101C005B015
FIX|CRM20231101016703 command 'sh int ethernet <IFNAME> statistics' doesn't work
V702R101C005B014
FIX|CRM20231115017010 fix grammatical errors in text on the web-interface
V702R101C005B013
FIX|CRM20231102016715 issue with snmp index error in some cases
V702R101C005B012
FIX|CRM20231101016704 add ability to config DHCP Snooping information option for range of ports
V702R101C005B011
FIX|CRM20231024016538 changing SSH key
V702R101C005B010
FIX|CRM20231009016273 removed command 'ipv6 route ::/0 null0'
V702R101C005B006
ADD|CRM20230919016058 add information about Port-Channel interfaces via command 'show interface status'
V702R101C005B004
FIX|CRM20230831015756 inheriting settings from physical ports to port-channel
V702R101C005B003
ADD|CRM20230801015381 realize sending DHCP Release while switch reboot and adding option 60 to DHCP
V702R101C005B002
FIX|CRM20230830015739 issue with task 'tDhcpRcv' when receive incorrect DHCP packet
V702R101C005B001
FIX|CRM20230807015477 switch returns incorrect PoE capacity value via SNMP
S2989G: V705R002C009 (8TX), V705R002C009 (24TX) и V705R002C009 (48TX)
Список изменений:
V705R002C009
ADD|recommended FW
FIX|CRM20240117018394 port link not up in low-temperature environment
V705R002C008
ADD|recommended FW
V705R002C007B003
FIX|CRM20240117018394 high temperature readings via SNMP if the temperature is below 0
V705R002C007B002
FIX|CRM20240111018253 issue with incorrect output at the WEB-Interface in some cases
V705R002C007B001
FIX|CRM20240109018213 issue with the operation of the ACL, which restricts using TCP-connection flags
FIX|CRM20240109018213 issue with link on ports at low temperatures in some cases
V705R002C007
FIX|CRM20231023016526 issue with lack of some options for config HTTPS secure-ciphersuite at the WEB-Interface
ADD|new WEB design
V705R002C006B010
SNR-S2990X-24FQ (HA): V706R202C004
SNR-S2990X-24FQ (non-HA): 7.5.3.2(R0010.0180)
SNR-S300X-24FQ (HA): V706R202C004
SNR-S300X-24FQ (non-HA): 7.5.3.2(R0010.0180)
7.5.3.2(R0010.0180)
Список изменений для HA версии:
V706R202C004
V706R202C003B037
ADD|CRM20231128017276 realize descriptions for L3-interfaces
V706R202C003B035
FIX|CRM20231116017030 add l2-multicast traffic forwarding without IP-header via command "multicast unknown-group drop exclude (<MAC-address> <mask> | host-destination-mac <MAC-address>)"
ADD|CRM20231107016827 add resetting TCP-session when entering the switch reboot command
V706R202C003B033
V706R202C003B027
V706R202C003B026
FIX|CRM20231009016293 issue with incorrect display of ports in the WEB-interface
V706R202C003B024
FIX|CRM20230927016181 correct power status value return via SNMP
V706R202C003B023
ADD|CRM20230825015674 add new formats of MAC-addresses to searching ARPs in the ARP-table
V706R202C003B016
FIX|CRM20230823015640 incorrect value of memory at switch logs
V706R202C003B015
FIX|CRM20230907015867 incorrect mac-notification working and 'show cpu monitor' command
ADD|CRM20230321013669 added support of multi address-range for any subvlan
V706R202C003B014
ADD|CRM20230625014868 changes at the "rate-violation" & "storm-control" functions
V706R202C003B010
V706R202C003B009
V706R202C003B006
V706R202C003B005
FIX|CRM20221213012753 MED tlv does not insert in LLDP if unset MED tlv and try to set MED tlv again
V706R202C003B004
ADD|CRM20230619014781 add password encryption to the command 'show aaa config'
V706R202C002B009
ADD|CRM20230724015258 switch doesn't send PIM Join in case, when IGMP Report Source IP isn't from subnet of interface
V706R202C002B006
V706R202C002B005
V706R202C002B004
FIX|CRM20230621014821 port status is not displaying with connected link in GUI
FIX|CRM20230611014672 doesn't forwarding multicast with Selective QinQ after enabling IGMP snooping
V706R202C002B001
SNR-S300G-24FX: V705R201C002
Список изменений:
V705R201C002
Релиз доступен по ссылке (теперь один файл для обеих ревизий):
Список изменений:
V705R204C002
V705R204C001B019
Уведомляем о выходе новой версии ПО для серии S7550
S7550: V705R203C001B042
Список изменений:
V705R203C001B042
V705R203C001B041
FIX|CRM20240204018710 error while deleting VRF in VxLAN environment
V705R203C001B039
ADD|CRM20231201017328 users got incorrect privilege level from MS NPS RADIUS-server
V705R203C001B038
ADD|CRM20231222017886 add route-map features
V705R203C001B036
FIX|CRM20231013016388 add ability to use VRF forwarding for info-center, SNMP and TACACS functions
V705R203C001B033
FIX|CRM20231113016940 issue with routing EVPN/VxLAN at distributed gateway scheme
V705R203C001B032
FIX|CRM20231128017281 issue with output MAC-address table with filtering by VLAN
V705R203C001B028
FIX|CRM20231009016289 issue with incorrect display state of power
  • 3 months later...
SNR-S2989G-8TX(-POE): V705R002C011, SNR-S2989G-24TX(-POE): V705R002C011, SNR-S2989G-48TX(-POE): V705R002C011
S2995G: V705R002C011
S3850G: V705R002C011
Список изменений:
V705R002C011
FIX|CRM20240520020833 corrected erratas in some commands at CLI
V705R002C010B025
FIX|CRM20240607021322 issue with configuration ip default-gateway
V705R002C010B024
FIX|CRM20240606021291 switch returned DDM value only from the first unit at VSF stack
FIX|CRM20240613021427 issue with packet statistics length (1024~1518) on SFP ports
V705R002C010B023
FIX|CRM20240524020952 fix wrong ID of IGMP Snooping authentication NAS-Port
V705R002C010B021
FIX|CRM20240417020096 issue with export info-center config by convert VSF mode
V705R002C010B019
ADD|CRM20240125018537 add config backup to a remote server during the execution of the 'write' command
V705R002C010B013
FIX|CRM20240422020180 add passwords encryption to the command 'show aaa config'
FIX|CRM20240422020181 fix problem with unencrypted keys for some protocols in running-config
V705R002C010B009
ADD|CRM20240425020291 change value of TX signal to -40 dBm when there is no output signal
ADD|CRM20240424020254 add restarting of VSF members via the WEB-interface
FIX|CRM20240429020370 issue with ping and SSH-connection by domain name
ADD|CRM20240427020325 issue with showing IPv6 routes in the WEB-interface
V705R002C010B008
FIX|CRM20240410019943 issue with showing Lease time in output of DHCP Snooping table
V705R002C010B007
ADD|CRM20240222018894 add command "show archive config differences ..." to compare configuration files
V705R002C010B006
FIX|CRM20240305019144 issue with task zOSPF in some cases
V705R002C010B003
FIX|CRM20240408019881 issue with rebooting switch with error in task tLldp
V705R002C010B002
ADD|CRM20240329019693 add command "passive-interface default" for OSPF
V705R002C010B001
FIX|CRM20240329019686 issue with incorrect processing of NFS-packets
FIX|CRM20240410019929 issue with incorrect names of button in WEB-Interface
ADD|CRM20240117018399 add ability to assign same IPv6 link-local address to different interfaces
V705R002C010
ADD|recommended FW
V705R002C009B015
FIX|CRM20240328019672 using the OSPF authentication area method if OSPF authentication on the port is not configured
V705R002C009B013
FIX|CRM20240228019013 add OID 1.0.8802.1.1.2.1.1.7.1 to enable LLDP Management-address TLV on ports
FIX|CRM20240129018590 issue with HTTP authorization when HTTPS is enabled
ADD|CRM20240109018204 change value of RX signal to -40 dBm when there is no signal
FIX|CRM20240228019018 issue with incorrect MAC-addresses in outputting of ARP debug in some cases
V705R002C009B011
FIX|CRM20240223018920 issue with outputting gateway ARP by SNMP in some cases
V705R002C009B010
FIX|CRM20240228019025 WEB-interface doesn't work via VRF
V705R002C009B008
FIX|CRM20240313019314 wrong description of some commands at "copy" mechanism
FIX|CRM20240219018830 fixed various errors at SNMP LLDP
V705R002C009B007
FIX|CRM20240207018765 fixed high CPU utilization on the last recommended FW (V705R002C009)
V705R002C009B004
FIX|CRM20240229019047 high delay while pinging switch
FIX|CRM20240207018757 switch returns DDM value via SNMP from another port in some cases
FIX|CRM20240220018862 issue with IGMP report messages while using command to replace MAC
V705R002C009B003
ADD|CRM20231128017278 add command to disable logs of user log-in on switch
V705R002C009B001
FIX|CRM20240111018259 issue with configuring rate-violation and LBD at the same time
SNR-S2990X-24FQ (HA): V706R202C005B016
SNR-S2990X-24FQ (non-HA): 7.5.3.2(R0010.0183)
SNR-S300X-24FQ (HA): V706R202C005B016
SNR-S300X-24FQ (non-HA): 7.5.3.2(R0010.0183)
7.5.3.2(R0010.0183)
7.5.3.2(R0010.0182)
FIX|CRM20240305019131 issue with link indicates on WEB-interface
ADD|CRMV706R202C004B010 add Selective QinQ
FIX|CRM20240124018500 issue with forwarding L2-multicast traffic at IGMP Snooping VLAN through VSF stack
ADD|CRM20231128017277 add isolation of Management-port by default
ADD|CRM20231206017398 add opportunity to check advertised/received routes via BGP at VRF
7.5.3.2(R0010.0181)
ADD|CRM20220407009877 managment vrf features
FIX|CRM20230809015511 issue with dot1x authentication in EAP-TLS mode
V706R202C005B016
FIX|CRM20240531021124 add an ability to swap logging mode to info-center mode
V706R202C005B013
FIX|CRM20240422020181 issue with unencrypted keys for some protocols in running-config
V706R202C005B008
ADD|CRM20211028007860 add info-center possibility for VRF
ADD|CRM20220223009349 add arbitrary UDP-port for syslog
V706R202C005
ADD|recommended FW
V706R202C004B016
ADD|CRM20231212017657 change output about TCAM usage
V706R202C004B015
ADD|CRM20231222017880 add info-center function
V706R202C004B012
FIX|CRM20240325019576 cos value dropped after VLAN translation
V706R202C004B011
FIX|CRM20240314019356 issue with outputting of helper-address in running-configuration
V706R202C004B009
ADD|CRM20240307019187 add special command for Selective QinQ
V706R202C004B008
FIX|CRM20240219018829 second unit at VSF stack froze in some cases
V706R202C004B005
V706R202C004B003
ADD|CRM20231128017277 add ability to assign MGMT-interface to any VRF
V706R202C004B002
SNR-S300G-24FX: V705R201C004
Список изменений:
V705R201C004
V705R201C003B011
V705R201C003B008
V705R201C003B007
ADD|CRM20231220017817 add command 'show locked user'
V705R201C003B006
FIX|CRM20230908015890 issue with missing mac addresses in VPLS after OSPF convergence
V705R201C003B004
V705R201C003B003
ADD|CRM20230412013956 ability to sending default route in VRF
V705R201C002B003
ADD|CRM20230425014115 ability to increase quantity of PIM groups (IPv4-routes)
V705R201C002B002
V705R201C002B001
ADD|CRM20230213013243 add an exception for VLANs which not belong to supervlan to use them in
SNR-S4650X-48FQ (R3): V705R204C003
Список изменений:
V705R204C003
V705R204C002B010
V705R204C002B007
V705R204C002B006
ADD|CRM20231128017276 add L3 interfaces descriptions
V705R204C002B004
FIX|CRM20231212017641 issue with sending incorrect timezone via NTP
V705R204C002B002
FIX|CRM20230911015913 issue with long time for outputting the VLAN list in some cases
V705R204C002B001
FIX|CRM20231026016584 switch floods traffic to all ports in some cases
S7550: V705R203C002
Список изменений:
V705R203C002
V705R203C001B043
ADD|CRM20240221018870 add ERPS
Уведомляем о выходе новой версии ПО для серии S5xxx
SNR-S5210G-24TX: 1.8.3
SNR-S5210G-24TX-POE: 1.8.3
SNR-S5210G-24FX: 1.8.3
SNR-S5210G-8TX: 1.8.3
SNR-S5210X-8F: 1.8.3
SNR-S5310G-48TX: 1.8.2
SNR-S5310G-48TX-POE: 1.8.2
Список изменений:
## [1.8.3] - 2024-05-02
### Fixed
- Не поднимается линк на XE портах при использовании 1G SFP модулей без DDMI (модели SNR-S5210G-24TX(-RPS|-UPS|-DC), SNR-S5210G-8TX, SNR-S5210X-8F(-RPS|-UPS|-DC), SNR-S5210G-24FX(-RPS|-UPS|-DC))
## [1.8.2] - 2024-04-17
### Added
- IPv6 DHCP Snooping
- IPv6 SAVI (режим dhcp-only)
- Поля VLAN и COS в IP ACL
- Режим одновременного конфигурирования несколькими пользователями (multi config access)
- Функционал "ip dhcp snooping blackhole"
- Поддержка многострочного баннера
- Поддержка моделей SNR-S5310G-48TX-DC и SNR-S5310G-48TX-2AC
- SNMP:
  - Отображение статуса LoopbackDetection (.1.3.6.1.4.1.40418.7.100.3.4)
  - OID и trap для мониторинга питания модификаций -RPS и -DC
### Changed
- Увеличен blksize по умолчанию для tftp клиента
- Скрыто отображение значения по умолчанию команды mls qos queue weight
- Добавлено отображение Description порта в выводе команды 'show interface brief'
- Символ "." разрешено использовать в snmp community и именах пользователей SNMP
- Убрано добавление префикса "Contact E-Mail Address: " в SNMP OID 1.3.6.1.2.1.1.4.0
- Добавлено автоматическое удаление всех завершающих пробелов в командах 'description <description>', 'snmp-server location <location>', 'snmp-server contact <contact>'
### Fixed
- Отключение Errdisable Recovery-timer при вводе команды 'shutdown' на порту
- Некорректное отображение уровня сигнала DDMI RX/TX -40 при определенных сценариях
- Вывод команды 'show interface capabilities'
- Некорректная работа IP-ACL, MAC-ACL (пакеты могли ошибочно подпадать под правила ACL)
- Отправка DHCP пакета обратно на порт получения при включенном "ip dhcp snooping"
- Отображение ограничения максимальной мощности POE на порту в команде 'show power inline interface' для моделей SNR-S5210G-24TX-POE и SNR-S5310G-48TX-POE
- Отображение режима работы вентиляторов 'show fan' для моделей SNR-S5210G-24TX-POE и SNR-S5310G-48TX-POE
- При выходе через Ctrl+C из диалогового режима команды 'copy', копирование файлов могло заблокироваться до перезагрузки
## [1.8.1] - 2024-03-04
### Added
- SNMP:
  - Поддержка RMON-MIB
  - Поддержка ENTITY-MIB
  - OID для получения групп IGMP Snooping
  - OID для мониторинга вентиляторов
  - Trap по событиям Login/Logout/AuthenticationFailure
  - Trap с причиной перезагрузки коммутатора
### Fixed
- LLDP пакеты не отправлялись на заблокированные по STP интерфейсы
- LLDP пакеты не отправлялись на интерфейсы включенные в агрегацию Po/Sa
- Некорректные значения в SNMP LLDP-MIB::lldpLocPortId
## [1.8.0] - 2024-02-28
### Added
- Проверка лицензионного ключа при загрузке коммутатора
- Протокол обнаружения односторонних линков (ULDP)
- Функционал изоляции портов в VLAN
- Accounting команд по протоколу TACACS+
- Авторизация команд по протоколу TACACS+
- Настройка приоритета 802.1p для пакетов отправляемых с L3 интерфейсов
- Настройка приоритета 802.1p для пакетов IGMP
- Поддержка TPID 0x88A8 и 0x9100 в QinQ
- Перемаркировка VLAN в сервисных политиках
- Добавлены SNMP OID:
  - Перезагрузка коммутатора
  - Выбор загрузочного файла
  - Настройка отложенной перезагрузки
  - Копирование файлов с/на коммутатор по протоколам tftp/ftp/sftp/scp
  - Диагностика кабеля
  - Управление локальными пользователями
  - Расширенная информация с SFP/SFP+ модулей (серийный номер, производитель, модель, тип и.т.д.)
### Changed
- Изменен порядок вывода логов от новых к старым
- Добавлено поле "Remote ip-address" в пакеты Tacacs+
- Добавлено поле "NAS-Identifier" в пакеты Radius
- Увеличена максимальная длина имени пользователя до 16 символов
### Fixed
- При загрузке startup-config, некорректные команды приводили к игнорированию всех остальных команд в режиме конфигурации интерфейса
- Запрет добавления физ.портов, используемых в monitor session, в Po/Sa
- Работа SNMPv3 с алгоритмами SHA и AES
- Перезагрузка коммутатора при некорректной настройке изоляции портов
## [1.7.3] - 2024-02-29
### Fixed
- Не применяется настройка 'ip address dhcp' из конфигурации при загрузке коммутатора
### Changed
- Строка приглашения при подключении по консоли
## [1.7.1] - 2024-02-10
### Fixed
- Исправлена работа индикатора DIAG на модели SNR-S5310G-48TX
- Некорректный source-MAC в пакетах OAM Dying Gasp
- При загрузке startup-config, если в настройках интерфейса присутствует команда 'alias', не загружались все остальные настройки интерфейса
### Changed
- OID ifDescr .1.3.6.1.2.1.2.2.1.2 всегда отдает имя интерфейса, а не description
- OID IfAlias .1.3.6.1.2.1.31.1.1.1.18 отдает description интерфейса, если description сконфигурирован, иначе, пустую строку. На запись OID IfAlias конфигурирует description интерфейса
- При отсутствии настройки глобального TACACS+ ключа, серверы без настроенного локального ключа в аутентификации enable не используются.
  • 5 months later...
S2962: V702R101C009
S2965: V702R101C009
S2982G: V702R101C009
S2985G: V702R101C009
S225Gi: V702R101C009
Список изменений:
V702R101C009
ADD|recommended FW
V702R101C008B029
ADD|CRM20240506020439 add RADIUS attribute Framed-IP-address for dot1x and MAB authenticated users using the DHCP Snooping binding table
V702R101C008B027
ADD|CRM20240611021373 add command 'mac-authentication-bypass user-ip-from dhcpsnooping enable' to output IP-addresses of clients authenticated via MAB
FIX|CRM20240715022268 change RADIUS service-type attribute in default
V702R101C008B026
FIX|CRM20240515020732 change name of button for port configuration on WEB-interface
V702R101C008B025
FIX|CRM20240705022039 issue with Dynamic ARP Inspection and broadcast arp packet
V702R101C008B023
FIX|CRM20240701021903 issue with traffic drops(and traffic peaks) on graphs in monitor systems
V702R101C008B022
FIX|CRM20240617021494 issue with incorrect packet identifier in RADIUS Accounting packet
V702R101C008B020
FIX|CRM20240520020832 issue with Dynamic ARP Inspection and isolation port
ADD|CRM20240125018545 add dhcp-client function on the switch with default config
V702R101C008B019
FIX|CRM20240607021322 issue with configuration 'ip default-gateway'
V702R101C008B016
ADD|CRM20240408019880 add ability configure different RADIUS-server for MAB and 802.1x authentication
V702R101C008B015
V702R101C008B012
ADD|CRM20240422020184 add changing of Source IP-address and Source MAC-address of IGMP packets for specific ports
V702R101C008B010
ADD|CRM20240329019691 add command 'dot1x user-ip-from dhcpsnooping enable' to output IP-addresses of clients authenticated via dot1x
V702R101C008B009
ADD|CRM20231115017016 add a possibility to download files from flash-memory using HTTP via WEB-interface (section "Device admin" -> subsection "HTTP")
V702R101C008B006
ADD|CRM20240321019521 add command to disable logs of user log-in on switch
V702R101C008B004
FIX|CRM20240329019684 change priority for PoE command 'max-power-type' between global and port configuration mode
V702R101C008B003
V702R101C008B001
FIX|CRM20240123018484 incorrect port-group qty
SNR-S2990X-24FQ (HA): V706R202C007
SNR-S300X-24FQ (HA): V706R202C007
Список изменений:
V706R202C007
ADD|recommended FW
V706R202C006B012
FIX|CRM20241030024888 issue with SNMP trap "authenticationFailure" when SSH session established
V706R202C006B010
ADD|CRM20240910023617 add command 'logging event link-status include speed-duplex' to check speed and duplex in logs when port goes in UP state
V706R202C006B009
FIX|CRM20240820023126 issue with dropping service VSF packets during high CPU utilization by bursts of other packets directed to the CPU
ADD|CRM20240717022339 add support for SNMP and TACACS via MGMT-interface in VRF
V706R202C006B005
ADD|CRM20240624021739 add prompt before changing VSF/Stand-alone mode
V706R202C006B003
FIX|CRM20240805022811 switch returned DDM value via SNMP only from the first unit at VSF stack
V706R202C006
V706R202C005B021
ADD|CRM20240603021157 add supporting of DDM for AOC-cables with QSFP-modules
V706R202C005B020
V706R202C005B017
FIX|CRM20220718011279 fix issue with unable to config mepid
SNR-S5110G-24TX: 1.12.0
SNR-S5110G-24TX-POE: 1.12.0
SNR-S5110G-48TX: 1.12.0
SNR-S5110G-48TX-POE: 1.12.0
SNR-S5210G-24TX: 1.12.0
SNR-S5210G-24TX-POE: 1.12.0
SNR-S5210G-24FX: 1.12.0
SNR-S5210G-8TX: 1.12.0
SNR-S5210G-8TX-POE: 1.12.0
SNR-S5210X-8F: 1.12.0
SNR-S5310G-48TX: 1.12.0
SNR-S5310G-48TX-POE: 1.12.0
SNR-S5311G-48TX-POE: 1.12.0
Список изменений:
## [1.12.0] - 2024-11-18
### Added
- Функционал MAC-IP-ACL
- Настраиваемое время жизни записей в кеше IGMP Snooping RADIUS Authentication
- SNMP ветка .1.3.6.1.4.1.40418.7.100.13 для управления функционалом DHCP Snooping
- SNMP OID .1.3.6.1.4.1.40418.7.100.1.6.0 для сохранения конфигурации
- SNMP OID .1.3.6.1.4.1.40418.7.100.1.11.14.0 - общий размер flash в байтах
- Команда 'logging server time-format local' для установки локального времени в timestamp Syslog сообщений
- Отправка сообщений Dying Gasp на Syslog сервер при отключении питания на коммутаторе
- Поддержка модели SNR-S5210G-24FX-2AC
### Changed
- Статическое распределение TCAM с фиксированным количеством правил для каждого функционала (MAC-ACL, IP-ACL, Binding, Policy-map и.т.п.) изменено на динамическое, в зависимости от используемого функционала на коммутаторе. Общее количество доступных TCAM правил увеличено до 1792 для моделей SNR-S5110G-24TX(-POE) и всех моделей серии S5210, и до 3840 для моделей SNR-S5110G-48TX(-POE) и всех моделей серии S5310
- Изменен алгоритм шифрования RADIUS и TACACS+ ключей в конфигурации на более стойкий. При этом сохранена обратная совместимость со старым алгоритмом шифрования
- Добавлена возможность использовать '.' в имени пользователя
- Минимальный интервал отправки пакетов LBD в команде 'loopback-detection interval-time' уменьшен до 1 сек.
- В режиме igmp snooping report-suppression добавлена задержка при отправке IGMP-Report с активными подписками при получении IGMP General Query (0,1 сек на каждые 32 пакета) для уменьшения pps IGMP пакетов на вышестоящих коммутаторах
- Изменен список доступных команд в непривилегированном режиме (удалены команды: 'clear', 'debug', 'undebug', 'license', 'ntp', 'sntp', 'ztp', 'poe-led-mode', 'reset', добавлены команды: 'ping', 'traceroute', 'telnet', 'ssh')
### Fixed
- В режиме авторизации 'aaa alternate-model' пользователи с ролью network-admin после успешной аутентификации попадали в непривилегированный режим
- В шаблоне '%h' формата DHCP опции 82 и PPPoE IA длина поддерживаемого hostname увеличена до 63 символов
- Исправлена совместная работа интерфейсов PO16 и SA1
- Команда 'igmp snooping limit group' ограничивала количество подписок на порту, исходя из общего количества подписок на коммутаторе, а не количества подписок на порту
- Некорректная работа OID lldpPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.1.6.1.4) на запись
- Нажатие 'Ctrl+Z' во время процесса обновления ПО коммутатора приводило к невозможности запустить обновление ПО повторно
- Обновление ПО по SNMP не из корневой папки сервера ('/' в имени файла-источника) приводило к невозможности запустить обновление ПО повторно
- Отправка SNMP-trap при применении команд 'snmp-server ...'
- При удалении TACACS+ сервера из конфигурации коммутатор продолжал использовать его для аутентификации
- Некорректная работа таймаута при недоступности TACACS+ сервера
- DHCP Server не запускался после перезагрузки коммутатора в определенных сценариях
## [1.11.1] - 2024-10-07
### Fixed
- Не работают команды установки доверия меткам CoS и DSCP на порту ('mls qos trust cos', 'mls qos trust dscp')
- Пользовательские сессии могли не закрываться по истечению exec-timeout
## [1.11.0] - 2024-09-17
### Added
- SNMP ветка .1.3.6.1.4.1.40418.7.100.26.10 для получения статуса PoE
- SNMP ветка .1.3.6.1.4.1.40418.7.100.32 для управления Port-Security
- Возможность настройки порта syslog сервера
- Поддержка broadcast ответов от DHCP-сервера в DHCP-клиенте коммутатора
### Changed
- В статистику SNMP OID ifOutDiscards (1.3.6.1.2.1.2.2.1.19) добавлены пакеты, отброшенные по причине отсутствия ресурсов
- Максимальное количество VLAN в DHCP Snooping увеличено до 32
- В функционал storm-control добавлен burst 10% от установленного ограничения (но не более 65535 пакетов/байт, в зависимости от типа ограничения)
### Fixed
- Перезагрузка PPPoE IA при получении специфического PPPoE пакета
- Port-security не переводит порт в состояние errdisable
- При наличии символа "." в hostname, в syslog сообщениях в hostname не передавались символы после "."
- Некорректная настройка изоляции портов, при указании более 50 интерфейсов
- Ошибка при настройке bandwitdh control receive на моделях SNR-S5310G-48TX, SNR-S5310G-48TX-POE, SNR-S5110G-48TX и SNR-S5110G-48TX-POE
- Невозможность залогиниться на коммутатор, при загрузке конфигурации с отключенным логированием на flash ('no logging logfile')
- Утечка памяти при выполнении команды 'show running-config'
- DHCP Server не стартует после перезагрузки коммутатора
## [1.9.7] - 2024-09-05
### Added
- Функционал MAC-VLAN
- Поддержка шаблонов hostname и slot в self-defined форматах DHCP опции 82 и PPPoE Intermediate agent
- Поддержка одновременного назначения меток VLAN и COS в policy-map
- Режим авторизации 'aaa alternate-model' при котором после успешной авторизации enable привилегия пользователя повышается до network-admin
### Fixed
- Отправка избыточных IGMP-report в режиме report-suppression при получении отписки от мульткаст группы, если на коммутаторе остались подписчики на данную группу
## [1.9.6] - 2024-08-21
### Added
- Поддержка модели SNR-S5210G-8TX-POE
- Поддержка модели SNR-S5210G-8TX-RPS
### Fixed
- Некорректная инициализация порта xe1 на моделях SNR-S5310G-48TX. SNR-S5310G-48TX-2AC, SNR-S5310G-48TX-2DC, SNR-S5310G-48TX-DC
## [1.9.4] - 2024-07-31
### Fixed
- Перезагрузка коммутатора при определенном multicast ACL
## [1.9.3] - 2024-07-26
### Changed
- В имени пользователя разрешены символы в верхнем регистре
- Из вывода SNMP убраны служебные интерфейсы
### Fixed
- SNMP OID ifAlias при пустом Description возвращает непустое значение
- Высокая загрузка CPU при опросе DDMI на SNR-S5210G-24TX-POE
## [1.9.2] - 2024-07-15
### Added
- Поддержка модели SNR-S5310G-48TX-2DC
### Fixed
- Ограничение передачи l2-mcast пакетов при включенном IGMP Snooping
- При срабатывании 'spanning-tree bpdu-guard' порты не восстанавливались из состояния Errdisable
- Исправлено значение SNMP OID LpbackDetecShowInformation (.1.3.6.1.4.1.40418.7.100.3.4.5.1.2)
- Исправлен вывод SNMP ENTITY-MIB
### Changed
- Передача имени пользователя в Tacacs+ пакете при авторизации enable через Tacacs+
## [1.9.0] - 2024-06-26
### Added
- Команда 'ip dhcp relay share-vlan relay-unicast' для включения DHCP-Relay для unicast DHCP пакетов
- SNMP OID .1.3.6.1.4.1.40418.7.100.26.6.0 для получения суммарной потребляемой мощности PoE
- Индикация наличия startup-config диодом DIAG (частота мигания DIAG - 1 сек. при наличии startup-config, 0,1 сек. при работе с конфигурацией по умолчанию)
- Поддержка в ZTP DHCP опции 125 - назначение на int vlan1 "ip address dhcp" при неуспешном завершении ZTP
- Поддержка модели SNR-S5110G-24TX-POE
- Поддержка модели SNR-S5110G-48TX-POE
- Поддержка модели SNR-S5311G-48TX-POE
- Поддержка модели SNR-S5210G-8TX-UPS
### Changed
- Перезапуск ZTP каждые 10 минут при загрузке коммутатора без конфигурации (перезапуск ZTP отменяется при переходе в конфигурационный режим или при сохранении конфигурации)
### Fixed
- На SFP+ портах в режиме 1G в автосогласовании включается flow-control
- IPv6 SAVI | Не создаётся запись по пакетам DHCPv6 REBIND/RENEW
- Пользовательские сессии могли не очищаться при применении команды 'clear line ..'
- При включенном ARP-Inspection, ARP-пакеты коммутировались без учета изоляции портов (isolate-traffic)
- Коммутация ULDP пакетов при включенном ULDP
- Отображение параметра DDMI "link length" для модулей с дальностью > 25 км.
- В выводе команды "show transceiver" на модели SNR-S5210G-24FX, значения DDMI могли отображаться на портах без SFP модулей
- Ошибка при копировании по SNMP файлов с расширением ".conf"
- Некорректный формат SNMP trap при UP/Down портов
  • 8 months later...
Уведомляем вас о выходе новой версии ПО для серий S2962, S2965, S2982G, S2985G, S225Gi
Релизы доступны по ссылкам:
S2962: V702R101C015
S2965: V702R101C015
S2982G: V702R101C015
S2985G: V702R101C015
S225Gi: V702R101C015
Список изменений:
V702R101C015
ADD|recommended FW
V702R101C014B012
ADD|CRM20250114027245 add commands to show ARP Inspection statistic
V702R101C014B011
FIX|CRM20250228028204 issue with incorrect work of OIDs for port-isolation (branch .1.3.6.1.4.1.40418.7.100.43)
FIX|CRM20250411029502 add support of 'Disconnect-Request' messages from server to forcibly disconnect users + add command "dot1x send-muticast-request" to trigger user's auth after they was forcibly disconnected
FIX|CRM20250506030373 issue with replacing VLAN MAC with VLAN CPU in option of DHCP messages
V702R101C014B006
FIX|CRM20250205027607 some little changes with web interface iteractions
V702R101C014B004
ADD|CRM20250307028379 add SNMP OIDs to get port utilization statistic in bits per second in directions IN/OUT for 5 seconds/5 minutes in OID branch 1.3.6.1.4.1.40418.7.100.3.2.1 (priPortEntry)
V702R101C014B002
FIX|CRM20250403029176 issue with incorrect processing logic of Policy-Map in some cases
V702R101C014B001
FIX|CRM20250318028673 issue with incorrect reading of DHCP Option 66 during the ZTP process in some cases
V702R101C013B002
ADD|CRM20241216026416 add Option 18 for IPv6 on port
V702R101C013B001
ADD|CRM20240909023576 add command 'dot1x timeout offline-detect <>' for users authenticated via 'dot1x port-method userbased standard' so that users cleared from mac-address-table after timeout when, for example, link goes down on port, otherwise MAC address stays in mac-address-table
V702R101C013
ADD|recommended FW
V702R101C012B001
FIX|CRM20250306028345 issue with authentication by MAB and dot1x configured simultaneously on port in some cases
V702R101C011B015
FIX|CRM20250221028012 issue with ARP learning when using vlan-translation
V702R101C011B014
FIX|CRM20250113027186 change values of SNMP object radiusAutServerHostAccessMode (OID 1.3.6.1.4.1.40418.7.100.10.5.5.1.6), new values: Access-mode MAB - 3, Access-mode IGMP - 4
FIX|CRM20250122027472 issue with WEB login in some cases
FIX|CRM20241206026090 add command 'erps node-id priority mode (standard | private)' for changing behavior ERPS NR messages according to G.8032/Y.1344 standard
ADD|CRM20241015024461 add SCP in 'archive running-config' command
V702R101C011B008
FIX|CRM20241105024988 expand functionality of the 'default-port-config' command
V702R101C011B006
ADD|CRM20241226026773 add rule-id for ACL
V702R101C011B005
FIX|CRM20241219026531 issue with snmp community encryption in running config and community in trap messages after switch reboot
V702R101C011B002
ADD|CRM20241105024988 add command 'default-port-config' to erase port configurations (it doesn't work for any configurations on port)
V702R101C010B004
FIX|CRM20241126025791 incorrect storm-control settings via SNMP when ports are in LAG
V702R101C010B003
FIX|CRM20241028024807 add deleting of DACL from port after break of client authentication
V702R101C010B002
ADD|CRM20240125018545 add variations of ZTP operation with DHCP option 125
V702R101C010
ADD|recommended FW
V702R101C009B013
FIX|CRM20241030024874 delete captive-portal from running-config
V702R101C009B011
V702R101C009B010
ADD|CRM20240611021374 add SNMP OID for NTP configuration
V702R101C009B009
ADD|CRM20240701021888 added ability to send DHCP option 82 only at certain VLANs
V702R101C009B007
FIX|CRM20240925023970 issue with traffic graphs (spikes and gaps) in different monitor systems
V702R101C009B006
FIX|CRM20240704021997 switch uses incorrect IP-address of TFTP-server during the auto-provisioning in some cases
V702R101C009B004
ADD|CRM20240910023602 add password encryption for archive command at running config
V702R101C009B001
ADD|CRM20240827023264 add ability to change syslog message format
FIX|CRM20240715022243 issue with applying command 'ip dhcp disable' at port-range mode
SNR-S2989G-8TX(-POE): V705R002C013
SNR-S2989G-24TX(-POE): V705R002C013
SNR-S2989G-24TX(-POE)-2AC: V705R002C013
SNR-S2989G-48TX(-POE): V705R002C013
Список изменений:
V705R002C013
ADD|recommended FW
ADD|CRM20241031024902 add support for SNMP and TACACS via MGMT-interface in VRF
V705R002C012B020
ADD|CRM20241105024991 add feature to change only password for MAB authentification
V705R002C012B018
FIX|CRM20250217027854 issue with port description disappearing after rebooting in some cases
V705R002C012B017
FIX|CRM20250205027615 issue with incorrect output of SNMP Object dot1qFdbDynamicCount (OID: 1.3.6.1.2.1.17.7.1.2.1.1.2) at the first request
FIX|CRM20250214027809 issue with tIPTimer task freezing in some cases
V705R002C012B016
FIX|CRM20250122027471 switch not add option 82 to unicast DHCP packets while using DHCP relay
V705R002C012B015
FIX|CRM20250207027659 after enabling port-security sticky on port word 'sticky' disappears when enabling STP
V705R002C012B014
V705R002C012B013
FIX|CRM20250114027210 issue with vlan-isolation and igmp-packets
FIX|CRM20250113027195 rebooted by watchdog with error in task tIgmpsnoopingv3 in some cases
V705R002C012B009
FIX|CRM20241210026225 issue with SNMPv3 and msgAuthoritativeEngineBoots do not increase after reboot
V705R002C012B008
ADD|CRM20241216026417 add features for mac-address flapping prevention function
FIX|CRM20241216026388 add deleting of DACL from port after break of client authentication
V705R002C012
ADD|recommended FW
V705R002C011B052
V705R002C011B050
FIX|CRM20241202025955 issue with adding port to LAG when port-security is enabled on other ports
ADD|CRM20240919023804 add SNMP trap branch .1.3.6.1.4.1.40418.7.101.133 for monitoring VSF stack state
V705R002C011B046
V705R002C011B045
ADD|CRM20240611021375 add SNMP branch .1.3.6.1.4.1.40418.7.100.16.4.20 for OSPF neighbor information collection for all processes
V705R002C011B044
V705R002C011B041
V705R002C011B040
FIX|CRM20241018024543 issue with memory leaking in process tSnmpd
ADD|CRM20241029024860 add prompt before changing VSF/Stand-alone mode
V705R002C011B037
V705R002C011B034
FIX|CRM20240830023358 break down of L3-network after VSF split
FIX|CRM20240807022867 fail to access WEB-interface via domain name in some cases
FIX|CRM20240918023762 issue with configuring ACL via SNMP
V705R002C011B032
FIX|CRM20240830023348 issue with removing SVI which configured at 'no passive-interface vlan X'
V705R002C011B030
ADD|CRM20240918023764 add support for OIDs tree fdbMacInfo (.1.3.6.1.4.1.40418.7.100.40)
ADD|CRM20240911023619 add posibility to get information about memory via SNMP in bytes
V705R002C011B029
ADD|CRM20240712022209 MAC-address flapping prevention functionality
ADD|CRM20240730022665 full support for wildcard masks
ADD|CRM20240711022177 add ability to discard both untagged frames on trunk/hybrid port and tagged frames where VLAN tag = PVID (command 'switchport trunk|hybrid native-vlan not-forward')
FIX|CRM20240910023593 issue with forming arguments in TACACS+ packet
V705R002C011B025
ADD|CRM20240117018395 add password encryption for archive command at running config
V705R002C011B023
FIX|CRM20240722022455 issue with logging while ERPS changeover
FIX|CRM20240801022744 issue with traffic flood with using Port-channel in some cases
V705R002C011B019
FIX|CRM20240816023043 issue with DHCP snooping and unicast DHCP packet in some cases
FIX|CRM20240820023125 corrected the standard format of syslog messages
V705R002C011B017
ADD|CRM20240506020438 add ability to change syslog message format
ADD|CRM20240515020729 add command 'clear arp-cache static [vlanid <VID>]' to clear static ARP-records
V705R002C011B016
FIX|CRM20240408019880 add ability configure different RADIUS-server for MAB and 802.1x authentication
ADD|CRM20240531021127 add command 'dot1x user-ip-from dhcpsnooping enable' to output IP-addresses of clients authenticated via dot1x
V705R002C011B013
FIX|CRM20240704021993 add opportunity to check advertised/received routes via BGP at VRF
V705R002C011B012
FIX|CRM20240710022146 issue with DHCP packets are transmitted between isolated ports
V705R002C011B009
ADD|CRM20240515020732 change name of button for port configuration on WEB-interface
V705R002C011B007
ADD|CRM20240618021559 add command 'show switch default info'
V705R002C011B005
ADD|CRM20240130018638 add AES algo encryption for user passwords, OSPF, NTP, SNMP keys at running-config
ADD|CRM20240620021650 add ability to assign MGMT-interface to any VRF
V705R002C011B004
ADD|CRM20240409019902 add IP SLA (NQA) function
V705R002C011B002
ADD|CRM20240130018631 OIDs for getting BGP session state at VRF (1.3.6.1.4.1.40418.7.100.16.6.1.x)
V705R002C011B001
ADD|CRM20240520020835 added the ability to use special characters in local user passwords
SNR-S2990X-24FQ (HA): V706R202C008
SNR-S300X-24FQ (HA): V706R202C008
Список изменений:
V706R202C008
ADD|recommended FW
V706R202C007B030
FIX|CRM20250514030616 different grammatical mistakes and some other fixes in NQA (IP SLA)
V706R202C007B029
FIX|CRM20250213027781 expand functionality of the 'default-port-config' command
V706R202C007B026
FIX|CRM20241105024988 add command 'default-port-config' to erase port configurations (it doesn't work for any configurations on port)
V706R202C007B025
FIX|CRM20250310028452 issue with config lost in stack on port of SM switch after stack reload
V706R202C007B023
FIX|CRM20250306028349 issue with burst of multicast packets in the CPU in some cases of port configurations
FIX|CRM20250320028762 issue with storm-control configurations (deleting the storm-control broadcast string causes the storm-control multicast string to be deleted as well)
V706R202C007B022
ADD|CRM20241015024459 add command '[no] ip pim spt-threshold infinity' to disable PIM SPT Switchover
ADD|CRM20241111025146 add IP SLA (NQA) function
V706R202C007B021
FIX|CRM20250224028077 issue with MAC-address learning on an interface after deleting QinQ configurations in some cases
V706R202C007B019
V706R202C007B018
FIX|CRM20241211026243 issue with saving config via WEB
ADD|CRM20241223026641 add command 'passive-interface default' for OSPF
V706R202C007B004
V706R202C007B003
ADD|CRM20240821023159 add authentication for OSPFv3
Уведомляем вас о выходе новой версии ПО для модели SNR-S300G-24FX
SNR-S300G-24FX: V705R201C005
Список изменений:
V705R201C005
V705R201C004B028
ADD|CRM20240827023266 add user-control per VLAN
V705R201C004B024
V705R201C004B023
FIX|CRM20240816023050 issue with drop OSPF packets in VPLS in some cases
V705R201C004B022
V705R201C004B021
ADD|CRM20240725022551 ability to watch ip route for any IP address in VRF
V705R201C004B020
FIX|CRM20240702021950 issue with configuration L2VPN on port-channel in VSF mode
V705R201C004B019
FIX|CRM20240617021493 issue with xconnect and vlan-translation
ADD|CRM20240702021926 add config backup to a remote server during the execution of the 'write' command
V705R201C004B018
V705R201C004B017
ADD|CRM20240626021772 add command 'passive-interface default' for OSPF
V705R201C004B016
V705R201C004B014
ADD|CRM20240130018632 add LDP Label filtering (router ldp mode: 'ldp accept-lable peer...','ldp advertise-lable peer...' )
V705R201C004B013
V705R201C004B010
ADD|CRM20240222018894 add command 'show archive config differences ...' to compare configuration files
V705R201C004B008
FIX|CRM20240403019800 delete unsupported commands from CLI
V705R201C004B006
V705R201C004B003
FIX|CRM20240304019121 issue with privilege configuration
V705R201C004B002
FIX|CRM20240227019001 issue with incorrect Forwarding Address in OSPF NSSA in some cases
V705R201C004B001
FIX|CRM20240307019174 issue in which it is impossible to delete l2overgre
Релиз доступен по ссылке:
S7550: V705R203C003
Список изменений:
V705R203C003
V705R203C002B040
ADD|CRM20241128025864 add commands about fan logs: 'no fan monitor', 'fan monitor'
V705R203C002B039
V705R203C002B038
FIX|CRM20241126025794 issue with loop in EVPN Multihoming-connection
V705R203C002B037
FIX|CRM20250109027108 issue with switch rebooting in the specific case of using SPAN
V705R203C002B036
ADD|CRM20241217026437 add adaptation of MC-LAG and IGMP Snooping for work together
V705R203C002B031
FIX|CRM20241021024585 issue with short-term loop during the MC-LAG establishing
V705R203C002B025
ADD|CRM20240907023555 add support for SNMP, TACACS, Telnet/SSH and info-center via MGMT-interface in VRF
V705R203C002B024
V705R203C002B020
ADD|CRM20240711022165 issue with incorrect DDM information for optical interfaces in some cases
V705R203C002B019
FIX|CRM20240906023531 traffic balance when traffic flows from global to VRF
FIX|CRM20240906023525 issue with short-time loop when one of the MC-LAG partners reboots
V705R203C002B016
FIX|CRM20240829023337 traffic flood in MC-LAG
V705R203C002B015
FIX|CRM20240731022700 issue with mac-learning after dismantle port-group with loopback-detection configured on port
V705R203C002B014
FIX|CRM20240710022137 issue with traffic losses with MC-LAG
V705R203C002B011
V705R203C002B009
V705R203C002B005
V705R203C002B004
FIX|CRM20240424020264 advertised BGP IPv6 routes disappear after some time
V705R203C002B003
FIX|CRM20240403019809 add outputting of prompt for unsupported command
Уведомляем вас о выходе новых версий ПО для моделей SNR-S4350X и SNR-S400X
SNR-S400X-24FC-2AC: V707R301C011
SNR-S4350X: V707R301C011
Список изменений:
V707R301C011
ADD|recommended FW
FIX|CRM20250506030373 issue with replacing VLAN MAC with CPU MAC in option of DHCP messages
V707R301C010
FIX|CRM20250521030818 switch stuck by LED SHUTOFF task afterwards 8-12 weeks since startup
V707R301C009B002
FIX|CRM20250507030410 issue with drop packets with ttl=1 when mc-lag is configured
V707R301C009
FIX|CRM20250304028293 issue with incorrect TCAM utilization
V707R301C007
FIX|CRM20250123027499 recommended FW
FIX|CRM20241204026044 issue with fanspeed periodically changing with no reason
FIX|CRM20241121025476 incorrect working of the command 'switchport mode trunk allow-null'
ADD|CRM20230418014019 add IP SLA (NQA) function
ADD|CRM20240704021993 add opportunity to check advertised/received routes via BGP at VRF
FIX|CRM20240515020729 add command 'clear arp-cache static [vlanid <VID>]' to clear static ARP-records
FIX|CRM20240515020730 issue with routing packet which should be encapsulated in a multicast Ethernet frame according to static-multicast ARP-record (required command: 'no arp check')
FIX|CRM20240702021940 issue with accidental reboot after configuration router bgp in some cases
SNR-S5110G-24TX: 1.16.0
SNR-S5110G-24TX-POE: 1.16.0
SNR-S5110G-48TX: 1.16.0
SNR-S5110G-48TX-POE: 1.16.0
SNR-S5210G-24TX: 1.16.0
SNR-S5210G-24TX-POE: 1.16.0
SNR-S5210G-24FX: 1.16.0
SNR-S5210G-8TX: 1.16.0
SNR-S5210G-8TX-POE: 1.16.0
SNR-S5210X-8F: 1.16.0
SNR-S5310G-48TX: 1.16.0
SNR-S5310G-48TX-POE: 1.16.0
SNR-S5311G-48TX-POE: 1.16.0
Список изменений:
## [1.16.0] - 2025-06-23
### Added
- Функционал 802.1X MAC-based
- Вставка опции 18 в DHCPv6 пакеты
- Логирование и отправка SNMP trap с информацией о пакетах, заблокированных функционалом DHCP Snooping Binding user-control или AM
- Команда для включения DHCP Snooping во всех VLAN (команда 'ip dhcp snooping vlan all')
- SNMP OID для управления изоляцией портов (.1.3.6.1.4.1.40418.7.100.100)
- Настройка формата PPPoE IA на портах
- Настройка формата MAC-адреса, передаваемого на RADIUS сервер при аутентификации MAB
- Добавлены атрибуты Called-Station-ID и Calling-Station-ID в RADIUS запрос при аутентификации MAB
- Возможность добавления VLAN 1 в ненулевой MST Instance
- Возможность указать Port-channel в качестве monitor session destination interface
- Установка VLAN + CoS в policy-map (команда 'add s-vid <vid> [cos <0-7>]')
- Команда для отбрасывания тегированных пакетов на порту ('switchport discard packet tag')
- Поддержка priority-tagged пакетов (VLAN 0) в QinQ
- Поддержка модели SNR-S5210G-24TX-2AC
### Changed
- Шифрование SNMP-community и паролей SNMP-user в конфигурации коммутатора
- При авторизации и аккаунтинге вводимых команд через TACACS+ введенные сокращенные команды дополняются до полных
- Минимальное значение ERPS WTR-timer уменьшено с 3 до 1 минуты
- Скорректирован вывод семейства команд 'show spanning-tree'
- Уменьшена загрузка CPU при опросе SNMP веток switchinfo, iftable, ifXtable на моделях SNR-S5310, SNR-S5311, SNR-S5110G-48TX(-POE)
- Удален символ '#' из вывода команды 'show interface brief'
### Fixed
- Атрибут SNR-User-Priv игнорировался, если он не был первым атрибутом в ответе RADIUS сервера
- В определенных сценариях после удаления RADIUS сервера на него продолжали отправляться запросы авторизации
- Не удалялась команда 'ip dhcp snooping binding user-control' с интерфейса, если на нем есть запись AM
- ERPS: исправлена некорректная очистка MAC-адресов при получении R-APS (SF) пакетов в состоянии Protection
- При удалении Multicast VLAN на портах, где он был ассоциирован, удалялся пользовательский VLAN
- Флап линка при первом включении LLDP на порту
- Номера OID в ветке poePortConfigEntry (.1.3.6.1.4.1.40418.7.100.26.10.1) приведены в соответствие с MIB
## [1.15.4] - 2025-06-10
### Fixed
- Использование Policy-map c пустым class-map или class-map со стандартным ACL, содержащим правило 'permit any', приводит к искажению существующего правила в ячейке №0 TCAM, что может привести к некорректной работе функционала ACL, DHCP Snooping binding user-control, SAVI и самого Policy-map с данным class-map.
## [1.15.2] - 2025-05-05
### Added
- Остановка процесса ZTP при выполнении команд 'copy', 'reload', 'delete', 'write', 'cp', 'mv'
- Добавлена поддержка ECDSA-ключей в SSH-сервер
### Changed
- Удалена команда 'ssh key dsa'
- Внесены правки в алгоритм обработки ARP-пакетов на основе RFC 826
- Изменен алгоритм DHCP Snooping binding в некоторых сценариях
- Увеличено время ожидания ответа от DHCP-сервера на запрос DHCP-клиента до 30 секунд для DHCP Snooping binding
- Символ "@" разрешено использовать в SNMP community и именах пользователей SNMP
- Добавлен запрет использования символа '#' в начале паролей auth-pass и priv-pass в команде создания пользователя SNMP
- Отключен аппаратно не поддерживаемый вывод DropPkts в команде 'show cpu-rx-ratelimit protocol' для моделей серий SNR-S5110G-48TX(-POE), SNR-S5310G-48TX(-POE), SNR-S5311G-48TX-POE
### Fixed
- Некорректная передача по SNMP информации о содержимом таблицы MAC-адресов
- Перезагрузка коммутатора при выполнении команды 'resequence access-list'
- Ошибка при выполнении команды 'no storm-control' в режиме конфигурации интерфейса на моделях серий SNR-S5110G-48TX(-POE), SNR-S5310G-48TX(-POE), SNR-S5311G-48TX-POE
- Авторизация паролей FTP с символами  '=', '*', '"', '$', '^', ':', '#'
- В команде 'no access-list (<100-199>|<2000-2699>)' параметр eq <0-65535> сделан необязательным
- Неверный вывод Control Mode в OID lpbackDetecShowInformation
- Перезагрузка коммутатора при использовании в команде 'username <name> sshkey file <filename>' значений <name> более 10 символов
- Некорректное STP-состояние порта в некоторых сценариях
- Неверное отображение маски IP-адресов в IPv4 ACL и Multicast ACL в конфигурации
- Не удаляется команда 'switchport protocol-vlan' на интерфейсе при переключении интерфейса в режим private-vlan
- Не работает ограничение на редактирование именованного ACL, если ACL применён к порту
- Дублирование информации DDM с GE на XE порты в некоторых сценариях на модели коммутатора SNR-S5210G-24FX
- Не удаляется по таймауту запись-candidate таблицы DHCP Snooping binding в некоторых сценариях
- Не удаляется запись-candidate таблицы DHCP Snooping binding при создании соответствующей записи-binding
- Не выполняется команда 'ip dhcp snooping binding user-control' в некоторых сценариях
## [1.15.0] - 2025-03-17
### Added
- Выбор резервной прошивки для моделей серий SNR-S5210 и SNR-S531x (требуется обновление bootrom до версии 1.10)
- Формат DHCP опции 82 'vs-cisco'
- SNMP OID для настройки и применения на порт IP-ACL, MAC-ACL, MAC-IP ACL (.1.3.6.1.4.1.40418.7.100.10.1)
- SNMP OID для настройки и применения на порт Multicast ACL (.1.3.6.1.4.1.40418.7.100.20)
- SNMP OID для включения LBD на порту (.1.3.6.1.4.1.40418.7.100.3.4.21)
- SNMP OID для настройки LBD interval (.1.3.6.1.4.1.40418.7.100.3.4.2)
- SNMP OID для настройки режима работы LBD (.1.3.6.1.4.1.40418.7.100.3.4.3)
- SNMP OID для настройки таймера восстановления порта в режиме LBD block (.1.3.6.1.4.1.40418.7.100.3.4.20.0)
- SNMP OID для включения/отключения таймера Errdisable-Recovery (.1.3.6.1.4.1.40418.7.100.3.30.0)
- SNMP OID для настройки значения таймера Errdisable-Recovery  (.1.3.6.1.4.1.40418.7.100.3.31.0)
- Поддержка модели SNR-S5310G-48TX-RPS
### Changed
- Максимальное количество одновременных RADIUS сессий для IGMP RADIUS Authentication увеличено до 128
- Уровень логирования по умолчанию на flash изменен с 2 (Critical) на 4 (Warning)
### Fixed
- Работа ветки SNMP storm-control .1.3.6.1.4.1.40418.7.100.3.3
- Авторизация паролей enable с символами ',' и '$' через RADIUS
- Не коммутируется трафик в isolated vlan между host и promiscuous портами
- Не удаляется multicast-vlan при смене режима порта с access на trunk по SNMP
- Блокировка пакетов PTP (IEEE1588) на портах с включенным 'spanning-tree disable'
- Блокировка пакетов из CPU (ARP, DHCP и.т.п.) на порты с включенной изоляцией в VLAN
- Перестроение дерева STP при получении повторных STP BPDU c флагом Proposal
## [1.14.0] - 2025-02-11
### Added
- Функционал Private Vlan
- Функционал SSH pre-shared key
- Команда для добавления статических записей в DHCP Snooping binding
- Поддержка скорости 2,5G на 10G SFP+ портах для моделей серии SNR-S5210 и SNR-S5110G-24TX(-POE)
- Настройка выделенного Radius сервера для IGMP RADIUS Authentication
- Возможность добавления второго тега VLAN в Policy-map (команда 'add s-vid')
- Автоопределение скорости SFP+ портов на основании значения DDMI link-length SFP+/SFP модуля
- Возможность изменения скорости консольного порта на 9600 для моделей серий SNR-S5210 и SNR-S531x
- Передача hostname в шаблоне %h DHCP Option-82, DHCPv6 Option 37/38, PPPoE IA в режиме HEX
- SNMP OID .1.3.6.1.2.1.4.22 (ipNetToMediaTable) для просмотра ARP-таблицы
- SNMP OID .1.3.6.1.4.1.40418.7.100.3.15 для очистки статистики портов
- SNMP OID .1.3.6.1.4.1.40418.7.100.1.11.25 - свободные ресурсы CPU за 1 минуту
- SNMP OID .1.3.6.1.4.1.40418.7.100.1.11.15 - объем занятой Flash в байтах
- Поддержка модели SNR-S5311G-48TX-R
- Поддержка модели SNR-S5310G-48TX-UPS
- Поддержка модели SNR-S5210G-8TX-DC
### Changed
- Максимальное количество Vlan с ARP inspection увеличено до 32
- В команду 'clear ip dhcp snooping binding' добавлена возможность очистки по IP, MAC, VLAN и порту
- В команду 'show spanning-tree brief' добавлено отображение Internal Root Path Cost
- Обновлён SSH сервер, отключены  цифровые подписи на базе RSA-ключей с хэшем SHA-1 ("ssh-rsa")
### Fixed
- Зависание коммутатора при большом количестве DHCP-пакетов (>50 pps) с включенным DHCP Relay share-vlan
- Зависание IGMP Snooping при обработке IGMP пакетов с некорректной опцией заголовка IPv4
- Некорректная работа TACACS+ ключей, содержащих символы "#" или "$"
- Из поля "remote address" пакетов TACACS+ удален номер порта
- Некорректное имя пользователя в пакетах RADIUS Accounting-Request
- Закрытие сессии пользователя при вводе пароля enable c пробелами
- Не удаляется порт из Port-Channel/Static-Aggregation-Channel при настроенном на порту storm-control
- Дропы в Iperf3 на скорости > 4Мбит/с
- Изменение метки CoS у транзитных пакетов
- Некорректное отображение статистики пакетов на физических портах после очистки статистики на Port-Channel/Static-Aggregation-Channel интерфейсах
- Команды terminal length и terminal width отменяли настройки друг друга
- Тегированные STP BPDU обрабатывались протоколом STP
- Возможность удаления всех Vlan с порта через SNMP OID: portTrunkAllowedvlan (.1.3.6.1.4.1.40418.7.100.3.2.1.20), portHybridTaggedAllowedvlan (.1.3.6.1.4.1.40418.7.100.3.2.1.21), portHybridUntaggedAllowedvlan (.1.3.6.1.4.1.40418.7.40418.3.2.1.22)
## [1.13.0] - 2024-12-16
### Added
- Функционал IPv6-ACL
- Функционал ERPS
- Функционал IPv6 VACL
- Функционал LBD per VLAN
- SNMP OID .1.3.6.1.4.1.40418.7.100.3.2.1.7 для просмотра статуса Bandwidth Control
- SNMP OID .1.3.6.1.4.1.40418.7.100.3.2.1.8 для просмотра максимальной пропускной способности
- SNMP OID .1.3.6.1.4.1.40418.7.100.3.2.1.9 для управления значением входящей пропускной способности
- SNMP OID .1.3.6.1.4.1.40418.7.100.3.2.1.10 для управления значением исходящей пропускной способности
- SNMP ветка .1.3.6.1.4.1.40418.7.100.3.3 для управления функционалом Storm Control
- SNMP ветка .1.3.6.1.4.1.40418.7.100.3.20 для управления действиями при срабатывании Storm Control
- SNMP ветка .1.3.6.1.4.1.40418.7.100.33 для управления MAC-notification
- Option 43, option 60 в функционал DHCP Server
- Логирование событий Spanning-Tree: состояния портов
### Changed
- Отменено минимальное ограничение имени пользователя в команде 'snmp-server user <username>'
- Размер лог файлов в RAM и FLASH ограничен в 400 Kbytes
- Изменен приоритет ACL, примененных на интерфейс. Приоритет приведен к виду:
       IPv6 ACL
       MAC-IP-ACL
       IP-ACL
       MAC-ACL
  (сверху вниз от наиболее приоритетного)
### Fixed
- Перезагрузка коммутатора при выполнении команды 'show logging logfile' в некоторых сценариях
- Не работает сочетание клавиш CTRL+Z для выхода в привилегированный режим
- Некорректный формат некоторых приватных snmp-traps
- Некорректное отображение в конфигурации состояния SSH-сервера
- Некорректное отображение правил MAC-IP-ACL, IP-ACL с зарезервированными номерами протоколов
- Некорректная работа MAC-IP-ACL при установке правила без указания протокола L4
- Зависание коммутатора при выполненной на интерфейсе команде 'ethernet-oam'
- Утечка памяти на прошивке 1.12.0, если включен функционал snmp-trap или функционал логирование на syslog-сервер
- Не создаются mstp instance на прошивке 1.12.0 при использовании команды end при выходе из режима 'spanning-tree mstp configuration'
- Не создаются mstp instance на прошивке 1.12.0 при загрузке коммутатора при некоторых конфигурациях
- Включается mstp на прошивке 1.12.0 при входе в режим 'spanning-tree mstp configuration'
  • 2 months later...
S2962: V702R101C018
S2965: V702R101C018
S2982G: V702R101C018
S2985G: V702R101C018
S225Gi: V702R101C018
Список изменений:
V702R101C018
ADD|recommended FW
V702R101C015B016
ADD|CRM20250307028380 add ability to configure several hosts under one DHCP Server pool
V702R101C015B008
ADD|CRM20250410029443 add OIDs 1.3.6.1.4.1.40418.7.100.1.(108-110) for switch reloading by timer
V702R101C015B007
FIX|CRM20250609031436 issue with incorrect removal of DACL after client authentication ended
FIX|CRM20250625031935 issue with RADIUS resource exhaustion in some cases
V702R101C015B005
FIX|CRM20250523030921 issue with SNMP does not set "ip dhcp snooping trust" on port with specific OID '.1.3.6.1.4.1.40418.7.100.13.3.17.1.4' when specific commands are enabled in some cases
V702R101C015B004
FIX|CRM20250423030017 add a troubleshooting command for R&D
Уведомляем вас о выходе новых версий ПО для серий S2989G/S2995G/S3850G
SNR-S2989G-8TX(-POE): V705R002C017
SNR-S2989G-24TX(-POE): V705R002C017
SNR-S2989G-24TX(-POE)-2AC: V705R002C017
SNR-S2989G-48TX(-POE): V705R002C017
SNR-S2995G: V705R002C017
SNR-S3850G: V705R002C017
Список изменений:
V705R002C017
ADD|recommended FW
V705R002C016B001
FIX|CRM20250821034051 issue with OID .1.3.6.1.4.1.40418.7.100.3.2.1.12 "shutdown port" if used SNMPv3
V705R002C015B031
ADD|CRM20250825034182 add ability to collect data via SNMP for counters in 'sh cpu-rx protocol all' with OID .1.3.6.1.4.1.40418.7.100.1.29
V705R002C015B021
FIX|CRM20250704032237 issue with broadcast traffic not forwarding in other VLANs when 'ip dhcp snooping binding user-control' was configured on a port in a specific VLAN
V705R002C015B020
FIX|CRM20250722032884 issue with MAB authentication after upgrade from C009 to C013 due to incorrect port type in RADIUS request
V705R002C015B017
ADD|CRM20250519030736 add option to use variables in path and filename in 'archive running-config ip x.x.x.x file wildcard'
V705R002C015B016
V705R002C015B012
FIX|CRM20250618031749 issue with STP process hanging in some cases
V705R002C015B011
V705R002C015B005
FIX|CRM20250619031759 memory leaking in stack when using DAI and port-security + memory leaking when adding dynamic MAC on SM
V705R002C015B001
FIX|CRM20250328028992 dot1x authentication with MacBook was not working in some cases
V705R002C014B034
FIX|CRM20250603031226 issue with burst of multicast packets in the CPU in some cases of port configurations
V705R002C014B033
ADD|CRM20250307028377 add command 'switchport port-security static mode cisco' to set Port-security Cisco-like static mode (If there is no link on a port, the switch stops protecting MAC addresses on that port)
V705R002C014B025
FIX|CRM20250425030093 issue with radius auth "AAA fail to get sockopt SO_VRF error.(radius_vrf_apply)" in stack
V705R002C014B021
ADD|CRM20250214027824 disable LLDP by default
V705R002C014B020
FIX|CRM20250425030094 issue with LLDP MED: switches in stack send several LLDP MED packets (each from himself) to one port
V705R002C014B018
FIX|CRM20250213027781 add command 'default-port-config' to erase port configurations (it doesn't work for any configurations on port)
V705R002C014B015
FIX|CRM20250416029695 issue with ethernet-oam not working
V705R002C014B013
V705R002C014B010
V705R002C014B009
FIX|CRM20250320028759 issue with incorrect SNMP OID output in ERPS for port Signal-Status "Failed"
V705R002C014B008
FIX|CRM20250311028489 issue with some users did not get DHCP address when using DHCP Relay and supervlan with subvlans
V705R002C014B007
ADD|CRM20240902023404 add ability to configure port-security function at the WEB-interface
V705R002C014B004
FIX|CRM20250305028329 issue with arp inspection in stack with devices connected to SM
V705R002C013B002
ADD|CRM20250214027824 enable LLDP by default
Уведомляем вас о важном изменении в новых версиях ПО для моделей SNR-S4350X
- изменилась нумерация версий ПО с формата V707R301CxxxBxxx на формат V707R401CxxxBxxx. Счётчики xxx в частях CxxxBxxx в новой нумерации начались с нуля;
Все файлы ПО для SNR-S4350X: All
Уведомляем вас о важном изменении в новых версиях ПО для моделей SNR-S400X
изменилась нумерация версий ПО с формата V707R301CxxxBxxx на формат V707R302CxxxBxxx. Счётчики xxx в частях CxxxBxxx в новой нумерации начались с нуля;
Все файлы ПО для SNR-S400X: All
Уведомляем о выходе первой актуальной стабильной версии ПО для новой серии S5010
Все файлы ПО для SNR-S5010: All
Уведомляем о выходе новой версии ПО для серии S5xxx (S5110, S5210, S5310)
SNR-S5110G-24TX: 1.17.0
SNR-S5110G-24TX-POE: 1.17.0
SNR-S5110G-48TX: 1.17.0
SNR-S5110G-48TX-POE: 1.17.0
SNR-S5210G-24TX: 1.17.0
SNR-S5210G-24TX-POE: 1.17.0
SNR-S5210G-24FX: 1.17.0
SNR-S5210G-8TX: 1.17.0
SNR-S5210G-8TX-POE: 1.17.0
SNR-S5210X-8F: 1.17.0
SNR-S5310G-48TX: 1.17.0
SNR-S5310G-48TX-POE: 1.17.0
SNR-S5311G-48TX-POE: 1.17.0
Список изменений:
## [1.17.0] - 2025-09-15
### Added
- DHCP Snooping Binding user-control в VLAN
- Gratuitous ARP
- User-defined ACL
- Шаблоны vendor и model в команде 'ip dhcp client vendor-identifier'
- Поддержка SHA-256 в шифровании паролей пользователей SNMPv3
- Логирование функционала 'spanning-tree guard root'
- SNMP OID на получение VLAN MAC коммутатора (1.3.6.1.4.1.40418.7.100.1.105.0)
- В SNMP OID sysName (1.3.6.1.2.1.1.5.0) добавлена возможность записи
- Поддержка модели SNR-S5310X-8TX
- Поддержка модели SNR-S5310G-48TX hardware version 2.x
### Changed
- Настройки SNMP выделены в отдельный режим конфигурации SNMP (сохранена совместимость с предыдущей конфигурацией)
- Одновременная перемаркировка и приоритезация трафика по полям DSCP и COS в Policy-map
- Оптимизирована работа автосогласования на SFP+ портах для совместимости с 1G SFP трансиверами сторонних вендоров
- Отключено хранение ключей (known hosts) в SSH клиенте
- Оптимизирован опрос параметров PoE в CLI и SNMP на моделях SNR-S5110G-24TX-POE и SNR-S5110G-48TX-POE
- SNMP Engine-ID приведен к виду 8000DF7603 + CPU MAC коммутатора
### Fixed
- Перезагрузка при записи пустой строки в некоторые SNMP OID
- Совместимость 802.1x c сервером Windows NPS
- Неверное расположение настроек ACL относительно class-map в конфигурации, что приводило к некорректному применению startup-config
- Скорректировано поведение DHCP Snooping Binding для записей с одинаковыми MAC и IP
- При применении команды 'no hostname' удалялся lldp system-name
- Скорректирована работа команды 'spanning-tree guard root' (состояние root-inconsistent на портах в DOWN, таймер восстановления)
- Обновление ARP записи при смене MAC
- Исправлено значение SNMP OID ifSpeed (1.3.6.1.2.1.2.2.1.5) на 0 для SFP+ портов в состоянии DOWN
- Из счетчика input error на интерфейсе исключены pause frame
- Исправлено отображение команды 'snmp-server host <host> {informs version 3 | traps version 3 | version 3 } priv' в конфигурации
- Невозможность использования спецсимволов '~ }{ & > < % ! + , ' в команде 'copy ..' в username и password
  • 3 months later...
S2962: V702R101C019
S2965: V702R101C019
S2982G: V702R101C019
S2985G: V702R101C019
S225Gi: V702R101C019
Список изменений:
V702R101C020B015
ADD|CRM20250901034510 add logging of STP topology change events (TCN/TC) in command "logging event spanning-tree topology-change"
V702R101C020B014
V702R101C020B013
FIX|CRM20250423030017 add the hidden command 'monitor network-operating-system enable' to force a reboot of the switch if the system hangs + optimization of the configuration saving mechanism
V702R101C020B012
ADD|CRM20251010035991 add support for Protocol-based VLAN configuration in port mode (port mode has higher priority than global)
V702R101C020B011
ADD|CRM20250702032172 add support for Dynamic VLAN via MAB without explicit VLAN configuration on ports
V702R101C020B010
ADD|CRM20250519030732 optimize WEB interface operation in some cases
FIX|CRM20251202038295 issue with STP behavior on MAB-configured ports
V702R101C020B008
ADD|CRM20251126038067 add new OIDs for flood-control in branch .priPortEntry (1.3.6.1.4.1.40418.7.100.3.2.1)
V702R101C020B004
FIX|CRM20251128038180 remove unsupported counters from interface statistic
V702R101C019
ADD|recommended FW
V702R101C018B021
ADD|CRM20250708032313 add ability to change timer in command 'dot1x send-muticast-request interval'
FIX|CRM20251028036723 issue with the private branch priMrppRing (.1.3.6.1.4.1.40418.7.100.38)
V702R101C018B020
ADD|CRM20251106037152 add "clear" and "clear all" commands to clear the screen and clear the screen with the scrollback buffer
ADD|CRM20250704032222 add output of some settings for port-channel interface at config
V702R101C018B018
FIX|CRM20251107037174 increased SSH send buffer to prevent session drops and errors when displaying large outputs
V702R101C018B016
ADD|CRM20250506030344 add SNMP OIDs to get port utilization statistic in percent per second of the negotiated speed in directions IN/OUT for 5 seconds/5 minutes in OID branch 1.3.6.1.4.1.40418.7.100.3.2.1 (priPortEntry)
V702R101C018B015
ADD|CRM20250702032177 add support for configuring the SSH port on the switch
V702R101C018B008
ADD|CRM20250815033843 add new SSH algorithms (hmac-sha2-256, hmac-sha2-256-etm@openssh.com, ssh-ed25519) and add support for configuring SSH MAC algorithms
Список изменений:
V705R002C017B042
FIX|CRM20260118040586 issue with error in task tphyDaemon in some cases
V705R002C017B040
FIX|CRM20260112040281 fix SSH connection timeout caused by short client version wait
V705R002C017B039
ADD|CRM20251126038066 add custom display option for DDM transceiver output in commands "show transceiver interface ethernet <port> detail custom", "show transceiver detail custom"
V705R002C017B037
FIX|CRM20251201038283 issue with reflector port blocking by STP in RSPAN scenario
V705R002C017B036
FIX|CRM20251231039765 add automatic reboot action on NQA ping failure in command "nqa entry <id> alarm reboot"
V705R002C017B034
ADD|CRM20250815033839 add remarks for named ACL
V705R002C017B031
V705R002C017B030
ADD|CRM20251114037495 add AES128-ctr and AES256-ctr algos for SSH-client
V705R002C017B028
ADD|CRM20251126038074 add support for 'reload after-sys-failure time' in VSF
V705R002C017B027
FIX|CRM20251114037489 several DHCP-client fixes for some cases
V705R002C017B025
ADD|CRM20250804033413 add command 'alias exec <Alias> <Command>' with the ability to create up to 256 aliases for commands
FIX|CRM20250930035840 issue with MAB-client authentication if it receives a VLAN via LLDP-MED (additionally, it's need to configure in global configuration mode: 'mac-authentication-bypass multiple-vlan enable')
V705R002C017B023
FIX|CRM20251021036430 issue with error in tasks checkTask and tftpCopyFile in some cases
V705R002C017B020
ADD|CRM20250722032886 add support for configuring SVI subnet masks via prefix notation
V705R002C017B018
ADD|CRM20250702032177 add support for configuring OSPF network descriptions
V705R002C017B016
FIX|CRM20250930035839 automatically send a BGP Route-refresh when the associated Route-map changes
V705R002C017B015
FIX|CRM20251009035963 issue with extra zero bytes in the OID dot1qVlanStaticName (Q-BRIDGE-MIB)
Уведомляем вас о выходе новых версий ПО для моделей SNR-S2990X-24FQ и SNR-S300X-24FQ
Список изменений:
V706R202C008B025
ADD|CRM20251030036827 issue with output for specific OID .1.3.6.1.4.1.40418.7.100.1.29.1.1.5.X.X for 'cpu-rx protocol all'. Now it is renew every 1 min (was every 30 min)
V706R202C008B023
FIX|CRM20251124037922 issue with switch freezing when entering the "show tcam usage" command in some cases
V706R202C008B022
V706R202C008B021
V706R202C008B020
FIX|CRM20251107037173 issue with OSPF authentication (which leads to OSPF failure) in case of failure of the VSF Active Master
V706R202C008B017
ADD|CRM20250722032887 add QoS configuration branch ("mls qos ...") in Port-channel configuration mode
V706R202C008B014
V706R202C008B013
Список изменений:
V705R201C005B029
V705R201C005B028
Уведомляем вас о выходе новой версии ПО для модели SNR-S4650X-48FQ
SNR-S4650X-48FQ: V705R204C004
Список изменений:
V705R204C004B001
FIX|CRM20251127038136 issue with switch hang during startup in some LDP targeted-peer cases
V705R204C004
ADD|ADD new stable FW version
V705R204C003B064
V705R204C003B063
V705R204C003B062
FIX|CRM20250819033971 issue with incorrect logic of Enhanced Load-balancing in some cases
V705R204C003B060
ADD|CRM20250520030787 improve adaptation of work with NLB
V705R204C003B059
FIX|CRM20250530031133 issue with configuration of port negotiation
V705R204C003B058
FIX|CRM20250609031420 issue with manual BGP Router ID configuration in some cases
V705R204C003B057
ADD|CRM20250312028509 adding ability to input several 'ip-addr-range' for subvlan under one supervlan
V705R204C003B056
FIX|CRM20250522030882 issue with incorrect meaning of MPLS error message
V705R204C003B055
FIX|CRM20250226028156 add command 'neighbor <Neighbor IP> fake-as <Fake-AS>' (works like «local-as» with keywords «no-prepend» and «replace-as»)
V705R204C003B054
FIX|CRM20250423030014 issue with incorrect OSPF routes metric in NSSA
V705R204C003B053
V705R204C003B051
FIX|CRM20250327028911 issue with stack hangs in some cases
FIX|CRM20250314028579 issue with DHCP Relay on supervlan in some cases
V705R204C003B050
ADD|CRM20250114027224 add support for static ARP record (with multicast MAC-address) operation in global configuration mode with static multicast MAC-address records for multiple ports
V705R204C003B046
FIX|CRM20250311028480 cosmetic incorrect(revers) output of ip address range of supervlan in 'sh int vl <supervlan id>'
V705R204C003B045
ADD|CRM20241030024867 route leaking from global to VRF by using PBR and balancing traffic inside VRF after traffic was leaked from global to VRF(if there is two or more routes in VRF)
V705R204C003B043
FIX|CRM20250303028262 issue with unavailability stack by task "tWebCfg"
V705R204C003B040
V705R204C003B038
FIX|CRM20250117027334 issue with incorrect work of ‘switchport mode trunk allow-null’ command on StandBy Master
V705R204C003B033
V705R204C003B031
FIX|CRM20240925023980 delete incorrect non-working commands from CLI
FIX|CRM20241105024980 issue with memory leak with MSTP process in some cases
V705R204C003B029
FIX|CRM20241029024831 issue with hang of SNMP in some cases
V705R204C003B028
V705R204C003B027
FIX|CRM20240907023555 add support for SNMP, TACACS, Telnet/SSH and info-center via MGMT-interface in VRF
V705R204C003B026
FIX|CRM20241031024913 issue with using command "local-arp trust ip ..."
V705R204C003B025
ADD|CRM20240725022553 add support for DHCP Server function in VRF
V705R204C003B022
ADD|CRM20240920023845 add supporting for DDM on AOC-cables with Quad Small Form-Factor
V705R204C003B021
ADD|CRM20240515020730 issue with routing packet which should be encapsulated in a multicast Ethernet frame according to static-multicast ARP-record (required command: 'no arp check')
ADD|CRM20240531021110 add 'tcp-connection filter' in LDP configuration
V705R204C003B017
FIX|CRM20210929007504 issue with LDP targeted-hello-accept filter
V705R204C003B015
FIX|CRM20240607021322 issue with configuration ip default-gateway
V705R204C003B014
FIX|CRM20240520020833 corrected erratas in some commands at CLI
V705R204C003B013
FIX|CRM20240507020449 add command 'passive-interface default' for OSPF
V705R204C003B012
FIX|CRM20240426020320 switch didn't drop packet with TTL 0 while using PBR
V705R204C003B005
FIX|CRM20240305019144 issue with task zOSPF in some cases
V705R204C003B004
ADD|CRM20231222017885 add output of some settings for port-channel interface at config
V705R204C003B003
Уведомляем о выходе новой версии ПО для серии S7550
S7550: V705R203C003
Список изменений:
V705R203C003B010
V705R203C003B009
V705R203C003B006
FIX|CRM20251017036313 issue with resetting MTU settings to default in VSF in some cases
Уведомляем о выходе новой версии ПО для серии SNR-S4350X
SNR-S4350X: V707R401C004
Список изменений:
V707R401C004
ADD|recommended FW
V707R401C003B020
FIX|CRM20251226039592 issue with incorrect temperature values in some cases
V707R401C003B019
FIX|CRM20251128038171 add command 'mls qos burst-mode (dynamic | standard)' to select the buffer allocation mechanism
V707R401C003B016
ADD|CRM20251112037374 add tcpdump function from CPU (command branch in enable mode: 'capture ...')
V707R401C003B012
FIX|CRM20251211038786 issue with starting OSPFv3 neighborship when a large number of routes are transmitted
V707R401C003B010
FIX|CRM20251125038017 add the 'hardware tunnel-capacity <0-2048>' command to expand the number of routes as FEC
V707R401C003B009
V707R401C003B008
FIX|CRM20251105037087 issue with switch rebooting by error in task "zL2_shell" in some cases (one more case)
FIX|CRM20250901034524 add WRR algorithm for QoS
Уведомляем о выходе новой версии ПО для серии SNR-S400X
SNR-S400X: V707R302C001
Список изменений:
V707R302C001B008
FIX|CRM20251216038996 fix MLAG ARP sync ordering with RSTP to prevent connectivity issues
V707R302C001B007
FIX|CRM20251208038616 issue with switch crash in some cases due to excessive CPU packet logging caused by driver counter overflow
V707R302C001B004
ADD|CRM20251030036807 add support VRF for DAD link in MCLAG
V707R302C001B003
V707R302C001B002
V707R302C001
ADD|recommended FW
SNR-S5110G-24TX: 1.18.0
SNR-S5110G-24TX-POE: 1.18.0
SNR-S5110G-48TX: 1.18.0
SNR-S5110G-48TX-POE: 1.18.0
SNR-S5210G-24TX: 1.18.0
SNR-S5210G-24TX-POE: 1.18.0
SNR-S5210G-24FX: 1.18.0
SNR-S5210G-8TX: 1.18.0
SNR-S5210G-8TX-POE: 1.18.0
SNR-S5210X-8F: 1.18.0
SNR-S5310G-48TX: 1.18.0
SNR-S5310G-48TX-POE: 1.18.0
SNR-S5310X-8TX: 1.18.0
SNR-S5311G-48TX-POE: 1.18.0
Список изменений:
## [1.18.0] - 2025-12-05
### Added
- SNMP: Добавлена ветка для управления функционалом ERPS erpsMgt (.1.3.6.1.4.1.40418.7.100.39)
- Добавлено шифрование паролей FTP, SFTP и SCP в команде 'archive running-config' при выводе конфигурации
- Логирование событий функционала 'ip dhcp snooping action blackhole'
- На оптических портах добавлен механизм Port-flap Errdisable, для исключения зависания ПО при большом количестве link-flap. Errdisable срабатывает при смене состояния порта более 10 раз в течение 5 секунд. Таймаут восстановления порта - 30 сек.
- Поддержка модели SNR-S5210G-24TX-R
### Changed
- Команда 'ip dhcp snooping binding user-control' разрешена на trunk и hybrid портах
- Добавлен фильтр кириллицы в логине и пароле и отображение количества введенных символов в пароле
- Добавлена обработка IGMP пакетов с IP-адресом назначения 224.0.0.0/23 функционалом multicast destination control
- Оптимизирована работа SNMP ветки POE на моделях SNR-S5110G-24TX-POE и SNR-S5110G-48TX-POE
- OpenSSH обновлен до версии 10.2p1. Дополнительно разрешены алгоритмы KEX: diffie-hellman-group1-sha1, diffie-hellman-group14-sha1, diffie-hellman-group-exchange-sha1, ciphers: aes128-cbc, aes192-cbc, aes256-cbc,3des-cbc, MAC: hmac-sha1, hmac-md5, hmac-sha1-96, hmac-md5-96, host и public ключи ssh-rsa
### Fixed
- Некорректное отображение статистики пакетов ACL
- Постоянная отправка SNMP Trap Dying Gasp при использовании нестандартного SNMP порта
- При включенном PPPoE Intermediate Agent PADR пакеты, полученные на trust порт, копировались обратно в этот же порт
- MSTP: некорректное отображение Designated Bridge в команде 'show spanning-tree mst instance'
- MSTP: неверный Bridge ID в пересылаемых BPDU
- RSTP: исправлена работа алгоритма Proposal-Agreement
- Ложное срабатывание storm-control при ограничении <= 10 pps на моделях SNR-S5110G-24TX(-POE), SNR-S5210
- SNMP: OID ifAdminStatus некорректно выключал интерфейс
- SNMP: OID shutdown (.1.3.6.1.4.1.40418.7.100.3.2.1.12) не восстанавливал интерфейс из состояния Errdisable
- SNMP: скорректировано значение OID ifSpeed для портов 10GbE
  • 2 months later...
S2962: V702R101C019
S2965: V702R101C019
Список изменений:
V702R101C022B005
FIX|CRM20260414043985 issue with error in MAC-IP ACL configuration in some cases
FIX|CRM20260410043829 issue with high CPU utilization after SSL certificate insertion
V702R101C022B003
ADD|CRM20260212041735 add SNMP trap branch .1.3.6.1.4.1.40418.7.101.138 for signaling CIST Root and MSTI Root changes in RSTP/MSTP
V702R101C022B002
ADD|CRM20260121040722 add remarks for named ACL
V702R101C022B001
ADD|CRM20260205041406 add command 'alias exec <Alias> <Command>' with the ability to create up to 256 aliases for commands
V702R101C020B028
ADD|CRM20260205041404 add new OIDs in branch .priSyslogMgt to manage syslog servers (.1.3.6.1.4.1.40418.7.100.44)
FIX|CRM20260316042621 issue with DHCP-Relay ignoring unicast flag in share-vlan mode
FIX|CRM20250908034752 expand functionality of the 'default-port-config' command
FIX|CRM20260211041685 issue with floating package length of TFTP
V702R101C020B021
FIX|CRM20260210041615 add missing punctuation marks to the interface information output
FIX|CRM20260204041357 fix SSH connection timeout caused by short client version wait
V702R101C020B020
FIX|CRM20260209041553 issue with switch crash after some case of DHCP pool configuration
V702R101C020B019
FIX|CRM20260126040877 issue with DHCP relay ignoring unicast flag in DHCP packets
ADD|CRM20250815033844 add command "snmp-server traps send-delay <seconds> module spanning-tree" to prevent SNMP trap loss during STP convergence
V702R101C020B018
FIX|CRM20260127040912 issue with delayed output of the 'show running-config' command
V702R101C020B017
ADD|CRM20251013036099 add ability to discard both untagged frames on trunk/hybrid port and tagged frames where VLAN tag = PVID (command 'switchport trunk|hybrid native-vlan not-forward')
SNR-S2989G-8TX(-POE): V705R002C020
SNR-S2989G-24TX(-POE): V705R002C020
SNR-S2989G-24TX(-POE)-2AC: V705R002C020
SNR-S2989G-48TX(-POE): V705R002C020
SNR-S2995G: V705R002C020
SNR-S3850G: V705R002C020
Список изменений:
V705R002C021B004
FIX|CRM20260319042805 add command 'bgp log-neighbor-changes' (BGP configuration mode) to enable logging of changes between BGP states
V705R002C021B003
FIX|CRM20260407043642 issue with switch rebooting after configuration of SNMP View in come cases
V705R002C021B002
FIX|CRM20260226041940 issue with suddenly reboot in VSF stack with task tSshdTask
FIX|CRM20260211041687 issue with incorrect formation of UDP Payload when transferring files via the TFTP
V705R002C020
ADD|recommended FW
ADD|VRF, RIP, OSPF, BGP, PIM (Для SNR-S2989)
FIX|CRM20260319042843 issue with truncated SSH output when executing commands with large output in non-interactive mode
FIX|CRM20260312042462 issue with memory leaking in some cases (when disabling/enabling HTTP and when encrypting during login)
FIX|CRM20260323042953 issue with incorrect operation of DHCP Relay when connecting DHCP clients via Port-Channel
V705R002C017B048
FIX|CRM20260204041330 issue with error in task tNACTask in some cases
FIX|CRM20260126040878 issue with DHCP relay ignoring unicast flag in DHCP packets
V705R002C017B046
V705R002C017B045
FIX|CRM20260210041603 issue with error in task zIMI in some cases
V705R002C017B044
FIX|CRM20260210041627 issue with not being able to change the OSPF network description
V705R002C017B043
FIX|CRM20260209041564 issue with the possibility of unauthorized access to the Linux shell when you are physically connected to a switch.
FIX|CRM20251013036099 add ability to discard both untagged frames on trunk/hybrid port and tagged frames where VLAN tag = PVID (command 'switchport trunk|hybrid native-vlan not-forward')
SNR-S2990X-24FQ (HA): V706R202C009
SNR-S300X-24FQ (HA): V706R202C009
Список изменений:
V706R202C009B004
V706R202C009B002
V706R202C009B001
V706R202C009
ADD|recommended FW
V706R202C008B033
ADD|CRM20250908034751 add logs for the ERPS process
FIX|CRM20260227041978 issue with incorrect generation of the PIM-Register on the Rendezvous-Point device
V706R202C008B031
ADD|CRM20250822034083 add ZTP feature
FIX|CRM20260204041356 fix SSH connection timeout caused by short client version wait
V706R202C008B029
ADD|CRM20260121040718 add new OIDs for flood-control in branch .priPortEntry (1.3.6.1.4.1.40418.7.100.3.2.1)
FIX|CRM20251030036827 add ability to collect data via SNMP for counters in 'sh cpu-rx protocol all' with OID .1.3.6.1.4.1.40418.7.100.1.29
Список изменений:
V705R201C007B004
V705R201C007B001
V705R201C005B040
V705R201C005B037
FIX|CRM20260228042007 issue with the ip helper-address disappearing on the SVI when changing the VRF in this SVI
V705R201C005B035
V705R201C005B033
ADD|CRM20251211038810 add commands 'show vpls port', 'show vpls port vfi <1-4294967295>' for VFI membership lookup on interfaces
V705R201C005B031
FIX|CRM20251210038725 problem with OID vplsMacCntQuery
V705R201C005B030
ADD|CRM20251027036683 increase the number of PIM VLAN to 200
Список изменений:
V705R204C004B015
FIX|CRM20260409043779 issue with no error output when xSPAN configuration cannot be accepted due to out of resources
V705R204C004B014
FIX|CRM20260407043609 issue with overloading the ILM table in the LDP process
V705R204C004B012
ADD|CRM20251224039469 add command 'show tcam usage' to show TCAM utilization
FIX|CRM20260305042242 issue with the inability to receive data about fans via SNMP
V705R204C004B009
FIX|CRM20260210041635 issue with PBR after the switch is rebooted
V705R204C004B008
FIX|CRM20260129041091 issue with error in task tLacp in some cases
V705R204C004B007
ADD|CRM20260128041022 add LDP Label filtering (router ldp mode: 'ldp accept-lable peer...','ldp advertise-lable peer...'
V705R204C004B006
V705R204C004B004
FIX|CRM20251211038792 issue with load balancing in some cases
S7550: V705R203C003
Список изменений:
V705R203C003B026
V705R203C003B024
V705R203C003B023
ADD|CRM20260106039951 add command "info-center format rfc5424" to change syslog message format to RFC 5424 standard
V705R203C003B022
ADD|CRM20251208038590 add SNMP OID (1.3.6.1.4.1.6339.100.1.8.1.27) to get FW-version of each VSF member
V705R203C003B018
FIX|CRM20260209041585 issue with error in task tSyncFlushFdb in some cases
V705R203C003B015
V705R203C003B014
ADD|CRM20251203038376 add support for MGMT-interface as BFD MAD Link for VSF
V705R203C003B012
ADD|CRM20250519030731 add support for static link aggregation for MC-LAG
Список изменений:
V707R401C006B004
V707R401C006B003
FIX|CRM20260320042860 issue with statistics of interface NVE
FIX|CRM20260414043998 issue with EVPN/VxLAN tunnels in case of a few tunnel interfaces
V707R401C006B001
V707R401C004B013
ADD|CRM20250721032841 add support for 2,5G speed on SFP+ ports ('force2500m-full')
ADD|CRM20251010035990 add command "info-center format rfc5424" to change syslog message format to RFC 5424 standard
V707R401C004B011
V707R401C004B010
V707R401C004B008
FIX|CRM20260213041757 issue with tUsrRoot task in some cases of Fan-out port mode configuration
V707R401C004B004
FIX|CRM20260122040782 issue with switch hanging in some cases when a large number of VLANs are created
V707R401C004B003
Список изменений:
V707R302C003B006
FIX|CRM20260401043452 issue with VLAN configuration on ports being lost after VSF switchover
FIX|CRM20260410043831 issue with DDM for QSFP28 port taken from wrong port (1/0/1 instead of 1/1/1) after VSF mode change
FIX|CRM20260415044013 issue with initializing QSFP28 link not used for VSF in VSF mode
V707R302C003B004
V707R302C001B018
ADD|CRM20260316042647 remove limitation of file extension for configuration of DHCP option Bootfile
V707R302C001B016
FIX|CRM20260319042804 add command 'bgp log-neighbor-changes' (BGP configuration mode) to enable logging of changes between BGP states
V707R302C001B014
FIX|CRM20260306042269 issue with the possibility of unauthorized access to the Linux shell when you are physically connected to a switch
V707R302C001B012
V707R302C001B010
FIX|CRM20260211041697 issue with memory leak in some cases
FIX|CRM20260130041145 issue with duplicated SNMP counter values for ifHCOutOctets (1.3.6.1.2.1.31.1.1.1.6) on VLAN interfaces
Уведомляем о выходе новой версии ПО для серии S5010
SNR-S5010G: 1.2.0
Список изменений:
## [1.2.0] - 2026-04-28
### Added
- Поддержка IPv6 на SVI
- Настройка выделенного RADIUS-сервера для MAB: 'radius-server host <ip> access-mode mab'
- Возможность применения IPv4 ACL на VLAN
- Команда 'ip dhcp snooping action shutdown'
- Режим Port-Security sticky
- Опциональное отключение сообщения "Last login .." при логине ('set cli hello-prompt {on | off}')
- Остановка процесса ZTP при применении настроек в WEB
- SNMP OID для настройки flood control на портах (.1.3.6.1.4.1.40418.7.100.3.2.1.43, .1.3.6.1.4.1.40418.7.100.3.2.1.44, .1.3.6.1.4.1.40418.7.100.3.2.1.45)
- SNMP OID для получения таблицы IP DHCP Snooping Binding (.1.3.6.1.4.1.40418.7.100.13.3.20)
### Changed
- Максимальное количество локальных пользователей увеличено до 32
- Оптимизирован размер файла прошивки
### Fixed
- Некорректная работа SNMP OID по сохранению конфигурации (sysWriteConfig)
- ERPS: Некорректное значение бита DNF в R-APS пакетах при выполнении команды 'clear command' в ERPS Instance
- Значение last topology change в команде 'show erps status'
- Некорректное отображение количества MAC-адресов при превышении 16194 изученных
- При настройке SNMP-сервера с нестандартным портом постоянно отправлялся Dying Gasp SNMP Trap
- При добавлении порта в режиме Hybrid в PO/SA удаляется VLAN 1 из списка разрешенных untag VLAN
- Лишние пробелы в running и startup конфигах
- В режиме 'no igmp snooping report-suppression' при получении IGMP Leave без опции Router-Alert в следующем IGMP Query пакете могли устанавливаться некорректные SRC_IP и DST_IP
- При настройке IPv4, IPv6 или MAC ACL правила, отличающиеся только по VLAN или по DST Port, ошибочно интерпретировались как дублирующие (% This object already exist)
- Некорректная работа функционала 'archive running-config'
- В MAB не авторизовывались пакеты, если SMAC изучен на другом порту коммутатора
- SNMP: В OID dot1qVlanCurrentUntaggedPorts (1.3.6.1.2.1.17.7.1.4.2.1.5) и dot1qVlanCurrentEgressPorts (1.3.6.1.2.1.17.7.1.4.2.1.4) не отдавались Static-Channel интерфейсы
## [1.1.0] - 2026-03-09
### Added
- WEB-интерфейс (HTTPS). Включен по умолчанию, для отключения (при необходимости) примените команду 'no ip http secure-server'
- VLAN-translation
- Voice/MAC/Protocol VLAN
- MAB
- Dot1X
- Функционал 'ip dhcp snooping blocked record'
- Функционал MAC-notification
- Команда 'port-security violation errdisable/restrict'
- SNMP: добавлена ветка для управления функционалом ERPS erpsMgt (.1.3.6.1.4.1.40418.7.100.39)
- На оптических портах добавлен механизм Port-flap Errdisable для исключения зависания ПО при большом количестве link-flap. Errdisable срабатывает при смене состояния порта более 10 раз в течение 5 секунд. Таймаут восстановления порта - 30 сек.
### Changed
- Добавлена обработка IGMP пакетов с IP-адресом назначения 224.0.0.0/23 функционалом Multicast Destination Control
### Fixed
- Некорректная обработка IGMP Query
- Некорректная работа 'ip dhcp snooping binding user-control vlan'
- При добавлении hybrid порта в PO/SA удалялся VLAN 1 из списка разрешенных untag vlan
- Утечка памяти при выполнении команды 'show running-config'
- Зависание коммутатора при вызове команды 'show ip dhcp binding' в определенных сценариях
- Некорректное время в выводе команды 'show ip dhcp snooping blocked'
- Некорректные индексы агрегированных портов в OID dot1qTpFdbPort (.1.3.6.1.2.1.17.7.1.2.2.1.2)
- Ошибка 'OID not increasing' при одновременном опросе OID dot1qTpFdbPort (.1.3.6.1.2.1.17.7.1.2.2.1.2) и dot1dTpFdbAddress (.1.3.6.1.2.1.17.4.3.1.1)
SNR-S5110G-24TX: 1.20.1
SNR-S5110G-24TX-POE: 1.20.1
SNR-S5110G-48TX: 1.20.1
SNR-S5110G-48TX-POE: 1.20.1
SNR-S5210G-24TX: 1.20.1
SNR-S5210G-24TX-POE: 1.20.1
SNR-S5210G-24FX: 1.20.1
SNR-S5210G-8TX: 1.20.1
SNR-S5210G-8TX-POE: 1.20.1
SNR-S5210X-8F: 1.20.1
SNR-S5310G-48TX: 1.20.1
SNR-S5310G-48TX-POE: 1.20.1
SNR-S5310X-8TX: 1.20.1
SNR-S5311G-48TX-POE: 1.20.1
Список изменений:
## [1.20.1] - 2026-04-13
### Fixed
- Некорректный адрес хоста в сообщении "Last login .." при логине
- SNMP: OID sysWriteConfig (.1.3.6.1.4.1.40418.7.100.1.6.0) не сохраняет startup.conf
- Некорректная работа TACACS+ в связке с SSH и TELNET при аутентификации на коммутаторе
## [1.20.0] - 2026-03-23
### Added
- Поддержка IPv6-маршрутизации
- Команда для блокировки unknown multicast-трафика на адреса 239.0.0.0/8 при включенном IGMP Snooping на моделях SNR-S5210, SNR-S5110G-24TX(-POE)
- SNMP OID для настройки flood control на портах (.1.3.6.1.4.1.40418.7.100.3.2.1.43, .1.3.6.1.4.1.40418.7.100.3.2.1.44, .1.3.6.1.4.1.40418.7.100.3.2.1.45 )
### Changed
- В команде iperf3 диапазон значений TOS расширен с <0-7> до <0-255>
### Fixed
- Названия источников питания для моделей SNR-S5310X-8TX-DC и SNR-S5310X-8TX-UPS
- Исправлен hostname по умолчанию для модели SNR-S5310G-48TX hw rev 2
- Negotiation на Fiber Combo-портах отключалось в режиме force1g-full
- Некорректная работа User-Defined ACL на моделях SNR-S531x, SNR-S5110G-48TX(-POE) (в ACL попадали пакеты с портов ge33-48 и xe, независимо от порта на который установлен ACL)
- Отображение статуса вентиляторов SNR-S5210G-24FX в WEB
- Исправлена работа функционала 'archive running-config'
- Решены проблемы совместимости конфигурации SNMP при обновлении с версий ниже 1.17.0
## [1.19.0] - 2026-02-16
### Added
- Поддержка моделей SNR-S5310X-8TX-2AC, SNR-S5310X-8TX-UPS, SNR-S5310X-8TX-RPS, SNR-S5310X-8TX-DC
### Changed
- Игнорирование административного включения/отключения портов в Port-flap Errdisable
- Отключена опция TCP-forwarding на SSH сервере
### Fixed
- Некорректные индексы агрегированных портов в OID dot1qTpFdbPort (1.3.6.1.2.1.17.7.1.2.2.1.2 )
This topic is now closed to further replies.
