Добрый! Настраиваю впервые. Делал все по https://github.com/opendp/dpdk-nginx. Суть проблемы в запуске ans да и вообще всех тестовых приложений в dpdk.
Запуск
sudo ./build/ans -c 0x2 -n 1  -- -p 0x1 --config="(0,0,1)"
EAL: Detected 4 lcore(s)
EAL: Probing VFIO support...
PMD: bnxt_rte_pmd_init() called for (null)
EAL: PCI device 0000:00:08.0 on NUMA socket -1
EAL:   probe driver: 8086:100f rte_em_pmd
EAL: PCI device 0000:00:09.0 on NUMA socket -1
EAL: PCI device 0000:00:0a.0 on NUMA socket -1
EAL: PCI device 0000:00:11.0 on NUMA socket -1
param nb 1 ports 3
port id 0
Start to Init port
 port 0:
 port name rte_em_pmd:
 max_rx_queues 1: max_tx_queues:1
 rx_offload_capa 0x0: tx_offload_capa:0x0
 Creating queues: rx queue number=1 tx queue number=1...
 MAC Address:08:00:27:89:89:A7
 Deault-- tx pthresh:0, tx hthresh:0, tx wthresh:0, txq_flags:0x0
 lcore id:1, tx queue id:0, socket id:0
 Conf-- tx pthresh:0, tx hthresh:0, tx wthresh:0, txq_flags:0xfffff1ff
Skipping disabled port 1
Skipping disabled port 2
Allocated mbuf pool on socket 0, mbuf number: 16384
Initializing rx queues on lcore 1 ...
Default-- rx pthresh:0, rx hthresh:0, rx wthresh:0
port id:0, rx queue id: 0, socket id:0
Conf-- rx pthresh:8, rx hthresh:8, rx wthresh:4
core mask: 2, sockets number:1, lcore number:1
start to init ans
USER8: LCORE[1] lcore mask 0x2
USER8: LCORE[1] lcore id 1 is enable
USER8: LCORE[1] lcore number 1
USER1: rte_ip_frag_table_create: allocated of 25165952 bytes at socket 0
USER8: LCORE[1] UDP layer init successfully, Use memory:4194304 bytes
USER8: LCORE[1] TCP hash table init successfully, tcp pcb size 448 total size 58720256
USER8: LCORE[1] so shm memory 16777216 bytes, so number 131072,  sock shm size 128 bytes
USER8: LCORE[1] Sock init successfully, allocated of 41943040 bytes
add eth0 device
USER8: LCORE[1] Interface eth0 if_capabilities: 0x0
add IP 200000a on device eth0
Show interface
eth0	HWaddr 08:00:27:89:89:a7
	inet addr:10.0.0.2
	inet addr:255.255.255.0
add static route
Destination		Gateway		Netmask			Flags		Iface
10.0.0.0		*		255.255.255.0		U C 		0
10.0.0.5		*		255.255.255.255		U H L 		0
10.10.0.0		10.0.0.5		255.255.255.0		U G 		0
USER8: LCORE[-1] ANS mgmt thread startup
Checking link status ..........................................................................................done
Port 0 Link Down
USER8: main loop on lcore 1
USER8:  -- lcoreid=1 portid=0 rxqueueid=0
nb ports 3 hz: 2194815794
Смущает
В чем ошибка? fedora 4.9.6-200.fc25.x86_64. dpdk 16.07.2
Network devices using DPDK-compatible driver
0000:00:08.0 '82545EM Gigabit Ethernet Controller (Copper)' drv=igb_uio unused=e1000
0000:00:09.0 '82545EM Gigabit Ethernet Controller (Copper)' drv=igb_uio unused=e1000
0000:00:0a.0 '82545EM Gigabit Ethernet Controller (Copper)' drv=igb_uio unused=e1000
Network devices using kernel driver
0000:00:11.0 '82545EM Gigabit Ethernet Controller (Copper)' if=enp0s17 drv=e1000 unused=igb_uio *Active*
Other network devices
<none>
Core and Socket Information (as reported by '/proc/cpuinfo')
cores =  [0, 1, 2, 3]
sockets =  [0]
      Socket 0
Core 0 [0]
Core 1 [1]
Core 2 [2]
Core 3 [3]
Edited by TriplePenetration
Ошибок ровно три:
1. ник
2. это форум провайдеров и хайлоад нгинха тут никому не интересен
3. это форум провайдеров и в таких тонких материях тут полтора человека разбирается
