Прветствую! Помогите решить проблемку:
Есть забавная не стыковка: DGS-3420 SFP+ портом не видит маков от XFP SPA с ASR1001
Интерфейс тестовый абсолютно аналогичен рабочим интерфейсам на Port-channel с которого надо переводить интерфейсы на TenGigabitEthernet0/1/0
Физика на 850nm двух глазые модули CISCO и SNR :)
interface TenGigabitEthernet0/1/0.99
description test99
encapsulation dot1Q 99
ip address 192.168.188.1 255.255.255.128
ip helper-address 192.168.100.100
ip verify unicast source reachable-via any
ip access-group 180 out
service-policy type control ISG-CUSTOMERS-POLICY
ip subscriber routed
 initiator unclassified ip-address
TenGigabitEthernet0/1/0 is up, line protocol is up
 Hardware is SPA-1X10GE-L-V2, address is a493.4c30.9610 (bia a493.4c30.9610)
 Description: DGS-3420_25port
 MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
    reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
 Keepalive not supported
 Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-SR/SW
 output flow-control is on, input flow-control is on
 ARP type: ARPA, ARP Timeout 04:00:00
 Last input never, output 00:04:00, output hang never
 Last clearing of "show interface" counters never
 Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: fifo
 Output queue: 0/40 (size/max)
 5 minute input rate 0 bits/sec, 0 packets/sec
 5 minute output rate 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes, 0 no buffer
    Received 0 broadcasts (0 IP multicasts)
    0 runts, 0 giants, 0 throttles
    133 input errors, 0 CRC, 133 frame, 0 overrun, 0 ignored
    0 watchdog, 0 multicast, 0 pause input
    17723 packets output, 1142501 bytes, 0 underruns
    0 output errors, 0 collisions, 15 interface resets
    0 unknown protocol drops
    0 babbles, 0 late collision, 0 deferred
    0 lost carrier, 0 no carrier, 0 pause output
    0 output buffer failures, 0 output buffers swapped out
ISG_ASR1#
DSG
# VLAN
create vlan 99 tag 99
config vlan 99 add tagged 20,22-23,25 advertisement disable
Command: show ports 25 details
Port : 25
Port Status                 : Link Up
Description                 : ASR_10G
HardWare Type               : Ten Gigabits Ethernet
MAC Address                 : 90-94-E4-0C-B1-18
Bandwidth                   : 10000000Kbit
Auto-Negotiation            : Disabled
Duplex Mode                 : Full Duplex
Flow Control                : Disabled
MDI                         : Normal
Address Learning            : Enabled
Last Clear of Counter       : 124 hours 53 mins ago
BPDU Hardware Filtering Mode: Disabled
Queuing Strategy            : FIFO
Last Linkchange             : 45:37:35:68
TX Load                     :   1/100,     127976 bits/sec,      176 packets/sec
RX Load                     :   0/100,          0 bits/sec,        0 packets/sec
Command: show error ports 25
Port Number : 25
                        RX Frames                            TX Frames
CRC Error               0              Excessive Deferral    0
Undersize               0              CRC Error             0
Oversize                0              Late Collision        0
Fragment                0              Excessive Collision   0
Jabber                  0              Single Collision      0
Buffer Full Drop        0              Collision             0
ACL Drop                0              STP Drop              0
Multicast Drop          0              HOL DROP              0
VLAN Ingress Drop       0              COS0 HOL DROP         0
Invalid IPv6            0              COS1 HOL DROP         0
STP Drop                0              COS2 HOL DROP         0
Storm and FDB Discard   0              COS3 HOL DROP         0
MTU Drop                0              COS4 HOL DROP         0
                                       COS5 HOL DROP         0
                                       COS6 HOL DROP         0
                                       COS7 HOL DROP         0
Рад любым подсказкам :)
Посмотрите статистку по кадрам на прием на D-Link, есть входящие?
В обратную сторону, с D-Link на ASR, передача данных судя по всему не работает:
не вяжется с
Edited by v_r
0 packets input
Что-то на физике/в модулях. Что - сказать сложно. Оба модуля многомодовые? Стандарт 10G на модулях точно не отличается? Патч-корд многомодовый? Расстояние? В логах про превышение уровня по оптике ничего нет?
0 packets input
Пачь многомодовый(одномод не поднимается вообще), 3 метра, бюджет SFP+/XFP - 300 метров.
в ASR: Оптический трансивер NS-XFP-10G-SRD, дальность до 300m, длина
волны 850nm, MM, LC, DDM
в DSG: Трансивер Cisco FET-10G= 100 метров 850нм LC, - (завтра уточню)
Port    Temperature   Voltage    Bias-Current   TX-Power     RX-Power
       (in Celsius)     (V)         (mA)         (dBm)        (dBm)
25        33.4388      3.3035       7.8053       -2.3035      -4.0908
Threshold     Temperature    Voltage    Bias-Current   TX-Power     RX-Power
High Alarm     75.0000      3.6300       11.8000      2.6998       2.9999
Low Alarm      5.0000       2.9700       4.0000       -11.3018     -13.9041
High Warning   70.0000      3.4650       10.8000      -1.3001      -1.0002
Low Warning    10.0000      3.1350       5.0000       -7.3002      -9.9012
А как посмотреть про превышение уровня на ASR?
Вы эту имели ввиду?
TX Counter
   Excessive Deferrals     : 0          Late Collisions  : 0
   Excess Collision        : 0          Single Collision : 0
   Collision               : 0
RX Counter
   Broadcast               : 0          Multicast        : 0
   CRC Errors              : 0          Dropped Packets  : 0
   Undersizes              : 0          Oversizes        : 0
   Fragments               : 0          Jabber           : 0TX Counter
Diman_xxxx не совсем, имел ввиду статистику по переданным и принятым кадрам, но и по вашему выводу понятно что входящего трафика от ASR на D-Link нету:
RX Counter
    Broadcast               : 0
Причина скорее всего в
Если не ошибаюсь, FET - специфические трансиверы для линков между Cisco Nexus, на других линках не работают.
поменять местами sfp с патчкордом... изменится ли на dgsке
прошивка на длинке какая? на старых прошивках был косяк с определением mdix, но там линк просто не поднимался, попробуйте вручную режимы позадавать.
С вероятностью 99% причина в FET-10G - это очень специфичный модуль (10GBASE-USR), стандарта на таковые нет, вполне возможно что у него отличается энкодинг, поэтому и frame error'ы лезут.
Т.е. скрестить его с 10GBASE-SR может и не получиться. Попробуйте два модуля cтандарта SR поставить с обеих сторон (то есть найти SFP+ 10GBASE-SR), по идее должно помочь.
