voodoo Posted January 19, 2017 Posted January 19, 2017 (edited) Коллеги , скажите , кто то использовал данную карту. Стоит FreeBSD 11, 2хXeon 5650 12 ядер без гипертрейдинга и карта Silicom PE310G4i71LB-XR , чипсет Intel FTXL710AM1 Судя по статистике , нагрузку гонят тока на 8 ядрах, 4 пустуют. Не подскажите как заставить использовать все ядра , или может она может только 8 очередей использовать ? CPU 0: 0.0% user, 0.0% nice, 0.0% system, 15.7% interrupt, 84.3% idle CPU 1: 0.0% user, 0.0% nice, 0.0% system, 16.5% interrupt, 83.5% idle CPU 2: 0.0% user, 0.0% nice, 0.0% system, 15.4% interrupt, 84.6% idle CPU 3: 0.0% user, 0.0% nice, 0.4% system, 12.2% interrupt, 87.4% idle CPU 4: 0.0% user, 0.0% nice, 0.4% system, 20.5% interrupt, 79.1% idle CPU 5: 0.0% user, 0.0% nice, 0.0% system, 14.6% interrupt, 85.4% idle CPU 6: 0.0% user, 0.0% nice, 0.0% system, 16.1% interrupt, 83.9% idle CPU 7: 0.0% user, 0.0% nice, 0.0% system, 13.8% interrupt, 86.2% idle CPU 8: 0.0% user, 0.0% nice, 0.0% system, 0.0% interrupt, 100% idle CPU 9: 0.0% user, 0.0% nice, 0.0% system, 0.0% interrupt, 100% idle CPU 10: 0.0% user, 0.0% nice, 1.2% system, 0.0% interrupt, 98.8% idle CPU 11: 0.0% user, 0.0% nice, 0.8% system, 0.0% interrupt, 99.2% idle Edited January 19, 2017 by voodoo Вставить ник Quote
Ivan_83 Posted January 19, 2017 Posted January 19, 2017 Если это не пппое то попробуй: sysctl net.isr.dispatch=deferred Вставить ник Quote
snvoronkov Posted January 19, 2017 Posted January 19, 2017 http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xl710-10-40-controller-datasheet.pdf MSI-X: Supports up to 1168 MSI-X vectors, shared among PFs and VFs. Up to 129 MSI-X interrupts can beassigned to a single PF and up to 17 MSI-X interrupts can be assigned to a single VF, depending on the number of enabled functions. В драйвере для дефолта: queues = (mp_ncpus > (available - 1)) ? (available - 1) : mp_ncpus; Возможно, на маме не хватает свободных прерываний. Вставить ник Quote
voodoo Posted January 19, 2017 Author Posted January 19, 2017 (edited) Если это не пппое то попробуй: sysctl net.isr.dispatch=deferred Данная команда вообще в одно ядро все переводит ( В драйвере для дефолта: queues = (mp_ncpus > (available - 1)) ? (available - 1) : mp_ncpus; Возможно, на маме не хватает свободных прерываний. Можно попродробнее, в данный момент стоит штатфный драйвер Feebsd ничего на нем не менялось. Дравейр стоит ixl0: <Intel(R) Ethernet Connection XL710/X722 Driver, Version - 1.6.6-k> mem 0x ixl0: Using MSIX interrupts with 9 vectors ixl0: fw 5.0.40043 api 1.5 nvm 5.02 etid 80002248 oem 0.0.0 ixl0: PF-ID[0]: VFs 32, MSIX 129, VF MSIX 5, QPs 384, I2C ixl0: Allocating 8 queues for PF LAN VSI; 8 queues active ixl0: Ethernet address: 00:e0:ed:75:1d:56 ixl0: PCI Express Bus: Speed 5.0GT/s Width x8 ixl0: PCI-Express bandwidth available for this device may be insufficient for op ixl0: For optimal performance, a x8 PCIE Gen3 slot is required. ixl0: SR-IOV ready ixl0: netmap queues/slots: TX 8/1024, RX 8/1024 Edited January 19, 2017 by voodoo Вставить ник Quote
snvoronkov Posted January 19, 2017 Posted January 19, 2017 Нету у меня 11-ой фри. На 10.3 смотрел. "man ixl" дает hw.ixl.max_queues. Идем в /usr/src/sys/dev/ixl и grep-им его на предмет поведения при умолчательном 0 в этой sysctl. Оно мне и дало эту строчку. Читать как: ЕСЛИ процессоров больше чем свободных прерываний - 1 ТО очередей будет = свободных прерываний - 1 ИНАЧЕ количество процессоров Вставить ник Quote
voodoo Posted January 19, 2017 Author Posted January 19, 2017 Нету у меня 11-ой фри. На 10.3 смотрел. "man ixl" дает hw.ixl.max_queues. Идем в /usr/src/sys/dev/ixl и grep-им его на предмет поведения при умолчательном 0 в этой sysctl. Оно мне и дало эту строчку. Читать как: ЕСЛИ процессоров больше чем свободных прерываний - 1 ТО очередей будет = свободных прерываний - 1 ИНАЧЕ количество процессоров Если попробовать поставить в loader.conf hw.ixl.max_queues = Количество ядер , изменит нет потому как по умолчанию стоит 0 , ман говорит что если 0 , то автовычисление https://www.freebsd.org/cgi/man.cgi?query=ixl&sektion=4 hw.ixl.max_queues Set the number of queues (each a TX/RX pair) for the port, this allows one to override the autocalculation if it is set to 0. Вставить ник Quote
Ivan_83 Posted January 19, 2017 Posted January 19, 2017 Данная команда вообще в одно ядро все переводит ( Там рядом крутилка есть чтобы количество потоков задать. net.isr.numthreads: 16 net.isr.bindthreads: 1 net.isr.maxthreads: 16 в лодере пропиши и ребут. Вставить ник Quote
voodoo Posted January 19, 2017 Author Posted January 19, 2017 Данная команда вообще в одно ядро все переводит ( Там рядом крутилка есть чтобы количество потоков задать. net.isr.numthreads: 16 net.isr.bindthreads: 1 net.isr.maxthreads: 16 в лодере пропиши и ребут. У меня 12 ядер , 12 нужно указать ? ) И вот еще хотел спросить , по опыту как лучше с гипертрейдингом или без , если гипер включить то 24 ядра будет. Вставить ник Quote
Ivan_83 Posted January 20, 2017 Posted January 20, 2017 Я вообще 1024 пишу, система сама правит до реальных цифр. ИМХО лучше без, но можешь попробовать и так и так, ибо моё мнение базируется на теории без практики на современных процах. Вставить ник Quote
voodoo Posted January 21, 2017 Author Posted January 21, 2017 Обратил внимание что сейчас в FreeBSD поддержка ipfw и nat идет как отдельный подгружаемый модуль в ядро , или лучше скомпилировать ядро с поддержкой IPFW Вставить ник Quote
vlad11 Posted January 21, 2017 Posted January 21, 2017 Обратил внимание что сейчас в FreeBSD поддержка ipfw и nat идет как отдельный подгружаемый модуль в ядро , или лучше скомпилировать ядро с поддержкой IPFW Все равно. Обычно при сетевых картах 10Г ОЗУ хватает. Вставить ник Quote
Ivan_83 Posted January 21, 2017 Posted January 21, 2017 Обратил внимание что сейчас в FreeBSD поддержка ipfw и nat идет как отдельный подгружаемый модуль в ядро , или лучше скомпилировать ядро с поддержкой IPFW Уже лет 5+. Без разницы, есть нюансы с дефолт аккепт/режект при загрузке но не более. Вставить ник Quote
voodoo Posted January 23, 2017 Author Posted January 23, 2017 Появилась проблема, через некоторое время, несколько часов работы под нагрузкой, kernel заваливает все ядра проца в потолок 100% , в логах ничего , и не понятно почему такое происходит, кто то встречал такое ? Вставить ник Quote
GrandPr1de Posted January 23, 2017 Posted January 23, 2017 ipfw NAT? deny_in решение Вставить ник Quote
Ivan_83 Posted January 24, 2017 Posted January 24, 2017 Появилась проблема, через некоторое время, несколько часов работы под нагрузкой, kernel заваливает все ядра проца в потолок 100% , в логах ничего , и не понятно почему такое происходит, кто то встречал такое ? kldload hwpmc pmcstat -TS instructions -w1 В помощь! Вставить ник Quote
