  • 3 months later...
  • Replies 115
  • Created
  • Last Reply
Top Posters In This Topic
Уведомляем вас о выходе новой версии ПО для серий SNR-S2965, SNR-S2985G, SNR-S2962, SNR-S2982G.
Релизы доступны по ссылкам:
SNR-S2965 7.0.3.5(R0241.0389)
SNR-S2985G 7.0.3.5(R0241.0389)
SNR-S2962 7.0.3.5(R0241.0389)
SNR-S2982G 7.0.3.5(R0241.0389)
Список изменений:
7.0.3.5(R0241.0389)
FIX|CRM20201106003151 wrong packet type for op.37 and op.38
7.0.3.5(R0241.0388)
FIX|CRM20201202003432 issue with 'reload'
7.0.3.5(R0241.0387)
FIX|CRM20201130003406 issue with OID erpsNodeState
7.0.3.5(R0241.0386)
FIX|CRM20201118003285 NIC_INTR_THREAD/tDMLL1Tx issue
7.0.3.5(R0241.0384)
FIX|RM20201106003158 issue with tIgmpsnoopingv3
7.0.3.5(R0241.0379)
FIX|CRM20200910002346 problem with SP algorithm
7.0.3.5(R0241.0378)
FIX|CRM20200908002307 add IPv6 snooping vlan
7.0.3.5(R0241.0376)
FIX|CRM20201026002931 issue with the interface counter 'Time since last status change'
7.0.3.5(R0241.0375)
FIX|CRM20201015002787 dhcpSnoopingVlanEnable OID problem
7.0.3.5(R0241.0374)
FIX|CRM20201009002656 incorrect description of interface-id option
7.0.3.5(R0241.0372)
FIX|CRM20200929002620 wrong format of TACACS+ accounting messages
Уведомляем о выходе новой версии ПО для серий S2995G и S3850G.
S2995G 7.5.3.2(R0004.0310)
S3850G 7.5.3.2(R0004.0310)
Список изменений:
7.5.3.2(R0004.0310)
FIX|CRM20210119004006 issue with 'rejected by security IP'
7.5.3.2(R0004.0304)
FIX|CRM20201231003797 issue with 'ip dhcp snooping suppress'
7.5.3.2(R0004.0299)
FIX|CRM20201118003291 problem with high SFP temperature
7.5.3.2(R0004.0298)
FIX|CRM20201201003411 issue with IP DHCP snooping binding with unicast ACK and DHCP Relay
7.5.3.2(R0004.0295)
FIX|CRM20201116003256 incorrect description of interface-id option
FIX|CRM20201015002789 MT722 send SNMP trap when switch reloaded
FIX|CRM20201015002790 MT722 Management of local users via SNMP
FIX|CRM20201015002792 MT722 send Dying GASP to syslog
FIX|CRM20201015002794 MT722 enable/disable WEB interface via SNMP
7.5.3.2(R0004.0294)
FIX|CRM20201106003163 tL2Input task hang up
FIX|CRM20201015002788 MT722 TCN-guard (TCN-Restriction)
7.5.3.2(R0004.0292)
FIX|CRM20201029003027 In WEB interface (POE models) wrong symbols was display
7.5.3.2(R0004.0291)
FIX|CRM20201014002746 together use with MAB and DCHP Snooping issue
7.5.3.2(R0004.0290)
FIX|CRM20201022002899 loopback port with LED issue
7.5.3.2(R0004.0287)
FIX|20201014002744 wrong format of TACACS+ accounting messages
7.5.3.2(R0004.0286)
FIX|20200910002346 problem with SP algorithm
7.5.3.2(R0004.0285)
FIX|CRM20201009002666 wrong output 'sh fan'
FIX|CRM20200930002629 reboot when archive
Уведомляем вас о выходе новой версии ПО для коммутатора SNR-S2990X-24FQ.
Релиз доступен по ссылке:
S2990X 7.5.3.2(R0010.0088)
Список изменений:
7.5.3.2(R0010.0088)
FIX|CRM20210125004112 issue with 'ip default-gateway'
7.5.3.2(R0010.0087)
FIX|CRM20200111003872 wrong temperature and broken DDM issue
7.5.3.2(R0010.0084)
FIX|CRM20201222003713 issue with Selective QinQ
7.5.3.2(R0010.0082)
7.5.3.2(R0010.0081)
FIX|CRM20201116003255 issue with 'rejected by security IP'
FIX|CRM20201113003235 radius auth failed
Уведомляем вас о выходе новой версии ПО для коммутатора SNR-S300X-24FQ.
S300X 7.5.3.2(R0010.0088)
Список изменений:
7.5.3.2(R0010.0088)
7.5.3.2(R0010.0087)
7.5.3.2(R0010.0084)
7.5.3.2(R0010.0083)
FIX|CRM20201214003574 issue with BUM-traffic balancing
7.5.3.2(R0010.0082)
7.5.3.2(R0010.0081)
Уведомляем о выходе новой версии ПО для коммутатора SNR-S300G-24FX.
S300G 7.0.3.5(R0010.0253)
Список изменений:
7.5.3.0(R0010.0253)
FIX|CRM20201119003300 string 'radius nas-ipv4 ...' dissapears after reboot
7.5.3.0(R0010.0252)
Уведомляем вас о выходе новой версии ПО для коммутатора SNR-S2989G-24FX.
S2989G 7.5.3.2(R0028.0040)
Список изменений:
7.5.3.2(R0028.0040)
FIX|CRM20210113003911 TCAM issue
7.5.3.2(R0028.0033)
FIX|CRM 20201211003549 issue with port-security and dhcp-snooping
7.5.3.2(R0028.0032)
FIX|CRM20201207003470 issue with write
7.5.3.2(R0028.0031)
FIX|CRM20201201003412 TCAM issue
7.5.3.2(R0028.0030)
FIX|CRM20201119003299 problem with DHCP Relay
7.5.3.2(R0028.0029)
FIX|CRM20201015002792 MT722 enable/disable WEB-interface via SNMP
7.5.3.2(R0028.0028)
ADD|CRM20201014002776 add auto provisioning
7.5.3.2(R0028.0027)
FIX|CRMCRM20201015002784 TCAM is not released after removing the configuration
7.5.3.2(R0028.0026)
FIX|CRM20200908002317 HTTPS login has been misprinted
Уведомляем вас о выходе новой версии ПО для серии SNR-S2990G.
S2990G 7.0.3.5(R0102.00312)
Список изменений:
7.0.3.5(R0102.0312)
FIX|CRM20201214003577 Issue with full data queue
7.0.3.5(R0102.0311)
FIX|CRM20201118003283 Problem with 49-50 ports
7.0.3.5(R0102.0309)
FIX|CRM20201111003217 Problem with learning MAC address of the gateway in a specific VLAN
7.0.3.5(R0102.0308)
FIX|CRM20201029003028 issue with task tHwMonitor
7.0.3.5(R0102.0307)
FIX|CRM20200825002130 iftype of port-channel issue
7.0.3.5(R0102.0306)
ADD|CRM20200726001678 console task connect error -105
7.0.3.5(R0102.0305)
ADD|CRM20200601000864 Loopback Detection messages format/level changed
  • 1 month later...
Список изменений:
7.0.3.5(R0241.0397)
FIX|CRM20210203004184 issue with password-encryption
7.0.3.5(R0241.0396)
FIX|CRM20210113003903 SNMP equivalent of the "authentication line {}" command
FIX|CRM20201015002793 storm-control, speed-duplex and mls commands with port-channel
7.0.3.5(R0241.0395)
FIX|CRM20210127004141 tAAAMainTask suspending
7.0.3.5(R0241.0394)
FIX|CRM20210127004144 hidden set SN
S2995G 7.5.3.2(R0004.0318)
S3850G 7.5.3.2(R0004.0318)
Список изменений:
7.5.3.2(R0004.0318)
FIX|CRM20210302004701 issue with 'interface-id'
7.5.3.2(R0004.0317)
FIX|CRM20210302004698 issue with 'debug ip dhcp relay packet'
7.5.3.2(R0004.0316)
FIX|CRM20210208004220 options 37, 38 in the wrong place into DHCPv6-RELAY-FORWARD message
7.5.3.2(R0004.0315)
FIX|CRM20210208004219 issue with OID erpsNodeState
7.5.3.2(R0004.0314)
FIX|CRM20210128004145 snmpwalk error
7.5.3.2(R0004.0313)
FIX|CRM20210202004179 issue with service-policy and LACP
7.5.3.2(R0004.0312)
FIX|CRM20210127004140 wrong packet type for op.37 and op.38
S2990X 7.5.3.2(R0010.0090)
Список изменений:
7.5.3.2(R0010.0090)
FIX|CRM20210219004229 issue with tLldp suspending
7.5.3.2(R0010.0089)
FIX|CRM20210115003948 PIM cause memory leaking
S300X 7.5.3.2(R0010.0090)
Список изменений:
7.5.3.2(R0010.0090)
7.5.3.2(R0010.0089)
S2989G 7.5.3.2(R0028.0043)
Список изменений:
7.5.3.2(R0028.0043)
FIX|CRM20210208004218 dhcp-client's error print
FIX|CRM20210219004230 double DHCP offer and ack
7.5.3.2(R0028.0042)
  • 1 month later...
SNR-S2965 7.0.3.5(R0241.0427)
SNR-S2985G 7.0.3.5(R0241.0427)
SNR-S2962 7.0.3.5(R0241.0427)
SNR-S2982G 7.0.3.5(R0241.0427)
Список изменений:
7.0.3.5(R0241.0427)
FIX|CRM20210312004871 issue with SAVI
7.0.3.5(R0241.0424)
FIX|CRM20210420005493 issue with MLD query
7.0.3.5(R0241.0422)
FIX|CRM20210318004984 'clear counters','clear counters interface...' SNMP OIDs
7.0.3.5(R0241.0421)
FIX|CRM20210420005487 issue with 'ip dhcp-client 'print
7.0.3.5(R0241.0415)
FIX|CRM20210416005453 issue with 'lacp timeout short'
7.0.3.5(R0241.0409)
FIX|CRM20210407005273 issue with ip igmp snooping limit group
7.0.3.5(R0241.0407)
FIX|CRM20210316004927 Merge link flap protect
7.0.3.5(R0241.0405)
FIX|CRM20210319005000 EFMOAM must be supported on the physical port even if it is in the LAG
FIX|CRM20210319004998 snmpwalk error
7.0.3.5(R0241.0403)
FIX|CRM20201119003297 BPDU-tunnel user-defined protocol requirements
7.0.3.5(R0241.0402)
FIX|CRM20210303004719 issue with pings more than 29592 bytes
7.0.3.5(R0241.0399)
FIX|CRM20210225004597 BPDU tunnel supports one tunnel to multiple protocols
S2995G 7.5.3.2(R0004.0336)
S3850G 7.5.3.2(R0004.0336)
Список изменений:
7.5.3.2(R0004.0336)
FIX|CRM20210326005148 'clear counters','clear counters interface...' SNMP OIDs
7.5.3.2(R0004.0334)
FIX|CRM20210414005400 dhcp-reply broadcasting via dhcp-relay
7.5.3.2(R0004.0332)
FIX|CRM20210407005274 issue with multiple BFD sessions in different router OSPF
7.5.3.2(R0004.0328)
FIX|CRM20210326005146 port based protocol VLAN
7.5.3.2(R0004.0325)
FIX|CRM20210309004820 issue with BGP
7.5.3.2(R0004.0323)
FIX|CRM20201119003297 BPDU tunnel user defined protocol requirements
7.5.3.2(R0004.0322)
FIX|CRM20210225004614 802.1p for IGMP message
7.5.3.2(R0004.0321)
FIX|CRM20210315004917 issue with flood in syslog
7.5.3.2(R0004.0319)
FIX|CRM20210304004744 double DHCP offer and ack
 Уведомляем вас о выходе новой версии ПО для коммутаторов SNR-S2990X-24FQ и SNR-S300X-24FQ
S2990X 7.5.3.2(R0010.0101)
S300X 7.5.3.2(R0010.0102)
Список изменений:
7.5.3.2(R0010.0102)
FIX|CRM2021042005494 doesn't display 'ip ospf cost 10' in running-config
7.5.3.2(R0010.0101)
FIX|CRM20210409005333 issue with 'bpdu-tunnel multi-protocol group'
7.5.3.2(R0010.0100)
FIX|CRM20210318004987 BPDU-tunnel user-defined protocol
7.5.3.2(R0010.0098)
FIX|CRM20210311004867 issue with SRC_MAC load-balance
7.5.3.2(R0010.0096)
FIX|CRM20210225004631 TCN-guard (TCN-Restriction)
S2989G 7.5.3.2(R0028.0054)
Список изменений:
7.5.3.2(R0028.0054)
FIX|CRM20210422005515 issue with flood in syslog
7.5.3.2(R0028.0053)
FIX|CRM20210324005094 'igmp snooping vlan X' blocks ICMPv6 traffic
7.5.3.2(R0028.0050)
FIX|CRM20210331005196 add'sh bandwidth control'
7.5.3.2(R0028.0048)
FIX|CRM20210316004927 link-flap protect
7.5.3.2(R0028.0047)
FIX|CRM20210316004934 setup'switchport port-security maximum X' BEFORE enabling port security
7.5.3.2(R0028.0046)
FIX|CRM20210208004218 Port-based configuration protocol vlan
7.5.3.2(R0028.0045)
FIX|CRM20210219004231 EFMOAM must be supported on the physical port even if it is in the LAG
S300G 7.0.3.5(R0010.0257)
Список изменений:
7.5.3.0(R0010.0257)
7.5.3.0(R0010.0256)
FIX|CRM20210225004625 issue with OID erpsNodeState
  • 2 months later...
S300G_7.5.3.0(R0010.0263)
Список изменений:
7.5.3.0(R0010.0263)
FIX|CRM20210609006077 issue with L2VPN Operation failed
7.5.3.0(R0010.0262)
FIX|CRM20210611006105 vlan-flow-statistics via SNMP
7.5.3.0(R0010.0259)
FIX|CRM20200703001271 DHCPv6 relay agent notification for PD
Уведомляем о выходе новой версии ПО для коммутатора SNR-S2989G-24FX.
S2989G_7.5.3.2(R0028.0057)
Список изменений:
7.5.3.2(R0028.0057)
FIX|CRM20210527005940 using isolate-port group with DAI issue
7.5.3.2(R0028.0056)
FIX|CRM20210511005785 flow control pause issue
7.5.3.2(R0028.0055)
FIX|CRM20210506005730 bpdu-tunnel multi-protocol
Уведомляем вас о выходе новой версии ПО для коммутаторов SNR-S2990X-24FQ и SNR-S300X-24FQ.
S2990X 7.5.3.2(R0010.0109)
S300X 7.5.3.2(R0010.0106)
Список изменений:
7.5.3.2(R0010.0109)
FIX|CRM20210507005746 add command 'match vlan range multi' in class-map
7.5.3.2(R0010.0108)
FIX|CRM20210517005835 issue with ARP loss
7.5.3.2(R0010.0107)
FIX|CRM20210517005837 show vlan issue
7.5.3.2(R0010.0106)
FIX|CRM20210414005415 add capture feature
7.5.3.2(R0010.0105)
FIX|CRM20210427005592 archive running-config
7.5.3.2(R0010.0103)
FIX|CRM2021042005494 BPDU tunnel user defined protocol add show statistical requirements
S2995G 7.5.3.2(R0004.0350)
S3850G 7.5.3.2(R0004.0350)
Список изменений:
7.5.3.2(R0004.0350)
FIX|CRM20210517005839 issue with DHCP Relay
7.5.3.2(R0004.0346)
FIX|CRM20210603006013 issue with vlan-flow-statistics via SNMP
7.5.3.2(R0004.0343)
FIX|CRM20210428005616 DHCPv6 Relay Agent Notification for Prefix Delegation
7.5.3.2(R0004.0341)
FIX|CRM20210524005886 Issue with logging actions via web-interface
7.5.3.2(R0004.0340)
FIX|CRM20210423005531 VSF member console lock
FIX|CRM20210517005836 issue with LLDP link aggregation status
7.5.3.2(R0004.0338)
FIX|CRM20210511005785 flow control issue
SNR-S2965 7.0.3.5(R0241.0445)
SNR-S2985G 7.0.3.5(R0241.0445)
SNR-S2962 7.0.3.5(R0241.0445)
SNR-S2982G 7.0.3.5(R0241.0445)
Список изменений:
7.0.3.5(R0241.0445)
FIX|CRM20210520005865 issue with 'savi ipv6 check source ip-address mac-address'
7.0.3.5(R0241.0443)
FIX|CRM20210531005981 VCT issue
7.0.3.5(R0241.0442)
FIX|CRM20210517005834 issue with logging actions via web-interface
7.0.3.5(R0241.0439)
FIX|CRM20210507005741 port-security maximum before enable the feature
7.0.3.5(R0241.0438)
FIX|CRM20210415005437 privileged EXEC Mode Commands without confirmation
7.0.3.5(R0241.0436)
FIX|CRM20210506005717 issue with 'savi ipv6 check source ip-address mac-address'
7.0.3.5(R0241.0433)
FIX|CRM20210427005582 capture command enter shell mode
7.0.3.5(R0241.0428)
FIX|CRM20210426005580 restart does not work
S2990G 7.0.3.5(R0102.00316)
Список изменений:
7.0.3.5(R0102.0316)
FIX|CRM20210617006130 issue with 'switchport discard packet untag'
7.0.3.5(R0102.0315)
FIX|CRM20210524005886 issue with logging actions via web-interface
7.0.3.5(R0102.0314)
FIX|CRM20210324005093 issue with tNACTask
  • 4 weeks later...
S2962_7.0.3.5(R0241.0457)
S2965_7.0.3.5(R0241.0457)
S2982G_7.0.3.5(R0241.0457)
S2985G_7.0.3.5(R0241.0457)
Список изменений:
7.0.3.5(R0241.0457)
FIX|CRM20210712006555 issue with RSTP
7.0.3.5(R0241.0456)
FIX|CRM20210708006461 new SNMP OID's
7.0.3.5(R0241.0455)
FIX|CRM20210715006589 speed downgrade
7.0.3.5(R0241.0454)
FIX|CRM20210708006458 Dot1x authentication-method
7.0.3.5(R0241.0453)
FIX|CRM20210705006421 issue with user-control
7.0.3.5(R0241.0451)
FIX|CRM20210708006484 issue with 'bpdu-tunnel multi-protocol group'
FIX|CRM20210705006415 issue with SNMP OID '1.0.8802.1.1.2.1.5.32962.1.3.3.1.2'
7.0.3.5(R0241.0449)
FIX|CRM20210705006416 shell accessibility using special characters
FIX|CRM20210630006321 issue with 'ip dhcp snooping binding user-control' and no enough ACL resource
S2995G_7.5.3.2(R0004.0358)
S3850G_7.5.3.2(R0004.0358)
Список изменений:
7.5.3.2(R0004.0358)
FIX|CRM20210623006185 vrf features
FIX|CRM20210716006602 issue with multicast
7.5.3.2(R0004.0357)
FIX|CRM20210714006581 issue with speed downgrade (only for SNR-S2995G-24FX)
7.5.3.2(R0004.0356)
FIX|CRM20210708006484 issue with ‘bpdu-tunnel multi-protocol group’
FIX|CRM20210611006108 LLDP management-address IPv6 and autonegotiation information
7.5.3.2(R0004.0354)
FIX|CRM20210617006129 fan error logs.
7.5.3.2(R0004.0353)
FIX|CRM20210702006371 issue with 1.3.6.1.2.1.31.1.1.1.18 (ifAlias)
7.5.3.2(R0004.0352)
FIX|CRM20210528005955 VRF supports TACACS and SNMP protocols
S300G_7.5.3.0(R0010.0264)
Список изменений:
7.5.3.0(R0010.0264)
FIX|CRM20210708006485 issue with DHCP Relay
  • 1 month later...
S2962: 7.0.3.5(R0241.0465)
S2965: 7.0.3.5(R0241.0465)
S2982: 7.0.3.5(R0241.0465)
S2985: 7.0.3.5(R0241.0465)
Список изменений:
7.0.3.5(R0241.0465)
FIX|CRM20210722006645 SNR-S2985G-8T hangs up issue
7.0.3.5(R0241.0464)
FIX|CRM20210802006742 issue with dot1qVlanStaticUntaggedPorts
7.0.3.5(R0241.0463)
FIX|CRM20210721006638 issue with extended PoE tlv
7.0.3.5(R0241.0462)
FIX|CRM20210729006692 issue with STP and IPv6 traffic
7.0.3.5(R0241.0460)
FIX|CRM20210729006693 issue with copying files
7.0.3.5(R0241.0459)
FIX|CRM20210708006461 issue with MIB walk section errors
S2995: 7.5.3.2(R0004.0369)
S3850: 7.0.3.5(R0241.0465)
Список изменений:
7.5.3.2(R0004.0369)
FIX|CRM20210823006934 issue with NTP via multicast/broadcast
7.5.3.2(R0004.0367)
FIX|CRM20210806006773 issue with radius-server access-mode
7.5.3.2(R0004.0364)
7.5.3.2(R0004.0361)
FIX|CRM20210723006653 issue with port-group message
7.5.3.2(R0004.0360)
FIX|CRM20210721006637 issue with cpu-protect
Уведомляем о выходе новой версии ПО для коммутатора S2989.
S2989: 7.5.3.2(R0028.0065)
Список изменений:
7.5.3.2(R0028.0065)
FIX|CRM20210729006697 issue with vlan-translation
S2990X: 7.5.3.2(R0010.0111)
S300X: 7.5.3.2(R0010.0111)
Список изменений:
7.5.3.2(R0010.0111)
FIX|CRM20210817006863 Issue with VSF and 'interface mode cr4'
Уведомляем о выходе новой версии ПО для коммутатора SNR-S225Gi.
S225Gi: 7.0.3.5(R0241.0464)
Список изменений:
7.0.3.5(R0241.0464)
7.0.3.5(R0241.0463)
7.0.3.5(R0241.0462)
7.0.3.5(R0241.0460)
7.0.3.5(R0241.0459)
FIX|CRM20210708006461 solves the problem of MIB walk section errors
7.0.3.5(R0241.0458)
FIX|CRM20210722006645 hangs up
7.0.3.5(R0241.0457)
7.0.3.5(R0241.0456)
7.0.3.5(R0241.0455)
FIX|CRM20210715006589 speed down-grade
7.0.3.5(R0241.0454)
S2990G: 7.0.3.5(R0102.0317)
Список изменений:
7.0.3.5(R0102.0317)
FIX|CRM20210729006695 hangs up
  • 3 months later...
S2962: 7.0.3.5(R0241.0495)
S2965: 7.0.3.5(R0241.0495)
S2982G: 7.0.3.5(R0241.0495)
S2985G: 7.0.3.5(R0241.0495)
Список изменений:
7.0.3.5(R0241.0495)
ADD|CRM20211203008423 add 'snmp-server fdbMacInfoTable-mib'
FIX|CRM20211209008555 issue with isolate-group
7.0.3.5(R0241.0493)
FIX|CRM20211207008509 issue with 'authentication ip access-class'
7.0.3.5(R0241.0492)
FIX|CRM20211009007550 issue with 'show aaa authenticated-user'
7.0.3.5(R0241.0491)
FIX|CRM20211130008382 issue with 'switchport port-security violation recovery'
7.0.3.5(R0241.0489)
FIX|CRM20211123008232 issue with task ZIMI and AAA
FIX|CRM20211118008177 high CPU load with some SNMP polls
7.0.3.5(R0241.0486)
FIX|CRM20211025007790 issue with task "tIgmpsnoopingv3"
7.0.3.5(R0241.0485)
FIX|CRM20211026007823 memory leaking
7.0.3.5(R0241.0480)
FIX|CRM20211011007585 issue with temperature
7.0.3.5(R0241.0479)
FIX|CRM20211009007552 issue with '::ffff: deny by security IPv6 or ACL:FAULT'
7.0.3.5(R0241.0470)
FIX|CRM20210906007122 special characters into shell on command line
S2995G: 7.5.3.2(R0004.0404)
S3850G: 7.5.3.2(R0004.0404)
Список изменений:
7.5.3.2(R0004.0404)
FIX|CRM20211028007851 'sh tcam usage' in VSF mode
7.5.3.2(R0004.0403)
FIX|CRM20210914007249 add 'ip dhcp snooping user-bind autosave time'
7.5.3.2(R0004.0402)
FIX|CRM20211118008178 static arp doesn't take effect
7.5.3.2(R0004.0401)
FIX|CRM20211014007633 change 'sh log' output
7.5.3.2(R0004.0400)
ADD|CRM20211028007858 issue with 'ip pim rp-candidate' when multiple multicast networks
7.5.3.2(R0004.0399)
FIX|CRM20211126008321 issue with BFD MAD
FIX|CRM20211028007865 issue with 'authentication ip access-class'
7.5.3.2(R0004.0397)
FIX|CRM20211123008230 VSF SNMP OIDs
7.5.3.2(R0004.0394)
7.5.3.2(R0004.0389)
FIX|CRM20211009007549 issue with bpdu-tunnel-protocol-stp
7.5.3.2(R0004.0388)
7.5.3.2(R0004.0387)
FIX|CRM20210929007501 issue with OSPF and TTL0 traffic
7.5.3.2(R0004.0385)
FIX|CRM20210916007279 issue with SNMP unavailability
7.5.3.2(R0004.0384)
FIX|CRM20210916007271 issue with SNTP
7.5.3.2(R0004.0383)
FIX|CRM20210915007258 issue with capture via VTY
7.5.3.2(R0004.0381)
FIX|CRM20210914007238 issue with ip dhcp snooping binding
7.5.3.2(R0004.0380)
FIX|CRM20210909007168 issue with cross-stack LAG to MLAG
7.5.3.2(R0004.0377)
FIX|CRM20210830007011 issue with ip dhcp snooping binding
7.5.3.2(R0004.0372)
FIX|CRM20210826006961 issue with http load cfg by eth0
FIX|CRM20210826006964 issue with VSF stack and MAB
7.5.3.2(R0004.0370)
FIX|CRM20210825006944 add new command ‘spanning-tree agreement-check-cancel’ for RSTP
Уведомляем о выходе новой версии ПО для серии S2989G.
S2989G: 7.5.3.2(R0028.0098)
Список изменений:
7.5.3.2(R0028.0098)
FIX|CRM20211203008428 change 'sh log' output
7.5.3.2(R0028.0097)
FIX|CRM20211207008507 issue with 'authentication ip access-class'
7.5.3.2(R0028.0096)
7.5.3.2(R0028.0093)
FIX|CRM20211118008178 issue with temperature
7.5.3.2(R0028.0090)
ADD|CRM20210924007403 SNMP trap requirement
7.5.3.2(R0028.0083)
FIX|CRM20210929007502 issue with capture via VTY
7.5.3.2(R0028.0082)
FIX|CRM20210924007402 issue with 'show ip route'
7.5.3.2(R0028.0080)
FIX|CRM20210924007379 incorrect dhcp request
FIX|CRM20210924007404 dying gasp snmp trap issue
7.5.3.2(R0028.0077)
FIX|CRM20210916007280 issue with SNMP unavailability
7.5.3.2(R0028.0074)
FIX|CRM20210813006770 dhcp snooping user-bind autosave
7.5.3.2(R0028.0067)
Уведомляем вас о выходе новой версии ПО для серий SNR-S2990X-24FQ и SNR-S300X-24FQ.
S2990X-24FQ: 7.5.3.2(R0010.0121)
S300X-24FQ: 7.5.3.2(R0010.0121)
Список изменений:
7.5.3.2(R0010.0121)
FIX|CRM20211207008508 issue with 'authentication ip access-class'
7.5.3.2(R0010.0119)
FIX|CRM20211123008231 VSF SNMP OIDs
7.5.3.2(R0010.0117)
FIX|CRM20211028007844 issue with 'logging executed-commands enable'
7.5.3.2(R0010.0116)
FIX|CRM20211021007743 issue with bpdu-tunnel-protocol-stp
7.5.3.2(R0010.0115)
FIX|CRM20210915007252 issue with monitor sessions
7.5.3.2(R0010.0112)
S2990G: 7.0.3.5(R0102.0318)
Список изменений:
7.0.3.5(R0102.0318)
FIX|CRM20210817006865 issue with many PARITY_ERROR
Уведомляем о выходе новой версии ПО для серии SNR-S300G-24FX.
SNR-S300G-24FX: 7.5.3.0(R0010.0278)
Список изменений:
7.5.3.0(R0010.0278)
FIX|CRM20211207008523 selective QinQ doesn't work with DHCP snooping
7.5.3.0(R0010.0276)
7.5.3.0(R0010.0275)
FIX|CRM20210929007504 issue with LDP targeted-hello-accept filter
7.5.3.0(R0010.0274)
FIX|CRM20211115008131 issue with zNSM task
7.5.3.0(R0010.0273)
FIX|CRM20210929007502 issue with 'capture' command
7.5.3.0(R0010.0271)
FIX|CRM20210916007259 issue with SNMP unavailability
7.5.3.0(R0010.0268)
FIX|CRM20201103003085 freezes when a large amount of broadcast/ARP passes through it
7.5.3.0(R0010.0267)
FIX|CRM20210826006962 memory leaking
7.5.3.0(R0010.0265)
FIX|CRM20210716006601 Archive running-config
7.5.3.0(R0010.0264)
Уведомляем о выходе новой версии ПО для серии SNR-S4550
S4550: 7.0.3.0(R0246.0151)
Список изменений:
7.0.3.0(R0246.0151)
FIX|CRM20211013007619 issue with SNMP
7.0.3.0(R0246.0150)
FIX|CRM20211014007638 issue with LACP
7.0.3.0(R0246.0149)
FIX|CRM20210531005979 monitor session issue
Уведомляем о выходе новой версии ПО для серии SNR-S4650X-48FQ
SNR-S4650X-48FQ: 7.5.3.2(R0016.0034)
Список изменений:
7.5.3.2(R0016.0034)
FIX|CRM20211207008510 issue with 'authentication ip access-class'
7.5.3.2(R0016.0032)
Critical|CRM20210929007491 high rtt with snmp monitoring
7.5.3.2(R0016.0031)
Critical|CRM20210827006975 issue with copy running-config
  • 2 months later...
S2962: 7.0.3.5(R0241.0501)
S2965: 7.0.3.5(R0241.0501)
S2982G: 7.0.3.5(R0241.0501)
S2985G: 7.0.3.5(R0241.0501)
Список изменений:
7.0.3.5(R0241.0501)
ADD|CRM20220207009150 add 'configure terminal' alias
7.0.3.5(R0241.0499)
ADD|CRM20220117009036 snmp lldp neighbor mac issue
7.0.3.5(R0241.0497)
ADD|CRM20211230008808 requirement for DHCP option 82 subscriber-id format vs-cisco
S2995G: 7.5.3.2(R0004.0427)
S3850G: 7.5.3.2(R0004.0427)
Список изменений:
7.5.3.2(R0004.0427)
FIX|CRM20220223009354 DHCP option82 subscriber-id format vs-cisco
7.5.3.2(R0004.0426)
FIX|CRM20220223009351 add 'configure terminal' alias
7.5.3.2(R0004.0424)
FIX|CRM20220225009371 issue with ospf point-to-multipoint
7.5.3.2(R0004.0423)
ADD|CRM20220223009349 syslog support udp port
7.5.3.2(R0004.0422)
ADD|CRM20220207009147 increase quantity sub vlans per supervlan
ADD|CRM20220207009149 displaying interface configuration in port-channel
7.5.3.2(R0004.0421)
ADD|CRM20220218009280 issue with isolate and ip arp inspection
7.5.3.2(R0004.0420)
ADD|CRM20220208009159 issue with admin-scope ranges RFC5059
7.5.3.2(R0004.0419)
ADD|CRM20220207009144 issue with POE command
7.5.3.2(R0004.0418)
ADD|CRM20211116008144 add DHCP server for VRF
7.5.3.2(R0004.0417)
ADD|CRM20211028007860 add info-center possibility for VRF
7.5.3.2(R0004.0416)
ADD|CRM20211112008080 issue with 'sh port-group'
7.5.3.2(R0004.0414)
FIX|CRM20211210008564 issue with 'switchport port-security violation recovery'
7.5.3.2(R0004.0410)
FIX|CRM20211222008721 issue with isolate and ip arp inspection
7.5.3.2(R0004.0408)
FIX|CRM20211214008603 add command 'show ip dhcp snooping user-bind autosave
S2989G: 7.5.3.2(R0028.0107)
Список изменений:
7.5.3.2(R0028.0107)
FIX|CRM20220307009525 'clear counters','clear counters interface...' SNMP OIDs
7.5.3.2(R0028.0105)
FIX|CRM20220207009146 add portTrunkAllowedVlanEntry oid's
7.5.3.2(R0028.0103)
7.5.3.2(R0028.0101)
FIX|CRM20211214008603 add command 'show ip dhcp snooping user-bind autosave'
S2990X-24FQ: 7.5.3.2(R0010.0133)
S300X-24FQ: 7.5.3.2(R0010.0133)
Список изменений:
7.5.3.2(R0010.0133)
FIX|CRM20220307009523 'clear counters','clear counters interface...' SNMP OIDs
7.5.3.2(R0010.0132)
FIX|CRM20220223009350 show port-group
7.5.3.2(R0010.0131)
FIX|CRM20220223009353 DHCP option82 subscriber-id format vs-cisco
7.5.3.2(R0010.0130)
ADD|CRM20220211009195 Add arbitrary UDP-port for syslog
7.5.3.2(R0010.0128)
FIX|CRM20220214009233 Issue with DHCP client to MGMT interface in VSF
7.5.3.2(R0010.0127)
FIX|CRM20220113008988 add DHCP client to MGMT interface
7.5.3.2(R0010.0126)
FIX|CRM20211227008782 Problem with NFS fragmented packets
7.5.3.2(R0010.0124)
FIX|CRM20211217008649 selective QinQ doesn't work with DHCP Snooping
7.5.3.2(R0010.0123)
FIX|CRM20211102007959 issue with oid xxx.100.3.13.1.3 (portHybridTaggedAllowedVlanAdd)
SNR-S300G-24FX: 7.5.3.0(R0010.0281)
Список изменений:
7.5.3.0(R0010.0281)
FIX|CRM20220222009338 issue with no arp when enable point-to-multipoint
7.5.3.0(R0010.0280)
FIX|CRM20220128009121 issue with SSH
SNR-S4650X-48FQ: 7.5.3.2(R0016.0041)
Список изменений:
7.5.3.2(R0016.0041)
ADD|CRM20211229008805 issue with 'show aaa authenticated-user'
7.5.3.2(R0016.0038)
FIX|CRM20211229008800 ospf crash after debug arp receive enabled
Уведомляем о выходе новой версии ПО для серии SNR-S225Gi-8T-POE
SNR-S225Gi-8T-POE: 7.0.3.5(R0241.0499)
Список изменений:
7.0.3.5(R0241.0499)
7.0.3.5(R0241.0497)
7.0.3.5(R0241.0495)
7.0.3.5(R0241.0493)
7.0.3.5(R0241.0492)
7.0.3.5(R0241.0491)
7.0.3.5(R0241.0489)
7.0.3.5(R0241.0486)
FIX|CRM20211025007790 issue with task "Igmpsnoopingv3"
7.0.3.5(R0241.0485)
7.0.3.5(R0241.0480)
7.0.3.5(R0241.0479)
7.0.3.5(R0241.0470)
7.0.3.5(R0241.0465)
  • 3 months later...
S2962: 7.0.3.5(R0241.0522)
S2965: 7.0.3.5(R0241.0522)
S2982G: 7.0.3.5(R0241.0522)
S2985G: 7.0.3.5(R0241.0522)
Список изменений:
7.0.3.5(R0241.0522)
FIX|CRM202206161010867 issue with spanning-tree output
7.0.3.5(R0241.0521)
ADD|CRM20220518010471 ssh-server encryption-algorithms
7.0.3.5(R0241.0519)
ADD|CRM20220512010411 dhcp client enable
7.0.3.5(R0241.0518)
FIX|CRM20220516010452 Configured bandwidth does not take effect
7.0.3.5(R0241.0517)
FIX|CRM20220513010414 issue with QINQ and bpdu-tunnel user-defined-protocol
ADD|CRM20220419009985 add oid for getting mac addresses on ports
7.0.3.5(R0241.0516)
FIX|CRM20220428010227 issue with VCT in cable status and length
7.0.3.5(R0241.0514)
FIX|CRM20220428010224 issue with default-gateway via DHCP client
7.0.3.5(R0241.0512)
FIX|CRM20220420010015 Unable to upgrade using http
ADD|CRM20220427010205 https issue
7.0.3.5(R0241.0511)
FIX|CRM20220426010163 issue with 'show erps ring' output
FIX|CRM20220414009934 Comment out the command line related to drop precedence
7.0.3.5(R0241.0510)
ADD|CRM20220406009854 add ability to view vlans in instance by snmp while spanning tree is not enable
7.0.3.5(R0241.0507)
ADD|CRM20220307009519 add ssh client
7.0.3.5(R0241.0506)
ADD|CRM20220321009695 add changing DHCP op 60
FIX|CRM20220329009778 issue with high latency
7.0.3.5(R0241.0504)
FIX|CRM20220328009765 wrong time in sh users while using ssh keys
7.0.3.5(R0241.0502)
ADD|CRM20220310009555 issue with plain text password for SNMPv3 user
S2995G: 7.5.3.2(R0004.0455)
S3850G: 7.5.3.2(R0004.0455)
Список изменений:
7.5.3.6(R0004.0455)
FIX|CRM20220616010867 issue with spanning-tree output
7.5.3.6(R0004.0453)
FIX|CRM20220606010740 memory leak in stack on AM
7.5.3.6(R0004.0452)
FIX|CRM20220518010465 issue with stack fall apart
7.5.3.6(R0004.0449)
ADD|CRM20220520010515 add oid for getting mac addresses on port
7.5.3.6(R0004.0448)
ADD|CRM20220516010453 add bfd echo
7.5.3.6(R0004.0447)
ADD|CRM20220330009789 add LACP dynamic aggregation port status change log
7.5.3.6(R0004.0445)
FIX|CRM20220419009986 issue with RIP authentication
ADD|CRM20220505010281 add port-led shutoff
7.5.3.2(R0004.0444)
FIX|CRM20220422010053 IPv6 BGP update source uses interface loopback1,BGP neighbors cannot be established
7.5.3.2(R0004.0443)
FIX|CRM20220420009998 issue with dhcp pool in vrf
7.5.3.2(R0004.0442)
ADD|CRM20220407009877 managment vrf features
7.5.3.2(R0004.0441)
FIX|CRM20220411009906 issue with automatic restart
7.5.3.2(R0004.0440)
ADD|CRM20220321009686 add loopback swapmac function of port
7.5.3.2(R0004.0439)
7.5.3.2(R0004.0437)
FIX|CRM20220406009856 issue with high latency
7.5.3.2(R0004.0435)
FIX|CRM20220402009818 issue with bgp ipv6 default route announce
7.5.3.2(R0004.0434)
FIX|CRM20220310009556 issue with high latency
7.5.3.2(R0004.0433)
FIX|CRM20220317009645 wrong time in 'sh users' while using ssh keys
7.5.3.2(R0004.0432)
ADD|CRM20220307009522 support 64 secondary IP address
7.5.3.2(R0004.0431)
FIX|CRM20220303009471 add 'loopback swap-mac'
S2989G: 7.5.3.2(R0028.0116)
7.5.3.2(R0028.0116)
FIX|CRM20220425010130 issue with default threshold temperature
7.5.3.2(R0028.0115)
ADD|CRM20220321009686 loopback swapmac
7.5.3.2(R0028.0114)
FIX|CRM20220406009847 https issue
7.5.3.2(R0028.0113)
FIX|CRM20220411009905 delete VRF command because VRF not support
7.5.3.2(R0028.0112)
FIX|CRM20220330009783 DHCP option82 subscriber-id format vs-cisco
7.5.3.2(R0028.0111)
FIX|CRM20220329009779 issue with dhcp relay self-defined Circuit ID
7.5.3.2(R0028.0110)
7.5.3.2(R0028.0109)
FIX|CRM20220314009607 add 'configure terminal' alias
7.5.3.2(R0028.0108)
S2990X-24FQ: 7.5.3.2(R0010.0146)
S300X-24FQ: 7.5.3.2(R0010.0146)
Список изменений:
7.5.3.2(R0010.0146)
ADD|CRM20220620010928 add 'show vsf config detail'
7.5.3.2(R0010.0145)
FIX|CRM20220606010740 issue with VSF stack reboot
7.5.3.2(R0010.0144)
FIX|CRM20220509010357 igmp didn't take effect while configuration is null
7.5.3.2(R0010.0143)
FIX|CRM20220426010202 issue with port-isolation in VSF mode
7.5.3.2(R0010.0141)
ADD|CRM20220328009767 wrong time in 'sh users' while using ssh keys
7.5.3.2(R0010.0139)
ADD|CRM20220314009608 add 'configure terminal' alias
7.5.3.2(R0010.0138)
ADD|CRM20220316009630 displaying interface configuration in port-channel
Уведомляем вас о выходе новой ветки ПО для серий SNR-S2990X-24FQ с поддержкой VSF HA
S2990X(VSF_HA): 7.6.3.3(R0001.0025)
7.6.3.3(R0001.0025)
ADD|CRM20220609010763 add 'show vsf config detail'
7.6.3.3(R0001.0024)
FIX|CRM20220606010742 issue with VSF stack reboot
S300G-24FX: 7.5.3.0(R0010.0286)
Список изменений:
7.5.3.0(R0010.0286)
FIX|CRM20220520010516 issue with adding a neighbor in exist peer-group
7.5.3.0(R0010.0285)
FIX|CRM20220328009768 wrong time in sh users while using ssh keys
7.5.3.0(R0010.0284)
7.5.3.0(R0010.0283)
FIX|CRM20211129008369 issue with router leaking
S4650X-48FQ: 7.5.3.2(R0016.0048)
Список изменений:
7.5.3.2(R0016.0048)
FIX|CRM20220524010581 no nexthop in address-family multicast
7.5.3.2(R0016.0046)
ADD|CRM20220513010418 Add show vsf config detail
7.5.3.2(R0016.0045)
ADD|CRM20220418009981 Archive running-config
7.5.3.2(R0016.0042)
FIX|CRM20220328009769 wrong time in 'sh users' while using ssh keys
FIX|CRM20220321009697 add 'configure terminal' alias
Уведомляем о выходе новой ветки ПО для серии SNR-S4650X-48FQ_R3
S4650X-48FQ_R3: 7.6.3.2(R0002.0025)
Список изменений:
7.6.3.2(R0002.0025)
FIX|CRM20220328009769 wrong time in sh users while using ssh keys
ADD|CRM20220321009697 add configure terminal
7.6.3.2(R0002.0024)
FIX|CRM20220310009553 issue with VRF_MAX
7.6.3.2(R0002.0022)
FIX|CRM20211129008368 show transciever cause network temporary network outage
ADD|CRM20211209008545 issue with 'show aaa authenticated-user'
ADD|CRM20210708006458 Dot1x authentication-method
7.6.3.2(R0002.0021)
FIX|CRM20211213008597 watchdog is disable in default
7.6.3.2(R0002.0020)
FIX|CRM20210929007491 long ping with snmp monitoring
7.6.3.2(R0002.0019)
FIX|CRM20220526010607 issue with copy running-config
7.6.3.2(R0002.0018)
FIX|CRM20210813006834 QINQ issue
S4550: 7.0.3.0(R0246.0152)
Список изменений:
7.0.3.0(R0246.0152)
FIX|CRM20220601010682 issue with task "tCommonPktRx"
Уведомляем о выходе новой версии ПО для серии SNR-S2200G-8T-POE
S2200G: V01D01P03SP17
Уведомляем о выходе новой версии ПО для серии SNR-S5210
S5210: 1.0.0
Список изменений:
### Added
- Обновлен загрузчик до версии 1.1
- Функционал фильтрации IGMP пакетов по типам  Report / Query на портах
- Функционал фильтрации IGMP подписок по адресам multicast групп
- Функционал ограничения количества IGMP подписок на порту
- Отображение заряда АКБ в %
- Команда traceroute
- Функционал DHCPv4 Relay
- Функционал DHCPv4 Relay share-vlan
- Функционал DHCP Snooping Binding
- Функционал DHCP Snooping Binding user-control
- Функционал ограничения кол-ва клиентов в dhcp snooping binding
- Настройка policy (keep,drop,replace) для DHCP Snooping Opt. 82
- Команда ip dhcp relay broadcast suppress
### Fixed
- Изменение диапазона допустимого номера группы channel-group
- Исправлена работа команды show mac-address-table limit
- Добавлено сообщение об ошибке во время выполнения команды igmp snooping multicast-vlan при отсутствии созданного vlan
- Добавлена очистка изученных MAC-адресов на порту при переходе порта в down
- Добавлен запрет пользователю с ролью network-operator выполнять команды mv, rm, delete startup-config, copy running-config startup-config
This topic is now closed to further replies.
