продаются 2 сервера HP integrity cx2620 AB403A
если коротко: 2 процессора итаниум2 по 1.6Ггц, 32Гб оперативы, винтов в комплекте нету, есть карта PCI-X 10Gbase-SR и PCI-X dual port 1000base, 2 блока питания 48В.
Подробно:
Two 64-bit Itanium 2 CPUs: Either 1.6GHz/3MB single-core
32 GB PC2100 ECC Registered DDR266A SDRAM
Two hot swap power supplies, providing N+1 protection and dual feed input
Four full size PCI-X/PCI IO adapter cards: 1)PCI-X 10Gbase-SR, 2)PCI-X dual port 1000base
Three internal hot plug LVD SCSI disks
Standard System Features:
Support for multiple operating environments (HP-UX 11i version 2, Linux)
Dual-channel Ultra320 SCSI controller, 2 internal disks on one channel, 1 internal disk on a second channel
External Ultra320 SCSI port 10/100/1000Base-TX LAN (auto speed sensing, RJ-45 connector 10/100/1000Base-TX LAN (auto speed sensing, wake-on capability, RJ-45 connector
Management Processor for remote management and HA monitoring
Telnet and web console via 10/100Base-TX management LAN (RJ-45 connector)
Two general purpose RS-232 serial ports
Three RS-232 serial ports linked to the management processor (multiplexed from a single DB-25 port)
Factory integration of CPUs, memory, disk drives, removable media, PCI/PCI-X I/O cards
High Availability:
N+1 Hot swap, front to rear chassis cooling
Two Hot swap power supplies required, provides N+1 protection and dual feed capability IPMI monitoring of system health and reporting to host based HA or remote manageability
Management processor with down system diagnostics and remote power down and boot ECC protected DDR memory
Memory chip spare to overcome single DRAM chip failures
On-line memory page de-allocation
Dynamic Processor resilience and de-allocation
Hot Plug internal disks
Two independent Ultra SCSI channels to internal disks for mirroring across disks and channels Journal file system for HP-UX
Цена: 50т.р. за штуку, торг возможен, отправка через ТК из г.Ижевск
телефон: +7-912-Чбб-О8-Ч9
091763095bffa9bdd5a50eaf95d7c48b.jpeg7e875db68b302de99c9ed83b7f64129c.jpeg_741a2f1d1a0777a442a42c297a45560a.jpeg
Edited by erzhenker
