Установил из портов UnrealIRCD, подправил конфигурационный файл:
unrealircd.conf
loadmodule "modules/commands.so";
loadmodule "modules/cloak.so";
include "help.conf";
include "badwords.channel.conf";
include "badwords.message.conf";
include "badwords.quit.conf";
me
       name "irc.host.ru";
       info "IRC Server";
       numeric 1;
admin {
       "mx";
       "mx";
       "info@host.ru";
class           clients
       pingfreq 90;
       maxclients 200;
       sendq 100000;
       recvq 8000;
class           servers
       pingfreq 90;
       maxclients 10;          /* Max servers we can have linked at a time */
       sendq 1000000;
       connfreq 100; /* How many seconds between each connection attempt */
allow {
       ip             *@*;
       hostname       *@*;
       class           clients;
       maxperip 5;
allow {
       ip             *@255.255.255.0;
       hostname       *@*;
       class           clients;
       password "ik";
       maxperip 1;
oper bobsmith {
       class           clients;
       from {
               userhost info@host.ru;
       password "ik1";
       flags
               netadmin;
               global;
listen         *:6697
       options
               clientsonly;
listen         *:6667;
ulines {
       irc.host.ru;
       irc.host.ru;
log "ircd.log" {
       /* Delete the log file and start a new one when it reaches 2MB, leave this out to always use the
          same log */
       maxsize 2097152;
       flags {
               oper;
               kline;
               connects;
               server-connects;
               kills;
               errors;
               sadmin-commands;
               chg-commands;
               oper-override;
               spamfilter;
/* Standard aliases */
alias NickServ { type services; };
alias ChanServ { type services; };
alias OperServ { type services; };
alias HelpServ { type services; };
alias StatServ { type stats; };
alias "services" {
       format "^#" {
               nick "chanserv";
               type services;
               parameters "%1-";
       format "^[^#]" {
               nick "nickserv";
               type services;
               parameters "%1-";
       type command;
alias "identify" {
       format "^#" {
               nick "chanserv";
               type services;
               parameters "IDENTIFY %1-";
       format "^[^#]" {
               nick "nickserv";
               type services;
       type command;
tld {
       mask *@*.fr;
       motd "ircd.motd";
       rules "ircd.rules.fr";
ban nick {
       mask "*C*h*a*n*S*e*r*v*";
       reason "Reserved for Services";
ban ip {
       mask 195.86.232.81;
       reason "Delinked server";
ban server {
       mask eris.berkeley.edu;
       reason "Get out of here.";
/* Network configuration */
set {
       network-name            "IRCD";
       default-server          "irc.host.ru";
       services-server         "irc.host.ru";
       stats-server            "irc.host.ru";
       help-channel            "#Support";
       hiddenhost-prefix       "rox";
       /* prefix-quit          "no"; */
       /* Cloak keys should be the same at all servers on the network.
        * They are used for generating masked hosts and should be kept secret.
        * The keys should be 3 random strings of 5-100 characters
        * (10-20 chars is just fine) and must consist of lowcase (a-z),
        * upcase (A-Z) and digits (0-9) [see first key example].
       cloak-keys {
               "aoAr1HfR6gl3sJ7hVz4Mb7x4awpW";
               "Vz4Ab7x4YfpY";
               "a3sJ7hVz4Zb7x4YFpq";
       /* on-oper host */
       hosts {
               local           "locop.host.ru";
               global          "ircop.fhost.ru";
               coadmin         "coadmin.host.ru";
               admin           "admin.host.ru";
               servicesadmin   "csops.host.ru";
               netadmin        "netadmin.host.ru";
               host-on-oper-up "no";
/* Server specific configuration */
set {
       kline-address "info@host.ru";
       modes-on-connect "+ixw";
       modes-on-oper    "+xwgs";
       oper-auto-join "#opers";
       dns {
               nameserver 127.0.0.1;
               timeout 2s;
               retries 2;
       options {
               hide-ulines;
               /* You can enable ident checking here if you want */
               /* identd-check; */
               show-connect-info;
       maxchannelsperuser 10;
       /* The minimum time a user must be connected before being allowed to use a QUIT message,
        * This will hopefully help stop spam */
       anti-spam-quit-message-time 10s;
       /* Make the message in static-quit show in all quits - meaning no
          custom quits are allowed on local server */
       /* static-quit "Client quit";   */
       /* You can also block all part reasons by uncommenting this and say 'yes',
        * or specify some other text (eg: "Bye bye!") to always use as a comment.. */
       /* static-part yes; */
       /* This allows you to make certain stats oper only, use * for all stats,
        * leave it out to allow users to see all stats. Type '/stats' for a full list.
        * Some admins might want to remove the 'kGs' to allow normal users to list
        * klines, glines and shuns.
       oper-only-stats "adfGsMEUEelLCszdM";
       /* Throttling: this example sets a limit of 3 connections per 60s (per host). */
       throttle {
               connections 3;
               period 60s;
       /* Anti flood protection */
       anti-flood {
               nick-flood 3:60;        /* 3 nickchanges per 60 seconds (the default) */
       /* Spam filter */
       spamfilter {
               ban-time 1d; /* default duration of a *line ban set by spamfilter */
               ban-reason "Spam/Advertising"; /* default reason */
               virus-help-channel "#help"; /* channel to use for 'viruschan' action */
               /* except "#help"; channel to exempt from filtering */
При подключении mirc'ом, выдает:
* Подключение к 192.168.0.1 ... (6667)
-irc.host.ru- *** Looking up your hostname...
-irc.host.ru- *** Couldn't resolve your hostname; using your IP address instead
-irc.host.ru- *** If you are having problems connecting due to ping timeouts, please type /quote pong 7381B489 or /raw pong 7381B489 now.
Ping? Pong!
Я так понимаю он не может преобразовать имя. Что исправить?
Поднятием ДНС сервера в сети и прописыванием вех клиентов в обратную зону. А вообще это не является критической ошибкой, судя по надпись Пинг? Понг! соединение установилось нормально...
ну не кретическое да... но хотелось, чтобы вообще без ошибок.
Каждого в ДНС прописать??? во-первых долго, во-вторых зря только нагружать лишними записями. Я имел ввиду, что надо указать в конфиге, чтобы он не пытался резолвить ip?
