Коллеги, приветствую!
Утром словил алерт на МХ240:
1 alarms currently active
Alarm time Class Description
2017-05-03 10:04:05 UTC Minor PEM 0 Fan Failed
В логе messages:
chassisd[1308]: CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
В логе chassisd:
May 3 10:04:05 send: yellow alarm set, device PEM 0, reason PEM 0 Fan Failed
May 3 10:04:11 CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
May 3 11:04:13 CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
May 3 12:04:15 CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
May 3 13:04:18 CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
May 3 14:04:20 CHASSISD_SNMP_TRAP6: SNMP trap generated: Power Supply failed (jnxContentsContainerIndex 2, jnxContentsL1Index 1, jnxContentsL2Index 0, jnxContentsL3Index 0, jnxContentsDescr PEM 0, jnxOperatingState/Temp 6)
Вот, что показывает sh chassis * касаемо PEM-ов:
PS LEDs:
PS 0 1 2 3
Red * . . .
Green . . * .
Temp
PEM 0 Check
PEM 1 Absent
PEM 2 OK 35 degrees C / 95 degrees F
PEM 3 Absent
PEM 0 Rev 01 740-022697 QCS******** PS 1.2-1.7kW; 100-240V AC in
PEM 2 Rev 01 740-022697 QCS******** PS 1.2-1.7kW; 100-240V AC in
PEM 0:
State: Present
AC input: Check (1 feed expected, 1 feed connected)
Capacity: 1590 W (maximum 1590 W)
DC output: 150 W (zone 0, 3 A at 50 V, 9% of capacity)
PEM 1:
State: Empty
Input: Absent
PEM 2:
State: Online
AC input: OK (1 feed expected, 1 feed connected)
DC output: 200 W (zone 0, 4 A at 50 V, 12% of capacity)
PEM 3:
State: Empty
Input: Absent
System:
Zone 0:
Allocated power: 573 W (1017 W remaining)
Actual usage: 350 W
Total system capacity: 1590 W (maximum 1590 W)
Total remaining power: 1017 W
Физический доступ к маршрутизатору получить пока проблемно. Вопрос: это БП умирает или просто его FAN сдох? Исходя из: DC output: 150 W (zone 0, 3 A at 50 V, 9% of capacity) - напряжение он отдает (?), но что тогда значит: AC input: Check (1 feed expected, 1 feed connected) ?
Edited by mse.rus77
Уверен? Present—PEM is present in the slot, but not online.
AC/DC Input—OK or Check—State of the AC or DC input power feed with the number of active and expected feeds (one or two).
Нет, не уверен, сомнения вызывает то, что он пишет DC output: 150 W (zone 0, 3 A at 50 V, 9% of capacity).
Однозначно, придется его заменить.
Хотя, тут такая инфа:
show chassis environment pem
PEM 0 status:
State Present
PEM 2 status:
State Online
Temperature OK
AC Input: OK
DC Output Voltage(V) Current(A) Power(W) Load(%)
50 4 200 12
У high capacity блоков питания для других платформ 2 ввода.
БП питает систему, сдох только вентилятор.
На MX блоки питания судя по всему честно показывают потребляемую системой мощность (а не зарезервированную компонентами).
Что ждать дальше и как скоро умрет БП не подскажу.
Спасибо за инфу. Попробую найти информацию на тему возможности замены вентилятора, хотя сомнительно:
the fan in the power supply isn't user serviceable, it's one big honkin' unit.
Regarding RMA, yes, the PEM should be RMAd. The fan tray is there to cool the main chassis section (line cards, REs), not the power supplies, so heat from the power supply itself isn't being dealt with properly with the PEM's fan broken. It may run for a while without the fan but its lifetime is unknown with hot spots building up inside it.
Коллеги, ищу для замены БП, есть два варианта:
MX480 1200W Power Entry Module AC, Redundant - PWR-MX480-1200-AC-R
MX480 1200W Power Entry Module AC, Spare - PWR-MX480-1200-AC-S
А в чем принципиальная разница между R и S?
ну в названии разница )
spare
а так одно и то же
мы в нескольких БП mx960 standart capacity
меняли вентиляторы. все ок.
spare
а так одно и то же
Спасибо за инфу. Там какие вентили? 2 или 3 pin?
3 pin delta
замена на схожий по параметрам sunon сходу результата не принесла.
морочится не стали - заказали delta с точно таким же p/n, дороже, но не та разница.
ты бы уже раскрутил да и посмотрел )
я то про бп 960 говорю, они другие
3 pin delta
Спасибо. Раскрутим, как БП приедет из ДЦ.
