Коллеги, объясните, пожалуйста, почему так происходит
Cisco ASR1001-X
IOS XE Version 03.16.02.S
запустил CG-NAT
ip local pool IP-POOL1 100.64.1.2 100.64.31.254
ip nat settings mode cgn
no ip nat settings support mapping outside
ip nat settings pap limit 30 bpa set-size 512
ip nat log translations flow-export v9 udp destination 172.16.5.26 9995 source TenGigabitEthernet0/0/0.11
ip nat translation timeout 3600
ip nat translation tcp-timeout 3600
ip nat translation pptp-timeout 3600
ip nat translation udp-timeout 60
ip nat translation icmp-timeout 30
ip nat translation max-entries all-host 2048
ip nat pool NAT-POOL x.x.205.64 x.x.205.127 prefix-length 26
ip nat inside source list nat-cust pool NAT-POOL overload
пользователи PPPOE, online 348
по моим расчетам должно быть утилизировано всего 12 адресов из пула НАТ, поскольку ограничил 30 серых на 1 белый
по факту так и вижу
sh platform hardware qfp active feature nat datapath pap laddrpergaddr
gaddr х.х.205.64 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.65 vrf 0 laddr-per-gaddr 27 mapid 1
gaddr х.х.205.66 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.67 vrf 0 laddr-per-gaddr 29 mapid 1
gaddr х.х.205.70 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.71 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.72 vrf 0 laddr-per-gaddr 29 mapid 1
gaddr х.х.205.73 vrf 0 laddr-per-gaddr 17 mapid 1
gaddr х.х.205.74 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.75 vrf 0 laddr-per-gaddr 27 mapid 1
gaddr х.х.205.76 vrf 0 laddr-per-gaddr 30 mapid 1
gaddr х.х.205.80 vrf 0 laddr-per-gaddr 15 mapid 1
однако
sh ip nat statistics
Hits: 5182567677 Misses: 30919887
Expired translations: 31915204
Dynamic mappings:
-- Inside Source
[id: 1] access-list nat-cust pool NAT-POOL refcount 28870
pool NAT-POOL: id 1, netmask 255.255.255.192
start x.x.205.64 end x.x.205.127
type generic, total addresses 64, allocated 31 (48%), misses 0
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
All Host Max allowed: 2048
In-to-out drops: 949840 Out-to-in drops: 1451
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
sh ip nat pool name NAT-POOL
NAT Pool Statistics
Pool name NAT-POOL, id 1
Assigned Available
Addresses 30 46
UDP Low Ports 0 0
TCP Low Ports 0 0
UDP High Ports 324 9252
TCP High Ports 386 9190
(Low ports are less than 1024. High ports are greater than or equal to 1024.)
утилизация пула почти 50%
не понимаю почему так происходит? так и должно быть?
может я с таймаутами что-то намудрил?
и еще смущают Misses: 30919887 и In-to-out drops: 949840 в статистике, жалоб от пользователей не слышно, но хотелось бы понять каков порядок цифр должен быть в этих параметрах
первый опыт настройки cgnat, прошу помощи у знающих.
Спасибо.
Edited by kartashevav
nat на asr - боль. может не работать просто "потому что идите ***й, вот почему".
Оно со стороны абонента видно, что что-то не работает? Есть реальные жалобы?
BPA у меня использовать не получилось - начались сходу жалобы. Просто PAP без BPA работает, жалоб нет.
со стороны абонента может выражаться в том, что перестают создаваться трансляции, например. а перестают создаваться - потому что забит пул. а пул забит, потому что ip nat translation max-entries all-host не работает.
абоненты до NAT работали за реальными адресами, пока жалоб нет
жду комментарии cisco-водов, может есть у кого опыт cgnat на asr.
BPA работает, до продакшена тестил на стенде, причем удалось нагенерить трафика до полной утилизации всех выделенных портов на IP, к тому же объем логов при BPA снижается в разы.
У меня очень быстро стали появляться ошибки исчерпания пула и жалобы. Даже кейс на циске создавал. Пришли к тому, что выключили эту мегафичу.
Объем логов трансляций на порядок меньше нетфлоу самих потоков, поэтому не критично.
а какой софт на ASR был?
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Вот что мне ответил TAC
I’d suggest removing BPA unless you know that you need it. If not, then I’d suggest you to reduce the port-set size, minimum value is 64. The command would be as :
- ip nat settings pap bpa set-size 64
Regards,
Pawan
продолжаю эксперименты)
убрал bpa, оставил только pap
утилизация пула в пике 60%, тоесть 40 адресов на 360 пользователей
откуда оно берется?
Ну захотели пользователи один и тот-же соурс порт, 123 например очень популярный. Она сперва старается соурс-порт удовлетворить. Потом заполняет уже как придется. ИМХО.
show platform hardware qfp active feature nat datapath stats
чего кажет?
т.е. то, что 40 адресов занято еще не значит что все соурс-порты заняты и не будут использованы.
non_extended 14 entry_timeouts 369 statics 0 static net 0 hits 64970 misses 392
non_natted 27916542
Proxy stats:
ipc_retry_fail 0 cfg_rcvd 3275 cfg_rsp 3281
Subcode #7 PARSE_ERR 6521
Subcode #14 SESS_CREATE_FAIL 1516137
Subcode #18 ALLOC_ADDR_PORT_FAIL 4688
Subcode #29 LIMIT 1516137
Subcode #38 PAP_FAIL 4271
Subcode #41 BPA_MALLOC_FAIL 417
А за какой период? Попробуй скинуть счетчики и не экспериментировать сколько-то времени.
Subcode #6  ALG_PKT_SANITY_FAIL 85
Subcode #7  PARSE_ERR 17722
Subcode #14  SESS_CREATE_FAIL 2370
Subcode #18  ALLOC_ADDR_PORT_FAIL 31
Subcode #29  LIMIT 2370
Subcode #38  PAP_FAIL 31
Аптайм неделя (проблемы с питанием были на узле, аппарат нормально работал, стабильно), пользюков 1200
Edited by ShyLion
почистил NAT статистику, и drop-subcodes
NAT сейчас с такими настройками
ip nat translation timeout 1800
ip nat translation tcp-timeout 300
ip nat translation pptp-timeout 1000
360 пользователей
40 адресов из пула в пике
смотрим
До включения ПАП пользователи жаловались на то что сбербанк-онлайн у них глючил периодически. Видимо не нравилось ему, что с разных адресов пользователь ломился в пределах одной прикладной сессии. После включения PAP жалобы прекратились.
поэтому я сразу делал с PAP, а для экономии объема логов еще и с BPA, но в ходе экспериментов bpa выключил, размер логов без bpa в среднем 30 Мбайт/сутки в формате netflow, это 360 пользователей
на днях переведу еще порядка 100 пользователей за NAT и увеличу пул до /24
буду наблюдать дальше
продолжаю наблюдения
добавил 100 пользователей и расширил пул до /24, теперь online 485 в пике, настройки NAT остались прежние
ip nat pool NAT-POOL х.х.204.1 х.х.204.254 prefix-length 24
в пике 40к трансляций и утилизируется 30 адресов из пула
жалоб от пользователей не поступает, может так и должно быть?
У меня пул в четыре раза меньше и 1000 пользователей и никто не жалуется :)
1000 это в пике? скажи пожалуйста сколько адресов утилизируется и какие настройки NAT?
Соврал, не 64, а 128 адресов в пуле, забыл что добавлял.
[id: 1] access-list nat pool nat_pool refcount 78959
pool nat_pool: id 1, netmask 255.255.255.0
       start x.x.x.65 end x.x.x.191
       type generic, total addresses 127, allocated 52 (40%), misses 0
asr-1002x-621#show subscriber session | count .*
Number of lines which match regexp = 1248
asr-1002x-621#show platform hardware qfp active feature nat datapath pap | count .*
Number of lines which match regexp = 1013
ip nat log translations flow-export v9 udp destination x.x.x.8 8889 source Loopback0
ip nat translation max-entries all-host 2000
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
ip nat pool nat_pool x.x.x.65 x.x.x.191 netmask 255.255.255.0
ip nat inside source list nat pool nat_pool overload
Интересная штука получается
смотрим
show platform hardware qfp active feature nat datapath pool | i x.x.204.21
addr x.x.204.21 refcnt 4 flags 0x0 vrfid 0 next 0x0
4 трансляций на адресе x.x.204.21
show platform hardware qfp active feature nat datapath bind | i x.x.204.21
bind 0x2f3e3340 oaddr 100.64.22.133 taddr x.x.204.21 oport 54445 tport 54445 vrfid 0 tableid 0 proto 6 domain 0 create time 1189523 refcnt 1 mask 0x2ef46c60 flags 20004800 timeout 60 ifhandle 29 wlan_info 0x0 flags 0x1000000 mapping 0x2c5ccdc0 cp_mapping_id 1 limit_type 4 last_use_ts 1229837 mibp 0x0 rg 0nak_retry 0
bind 0x2f43f500 oaddr 100.64.22.133 taddr x.x.204.21 oport 54445 tport 54445 vrfid 0 tableid 0 proto 17 domain 0 create time 1187135 refcnt 1 mask 0x2ef46c60 flags 0 timeout 60 ifhandle 29 wlan_info 0x0 flags 0x1000000 mapping 0x2c5ccdc0 cp_mapping_id 1 limit_type 4 last_use_ts 1229837 mibp 0x0 rg 0nak_retry 0
bind 0x2ef46c60 oaddr 100.64.22.133 taddr x.x.204.21 oport 0 tport 0 vrfid 0 tableid 0 proto 0 domain 0 create time 1128276 refcnt 3 mask 0x0 flags 0 timeout 2 ifhandle 162 wlan_info 0x0 flags 0x0 mapping 0x2c5ccdc0 cp_mapping_id 1 limit_type 4 last_use_ts 1229774 mibp 0x0 rg 0nak_retry 0
bind 0x2f374300 oaddr 100.64.22.133 taddr x.x.204.21 oport 143 tport 143 vrfid 0 tableid 0 proto 6 domain 0 create time 1229836 refcnt 1 mask 0x2ef46c60 flags 20004000 timeout 60 ifhandle 29 wlan_info 0x0 flags 0x1000000 mapping 0x2c5ccdc0 cp_mapping_id 1 limit_type 4 last_use_ts 1229848 mibp 0x0 rg 0nak_retry 0
sh ip nat translations | i x.x.204.21
tcp x.x.204.21:54445 100.64.22.133:54445 --- ---
udp x.x.204.21:54445 100.64.22.133:54445 --- ---
--- x.x.204.21 100.64.22.133 --- ---
tcp x.x.204.21:143 100.64.22.133:143 --- ---
вроде все сходится, НО
show platform hardware qfp active feature nat datapath pap laddrpergaddr | i x.x.204.21
в РАР этого адреса нет и вообще
sh users | i 100.64.22.133
онлайн юзера нет с таким ИПшником
вот они адреса, которые утилизаруются сверх PAP
Это типа если пользователь некорректно разорвал сессию и трансляции не освободились, то они и висят и их долбят снаружи?
или просто бага? где-то на форуме проскакивала инфа, уже не найду
  • 3 years later...
Коллеги, оказалось, что опция
не на всех устройствах циско есть.
Cisco IOS Software, 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.4(3) - опции settings отсутствует.
Возникает проблема - а как тогда ограничить количество адресов трансляций на один адрес из публичного пула?
  • 3 years later...
Здравствуйте.
Поделитесь пожалуйста рабочим конфгом для цыски ASR для логирования НАТа по 263 шаблону.
Сейчас так сконфигурено:
Абоны получают IP на SE600, там средствами PBR бегут на ASR, где НАТятся.
Конфиг АСР:
flow record FLOW-RECORD
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect interface output
 collect flow sampler
 collect ipv4 ttl minimum
 collect ipv4 ttl maximum
 collect transport tcp flags
 collect routing destination as
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter FLOW-ASR
 destination 10.252.1.2
 source TenGigabitEthernet0/0/0.3904
 transport udp 1532
flow monitor FLOW-monitor
 exporter FLOW-ASR
 cache timeout active 60
 record FLOW-RECORD
ip nat log translations flow-export v9 udp destination 10.252.1.2 1532 source TenGigabitEthernet0/0/0.3904
ip nat log translations flow-export v9 vrf 0 on
ip nat pool nat-pool x.x.x.x y.y.y.y prefix-length 29
ip nat inside source list 100 pool nat-pool overload
interface TenGigabitEthernet0/0/0.3906
 description TO_FLOW_collector
 encapsulation dot1Q 3906
 ip address 10.252.1.1 255.255.255.252
interface TenGigabitEthernet0/0/0.3904
 description p2p_ASR-SE_for_NAT
 encapsulation dot1Q 3904
 ip address 10.251.1.2 255.255.255.252
 ip nat inside
 ip flow monitor FLOW-monitor input
 ip flow monitor FLOW-monitor output
interface TenGigabitEthernet0/0/0.3905
 description INET
 encapsulation dot1Q 3905
 ip address Y.Y.Y.Y 255.255.255.252
 ip nat outside
При таком конфгие льются 262 и 264 шаблоны (верхний конфг flow). А 263 шаблон (который ip nat log translations flow-export v9 udp destination 10.252.1.2 1532 source TenGigabitEthernet0/0/0.3904 - не льется)
ip nat log translations flow-export v9 udp destination 10.252.1.2 1532 - так тоже не льется
ip nat log translations flow-export v9 udp destination 10.252.1.2 1532 source TenGigabitEthernet0/0/0.3906 - тоже не льется
Вопрос:
Что указывается в соурсе логирования НАТа? Интерфейс коллектора? Интерфейс абонентов? В описании вообще нет про это ничего) Можно с ним, можно без него. А как правильно?)
Читал соседнюю тему, там был баг у цыски. С какими то костылями в виде маршрутов, чтоб заработал V9
Так и не понял зачем и куда его заворачивать.
укажите в destination хотя бы разные порты для обычных flows и для NEL, чтобы видеть, какой поток реально льется с ната, и льется ли вообще
в качестве source можно вообще ничего не указывать, польется с того интерфейса, через который идет маршрут на destination (в вашем случае 3906, видимо)
у меня все работает вот так
interface GigabitEthernet0/0/0.130
 encapsulation dot1Q 130
 vrf forwarding Mgmt-intf-2
 ip address 172.20.10.100 255.255.255.0
ip nat log translations flow-export v9 udp destination 172.20.10.20 9995 vrf Mgmt-intf-2
где vrf - это служебная подсеть биллинга, отделенная от абонентов, чтобы не лазили. работать будет и без указания vrf, это мои заморочки с закрыванием ненужного.
ps: на всякий случай - то, что вы конфигурите в flow record, на NEL не влияет никак.
Edited by nixx
