Проблема с DGS3100-24, прыгнуло напряжение в сети. БП остался живой, напряжения все в норме.
Скрин телнета.
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
Restoring system configuration defaults
BOOT Software Version 1.0.1.05 Built 13-Oct-2009 15:37:32
MAC Address : f0:7d:68:af:5e:ca.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
About to erase CDB. Terminal baud rate will now be set to default!
*** Running SW Ver. 3.60.30 Date 12-Aug-2010 Time 08:50:35 ***
Serial Number : F3DR2A7000304.
HW version is: a2
Base Mac address is: f0:7d:68:af:5e:ca
Dram size is: 64M bytes
Flash size is: 16M bytes
01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - DGS-3100-24 ST
-- Unit Number 1 --
На команды с клавы не реагирует.
