помогите не проходит авторизация при radtest:
ubilling@ubilling:/var/log# radtest 00001 5o3d40yo 127.0.0.1 0 dec0071981b1
Sending Access-Request of id 163 to 127.0.0.1 port 1812
User-Name = "0001"
User-Password = "5o3d40yo"
NAS-IP-Address = 127.0.0.1
NAS-Port = 0
Message-Authenticator = 0x00000000000000000000000000000000
rad_recv: Access-Reject packet from host 127.0.0.1 port 1812, id=163, length=20
в логах при загрузке
Tue Jun 6 15:28:47 2017 : Info: Signalled to terminate
Tue Jun 6 15:28:47 2017 : Info: Exiting normally.
Tue Jun 6 15:28:47 2017 : Info: rlm_sql (sql): Closing sqlsocket 4
Tue Jun 6 15:28:47 2017 : Info: rlm_sql (sql): Closing sqlsocket 3
Tue Jun 6 15:28:47 2017 : Info: rlm_sql (sql): Closing sqlsocket 2
Tue Jun 6 15:28:47 2017 : Info: rlm_sql (sql): Closing sqlsocket 1
Tue Jun 6 15:28:47 2017 : Info: rlm_sql (sql): Closing sqlsocket 0
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect to root@localhost:3306/stg
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
Tue Jun 6 15:30:38 2017 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Connected new DB handle, #0
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
Tue Jun 6 15:30:38 2017 : Info: rlm_sql_mysql: Starting connect to MySQL server for #1
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Connected new DB handle, #1
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
Tue Jun 6 15:30:38 2017 : Info: rlm_sql_mysql: Starting connect to MySQL server for #2
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Connected new DB handle, #2
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
Tue Jun 6 15:30:38 2017 : Info: rlm_sql_mysql: Starting connect to MySQL server for #3
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Connected new DB handle, #3
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
Tue Jun 6 15:30:38 2017 : Info: rlm_sql_mysql: Starting connect to MySQL server for #4
Tue Jun 6 15:30:38 2017 : Info: rlm_sql (sql): Connected new DB handle, #4
Tue Jun 6 15:30:39 2017 : Info: Loaded virtual server <default>
Tue Jun 6 15:30:39 2017 : Info: Loaded virtual server inner-tunnel
Tue Jun 6 15:30:39 2017 : Info: Ready to process requests.
может ошибаюсь, помоему нет связи и базой данных
driver = "rlm_sql_${database}"^M
^M
# Connection info:^M
server = "localhost"^M
port = 3306^M
login = "root"^M
password = "mys0c7c86b1"^M
^M
Так проверте, попробуйте соедениться клиентом mysql к базе.
судя по
соеденяется, как я понял.
Ошибок то нет.
судя по
Ошибок то нет.
да соединяется, запуск radiusd -X
# radiusd -X
radiusd: FreeRADIUS Version 2.2.9, for host amd64-portbld-freebsd10.3, built on Apr 24 2017 at 17:47:58
Copyright © 1999-2015 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License.
For more information about these matters, see the file named COPYRIGHT.
Starting - reading configuration files ...
including configuration file /usr/local/etc/raddb/radiusd.conf
including files in directory /usr/local/etc/raddb/modules/
including configuration file /usr/local/etc/raddb/modules/always
including configuration file /usr/local/etc/raddb/modules/attr_filter
including configuration file /usr/local/etc/raddb/modules/attr_rewrite
including configuration file /usr/local/etc/raddb/modules/cache
including configuration file /usr/local/etc/raddb/modules/chap
including configuration file /usr/local/etc/raddb/modules/checkval
including configuration file /usr/local/etc/raddb/modules/counter
including configuration file /usr/local/etc/raddb/modules/cui
including configuration file /usr/local/etc/raddb/modules/detail
including configuration file /usr/local/etc/raddb/modules/detail.example.com
including configuration file /usr/local/etc/raddb/modules/detail.log
including configuration file /usr/local/etc/raddb/modules/dhcp_sqlippool
including configuration file /usr/local/etc/raddb/sql/mysql/ippool-dhcp.conf
including configuration file /usr/local/etc/raddb/modules/digest
including configuration file /usr/local/etc/raddb/modules/dynamic_clients
including configuration file /usr/local/etc/raddb/modules/echo
including configuration file /usr/local/etc/raddb/modules/etc_group
including configuration file /usr/local/etc/raddb/modules/exec
including configuration file /usr/local/etc/raddb/modules/expiration
including configuration file /usr/local/etc/raddb/modules/expr
including configuration file /usr/local/etc/raddb/modules/files
including configuration file /usr/local/etc/raddb/modules/inner-eap
including configuration file /usr/local/etc/raddb/modules/ippool
including configuration file /usr/local/etc/raddb/modules/krb5
including configuration file /usr/local/etc/raddb/modules/ldap
including configuration file /usr/local/etc/raddb/modules/linelog
including configuration file /usr/local/etc/raddb/modules/logintime
including configuration file /usr/local/etc/raddb/modules/otp
including configuration file /usr/local/etc/raddb/modules/mac2ip
including configuration file /usr/local/etc/raddb/modules/mac2vlan
including configuration file /usr/local/etc/raddb/modules/mschap
including configuration file /usr/local/etc/raddb/modules/ntlm_auth
including configuration file /usr/local/etc/raddb/modules/opendirectory
including configuration file /usr/local/etc/raddb/modules/pam
including configuration file /usr/local/etc/raddb/modules/pap
including configuration file /usr/local/etc/raddb/modules/passwd
including configuration file /usr/local/etc/raddb/modules/perl
including configuration file /usr/local/etc/raddb/modules/policy
including configuration file /usr/local/etc/raddb/modules/preprocess
including configuration file /usr/local/etc/raddb/modules/radrelay
including configuration file /usr/local/etc/raddb/modules/radutmp
including configuration file /usr/local/etc/raddb/modules/realm
including configuration file /usr/local/etc/raddb/modules/redis
including configuration file /usr/local/etc/raddb/modules/rediswho
including configuration file /usr/local/etc/raddb/modules/replicate
including configuration file /usr/local/etc/raddb/modules/smbpasswd
including configuration file /usr/local/etc/raddb/modules/smsotp
including configuration file /usr/local/etc/raddb/modules/soh
including configuration file /usr/local/etc/raddb/modules/sql_log
including configuration file /usr/local/etc/raddb/modules/sqlcounter_expire_on_login
including configuration file /usr/local/etc/raddb/modules/sradutmp
including configuration file /usr/local/etc/raddb/modules/unix
including configuration file /usr/local/etc/raddb/modules/wimax
including configuration file /usr/local/etc/raddb/modules/acct_unique
including configuration file /usr/local/etc/raddb/eap.conf
including configuration file /usr/local/etc/raddb/sql.conf
including configuration file /usr/local/etc/raddb/sql/mysql/dialup.conf
including files in directory /usr/local/etc/raddb/sites-enabled/
including configuration file /usr/local/etc/raddb/sites-enabled/default
including configuration file /usr/local/etc/raddb/sites-enabled/inner-tunnel
including configuration file /usr/local/etc/raddb/sites-enabled/control-socket
main {
user = "freeradius"
group = "freeradius"
allow_core_dumps = no
including dictionary file /usr/local/etc/raddb/dictionary
main {
name = "radiusd"
prefix = "/usr/local"
localstatedir = "/var"
sbindir = "/usr/local/sbin"
logdir = "/var/log"
run_dir = "/var/run/radiusd"
libdir = "/usr/local/lib/freeradius-2.2.0"
radacctdir = "/var/log/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
pidfile = "/var/run/radiusd/radiusd.pid"
checkrad = "/usr/local/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = yes
auth = yes
auth_badpass = yes
auth_goodpass = no
security {
max_attributes = 200
reject_delay = 1
status_server = yes
allow_vulnerable_openssl = no
radiusd: #### Loading Realms and Home Servers ####
radiusd: #### Loading Clients ####
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating module "exec" from file /usr/local/etc/raddb/modules/exec
exec {
wait = no
input_pairs = "request"
shell_escape = yes
timeout = 10
Module: Linked to module rlm_expr
Module: Instantiating module "expr" from file /usr/local/etc/raddb/modules/expr
radiusd: #### Loading Virtual Servers ####
server { # from file /usr/local/etc/raddb/radiusd.conf
modules {
Module: Creating Auth-Type = digest
Module: Checking authenticate {...} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating module "pap" from file /usr/local/etc/raddb/modules/pap
pap {
encryption_scheme = "auto"
auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating module "chap" from file /usr/local/etc/raddb/modules/chap
Module: Linked to module rlm_mschap
Module: Instantiating module "mschap" from file /usr/local/etc/raddb/modules/mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = no
allow_retry = yes
Module: Linked to module rlm_digest
Module: Instantiating module "digest" from file /usr/local/etc/raddb/modules/digest
Module: Linked to module rlm_unix
Module: Instantiating module "unix" from file /usr/local/etc/raddb/modules/unix
unix {
radwtmp = "/var/log/radwtmp"
Module: Linked to module rlm_eap
Module: Instantiating module "eap" from file /usr/local/etc/raddb/eap.conf
eap {
default_eap_type = "md5"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 1024
Module: Linked to sub-module rlm_eap_md5
Module: Instantiating eap-md5
Module: Linked to sub-module rlm_eap_leap
Module: Instantiating eap-leap
Module: Linked to sub-module rlm_eap_gtc
Module: Instantiating eap-gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
Module: Linked to sub-module rlm_eap_tls
Module: Instantiating eap-tls
tls {
rsa_key_exchange = no
dh_key_exchange = yes
rsa_key_length = 512
dh_key_length = 512
verify_depth = 0
CA_path = "/usr/local/etc/raddb/certs"
pem_file_type = yes
private_key_file = "/usr/local/etc/raddb/certs/server.pem"
certificate_file = "/usr/local/etc/raddb/certs/server.pem"
CA_file = "/usr/local/etc/raddb/certs/ca.pem"
private_key_password = "whatever"
dh_file = "/usr/local/etc/raddb/certs/dh"
fragment_size = 1024
include_length = yes
check_crl = no
check_all_crl = no
cipher_list = "DEFAULT"
make_cert_command = "/usr/local/etc/raddb/certs/bootstrap"
ecdh_curve = "prime256v1"
cache {
enable = no
lifetime = 24
max_entries = 255
verify {
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
Module: Linked to sub-module rlm_eap_ttls
Module: Instantiating eap-ttls
ttls {
copy_request_to_tunnel = no
use_tunneled_reply = no
virtual_server = "inner-tunnel"
Module: Linked to sub-module rlm_eap_peap
Module: Instantiating eap-peap
peap {
default_eap_type = "mschapv2"
proxy_tunneled_request_as_eap = yes
soh = no
Module: Linked to sub-module rlm_eap_mschapv2
Module: Instantiating eap-mschapv2
mschapv2 {
send_error = no
Module: Checking authorize {...} for more modules to load
Module: Linked to module rlm_preprocess
Module: Instantiating module "preprocess" from file /usr/local/etc/raddb/modules/preprocess
preprocess {
huntgroups = "/usr/local/etc/raddb/huntgroups"
hints = "/usr/local/etc/raddb/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
reading pairlist file /usr/local/etc/raddb/huntgroups
reading pairlist file /usr/local/etc/raddb/hints
Module: Linked to module rlm_sql
Module: Instantiating module "sql" from file /usr/local/etc/raddb/sql.conf
sql {
driver = "rlm_sql_mysql"
port = "3306"
login = "root"
radius_db = "stg"
read_groups = yes
sqltrace = no
sqltracefile = "/var/log/sqltrace.sql"
readclients = yes
deletestalesessions = yes
num_sql_socks = 5
lifetime = 0
max_queries = 0
sql_user_name = "%{User-Name}"
default_user_profile = ""
nas_query = "SELECT (@cnt := @cnt + 1) AS `id`, `nasname`, `shortname`, `type`, `secret`, `server` FROM `radius_clients` CROSS JOIN (SELECT @cnt := 0) AS `dummy` ORDER BY `id`"
authorize_check_query = "SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_check` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `id`"
authorize_reply_query = "SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_reply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `id`"
authorize_group_check_query = "SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupcheck` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id`"
authorize_group_reply_query = "SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupreply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id`"
accounting_onoff_query = " UPDATE radius_acct SET acctstoptime = '%S', acctsessiontime = unix_timestamp('%S') - unix_timestamp(acctstarttime), acctterminatecause = '%{Acct-Terminate-Cause}', acctstopdelay = %{%{Acct-Delay-Time}:-0} WHERE acctstoptime IS NULL AND nasipaddress = '%{NAS-IP-Address}' AND acctstarttime <= '%S'"
accounting_update_query = " UPDATE radius_acct SET framedipaddress = '%{Framed-IP-Address}', acctsessiontime = '%{Acct-Session-Time}', acctinputoctets = '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_update_query_alt = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctsessiontime, acctauthentic, connectinfo_start, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, servicetype, framedprotocol, framedipaddress, acctstartdelay, xascendsessionsvrkey) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', DATE_SUB('%S', INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), '%{Acct-Session-Time}', '%{Acct-Authentic}', '', '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', '%{Called-Station-Id}', '%{Calling-Station-Id}', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '0', '%{X-Ascend-Session-Svr-Key}')"
accounting_start_query = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay, xascendsessionsvrkey) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', '%S', NULL, '0', '%{Acct-Authentic}', '%{Connect-Info}', '', '0', '0', '%{Called-Station-Id}', '%{Calling-Station-Id}', '', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '%{%{Acct-Delay-Time}:-0}', '0', '%{X-Ascend-Session-Svr-Key}')"
accounting_start_query_alt = " UPDATE radius_acct SET acctstarttime = '%S', acctstartdelay = '%{%{Acct-Delay-Time}:-0}', connectinfo_start = '%{Connect-Info}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_stop_query = " UPDATE radius_acct SET acctstoptime = '%S', acctsessiontime = '%{Acct-Session-Time}', acctinputoctets = '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', acctterminatecause = '%{Acct-Terminate-Cause}', acctstopdelay = '%{%{Acct-Delay-Time}:-0}', connectinfo_stop = '%{Connect-Info}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_stop_query_alt = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', DATE_SUB('%S', INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), '%S', '%{Acct-Session-Time}', '%{Acct-Authentic}', '', '%{Connect-Info}', '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', '%{Called-Station-Id}', '%{Calling-Station-Id}', '%{Acct-Terminate-Cause}', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '0', '%{%{Acct-Delay-Time}:-0}')"
group_membership_query = "SELECT `GroupName` FROM `radius_usergroup` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `priority`"
connect_failure_retry_delay = 60
simul_count_query = ""
simul_verify_query = "SELECT radacctid, acctsessionid, username, nasipaddress, nasportid, framedipaddress, callingstationid, framedprotocol FROM radius_acct WHERE username = '%{SQL-User-Name}' AND acctstoptime IS NULL"
postauth_query = "INSERT INTO radius_postauth (username, pass, reply, authdate) VALUES ( '%{User-Name}', '%{%{User-Password}:-%{Chap-Password}}', '%{reply:Packet-Type}', '%S')"
safe-characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /"
rlm_sql (sql): starting 0
rlm_sql (sql): starting 1
rlm_sql (sql): starting 2
rlm_sql (sql): starting 3
rlm_sql (sql): starting 4
rlm_sql (sql): Processing generate_sql_clients
rlm_sql (sql) in generate_sql_clients: query is SELECT (@cnt := @cnt + 1) AS `id`, `nasname`, `shortname`, `type`, `secret`, `server` FROM `radius_clients` CROSS JOIN (SELECT @cnt := 0) AS `dummy` ORDER BY `id`
rlm_sql (sql): Reserving sql socket id: 4
rlm_sql (sql): Read entry nasname=10.1.0.1,shortname=Cisco 7200,secret=897269d6f1d8
rlm_sql (sql): Adding client 10.1.0.1 (Cisco 7200, server=<none>) to clients list
rlm_sql (sql): Read entry nasname=127.0.0.1,shortname=Test,secret=dec0071981b1
rlm_sql (sql): Adding client 127.0.0.1 (Test, server=<none>) to clients list
rlm_sql (sql): Released sql socket id: 4
Module: Linked to module rlm_expiration
Module: Instantiating module "expiration" from file /usr/local/etc/raddb/modules/expiration
expiration {
reply-message = "Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating module "logintime" from file /usr/local/etc/raddb/modules/logintime
logintime {
reply-message = "You are calling outside your allowed timespan "
minimum-timeout = 60
Module: Checking preacct {...} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating module "acct_unique" from file /usr/local/etc/raddb/modules/acct_unique
acct_unique {
key = "User-Name, Acct-Session-Id, NAS-IP-Address, NAS-Identifier, NAS-Port"
Module: Checking accounting {...} for more modules to load
Module: Linked to module rlm_attr_filter
Module: Instantiating module "attr_filter.accounting_response" from file /usr/local/etc/raddb/modules/attr_filter
attr_filter attr_filter.accounting_response {
attrsfile = "/usr/local/etc/raddb/attrs.accounting_response"
key = "%{User-Name}"
relaxed = no
reading pairlist file /usr/local/etc/raddb/attrs.accounting_response
Module: Checking session {...} for more modules to load
Module: Linked to module rlm_radutmp
Module: Instantiating module "radutmp" from file /usr/local/etc/raddb/modules/radutmp
radutmp {
filename = "/var/log/radutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
perm = 384
callerid = yes
Module: Checking post-proxy {...} for more modules to load
Module: Checking post-auth {...} for more modules to load
Module: Instantiating module "attr_filter.access_reject" from file /usr/local/etc/raddb/modules/attr_filter
attr_filter attr_filter.access_reject {
attrsfile = "/usr/local/etc/raddb/attrs.access_reject"
relaxed = no
reading pairlist file /usr/local/etc/raddb/attrs.access_reject
} # modules
} # server
server inner-tunnel { # from file /usr/local/etc/raddb/sites-enabled/inner-tunnel
modules {
Module: Linked to module rlm_realm
Module: Instantiating module "suffix" from file /usr/local/etc/raddb/modules/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
Module: Linked to module rlm_files
Module: Instantiating module "files" from file /usr/local/etc/raddb/modules/files
files {
usersfile = "/usr/local/etc/raddb/users"
acctusersfile = "/usr/local/etc/raddb/acct_users"
preproxy_usersfile = "/usr/local/etc/raddb/preproxy_users"
compat = "no"
reading pairlist file /usr/local/etc/raddb/users
reading pairlist file /usr/local/etc/raddb/acct_users
reading pairlist file /usr/local/etc/raddb/preproxy_users
} # modules
} # server
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
listen {
type = "acct"
ipaddr = *
port = 0
listen {
type = "control"
listen {
socket = "/var/run/radiusd/radiusd.sock"
listen {
type = "auth"
ipaddr = 127.0.0.1
port = 18120
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on command file /var/run/radiusd/radiusd.sock
Listening on authentication address 127.0.0.1 port 18120 as server inner-tunnel
Listening on proxy address * port 1814
radtest :
rad_recv: Access-Request packet from host 127.0.0.1 port 10036, id=251, length=75
User-Name = "00001"
NAS-Port = 0
Message-Authenticator = 0x1836e418ec0caab5ea6192efef334233
# Executing section authorize from file /usr/local/etc/raddb/sites-enabled/default
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
[eap] No EAP-Message, not doing EAP
++[eap] = noop
   expand: %{User-Name} -> 00001
[sql] sql_set_user escaped user --> '00001'
rlm_sql (sql): Reserving sql socket id: 3
[sql] expand: SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_check` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `id` -> SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_check` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '00001' ORDER BY `id`
[sql] expand: SELECT `GroupName` FROM `radius_usergroup` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `priority` -> SELECT `GroupName` FROM `radius_usergroup` WHERE `UserName` = '00001' ORDER BY `priority`
[sql] expand: SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupcheck` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id` -> SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupcheck` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '1:167837697' ORDER BY `id`
[sql] User found in group 1:167837697
[sql] expand: SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupreply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id` -> SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupreply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '1:167837697' ORDER BY `id`
rlm_sql (sql): Released sql socket id: 3
++[sql] = ok
++[expiration] = noop
++[logintime] = noop
[pap] WARNING! No "known good" password found for the user. Authentication may fail because of this.
++[pap] = noop
+} # group authorize = ok
ERROR: No authenticate method (Auth-Type) found for the request: Rejecting the user
Failed to authenticate the user.
Login incorrect: [00001/5o3d40yo] (from client Test port 0)
Using Post-Auth-Type Reject
# Executing group from file /usr/local/etc/raddb/sites-enabled/default
+group REJECT {
[attr_filter.access_reject] expand: %{User-Name} -> 00001
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] = updated
+} # group REJECT = updated
Delaying reject of request 0 for 1 seconds
Going to the next request
Waking up in 0.8 seconds.
Sending delayed reject for request 0
Sending Access-Reject of id 251 to 127.0.0.1 port 10036
Waking up in 4.9 seconds.
Cleaning up request 0 ID 251 with timestamp +183
нашел, вопрос по атрибутам!
> test Auth-Type := Local, User-Password == "test"
That should be
test Auth-Type = Local, User-Password := "test"
вот здесь https://www.linux.or...m/admin/4687789, всем спасибо!
ubilling@ubilling:/usr/local/etc/raddb/sites-enabled# radtest 00001 00001 127.0.0.1 0 dec0071981b1
Sending Access-Request of id 232 to 127.0.0.1 port 1812
User-Name = "00001"
User-Password = "00001"
NAS-Port = 0
rad_recv: Access-Accept packet from host 127.0.0.1 port 1812, id=232, length=20
